The Blacker the Theater, The Better the Image - Page 185 - AVS Forum | Home Theater Discussions And Reviews
 3761Likes
post #5521 of 7721 Old 12-20-2018, 06:22 AM
Quoted: 156 Post(s)
Liked: 107
Originally Posted by lizrussspike View Post
Thanks @ScottieBoysName, I will look to get the Royalty 3 for on top of the speakers.
I am using the Premier Velvet. It is super luxurious - only velvet I've seen out of which I would want a stylish sportcoat
https://www.joann.com/premier-velvet/xprd540653.html
JVC RS620 | 100" Stewart ST100 Screen | Panasonic UB900 | Lumagen Radiance Pro 4242
Atmos 7.3.4 | Denon 4300 | Outlaw M2200 for HTD Level 3 L/C/R & in-wall surrounds & atmos
3 x PE UM15-22 sealed subwoofers | Crown XLS 2502 | miniDSP HD
dgkula is offline
post #5522 of 7721 Old 12-20-2018, 06:25 AM
Quoted: 156 Post(s)
Liked: 107
Those speakers look familiar I built a pair of the 18" Ultimax and originally painted them with the Rosco paint but they stood out vs. the velvet in the room and had to cover them. now they disappear
once you start with the velvet it's hard to stop until it's all done
I built a pair of the UM15 sealed subs and they are great. I just had a moment of insanity and ordered a third flatpack kit! In my 12 x 14 x 7 room the bass is unreal. REW shows it flat to 5Hz. The end of Ready Player One helped me localize one final vibration - and almost ripped my house off the foundation!!
dgkula is offline
post #5523 of 7721 Old 12-20-2018, 07:18 AM
lizrussspike's Avatar
Quoted: 1575 Post(s)
Liked: 2440
Thanks @dgkula. as that is what I want. As you can see, I have a glare on the top of my speakers. Wouldn't you know it, my local store in Davenport is out. Will have to order on-line then!
lizrussspike is offline
post #5524 of 7721 Old 12-20-2018, 03:04 PM
enricoclaudio's Avatar
Quoted: 4358 Post(s)
Liked: 5772
I got today a yard of Joann's Royalty Black Velvet. This thing is BLACK. As black as the velour on the frame of my Stewart ST100 screen. The only issue is that it frays a lot and also it's a little bit shiny/reflective. After exchanging several emails with Jon Kaisand from Seymour AV, he is sending me today samples of Fidelio Velvet and their Baritone Velvet to decide which one is the best. Here are some pictures comparing the Joann Royalty velvet and the Bravo Fabric Velvet. Only when you do a side by side comparison is when you see why the Bravo Fabric velvet is so cheap. That velvet is not even black and more like dark grey. It's good for side walls and back walls but definitely not for front walls or the walls and ceiling around the screen. Next week I'll be receiving swatches of Fidelio Velvet (Vogue Fabrics and Seymour AV), Baritone Velvet (Seymour AV), Soprano (Vogue Fabrics), Triple Black Velvet (Vogue Fabrics) and Plush Triple Velvet (Sy Fabrics). I'll be doing a comparison to see which one absorbs more light and is the blackest one
ID:	2499174   Click image for larger version
ID:	2499176   Click image for larger version
Enrico Castagnetti @ Rythmik Audio - Dialing In Rythmik Audio Subwoofers - REW for macOS
Media Room: Sierra Towers w/RAAL, Horizon w/RAAL, Sierra 2s & Lunas | Rythmik G22 (x2) + FV25HP | Denon X6500H | Panny 820 + ATV 4K | Bluesound Node 2 | Sony 77A9G OLED |
Desktop: Dynaudio BM5 mkIII | Rythmik L22 | Apogee Quartet | 27" iMac| Bedroom: B&W 685 S2 | Rythmik LVX12 | Marantz SR6013 | Sony X700 + ATV 4K | Sony XBR-65Z9D |
enricoclaudio is offline
post #5525 of 7721 Old 12-20-2018, 05:30 PM
madermat's Avatar
Quoted: 73 Post(s)
Liked: 34
the joann stuff is good .i used it because i can get it locally easy .and they seem to always have some coupon
madermat is offline
post #5526 of 7721 Old 12-21-2018, 02:02 AM
unretarded's Avatar
Quoted: 1734 Post(s)
Liked: 2142
....and to answer the question from a few pages back about diminishing returns....there are none.
I did my room in stages and every stage had a measurable improvement.
Side walls, then ceiling , then rear wall, then the rest of the sides.
If you go 90 degrees from each side of your head at the MLP and stopped with the velvet on the side walls and ceiling, then did the back wall, maybe what was left might be as drastic as the other locations, but there will not be much left to do at that point, might as well do it too....in my room that left 50 inches on each side wall and it made a difference, maybe not as much as directly around the screen and the back wall, but it made a difference.
cardoski likes this.
Link to Stereo Integrity SI HT 18 sub build......https://www.avsforum.com/forum/155-d...-pedestal.html
Theater house build.....https://www.avsforum.com/forum/15-ge...hed-house.html
unretarded is offline
post #5527 of 7721 Old 12-21-2018, 08:30 AM
ScottAvery's Avatar
Quoted: 872 Post(s)
Liked: 254
The 45" wide bolts from Fabric Bravo do not look like that. I guess I can be glad I got the original product even if the width is inconvenient. There are pictures further back in this thread showing it is near identical to Sy's triple plush, at 5-10% of the cost of Fidelio.
ScottAvery is offline
post #5528 of 7721 Old 12-21-2018, 09:43 AM
tigerhonaker's Avatar
Quoted: 1079 Post(s)
Liked: 1323
Post
Joann is also what I went with to have custom covers for all the components in front of my screen made by a seamstress.
The Black Velvet worked perfect and now No-Reflections to screen at all.
Before pictures,
After pictures,
Terry
carp, skypop and cardoski like this.
tigerhonaker is offline
post #5529 of 7721 Old 12-21-2018, 09:56 AM
ScottieBoysName's Avatar
Quoted: 1492 Post(s)
Liked: 571
Perfect. That's exactly what I wanted to know. I'll stick with Joann's then.
ScottieBoysName is offline
post #5530 of 7721 Old 12-21-2018, 10:08 AM
Liked: 5772
Don't like Joann's Royalty 3 Velvet as it's a little bit shiny. Most likely I would get Fidelio or Baritone. Both the Baritone and Fidelio are made by the same company, JB Martin. They are quite similar products with the Fidelio only being slightly more dense pile of fibers. Fidelio has a 99.7% of light absorbance and Baritone has 99.5%. Also, Fidelio comes in 44" wide and Baritone in 60" wide.
post #5531 of 7721 Old 12-21-2018, 10:20 AM
Liked: 571
I've got the JR3 on my screen walls and side walls now, and while it might have a bit of sheen to it - using coupons when available makes it a better value than the Bariton or Fidelio - correct? What are are the costs associated with those?
post #5532 of 7721 Old 12-21-2018, 10:42 AM
zombie10k's Avatar
Quoted: 5684 Post(s)
Liked: 6274
My entire room is wrapped in JR3, you will not see an ounce of sheen in practical use - my room is pitch black during movie viewing.
We just watched the new Predator movie & Venom in the same night, both movies looked amazing. Full room blackout never gets old, guests are always impressed how dark it is with the lights on and blown away with lights out.
zombie10k is online now
post #5533 of 7721 Old 12-21-2018, 10:44 AM
Liked: 5772
I know Fidelio and Baritone are expensive compared to Royalty 3 but the amount of Velvet I need to accomplish my project is only 12 yards. Fidelio is $11.95 linear ft and Baritone is $9.95 linear ft. Total Fidelio project would be around $450. That's 7% of what I already paid for the new Sony projector + Stewart screen.
Either way I'm not making any decision until I get the samples. I already messed it up going with the velvet from Amazon. This time I want to do it right without thinking on the cost.
post #5534 of 7721 Old 12-21-2018, 10:54 AM
Liked: 571
Agreed. If the cost is minimal in the long run, do it right.
post #5535 of 7721 Old 12-21-2018, 10:54 AM
Liked: 571
My JR3 looks like a black hole with the lights out.
post #5536 of 7721 Old 12-21-2018, 12:34 PM
Liked: 5772
Joann Royalty 3 Velvet top and Sy Fabrics Plush Triple Velvet bottom. Right now, Sy Fabrics is winning the light absorption competition. Monday will compare with Fidelio and Baritone.
post #5537 of 7721 Old 12-21-2018, 12:48 PM
zombie10k's Avatar
Liked: 6274
A number of these tests have been done in the past. Most will agree it's splitting hairs once you get to really dark products.
I would focus more on ensuring coverage for areas that are reflecting light back to the screen. That will have more impact than trying to find the next 1% extra of light absortion.
http://projectiondream.com/en/protos...velvet-devore/
post #5538 of 7721 Old 12-21-2018, 02:17 PM
DavidK442's Avatar
Quoted: 903 Post(s)
Liked: 765
@SOWK Can you add to your first post a couple of these comparison shots that Zombie has pulled together. Might save people from asking the same questions or reinventing the wheel.
zombie10k likes this.
DavidK442 is offline
post #5539 of 7721 Old 12-21-2018, 06:27 PM
Liked: 571
Those are the favs from past years. I saw some folks have bad luck with Sy in the construction department (maybe just one guy) and JR3 was 70% off that day. Went with JR3.
post #5540 of 7721 Old 12-21-2018, 11:17 PM - Thread Starter
Home Theater Enthusiast
SOWK's Avatar
Quoted: 1743 Post(s)
Liked: 1351
Done!
DavidK442 likes this.
Wisconsin Home Theater Enthusiasts Meet
SOWK Home Theater
SOWK is online now
post #5541 of 7721 Old 12-22-2018, 05:04 PM
william.mack's Avatar
Has anyone done comparisons recently on the blackest/most light absorptive carpet with current availability in the US? I saw some older posts on here that compared a few brands, but the top ones were not available in the states.
william.mack is offline
post #5542 of 7721 Old 12-23-2018, 06:05 AM
Venger99's Avatar
Quoted: 146 Post(s)
Liked: 32
Watched test film for first time in my room last night. Definitely a bit of reflection off the black painted soft fit near screen and more from top of the speakers. Photos don’t really show it.
Going to put up my Devore velvet.
I will make a simple cover for the top and sides of the speakers.
Simplest way to cover the walls will be to hang and staple the fabric in the approx 1m (3’) wide lengths it comes in, from the inside edge of the soft fit, around the soft fit to wall and then down the wall to the floor, rather than cutting separate long horizontal rows.
I was planning to fold over and staple the edge on the overlapping columns of fabric to give a cleaner edge.
Do you think there is any difference having the overlap edge facing the screen direction or viewing position?
Reflection will be from screen, I assume the overlap will be more visible if facing the seating.
My inclination is to have it face the screen.
Appreciate any thoughts.
Venger99 is offline
post #5543 of 7721 Old 12-23-2018, 01:52 PM
audioguy's Avatar
Quoted: 5792 Post(s)
Liked: 4892
I re-did the front half of my theater so that at least the first 7 feet is black. I had previously covered the side walls but changed to these beveled panels. Cosmetically, the theater is "finally" complete. The first image is prior to undertaking the initial project. All of the passive room treatment is still there but hidden under the panels. When watching movies (vs listening to music) the grills are on the speakers. It is not obvious from these photos but the side of the speaker closest to the screen of both speakers are covered in black velvet. I also redid the lighting from regular light to 5000K LEDs.
audioguy is online now
post #5544 of 7721 Old 12-23-2018, 02:24 PM
Liked: 5772
Beautiful Speakers and Beautiful room !! Now you need these to cover the speaker cables
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
unretarded likes this.
post #5545 of 7721 Old 12-23-2018, 03:32 PM
audioguy's Avatar
Liked: 4892
Thanks for the kind words. I looked at something like what you recommended but I need something to hold the wire down. There is a "hidden" door on the left side of the screen to get to my equipment room. More than once, I have almost tripped over the wire. The most certainly stand out like a sore thumb but I have yet to find exactly what I am looking for. I initially wrapped them in black velvet but I still had the potential tripping problem.
post #5546 of 7721 Old 12-23-2018, 03:41 PM
Liked: 5772
Gaffer tape to the rescue I use it a lot on stage. Can't work without it!!
https://www.amazon.com/dp/B00GZE3UJ8...a-dff16524fffe
Killroy likes this.
post #5547 of 7721 Old 12-23-2018, 04:05 PM
audioguy's Avatar
Liked: 4892
Perfect. I am using some gaffers tape to hold some cables that go to the rear of the room against the door threshold of the door that goes into the equipment room.; I have some gaffers tape that I can use.
Thanks for reminding me.
post #5548 of 7721 Old 12-23-2018, 04:09 PM
Killroy's Avatar
Quoted: 779 Post(s)
Liked: 763
Next to duct tape, gaffers tape "is magic and should be worshiped.”
Killroy is online now
post #5549 of 7721 Old 12-23-2018, 06:47 PM
Gabre's Avatar
Quoted: 460 Post(s)
Liked: 74
You don't have a center channel?
Awesome transformation. Would be nice to see how did you build those wall panels
Gabre is offline
post #5550 of 7721 Old 12-23-2018, 07:07 PM
audioguy's Avatar
Liked: 4892
The center channel is behind the screen. I put the L&R in the room to get better imaging when I listen to music.
Thank you. This was the look I have been trying to achieve for a long time
Actually, I bought each of those individual panels from Acoustimac. I could have built them myself (I built the previous panels) but didn't want to invest in the tools necessary to do the beveled edges since this was a "once and done" project.
But because they are not PERFECTLY rectangular, I used clamps to hold them together (two at a time) and then used a brad nails to nail them together. So every panel is attached/nailed to the panels on each side of it. Then I built some bracing behind all 9 panels to give it stability and mounted all nine panels at the same time (my wife assisted). Took a while but the outcome was what I was looking for. None of those panels uses any acoustic products. They just have acoustically transparent cloth on them to allow the sound to go through them and be dealt with by the acoustic treatment behind the panels.
Below is a photo the previous panels I built. Functional but lacked "character":
Name:	Screen Shot 2018-12-23 at 10.21.03 PM.png
Epson 5020ub Powerlite Home Cinema 3d Front Projector , Mitsubishi , Panasonic Blu Ray Disc Player Dmp Bd30k
