Projector Mini-Shootout Thread - Page 476 - AVS Forum | Home Theater Discussions And Reviews
 4911Likes
post #14251 of 19419 Old 05-01-2016, 09:50 AM
seanbryan's Avatar
Quoted: 279 Post(s)
Liked: 172
Originally Posted by john2910 View Post
Hello i have a strange problem with my JVC rs400.
I looks the same as ghosting in 3d but it happens in 2d
When there is a people face or a black sword or something with a white background you see a silhouette round the people face or sword when the camera pans.
It has the same look as ghosting in 3d..
I dont know what is is.i cant find a solution
Are you using the motion enhance setting? If so, try turning that off.
seanbryan is offline
post #14252 of 19419 Old 05-01-2016, 09:52 AM
john2910's Avatar
Quoted: 109 Post(s)
Liked: 41
Hello there.
Even with that setting off you see it.
john2910 is offline
post #14253 of 19419 Old 05-01-2016, 09:54 AM
seanbryan's Avatar
Quoted: 279 Post(s)
Liked: 172
Hello there.
Not sure then. I will see something similar to what you describe when using the motion enhance setting (not clear motion drive, but the motion enhance). But when motion enhance is off, I don't see that.
post #14254 of 19419 Old 05-01-2016, 09:58 AM
john2910's Avatar
Quoted: 109 Post(s)
Liked: 41
Maybe theres a bug that my motion enhance stays on even when i turn it off....
john2910 is offline
post #14255 of 19419 Old 05-01-2016, 01:25 PM
RobTi's Avatar
Quoted: 17 Post(s)
Liked: 4
Hmm, not sure if it's exactly relevant but avforums (https://www.avforums.com/review/jvc-...r-review.12191) reported a bug in their X7000 review earlier in January:
And to wrap up on the subject of new formats and the compatibility issues we noticed - when fed an Ultra HD signal from the Fire TV box via Amazon Prime or Netflix the screen would go blank for a few seconds as it switched to 3840 x 2160/24p and when the image returned it did so with CMD frame interpolation on full, even when in the menus CMD would be showing as off. This is clearly a bug as we were able to switch CMD on and the off again to clear the issue and turn off interpolation. We have fed this back to JVC. Also note that when switching to 3D mode the exact same thing happens.
RobTi is offline
post #14256 of 19419 Old 05-01-2016, 03:20 PM
seanbryan's Avatar
Quoted: 279 Post(s)
Liked: 172
There is a bug in the original firmware that can cause "clear motion drive" to be on even when you have it off. But as far as I'm aware this bug did not affect the motion enhancement setting (which is a completely separate setting).
CMD doesn't cause the type of issue you are dscribing, but motion enhancement can (in my experience).
post #14257 of 19419 Old 05-01-2016, 04:31 PM
tigerfan33's Avatar
Quoted: 429 Post(s)
Liked: 217
Hello there.
Turn e-shift off and see if that helps.
tigerfan33 is offline
post #14258 of 19419 Old 05-02-2016, 12:55 AM
john2910's Avatar
Quoted: 109 Post(s)
Liked: 41
Hello there,
I dont use eshift.
john2910 is offline
post #14259 of 19419 Old 05-02-2016, 04:22 AM
tigerfan33's Avatar
Quoted: 429 Post(s)
Liked: 217
Hello there,
I dont use eshift.
I'm sorry. I meant to say turn e-shift ON.
Somehow this is tied to e-shift. Even using high with e-shift on causes no problem.
I ended up with this feature off and e-shift off as I didn't see any benefit from either on 1080p or 1080i sources.
post #14260 of 19419 Old 05-02-2016, 03:48 PM - Thread Starter
zombie10k's Avatar
Quoted: 5236 Post(s)
Liked: 5488
I was thinking about upgrading my trusted Mede8ter with the new Dune 4K Solo but it looks like the new owners are experiencing a number of different issues upon it's release.
https://www.avsforum.com/forum/39-net...player-57.html
https://www.duneplayer.com/hd4ksolo.html
as much as I like torture and pain, I may wait until this one gets vetted out by the media player fanatics.
Dune had a big name in this area at one point. This is their chance to get back that spotlight but all the key features have to work and work well. Let's see how quickly they fix these current bugs and I'll reconsider. I've done enough beta-testing of gear to last a lifetime.
RickAVManiac likes this.
zombie10k is online now
post #14261 of 19419 Old 05-02-2016, 04:32 PM
Rob-Houston's Avatar
Quoted: 143 Post(s)
Liked: 95
AH! Tired of "living on the bleeding edge"?
You've taken enough arrows in the back for others.
Sit back and enjoy (your new room).
I got out of the rat race in 2001. Do what I want when I want.
zombie10k likes this.
Rob-Houston is offline
post #14262 of 19419 Old 05-02-2016, 06:15 PM - Thread Starter
zombie10k's Avatar
Liked: 5488
john what firmware version is installed on your JVC?
post #14263 of 19419 Old 05-02-2016, 08:54 PM
john2910's Avatar
Quoted: 109 Post(s)
Liked: 41
Hello there it must be the first firmware,i never updated my JVC.
Here is an example of what i mean,look around his face.
john2910 is offline
post #14264 of 19419 Old 05-03-2016, 07:54 AM
Seegs108's Avatar
Quoted: 5167 Post(s)
Liked: 2593
That looks like edge enhancement. Go under the MPC settings and turn all the sliders to 0. Then find the Clear Black settings in the menu and turn it to Off. Also make sure that the Motion Enhance feature is turn to Off as well. What else is in your video chain? Is there anything else that might be doing video processing. A blu-ray player or A/V receiver perhaps?
Seegs108 is offline
post #14265 of 19419 Old 05-03-2016, 08:26 AM
john2910's Avatar
Quoted: 109 Post(s)
Liked: 41
Hello there thx for the reply,
I shall try that tonight,but it only happens when the camera pans..
john2910 is offline
post #14266 of 19419 Old 05-03-2016, 08:51 AM
Seegs108's Avatar
Liked: 2593
Then it's the motion enhancement causing the issue. Open up the main menu and then go under Picture Adjust --> Blur Reduction --> Motion Enhance and set it to "Off". It should fix this issue.
Seegs108 is offline
post #14267 of 19419 Old 05-03-2016, 09:01 AM
john2910's Avatar
Quoted: 109 Post(s)
Liked: 41
Hello there i have this setting on off.
john2910 is offline
post #14268 of 19419 Old 05-03-2016, 09:09 AM
Seegs108's Avatar
Liked: 2593
You have both CMD and the Blur Reduction to off? I really can't think of anything else it might be. The projector does save settings on an input and picture mode basis so if you've gone to a new mode or HDMI input you should double check to make sure it's not re-enabled.
Seegs108 is offline
post #14269 of 19419 Old 05-03-2016, 09:11 AM
Craig Peer's Avatar
Quoted: 6617 Post(s)
Liked: 7689
Do you see this problem with all sources ?
Craig Peer is offline
post #14270 of 19419 Old 05-03-2016, 09:13 AM
thezaks's Avatar
Quoted: 613 Post(s)
Liked: 125
I know what you meant - just looks funny
Dave
thezaks is offline
post #14271 of 19419 Old 05-04-2016, 02:51 PM - Thread Starter
zombie10k's Avatar
Liked: 5488
I don't watch much TV but every once in a while I like to see what's going on with current TV hardware.
It looks like there are some noticeable issues with some sets out there. I just happened to see this thread regarding a 2016 Sony XBR-65X930D. A quick lookup shows this streets for around $3300 US.
https://www.avsforum.com/forum/166-lc...d-sony-tv.html
quick executive summary of the issues
* Frame is bent to varying degrees (not just 1 copy)
* Major 3D issues (crosstalk)
*Color uniformity issues
* Flashlighting (Or 'Bright Corners')
In the posted youtube video on the link, 8:34 shows very obvious cloudy corners - that would drive me mad during low APL scenes.
the interaction between the forum member and Sony + Crutchfields interaction with Sony on these issues is worth reading.
It makes me feel a bit better about some of the issues we discuss regarding the different projectors. They seem mild in comparison to a set like this with high level advertised features and then obvious issues when the rubber meets the road.
I have several Panasonic Plasma's from 2008 that still work fine and a few LCD's that wont die. When they come down in price, definitely an OLED. Galaxy S7 screen spoils like no other.
I'd like to buy a nice 27"-30" OLED PC Monitor. How come we haven't see these yet?
post #14272 of 19419 Old 05-04-2016, 06:40 PM
Wizziwig's Avatar
Quoted: 2194 Post(s)
Liked: 1475
It's not like projectors are immune from bright corners either. Just look back at the complaints posted here earlier in the year.
I wonder if JVC has managed to improve uniformity on the latest batches being produced now or if it's still luck of the draw.
Wizziwig is offline
post #14273 of 19419 Old 05-04-2016, 10:33 PM - Thread Starter
zombie10k's Avatar
Liked: 5488
it's the sum of the issues that is alarming for a $3300 product. Structural issues, below average 3D, color uniformity issues (that looked significant in the examples) and the noticeable clouding which looks like it would have been visible on more than low APL scenes. I've seen crap LCD monitors with the same behavior.
regarding the BC on the JVC, I can only go by 5 different units that were in my HT. The first 4 were early production (Nov/Dec) and had the BC to varying degrees. The best of those 4 happened to be mine and it met an unfortunate fate with powering down in the middle of viewing. The replacement was a blessing (March 2016 build) and the BC is considerably better than the first 4.
This is an excellent sample with even focus uniformity and convergence I wouldn't touch, it's that good on this specific unit. I haven't seen any recent complaints from new owners and have seen patterns from a few different RS500's that looked quite good - certainly better than what we saw on those early production runs. Has it been resolved? I don't have the answer but am quite happy with this specific RS600 right now.
regarding issues for projectors in general - the JVC is certainly not the only one that had or could have had issues. We saw some 4K Sony's with terrible OOTB convergence on the German forums. VW1000/1100's losing contrast, Epson models also with below average OOTB convergence. Even the uber-expensive Sony VW5000ES had a few reports of new owners with noticeable convergence issues. Maybe from shipping... maybe from poor QC, who knows. For that price, it better be flawless and make me breakfast in the morning.
Wizziwig likes this.
post #14274 of 19419 Old 05-05-2016, 03:14 AM
Wizziwig's Avatar
Liked: 1475
Surprised JVC sent you a new replacement instead of going through the ordeal of having the original one shipped around for repair service. Based on the lack of recent BC complaints compared to the launch period, it does seem like things must have improved somewhat. I guess that's the price of being an early adopter.
Wizziwig is offline
post #14275 of 19419 Old 05-05-2016, 06:27 AM
Mike Garrett's Avatar
Quoted: 11820 Post(s)
Liked: 9352
That would be great, if it would peel my oranges and separate the sections.
Mike Garrett is offline
post #14276 of 19419 Old 05-05-2016, 06:30 AM
Liked: 9352
Why would you say that? We only had one guy that sent his in for repair and that was because everything was excellent on the projector, except for a noise issue. All of the rest, were exchanged.
post #14277 of 19419 Old 05-05-2016, 07:01 AM
Wookii's Avatar
Quoted: 2861 Post(s)
Liked: 2049
My replacement X9000 (RS600) that I took delivery of a few weeks ago also has significantly better convergence and overall sharpness than the unit it replaced that was delivered to me in December.
EDIT: Interestingly the new unit also required no adjustment to contrast or brightness out of the box either, they were both spot on left on zero (never had that before), and it fully resolves 17 on the brightness test pattern without any 'help' from my Lumagen or anywhere else!
Wookii is offline
post #14278 of 19419 Old 05-05-2016, 07:09 AM
DavidHir's Avatar
Quoted: 2532 Post(s)
Liked: 2198
I've heard for sometime now with JVCs that early production models tend to have more issues where as later ones are more solid in this regard.
DavidHir is offline
post #14279 of 19419 Old 05-05-2016, 07:33 PM
Wizziwig's Avatar
Liked: 1475
Zombie's original was from Dec and his replacement was from March. So I'm assuming around 4 months passed between receiving the first and second unit.
That's well past any store's return/exchange policy that I'm aware of. Are you saying JVC themselves directly exchanged it for him after all that time?
Wizziwig is offline
post #14280 of 19419 Old 05-05-2016, 07:42 PM
Wizziwig's Avatar
Liked: 1475
Can't speak to previous years, but they had a really tough time meeting demand this year. As a result, the RS500/600 were severely delayed in Europe - only really becoming widely available recently. That's why the Cine4Home review was so delayed on the upper models. Maybe in their rush to meet demand they cut a few corners or relaxed their QC standards. Who knows. Now that the pressure if off, maybe they are spending more time on QC or have excess inventory of higher spec parts to put in projectors.
It's all speculation anyway. I'm basing this only on the amount of complaints I'm seeing now vs. earlier in the year. But maybe sales in general are just slower now and nothing has really changed as far as quality. We would need a larger sample size of people who replaced older builds with new ones to draw any conclusions.
DavidHir likes this.
Wizziwig is offline
Benq W7000 Home Projection System , Jvc Dla Rs55 Bundle , Jvc Dla Rs45 Home Theater Projector 1080p Hdmi , Epson V11h502020 Powerlite Home Cinema 3020e 2d And 3d 1080p Wireless Home Theater Projector , Sony Vpl Hw50es 3d Projector , Epson 5010 Powerlite Home Cinema 3d Front Projector , Epson Powerlite Home Cinema 3010 2d And 3d Projector V11h421020 , Panasonic Ptae8000u Hd Projector , Mitsubishi Hc7900dw Home Theater 3d Projector , Mitsubishi Hc8000dbl Dlp 3d Home Theater Projector With Spare Lamp 1300 Ansi 12 6 Lbs , Darbeevision Darblet Hdmi Video Processor , Epson 5020ub Powerlite Home Cinema 3d Front Projector
