Min Throw Distance question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-01-2012, 04:25 PM - Thread Starter
TVAddikt's Avatar
Quoted: 17 Post(s)
I have a 120" w cinescope (CIH) screen installed and a Panasonic AE4000u. I have the projector installed at a throw of 14'. The throw is perfect for the size of my screen. Here is my dilemma. I am now wanting to increase the size of my screen to 153" w. I have been looking at throw distances calculators and the min stated is 17' (give or take). Without greaaaaat effort, I cannot move my projector. This is a factor that I did not consider when I installed everything.
So with a throw of 14', do I have to stay with a 120" wide screen? I am wanting to increase the size of the screen to increase the size of screen for 1.85:1 movies. I have a big room. If my projector is at a throw of 14' and I increase my screen from 120" to 153", will the projector not be able to fill the screen?
I am wondering what my options are?
I appreciate any input/suggestions
TVAddikt is offline
post #2 of 3 Old 10-01-2012, 05:35 PM
Craig Peer's Avatar
Quoted: 7093 Post(s)
Liked: 8420
You could use something like a Navitar Screenstar Conversion Lens - http://navitar.com/product/hd-screenstar-lenses.aspx
The HD ones work really well.
[email protected] JVC RS4500, Lumagen Radiance Pro, Panamorph Paladin DCR lens, Stewart Luxus Model A ElectriScreens - 128" diagonal 2.35:1 ST130 & 122" diagonal 16:9 Cima Neve, Denon X8500, Parasound A 52+ amp, Martin Logan Motion series 9.4 speakers, four SVS subs, Panasonic UB820, Oppo 203, PFP M1500 UPS
Craig Peer is online now
post #3 of 3 Old 10-01-2012, 07:53 PM
Mike Garrett's Avatar
Quoted: 12670 Post(s)
Liked: 10296
I agree with Craig, look at the HD, not the regular ones and you will like the image that you will get. If we can help you, let us know.
Mike Garrett is offline
Panasonic Pt Ae4000u 1600 Lumen Lcd Home Theater Projector
