The Blacker the Theater, The Better the Image - Page 134 - AVS Forum | Home Theater Discussions And Reviews
 2944Likes
post #3991 of 6645 Old 07-19-2017, 10:44 AM
grendelrt's Avatar
Quoted: 578 Post(s)
Liked: 308
Question for those of you who wrapped plywood with velvet for the ceiling. Did you velvet sag at all over time? I stretched mine over frames on the walls and it definitely loosened a little bit over time. Curious about the ceiling because I don't want it to sag down off the ceiling.
Sent from my SM-G920V using Tapatalk
grendelrt is offline
post #3992 of 6645 Old 07-19-2017, 10:59 AM
audioguy's Avatar
Quoted: 4987 Post(s)
Liked: 3829
If it sags on the ceiling you won't notice it. You can also use spray adhesive when you mount it to the wood but when I did that, I still had wrinkles. But one of the velvets supposedly doesn't sag at all.
audioguy is offline
post #3993 of 6645 Old 07-19-2017, 11:42 AM
grendelrt's Avatar
Quoted: 578 Post(s)
Liked: 308
Yeah i am using the joann fabrics velvet and it definitely loosened and left wrinkles/waves in it after time. Its not noticeable unless you get up on it. I was more afraid on the ceiling because of gravity coming more into play.
post #3994 of 6645 Old 07-19-2017, 06:51 PM
Quoted: 103 Post(s)
Liked: 61
I sprayed 3M 77 adhesive on the plywood and the back of the velvet before wrapping. No sag
dgkula is online now
post #3995 of 6645 Old 07-19-2017, 06:54 PM
grendelrt's Avatar
Quoted: 578 Post(s)
Liked: 308
Seems like that is the way to go, thanks for the replies!
post #3996 of 6645 Old 07-20-2017, 04:20 AM
audioguy's Avatar
Liked: 3829
FWIW, I recommend that you do this with at least two people. The chances of wrinkles being in the final product are much higher if you try to do this by yourself. That was recommend by someone else on this thread and I highly recommend it as well.
On the other hand, if you can find the non-stretch version of black velvet, then you can do it without adhesive and just use staples on the back side to hold it in place and end up with a much smoother end product.
audioguy is offline
post #3997 of 6645 Old 07-20-2017, 05:53 AM
grendelrt's Avatar
Quoted: 578 Post(s)
Liked: 308
Yeha I did most of my panels with my wife helping. How can you tell which is non stretch? I would probably go with the same Joanne stuff though anyways just to make sure it matches. I would like to do a square shape that ends in a half circle to make it look a little nicer but I dont know how hard that would be to stretch out evenly.
post #3998 of 6645 Old 07-20-2017, 06:46 AM
Buddylee123's Avatar
Quoted: 904 Post(s)
Liked: 622
This is another very popular velvet choice and it's cheaper than Joanns. http://www.syfabrics.com/View.aspx/s...e-Velvet/681/0
Buddylee123 is offline
post #3999 of 6645 Old 07-20-2017, 06:49 AM
audioguy's Avatar
Liked: 3829
THAT'S the one that states it is NO STRETCH and what I would now use instead of JoAnnes or any other for making panels.
audioguy is offline
post #4000 of 6645 Old 07-20-2017, 06:53 AM
Quoted: 904 Post(s)
Liked: 622
I thought it was no stretch but couldn't remember. It will be covering most of my walls as soon as I can talk myself into parting with the money.
post #4001 of 6645 Old 07-20-2017, 07:17 AM
grendelrt's Avatar
Quoted: 578 Post(s)
Liked: 308
How well do you think it would match the Joann Royalty Velvet 3, that's what my walls are in currently.
post #4002 of 6645 Old 07-20-2017, 08:03 AM
Moderator
rboster's Avatar
Quoted: 1627 Post(s)
Liked: 2235
Please note the thread's title change reflects content and focus of the thread.
Ron
rboster is offline
post #4003 of 6645 Old 07-20-2017, 08:16 AM
audioguy's Avatar
Liked: 3829
I have no clue but others may know. My guess would be that with the lights off, little to no difference.
audioguy is offline
post #4004 of 6645 Old 07-20-2017, 08:18 AM
audioguy's Avatar
Liked: 3829
Ron
WOW. Long Title
audioguy is offline
post #4005 of 6645 Old 07-20-2017, 08:18 AM
grendelrt's Avatar
Quoted: 578 Post(s)
Liked: 308
Just remembered that I cant run a board on the ceiling, was going to remove some spotlight that are up there to do it but they have actually been useful. Have to rethink what I want to do :O
post #4006 of 6645 Old 07-20-2017, 08:49 AM
Mike Garrett's Avatar
Quoted: 12534 Post(s)
Liked: 10148
Why not? Just cut a hole in the panel and place the trim ring for the light, over the panel.
Mike Garrett is offline
post #4007 of 6645 Old 07-20-2017, 10:04 AM
Quoted: 904 Post(s)
Liked: 622
Ron
Kinda looses the spirit of the thread. Almost everything in this thread is about finding the blackest material that will absorb the most light.
audioguy likes this.
post #4008 of 6645 Old 07-20-2017, 10:07 AM
Moderator
rboster's Avatar
Liked: 2235
so what would you suggest?
rboster is offline
post #4009 of 6645 Old 07-20-2017, 10:07 AM
audioguy's Avatar
Liked: 3829
Agreed. Someone must have decided the original title was politically incorrect. But the new one is way too long. Something like: "The Blacker The Theater, The Better The Image", while still too long, is more descriptive !!
audioguy is offline
post #4010 of 6645 Old 07-20-2017, 10:08 AM
audioguy's Avatar
Liked: 3829
How about a contest and the winner gets a new $35,000 JVC projector ........... or not !
audioguy is offline
post #4011 of 6645 Old 07-20-2017, 10:11 AM
Quoted: 904 Post(s)
Liked: 622
I really like this one, and can't think of something better at the moment.
post #4012 of 6645 Old 07-20-2017, 10:13 AM
Moderator
rboster's Avatar
Liked: 2235
I don't want this to be a elongated process.....(trying to carry on with my daily life too )....so hit me up with something that makes sense and I'll make this a one-off change. ....then we can all move on with our lives.
rboster is offline
post #4013 of 6645 Old 07-20-2017, 10:13 AM
Quoted: 904 Post(s)
Liked: 622
I like this idea even more lol. Maybe we should leave it open to suggestions for a bit.
post #4014 of 6645 Old 07-20-2017, 10:21 AM
Quoted: 904 Post(s)
Liked: 622
Thanks @rboster
post #4015 of 6645 Old 07-20-2017, 10:25 AM
grendelrt's Avatar
Quoted: 578 Post(s)
Liked: 308
They aren't just hole lights, they have like 18" rails they slide down and are pretty large, I may still try something similiar with velvet, but I need to paint the lights and rails as well. I still need to decide on side walls and floor, so trying to prioritize which one I will do first hehe.
post #4016 of 6645 Old 07-20-2017, 10:26 AM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5986 Post(s)
Liked: 5115
The original didn't need changing but.... this will do.
Scott Simonian is offline
post #4017 of 6645 Old 07-20-2017, 10:27 AM
Liked: 10148
Okay. You have track lights. That is even easier. Take the track light down. Drill small hole in panel for electrical wiring. Pull wire through hole and secure panel. Then install track lighting.
cardoski likes this.
post #4018 of 6645 Old 07-20-2017, 11:36 AM
stanger89's Avatar
Quoted: 4156 Post(s)
Liked: 2388
Exactly, whoever didn't have a sense of humor can just take their lack of sense of humor elsewhere
Mikenificent1 likes this.
stanger89 is offline
post #4019 of 6645 Old 07-20-2017, 12:45 PM
Boggle's Avatar
Quoted: 42 Post(s)
I put the syfabrics onto my drop ceiling tiles using staples. While the fabric doesnt stretch, it is very very hard to get it super tight in this case. So I still ended up with some small amount of loose fabric. Depending on how picky you are and how low your ceiling is you may be ok. Also plywood has less give than a ceiling tile, so you could pull it harder. But I do remember pulling quite firmly and still ended up with some sagging on the biggest tiles (2X4) I remember pulling hard enough that I would lose staples on the other side sometimes. But again drop ceilings are softer than plywood.
Boggle is offline
post #4020 of 6645 Old 07-20-2017, 12:54 PM
audioguy's Avatar
Liked: 3829
Originally Posted by unretarded View Post
I have been eying those for some of the same reasons ! How does it do on all that black fabric now ? My only concern with shelling out 150-200 bucks for high end one was performance on the black fabric.
When the lights are off you most certainly can see the dots (stars ????) on the black material, including black velvet. The "clouds" is a different story !!
unretarded likes this.
audioguy is offline
Epson 5020ub Powerlite Home Cinema 3d Front Projector , Mitsubishi , Panasonic Blu Ray Disc Player Dmp Bd30k
