The Blacker the Theater, The Better the Image - Page 186 - AVS Forum | Home Theater Discussions And Reviews
 2807Likes
post #5551 of 6383 Old 12-25-2018, 08:20 AM
enricoclaudio's Avatar
Quoted: 3697 Post(s)
Liked: 4471
Here is a comparison between Fidelio Velvet and Soprano Velvet from Vogue Fabrics. Fidelio may be just a little bit darker but Soprano is very good. It also comes in 60" wide instead of the Fidelio 44" wide. The price for Soprano is $29.99 yard and Fidelio is $39.99 yard but the wholesale price for Soprano 18 yards bolt is $423 ($23.5 yard) making the price even better. I'm just waiting for the samples of Fidelio and Baritone from Seymour AV but at this point Soprano is about to be the one I'll be ordering.
rboster likes this.
Enrico Castagnetti @ Rythmik Audio - Dialing In Rythmik Audio Subwoofers - REW for macOS
Media Room: Sierra Towers w/RAAL, Horizon w/RAAL, Sierra 2s & Lunas | Rythmik F12SE(x2) + FV25HP | Denon X6500H | Panny 820 + ATV 4K | Bluesound Node 2 | Display-less |
Desktop: Dynaudio BM5 mkIII | Rythmik L22 | Apogee Quartet | 27" iMac| Bedroom: B&W 685 S2 | Rythmik LVX12 | Marantz SR6013 | Sony X700 + ATV 4K | Sony XBR-65Z9D |
enricoclaudio is offline
post #5552 of 6383 Old 12-27-2018, 04:52 PM
ScottieBoysName's Avatar
Quoted: 1128 Post(s)
Liked: 306
I hope it turns out awesome man. Excited you found something you like.
I’m about to do my ceiling about 3-4 feet out from the screen with 1/4 plywood wrapped in velvet. I just finished the screen wall and sidewalls. Ceiling and carpet are next.
Bruce N likes this.
ScottieBoysName is offline
post #5553 of 6383 Old 12-27-2018, 05:03 PM
Liked: 4471
Yes. I got 15 yards of Soprano Velvet from their retail store as the wholesale bolt was not in stock and it takes to JB Martin between 6 to 8 weeks to manufacture it. The Soprano Velvet is basically a Fidelio Velvet but about 2% less black but the advantage of the Soprano Velvet is that it comes in 58" wide while the Fidelio Velvet is only 44" wide. Both of them are made by JB Martin here in the USA.
post #5554 of 6383 Old 12-27-2018, 05:20 PM
Liked: 306
I’m looking forward to seeing how well it compares to what you currently have. I just picked up 13 more yards of JR3 to finish everything out.
That velour tape you turned me on to works AWESOME. I have a 1/2 hole punch that I use on it to pop out screw covers for my panels.
I also used it for the baseboards like you did. Good stuff. I used the 60 foot 4 inch role. Still have a bunch of it left.
post #5555 of 6383 Old 12-27-2018, 06:31 PM
Mike Garrett's Avatar
Quoted: 11991 Post(s)
Liked: 9504
Originally Posted by audioguy View Post
Perfect. I am using some gaffers tape to hold some cables that go to the rear of the room against the door threshold of the door that goes into the equipment room.; I have some gaffers tape that I can use.
Thanks for reminding me.
Velvet tape.
https://www.amazon.com/4-5-Velvet-Pr.../dp/B004MO3JTO
Mike Garrett is online now
post #5556 of 6383 Old 12-27-2018, 06:39 PM
Liked: 306
Originally Posted by Mike Garrett View Post
I used this stuff.
4 in x 60 ft - Vibrancy Enhancing Projector Felt Tape Border - by ConClarity – Dee...
https://www.amazon.com/dp/B01NCTQIR1..._SYyjCbM58XN0P
post #5557 of 6383 Old 12-27-2018, 09:30 PM
Pultzar's Avatar
Quoted: 202 Post(s)
Liked: 117
Thanks for the comparison! You should test them with different angle of incidence between the light and your eye. Some velvets like fidelio perform exceptionally when you are viewing the velvet from the same direction as the light source, which is why it is so good for screen masking. Other velvets may do just as good for cheaper when the light source is at the opposite side of the velvet from your viewing position, such as velvet on the ceiling or side walls.
Pultzar is online now
post #5558 of 6383 Old 12-28-2018, 05:48 AM
GPBURNS's Avatar
Quoted: 393 Post(s)
Liked: 722
I re-did the front half of my theater so that at least the first 7 feet is black. I had previously covered the side walls but changed to these beveled panels. Cosmetically, the theater is "finally" complete. The first image is prior to undertaking the initial project. All of the passive room treatment is still there but hidden under the panels. When watching movies (vs listening to music) the grills are on the speakers. It is not obvious from these photos but the side of the speaker closest to the screen of both speakers are covered in black velvet. I also redid the lighting from regular light to 5000K LEDs.
Ha – I remember many/many a yrs ago I mentioned I had done my room in total velvet on some forum we were on ( maybe Seaton)–
We joked a bit but I always warned never start the project as always leads
to complete blackout as the benefits are revealed 😁
zombie10k likes this.
15400 Watts of Atmos Seaton Power -Quad SubMersived - JVC N7
GPBURNS is offline
post #5559 of 6383 Old 12-28-2018, 07:52 AM
Quoted: 299 Post(s)
Liked: 75
Need help for a set up in a family room. My ceiling is a dark grey colour and walls are dark red was thinking about blacking out the first 3'-5' on the side walls. Can't do Velvet what other options can be used thanks.
jsil is offline
post #5560 of 6383 Old 12-28-2018, 08:08 AM
zombie10k's Avatar
Quoted: 5270 Post(s)
Liked: 5543
Are you able to hang curtains? I made velvet curtains, it was relatively straight forward. If the walls have to stay bare then the black Rosco paint may be the only alternative but it's definitely not as dark / light resistant as the velvet.
zombie10k is online now
post #5561 of 6383 Old 12-28-2018, 08:20 AM
Quoted: 299 Post(s)
Liked: 75
That crossed my mind about using curtains. I told my wife that and she thought I was going crazy and need to see a psychiatrist lol.
jsil is offline
post #5562 of 6383 Old 12-28-2018, 08:51 AM
golden78's Avatar
Quoted: 403 Post(s)
Liked: 131
Tell her you are not alone 😃
golden78 is offline
post #5563 of 6383 Old 12-28-2018, 08:52 AM
golden78's Avatar
Quoted: 403 Post(s)
Liked: 131
I did that too about 5 ft out . That lasted a week. Prepare to end up doing your whole ceiling 😉
golden78 is offline
post #5564 of 6383 Old 12-28-2018, 09:11 AM
Liked: 306
My wife will kill me - though not for what you think.
I didn't like the way the velvet looked when I was just stapling it to the wall. So - I've been doing 1/4 sheets of plywood wrapped in it. Works perfect and adds mass to the walls.
I've been doing 2' x 4' pieces (pre-cut from HD) and I use an upholstery stapler (Porter Cable) to attach it to the panels.
I don't want to really dirty the velvet up in the garage on the floor - so I do it in the house - in the entry way - on the wood floor.
It's flat, not dirty, and it's not 35 degrees like the garage.
This means my air compressor is in the house...and I'm shooting a pneumatic stapler...in the house.
Fun times.
IMDave and Mike Garrett like this.
post #5565 of 6383 Old 12-28-2018, 12:03 PM
Liked: 4471
Fun times.
I'm using the same method. I got 4' x 8' x 7/32" underlayment panels from Home Depot and asked them to cut at 2' x 4' These are the ones I got:
https://www.homedepot.com/p/Underlay...1178/203183010
Next week I'll be replacing the crappy velvet I got from Amazon with JB Martin Soprano Velvet. I may need to get new underlayment panels as it would take more time to get the fabric and T50 staples from the panels than paying $40 for a new set of panels. I use two staplers, one with T50 staples and the other with JT21 staples and they work just great. Then I put the panels on the wall with black drywall screws and covered with 1/2' circles of self adhesive velour tape. I also do everything inside the living room. I have a 6ft folding table to cut and wrap the panels with velvet and a Keter Folding Compact Workbench Sawhorse Work Table outside in the balcony to custom cut a few panels.
post #5566 of 6383 Old 12-28-2018, 12:04 PM
Gabre's Avatar
Quoted: 456 Post(s)
Liked: 71
Not sure who needs psychiatrist taking into consideration RED walls in the house
Gabre is offline
post #5567 of 6383 Old 12-28-2018, 12:20 PM
Liked: 306
I would get new panels. Unless you can pull all of the staples easily.
I'm using this guy:
https://www.amazon.com/Porter-Cable-...lstery+stapler
A table would for sure help me.
post #5568 of 6383 Old 12-28-2018, 01:48 PM
Liked: 4471
I'm using this guy:
Went to HD and got new panels already
post #5569 of 6383 Old 12-28-2018, 02:12 PM
Liked: 306
Sweet! Can’t wait to see it. I’ve gotten pretty good with this gun. I can’t do an entire 2’ x 4’ panel in about 2-4 minutes.
post #5570 of 6383 Old 12-29-2018, 06:03 AM
skypop's Avatar
Quoted: 369 Post(s)
Liked: 252
Those JBL Scs8's Look good up there,'m using 4 of those for my height speakers also, great sound.
2 Channel: Fi 2A3 mono's,Hovland HP100,Technics SP10MK2/SME/Benz....HT:126" Seymour AT Screen,JBL Studio 590's for LCR, Side and Rear Surrounds. Jbl SCS8'S for Fr Heights, and Rear Heights,2 Epik Empire Subs,2 Behringer B1200D Midbass Subs,Marantz 7702MK2,Proceed Amp-5,Outlaw 7125,Panasonic UB820 ,Toshiba HD35,JVC RS600. Black Velvet.
skypop is offline
post #5571 of 6383 Old 12-29-2018, 06:53 AM
Liked: 306
Thanks! I love them. The bracket and the ability to aim them is worth its weight in gold. They’re perfect. They match up well with the JTR stuff I have and they have a huge dispersion pattern. I’m using them for rear heights also.
Heights - DTS:X
Tops - Atmos
post #5572 of 6383 Old 12-29-2018, 08:00 AM
skypop's Avatar
Quoted: 369 Post(s)
Liked: 252
Heights - DTS:X
Tops - Atmos
Mine are 4 feet in front of my couch and 4 feet behind,they sound great I'm using JBL studio 590's all the way around.
skypop is offline
post #5573 of 6383 Old 12-29-2018, 08:21 AM
Liked: 306
I like it! Looks good and dark too.
skypop likes this.
post #5574 of 6383 Old 12-29-2018, 09:07 AM
brazensol's Avatar
Quoted: 715 Post(s)
Liked: 532
I've got JR3 on my screen wall and it turned into a black hole! I'm considering doing the ceiling in front of the screen but haven't come up with a way of getting it up there that looks right. Also, and more importantly, I need some kind of anti-reflection film for my stage light lenses. I notice these far more than the semi-eggshell paint on the ceiling directly in front of my screen. Anyone have any ideas on what to use on the lenses?
Denali Cinema
JVC-RS540, 124" Wide 2.40:1 DIY Screen, Denon 8500H, Denon 6200W, Panasonic UB820 UHD Player, (3) iNuke 6000DSP's; (3) HTM-12's; (14) RSL C34e surrounds; (2) 18" Dayton Audio RSS460HO-4 Subwoofers; (1) Dayton Audio UM18-22 18" Ultimax Subwoofer; (4) Dayton Audio RSS390HO-4 15" Reference HO Subwoofers
brazensol is offline
post #5575 of 6383 Old 12-29-2018, 05:42 PM
skylarlove1999's Avatar
Quoted: 346 Post(s)
Liked: 275
I used velvet with magnets attached to a black inner facing then sewn all together. I have a drop ceiling that I attached velvet to each ceiling tile and then I use black protostar tape for the grid. When the lights are out you really can't see the ceiling at all when you're watching a movie I know it doesn't look like that from the picture but I had to put the flash on to take the picture.
brazensol likes this.
skylarlove1999 is online now
post #5576 of 6383 Old 12-29-2018, 05:51 PM
Quoted: 346 Post(s)
Liked: 275
My screen is 120 in Seymour glacier white and it is about 3 in from my ceiling
post #5577 of 6383 Old 01-03-2019, 05:24 AM
Liked: 4471
Got the JB Martin Soprano Black Velvet yesterday and started redoing my velvet blacking. Panels are rewrapped already and I should be done with the project by the end of today. Here is a picture comparing Soprano Black Velvet with what I got from Amazon, which I think is not even Velvet. The material from Amazon was sold by Maybecca as Triple Black Velvet 30 yards. A picture worth more than a thousand words.
dlinsley likes this.
post #5578 of 6383 Old 01-03-2019, 06:18 AM
Liked: 306
Muuuuuuuuch better!
post #5579 of 6383 Old 01-03-2019, 06:42 AM
grendelrt's Avatar
Quoted: 557 Post(s)
Liked: 294
Cool picture, do you still have some Joanne Royalty 3 you could put beside your new panels? Curious the difference there if I ever redo my room (or more likely move).
grendelrt is offline
post #5580 of 6383 Old 01-03-2019, 06:47 AM
Liked: 4471
Here you go: Joann's Royalty 3 Black Velvet vs JB Martin Soprano Black Velvet.
JB Martin Soprano Black Velvet is literally JB Martin Fidelio but the pile is less dense, meaning a bit less expensive. The good advantage of Soprano is that the velvet is 60" wide while Fidelio is 44" wide.
grendelrt likes this.
Epson 5020ub Powerlite Home Cinema 3d Front Projector , Mitsubishi , Panasonic Blu Ray Disc Player Dmp Bd30k
