The Blacker the Theater, The Better the Image - Page 153 - AVS Forum | Home Theater Discussions And Reviews
 3023Likes
post #4561 of 6765 Old 02-02-2018, 02:28 PM
VideoGrabber's Avatar
Quoted: 522 Post(s)
Liked: 324
Anyone got any ideas on the LEAST MESSY way to cover a metal case of an Electric Screen with material?
A very, very, very, very long sock?
That might make it difficult to roll the screen out of though.
More seriously, how about just wrapping a long piece of velvet fabric around it, and securing it to a few spots with velcro?
[ if you did paint it, you could just use a brush, and not have to haul it out to the back yard. how perfect does it have to be? ]
VideoGrabber is offline
post #4562 of 6765 Old 02-02-2018, 03:46 PM
coderguy's Avatar
Quoted: 2457 Post(s)
Liked: 1325
I'm banned from ever using paint in my house again.
Going to try the Protostar method.
**Updated Projector Calculator Released NOV 2017**
-- www.webprojectorcalculator.com --
coderguy is offline
post #4563 of 6765 Old 02-02-2018, 05:34 PM
Jive Turkey's Avatar
Quoted: 590 Post(s)
Liked: 494
Originally Posted by Craig Peer View Post
In fact I'm going to put some Protostar on the case of my Stewart screen, where there is a slight reflection off the black case
My masking panels are Protostar covered and work great. Being self-adhesive really comes in handy.
Craig Peer likes this.
See ya. Dave
"High Fidelity audio has been like a dog chasing his tail. High Fidelity in my marriage has been much more rewarding because she knows where I sleep."
Jive Turkey is offline
post #4564 of 6765 Old 02-02-2018, 05:36 PM
Gabre's Avatar
Quoted: 456 Post(s)
Liked: 71
Today I ordered 15 yards of that morex velvet.
So we'll see whose ship is making black woll
Sent from my HTC U11 using Tapatalk
unretarded likes this.
Gabre is offline
post #4565 of 6765 Old 02-02-2018, 11:15 PM
coderguy's Avatar
Liked: 1325
Has anyone in the thread compared it to the contact adhesive velvet paper you can buy on Ebay?
Might be the same thing, no idea. I just noticed that it looks similar, comes in the same general sizes on Alibaba, and is also self-adhesive.
Protostar is good, but seems overpriced. I can get the Velvet tape in amounts for overall about 1/2 price per Sq. Ft...
The contact paper is even cheaper than the tape, per sq ft that is.
coderguy is offline
post #4566 of 6765 Old 02-03-2018, 12:24 PM
Moderator
rboster's Avatar
Quoted: 1637 Post(s)
Liked: 2261
I would be shocked if a velvet wallpaper had the same absorption properties as protostar. Protostar was developed for use inside of telescopes...the HT application is a side market segment for the product.
Sorry, but it seems like wishful/hopeful thinking.
rboster is offline
post #4567 of 6765 Old 02-03-2018, 12:43 PM
zombie10k's Avatar
Quoted: 5416 Post(s)
Liked: 5771
This may work ok for covering the metal screen casing, the question is how good is the adhesive at this price point. It's cheap enough to order and find out if it works ok.
https://www.ebay.com/itm/Self-adhesi...k/331966572485
zombie10k is offline
post #4568 of 6765 Old 02-03-2018, 03:05 PM
carp's Avatar
Quoted: 3547 Post(s)
Liked: 3304
Originally Posted by jdlynch View Post
Carp- how did you attach the black velvet to your ceiling? I've been thinking for too long now about how to do my own ceiling; I want to go 5-6 ft out from the screen wall.
I used staples. However, I did realize that I couldn't pull the velvet as tight as I wanted without the staples pulling out so I used tacks to initially hold sections of the velvet in place and then I would staple and remove the tacks.
carp is offline
post #4569 of 6765 Old 02-04-2018, 09:39 AM
SteveCallas's Avatar
Quoted: 856 Post(s)
Liked: 783
Pretty sure quality velvet has already been tested against protostar and the velvet was significantly darker.
SteveCallas is offline
post #4570 of 6765 Old 02-04-2018, 11:04 AM
zombie10k's Avatar
Liked: 5771
The velvet is darker, but the protostar works better in certain places that velvet doesn't. Wrapping the casing of a electric screen was the specific use case being discussed above.
velvet left / protostar right.
thickness example in 2nd photo
for 'blackness' the protostar is much closer to the velvet vs. rosco paint.
Rosco ends up looking dark grey compared to the velvet. I ended up drapping velvet over the 18" subs and they disappear in the room now.
coderguy likes this.
post #4571 of 6765 Old 02-04-2018, 05:58 PM
vampat's Avatar
Quoted: 82 Post(s)
Liked: 26
Hello,
I have the project to covert my celling with panel covered with velvet, do you think 37 inch large will be enough to decrease light on the ceiling?
All my room is black, carpet, walls with carpet and the ceiling is painted in black too.
vampat is offline
post #4572 of 6765 Old 02-04-2018, 10:57 PM
ereed's Avatar
Quoted: 2324 Post(s)
Liked: 1637
Originally Posted by vampat View Post
Hello,
3 feet is better than nothing!
Theater room: Sony 45es | 120 inch screen | Panasonic BDT500 | Rotel RMB-1077 | Outlaw Audio 976 | Klipsch RP-280F/RP-450C/RP-160M (x4) | Funk Audio subs (x2) | MiniDSP 2x4HD | Crowson D-501/Shadow-8 Actuators (x2) | Monster Power Conditioner | GIK acoustic panels
TV Room: Panny 60 inch | Rotel RMB-1075 | Rotel RSP-1068 | Axiom Audio M60/VP150/QS8
ereed is offline
post #4573 of 6765 Old 02-05-2018, 12:44 PM
carp's Avatar
Liked: 3304
True, velvet is darker. Years ago I used masking panels with protostar on some plastic sheets. Worked great and they were way darker than black paint but still weren't as dark as velvet.
Only pic I could find that had both protostar and velvet. In the pic the velvet looks lighter but it's not.
I stopped using the masking panels when I got a projector with lens memory, too much of a hassle to the panels on and off.
ID:	2356594   Click image for larger version
ID:	2356596   Click image for larger version
carp is offline
post #4574 of 6765 Old 02-05-2018, 12:46 PM
jh901's Avatar
Quoted: 758 Post(s)
Liked: 298
There is a chance that reflection from the large, untreated area will be more distracting when contrasted with Royalty 3 (or other preferred) velvet.
HT: Panasonic DP-UB820 | JVC RS600 | 106" x 45" Stewart ST 100 | Cary Audio Cinema 12 | NAD M27 | Elac Uni-Fi UF5, UC5, Debut F5/B6; Focal CMS Sub
STEREO: [Shunyata Denali] Playback Designs MPS-5 (fully upgraded) | Cary Audio SLP-05 tube line level | Cary Audio SA-200.2 ES | Focal Diablo Utopia III DEN: 60" Panasonic VT60
jh901 is offline
post #4575 of 6765 Old 02-05-2018, 03:29 PM
vampat's Avatar
Quoted: 82 Post(s)
Liked: 26
Ok I see...
So do you recommend to install velvet on all the surface, it will cost $$$...
maybe I can add a 1 feet so I would have 4 foot....
of I install Nothing and save $$$!!
Projector: JVC DLA-X770R | Screen: Stewart Filmscreen Cima Neve 2.35:1 125’’ Bluray: Oppo BDP-203 | Receiver: Arcam FMJ AVR-550
Speakers: Totem Forest (front) | Model 1 Signature (center) | Rainmaker (surround) | Mini Kin Flex (Atmos) Subwoofer: Funk Audio 18.0C
Light Control: Lutron Maestro | Remote: Harmony Elite
vampat is offline
post #4576 of 6765 Old 02-05-2018, 05:02 PM
lcrenshaw7's Avatar
I am wanting to cover the front part of my theater in some sort of velvet. About 4 feet out on the ceiling, screen wall and side walls. I?m close to pulling the trigger on Protostar. Will it be easy to put on the ceiling and on the walls? My wife is on me about making sure it looks good. Here is a pic of my room. Thank you for your help
lcrenshaw7 is offline
post #4577 of 6765 Old 02-05-2018, 08:30 PM
coderguy's Avatar
Liked: 1325
I will compare the Protostar stuff to the Ebay stuff, I'm interested if it really is better, because if not, then why pay more.
I got impatient waiting on the screen, so I ran to Walmart and grabbed enough blackout cloth to make a 120" 2.35 screen.
The homemade screen came out surprisingly well (though not perfect), I very well may leave it as a second screen behind my new Electric Screen.
It would have been perfect, but I over-tensioned part of it and created 2 small waves (cannot see them with lights off). I think I can get the waves out.
I wasn't trying to actually create a 'good' screen, I was simply trying to visualize how the screen would work so decided to use TACKS and some blackout cloth as a quick solution.
I had the screen up in 30 minutes and it cost me $25 to buy the blackout cloth, and it looked pretty decent after I was done, was surprised.
I may go online and order some different DIY screen material and experiment with it. Need to try out some different DIY materials.
Blackout Cloth is a great way to setup a TEMP screen for anyone that is building an HT and isn't sure about the screen size or 2.35 vs. 16:9 or whatever. The blackout cloth only comes in 54" high, but it is enough for about 135" (or even slightly bigger) 2.35 screen.
I just don't see myself spending real money on another screen until I'm sure how to handle 2.35 switching.
I was also curious to how cheap blackout cloth would look against the HP 2.4 screen, well besides the brightness the HP screen is just slightly sharper, but not a huge difference.
I think the blackout cloth MIGHT have less texture in arctic white scenes, but didn't test much white content yet. The difference in sharpness was say 20% maybe, not huge but it was there.
I didn't do a same-room test though, as my HP screen and blackout cloth screen are in 2 separate rooms.
I have the HP in a gameroom but I think I may retire it soon, at least temporarily.
I'm going to Home Depot tomorrow to get some Foam Board, I'm just going to buy whatever is thinnest and cheapest and try that first.
coderguy is offline
post #4578 of 6765 Old 02-05-2018, 10:19 PM
coderguy's Avatar
Liked: 1325
Did you apply it directly to the wall or use foam panels first?
Is that black paint around the power outlet, or something else?
coderguy is offline
post #4579 of 6765 Old 02-06-2018, 07:31 AM
carp's Avatar
Liked: 3304
Ha, I have to think about it because that was years ago and I've made so many changes since then. It was a very dark gray, almost black.
Your first question - are you asking about the velvet? I attached it directly to the wall and ceiling.
carp is offline
post #4580 of 6765 Old 02-06-2018, 07:40 AM
carp's Avatar
Liked: 3304
If you are asking about the panels, this pic shows it. I attached the protostar to the panels and they were just the right size to fit in to mask 16:9 content.
carp is offline
post #4581 of 6765 Old 02-06-2018, 08:26 AM
Mike Garrett's Avatar
Quoted: 12671 Post(s)
Liked: 10297
Might be a lot of tape though.
Edit
Now that I think of it...
They also sell Velvet Tape on Ebay which is very dark, but I wish it came in wider strips and it can get expensive fast if you need a lot of it. I'm going to check ALi-Baba and see if I can order some wider strips of it or order it in a larger quantity to do some custom masking.
I have used it before, the tape is so easy to use, and it sticks on perfectly and looks completely normal and seamless. Not sure how well it would stick to metal, but should be fine if you clean it with alcohol first.
4.5" wide is available on Amazon.
https://www.amazon.com/4-5-Velvet-Pr.../dp/B004MO3JTO
Mike Garrett is offline
post #4582 of 6765 Old 02-06-2018, 09:10 PM
unretarded's Avatar
Quoted: 1688 Post(s)
Liked: 2081
[QUOTE=coderguy;55640744]I will compare the Protostar stuff to the Ebay stuff, I'm interested if it really is better, because if not, then why pay more.
I QUOTE]
Carls sells huge pieces of black out cloth cheap......I purchased a bunch of different materials from carls when choosing what material to go with and the black out cloth looked really good, especially for the price and would probably work for a lot of people with 1080 PJ`s.
I am trying the spandex next for AT........
Link to Stereo Integrity SI HT 18 sub build......https://www.avsforum.com/forum/155-di...-pedestal.html
Speakers and subs for sale...https://www.avsforum.com/forum/209-au...kers-subs.html
unretarded is offline
post #4583 of 6765 Old 02-06-2018, 09:19 PM
coderguy's Avatar
Liked: 1325
I just purchased Carl's Sample Pack, not sure what is in it, was $10 for the samples. I'm also going to grab a piece of smooth white vinyl from a fabric store to see how it compares. The white vinyl does have some texture, but it's a very different kind of texture compared to BO cloth. Posterboard could be interesting since it's so smooth, but it might be too glossy, and hard to get in a big enough piece.
As far as the Draper Electric Screen I purchased, well that's a big Question if I will ever even get it. Still no update from the freight shipping company. Going to have to contact Provantage again.
I'm curious to see if Carl's Blackout Cloth is superior to the stuff I got at Walmart (which is amazingly cheap, but is a bit rough compared to a higher-end screen like a Da-lite HP).
I might get some samples from Elite and Elunevision next.
coderguy is offline
post #4584 of 6765 Old 02-06-2018, 09:27 PM
coderguy's Avatar
Liked: 1325
For the walls, I'm going with black vinyl trim over black velvet (or similar).
The bigger panels will be black velvet, and then the vinyl will be used as a trim to form spacer barriers every few 2-3 feet.
Trying custom-cut cardboard sheets from an online vendor instead of foam board to cover with the vinyl, don't think you would be able to tell the difference, but not sure.
Obviously the cardboard could warp easier over time, especially if someone leans against the wall, but then if that happens replacing one board should be simple.
Testing it on one cardboard sheet first to see how seamless I can make it look.
coderguy is offline
post #4585 of 6765 Old 02-07-2018, 10:07 AM
bjhess's Avatar
Quoted: 49 Post(s)
Liked: 26
Hi, I've done a fair bit of browsing in the thread, but can't quite get my head wrapped around things.
I would love to start applying velvet/fabric to my home theater in order to improve contrast, and definitely before doing any acoustic treatments. I think what I see here in terms of application is taut fabric on walls, stapled or pinned. There are occasional instances of curtain treatments with curtain rods.
My room is a family room. While the area of the room with my theater system is primarily used for just that, it is a shared space, visible to the rest of the house, and worth making look nice while being as functional as possible.
What I always had been thinking is not black paint or taut fabric applied to a wall, but rather the "folded over" velvet look, similar to the movie theaters I grew up on in the 80s and 90s. (Literally. My parents owned a two-screen, small town theater. Here is a very bad picture of what I mean by "folded over.")
In any case, I suspect "folded over" has at least two bad features:
  • Tedious to install. Would have to carefully create each fold to make them reasonably parallel vertically.
  • Would probably use double the fabric. Cost.
Good features:
  • The additional fabric would provide an acoustic benefit.
  • If done well, might look nicer than other options.
I'm leaning toward giving it a try, so my practical questions (that probably are answered in this thread, but I'm having trouble discovering anything with search):
  • How would I mount this fabric with aesthetics in mind at the top and bottom seams? I can imagine attaching a thin board to the wall at the top and bottom fabric mounting positions, stapling the fabric directly to the top and bottom boards, and then covering the staples/seams with trim painted matte black.
  • How would I account for aesthetics on side seams? The screen wall of my theater runs 20', but only about 10' of it is in the theater section of the room. I won't run fabric the full 20', but maybe just 12'. My thought is to staple the side seam to the wall directly and again cover it with trim painted matte black.
Crazy ideas? Adjustments you would make? (I'm betting I'm over-complicating this whole thing.) If this wall-mounted-board, staples, matte black trim idea seems reasonable, are there any examples in the thread of others doing a similar install? Would love to see detailed pictures (or videos!) of the actual installation process.
Thanks for reading!
bjhess
bjhess is offline
post #4586 of 6765 Old 02-08-2018, 02:22 AM
DJR662's Avatar
Quoted: 636 Post(s)
Liked: 417
Not sure if this is the right topic to ask, but I thought I'd ask anyway. Please re-direct me to the appropiate threads/topics if necessary.
Does anyone know of any DIY solutions for scope masking on a tab tensioned dropdown 16:9 screen? All I see are suggestions for fixed screens.
Thank you.
Sony VPL-VW360ES | 110" Elite Screens CineGrey 5D Saker Tab | Sony KD-75ZD9 | Sony UBP-X800 | Panasonic DP-UB824 | Sony STR-DN1070 | B&W 5.1 setup
Sony KD-65ZD9 | Sony UBP-X1000ES | Sony STR-DN1050 | Boston Acoustics 5.1 setup
DJR662 is offline
post #4587 of 6765 Old 02-08-2018, 04:10 AM
coderguy's Avatar
Liked: 1325
You can use a modified version of Zombie's technique, just glue a magnet on a small piece of board and attach the board to the wall just past the point of where your screen ends. Hence, create an extrusion next to your screen's edges with the magnets on them. Then your magnetized piece of boards can hold the piece of velvet covered foam or cardboard to go over the screen. As long as your screen area is covered in black, I'm sure you can make it look natural, either make the board sloping or just make a natural vertical trim. Hence, 2 vertical pieces of wood covered in black velvet next to the screen coming from the ceiling to the floor that looks like a decorative divider. Once the lights are out, you'll no longer see it anyhow.
Otherwise, you can try motorized methods, which would be a bit more complicated to get the tracks lined up and working with the motors.
coderguy is offline
post #4588 of 6765 Old 02-08-2018, 10:42 AM
DJR662's Avatar
Quoted: 636 Post(s)
Liked: 417
Thanks for the suggestion but in my case, I don't think that would work. I have a TV mounted to the wall, and the screen actually drops in front of the TV when I watch something on my projector. Also my front speakers are located exactlty next to the borders of the screen when it has been dropped.
Thinking about it now, if I could choose a screen again, I probably would have went for a 2:35.1 one...
DJR662 is offline
post #4589 of 6765 Old 02-08-2018, 11:47 AM
coderguy's Avatar
Liked: 1325
Well yah, no-one can tell you unless they saw it in that case.
Make a magnetic holder connected to the side or top of the speaker I guess. There should be a way.
coderguy is offline
post #4590 of 6765 Old 02-08-2018, 12:02 PM
DJR662's Avatar
Quoted: 636 Post(s)
Liked: 417
Lol, yeah you're right. I should have been more specific regarding my setup.
DJR662 is offline
Epson 5020ub Powerlite Home Cinema 3d Front Projector , Mitsubishi , Panasonic Blu Ray Disc Player Dmp Bd30k
