Official JVC DLA-RS46 / DLA-X35 owners thread - Page 101 - AVS Forum | Home Theater Discussions And Reviews
 230Likes
post #3001 of 3003 Old 01-09-2020, 07:38 PM
guida74's Avatar
Quoted: 12 Post(s)
Does anyone know if you perform a factory reset on the X35 (RS46) via the service menu does this simply reset all the projector user menu settings to factory default including the bulb timer hours or do the hours remain after the reset?
I want to calibrate with i1 Display Pro and prefer to set projector back to factory condition before doing so.
guida74 is offline
post #3002 of 3003 Old 01-09-2020, 09:41 PM
gazzagazza's Avatar
Please post on your process here. I will be doing the same thing in a few months. Thanks!
Sent from my MI 8 using Tapatalk
gazzagazza is offline
post #3003 of 3003 Old 01-14-2020, 10:22 AM
annihilator's Avatar
I'm enjoying so much my RS46 man. It's such a big step from my previous RS2...today i was watching a bit with some ambient light (quite al lot i would say) and was perfectly watchable on my 203cm base painted wall (not really whit i would say 0.8 gain) on low lamp and -13 iris...so great.
I changed today my long hdmi cable because had some issue with signal but it's not the projector it's that goddamn darbee which is great but so sensitive about cables...some **** ones could be ok some great no..
Anyway my previous one was also a bit too big so i changed it. Just tried like 15 mins and seems perfect, will watch mission impossible 2 tonight and will see
some images here
https://imgur.com/waE0lKb
https://imgur.com/xTDuCLS
https://imgur.com/2cRaSFr
https://imgur.com/qXMWWzb
https://imgur.com/E0YEzGV
I think i will not update projector for long time...the matrix are such perfect, focus is a sword and it's such great! With 203 base i think it's even too much ahah
the only thing now is...i need to change the screen, i feel i use jvc at 50 percent with the wall...
Looking for some ALR screen...
jsgrise likes this.
annihilator is offline
Jvc Dla Rs46 Projector , Jvc Dla X35 3d Hd Front Projector , Optoma Hd72 720p Dlp Home Theater Projector , Panasonic Viera Ty Er3d4mu Active Shutter 3d Eyewear , Samsung Ssg 4100gb 3d Active Glasses 2012 Model
