The Blacker the Theater, The Better the Image - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 3656Likes
post #31 of 7605 Old 03-26-2013, 01:34 PM
sonichart's Avatar
Quoted: 698 Post(s)
Liked: 583
So what is the general consensus on using GOM fabric on the side walls for light absorption (aka screen floating in black)... I bought some thinking I would install it as part of my screen wall... but now I'm thinking black velvet around the screen... and GOM on the walls in the front half of the room that contains the screen.
Edit: Also thinking about installing GOM on the ceiling space immediately in front of the screen.
JVC RS600 ¤ 130" Wide Seymour XD 2.35:1
Denon x4200 ¤ Onkyo M5010 ¤ iNuke 3000 ¤ 7.2.2
HTPC GTX1080 + MadVR is my master now ¤ Zidoo X8
sonichart is offline
post #32 of 7605 Old 03-26-2013, 01:46 PM
Toe
Toe's Avatar
Quoted: 2821 Post(s)
Liked: 3773
GOM fabric?
Velvet is the best, so use that as much as possible/practical.
Toe is offline
post #33 of 7605 Old 03-26-2013, 03:07 PM
dave1969's Avatar
i have these in my theater. they have a little sheen to them but they are 100x better than a white ceiling. Plus they're only $7 a piece and light weight.
http://www.ceilume.com/ceilingtile_detail.cfm/productID.900
gtorresn likes this.
dave1969 is offline
post #34 of 7605 Old 03-26-2013, 03:09 PM
mark haflich's Avatar
Quoted: 1418 Post(s)
Liked: 1015
Gillford (spelling could be wrong) of Maine is a fabric company whose fabric is used to cover acoustical panels of even whole rooms with the panels or treatment behind. They are designer type fabrics, they cover all the treatments in my room and I chose a very dark black one. Sort of like a speaker grill cloth. Available in hundreds of colors and styles.My room has treatments covering almost every inch of wall except for wood where on wall speakers are mounted and the wood is covered by the fabric..
mark haflich is offline
post #35 of 7605 Old 03-26-2013, 03:20 PM
Toe
Toe's Avatar
Liked: 3773
Cool! Thanks for the info.
Toe is offline
post #36 of 7605 Old 03-27-2013, 07:45 AM
sonichart's Avatar
Quoted: 698 Post(s)
Liked: 583
Alright, I've decided on attaching the triple black velvet (syfabrics) to the ceiling area of my room (see zone 1). I also intend to make panels out of the same material for the area immediately surrounding the screen-- mimicking the BIG's minimalist screenwall approach.
Question for the blackout specialists here: Does it make sense to cover the soffits (see single ?) with black velvet or the walls around the screenwall (see ?? area). Otherwise, those areas will be painted flat black.
post #37 of 7605 Old 03-27-2013, 08:12 AM
Toe
Toe's Avatar
Liked: 3773
Definitely cover those areas as well. I even covered my couch and rear wall since both were very reflective, especially now with my HP screen.
Toe is offline
post #38 of 7605 Old 03-27-2013, 09:59 AM
Craig Peer's Avatar
Quoted: 7963 Post(s)
Liked: 10351
Having the entire area around the screen black - one way or another - really makes a difference.
Craig Peer is offline
post #39 of 7605 Old 03-27-2013, 10:20 AM
Toe
Toe's Avatar
Liked: 3773
Agreed, but there is a significant difference between flat black paint and black velvet which my ceiling (flat black paint) reminds me of every night vs my floor and sidewalls (black velvet) biggrin.gif I need to finish off my ceiling at some point with velvet.
Toe is offline
post #40 of 7605 Old 03-27-2013, 10:42 AM
Mike Garrett's Avatar
Quoted: 13799 Post(s)
Liked: 11452
I would go the black velvet route myself, except for one problem. I keep changing things in the room every few months. smile.gif I guess I could do the ceiling, but my low gain (0.85) screen is not lighting up my walls and ceiling very much at all on bright scenes.
Mike Garrett is offline
post #41 of 7605 Old 03-27-2013, 11:04 AM
mante's Avatar
The best temporary (4 years ago) upgrade I did was to add black velvet to the walls, floor and ceiling of the first 5 feet of my theatre. The velvet installed easily with staples and was a very inexpensive solution from Jo-Ann's
mante is offline
post #42 of 7605 Old 03-27-2013, 11:17 AM
Craig Peer's Avatar
Liked: 10351
True, but some people have limitations on what they can do.
post #43 of 7605 Old 03-27-2013, 11:30 AM
sonichart's Avatar
Quoted: 698 Post(s)
Liked: 583
I'm not renting, but that's something i've been thinking about (protostar)... I hate the idea of sticking something to my brand-new drywall that will destroy it if I ever want to change something.. I had a similar experience with some plastic stick-on conduit that, when I removed it to sell my townhouse, took a strip of drywall off with it.
My understanding is that black velvet is slightly better than protostar anyway... now I just need to find a way to attach it to the ceiling, walls, soffit (while being mindful of existing 3" can lights). Right now it seems that Fabricmate is in the lead for providing a solution. I thought about just handing black velvet curtains on the side walls... that still doesn't take care of the soffits...
Trying my very hardest to get all of this right the first time. If there are reflections on the ceiling / walls... I'm going to see it and it will bug me.
post #44 of 7605 Old 03-27-2013, 12:57 PM
cardoski's Avatar
Quoted: 2717 Post(s)
Liked: 3144
Nice looking rooms guys. I recently blacked out my entire space with black fabric. Cost me 120 bucks and some staples.The result is a black hole, I kid you not, impossible to see in the room and even when the lights are on it is still very dark. . Really has helped with the image and thankfully my remotes have lights or I would be unable to use them. Lucky for me I am single because I could not see any of my ex wife approving.biggrin.gif
Listening with Focal Elex headphones, Topping DSD Dac, SENCUN-audio tube preamp with tone control and Modded Little Dot hybrid tube amp with Voshkod 6ZH1P-EV tubes, Dual Discrete Op-Amp SS3602, and Alps Blue Velvet volume pot.
Watching in a room ensconced in velvet.
cardoski is offline
post #45 of 7605 Old 03-28-2013, 01:11 AM
jbkbs's Avatar
So for those of you that have installed the black velvet, have you had any issues with it showing every little bit of dirt or white fluff? This is what my wife is worried about? Can some kind of sound panel be covered to help the sound be better at the same time?
jbkbs is offline
post #46 of 7605 Old 03-28-2013, 04:46 AM - Thread Starter
Home Theater Enthusiast
SOWK's Avatar
Quoted: 1715 Post(s)
Liked: 1266
I am OCD, so I vacumm after every use of the theater, it's not bad in that scenario, but I could see it being an issue if you let it go for a month or so.
Also depends on how many people walk close to the screen, and parts of the theater with the black velvet.
Wisconsin Home Theater Enthusiasts Meet
SOWK Home Theater
SOWK is offline
post #47 of 7605 Old 03-28-2013, 05:48 AM
joerod's Avatar
Quoted: 1245 Post(s)
Liked: 1384
Sowk, you are the man when it comes to black! Wait, did that sound right? biggrin.gif
You made me paint my area around my screen black which I then recently did my ceiling black to. Now I am going to hit either Joanne or Michaels or a walmart and pick up some black velvet today to do around my screen area. smile.gif
I have an amazing 995ES with the new 3.1 firmware for sale. Send me a PM...
joerod is offline
post #48 of 7605 Old 03-28-2013, 05:51 AM
joerod's Avatar
Liked: 1384
http://hstrial-jrodriguez996.homestead.com/HomeTheater-DIY-Upgrades-*****************-com.html?_=1340418981039
joerod is offline
post #49 of 7605 Old 03-28-2013, 06:02 AM
Done Deal DR's Avatar
Quoted: 99 Post(s)
Liked: 147
That link doesn't work.
Home Theater Build in Progress (Contemporary living room, Klipsch RF-7 II 5.2 audio, Sony VPL-HW50ES Projector, Da-Lite 16:9 159" HP, recessed Mid Atlantic rack, etc)
Done Deal DR is offline
post #50 of 7605 Old 03-28-2013, 06:43 AM
joerod's Avatar
Liked: 1384
Still not sure why my site is still censored. I don't sell anything there. I even at times put links to AVS on there. Anyway, just tap on HOME in that link and at the top of my main page click (light blue box) and go to page 5. Then under the white review section (to the right at the bottom of the page) click on DIY Upgrades. I know, it is like a journey and I apologize. I will post some pics when I get home later.
joerod is offline
post #51 of 7605 Old 03-28-2013, 06:44 AM
joerod's Avatar
Liked: 1384
Actually just tap on the word HOME on that link and it takes you right to my main page!
joerod is offline
post #52 of 7605 Old 03-28-2013, 08:06 AM
Toe
Toe's Avatar
Liked: 3773
Non issue. I have had my velvet lined floor, walls, etc....for about eight years and is not showing any dirt or white fluff. Just vacuum once in a while and your good (I only vacuum down there once every three weeks or so).
I covered both my first reflection and bass traps on the side walls with velvet and honestly dont know what it does for sound good or bad. I do know that the velvet is not anywhere near dense enough to affect the LFE range, but not sure about highs/mids.
Toe is offline
post #53 of 7605 Old 03-28-2013, 08:50 AM
R Harkness's Avatar
Quoted: 2889 Post(s)
Liked: 2861
I have lots of vertically mounted black velvet (e.g. around the screen wall, and hanging black velvet panels for image masking). In over 3 years I haven't had to clean it as it doesn't show any visible dirt or dust.
I also have black velvet on my floor and speakers. The top surfaces will allow dust to settle over time. It's not dirt, just a slightly lighter haze that forms on top of the velvet.
It's never enough to make the velvet visible during movies, but to get the deepest black look for lights on conditions I lightly vacuum those surface areas about once every one or two months. (The velvet doesn't pick up dirt, really, because no one walks on it).
R Harkness is offline
post #54 of 7605 Old 03-29-2013, 05:14 AM
joerod's Avatar
Liked: 1384
So I started my black velvet journey yesterday. I went to two Joanne Fabrics (they were fairly close to each other) and was able to use two 50% off coupons which made a huge difference. A cute girl working at one gave them to me. Anyway, I also hit a kmart and picked up the same best step pads Sowk has. I also noticed my local Sears hardware also has the same exact ones (because they are together more than likely). Of course they are much cheaper at kmart! So last night I did one wall. I used an electric staple gun for most of it and for the edges I used the spray adhesive the girl at Joanne Fabrics suggested. It works perfectly! It makes the velvet lay down like a second skin! I can see a difference which is significant when looking at the velvet and comparing it to the flat black paint. This is really fun...
joerod is offline
post #55 of 7605 Old 03-29-2013, 06:54 AM
Liked: 1015
Damn. My computer is really screwed up. I keep hitting the $3K projector forum icon and this DIY HT construction thread keeps coming up. I tried rebooting, same result. Maybe I should seek out some cute computer girl somewhere to fix it.
RDalton likes this.
post #56 of 7605 Old 03-29-2013, 07:12 AM
sonichart's Avatar
Quoted: 698 Post(s)
Liked: 583
Did you just staple the velvet straight to the drywall then?
I'm thinking about building a second wall... or panels on top of the drywall using 1x2 boards... the the frame border would be 1 inch wide (all around) and 2" deep... That way I could attach a backing board and stick piece of 1" thick OC703 behind the velvet..
post #57 of 7605 Old 03-29-2013, 07:24 AM
R Harkness's Avatar
Liked: 2861
There's no doubt you'll love the results.
There really is a difference in the viewing experience when you go from being able to perceive anything around the image to true pitch black. It moves the experience even more into the "Professional, Cinematic" territory. (Which is a bit ironic because even theaters don't have as pitch black surrounding as you end up with when using black velvet. But that's the vibe I get the more I make my room disappear).
post #58 of 7605 Old 03-29-2013, 09:30 AM
Craig Peer's Avatar
Liked: 10351
Rich, I have to give you credit - after just watching movies happily in our theater for the last 3 years, I ran across your theater build thread again here at AVS forum a couple of months ago. For some reason, it gave me the bug to start changing my theater to see if I could darken it enough ( without going to the " every square inch is black velvet " extreme and pissing off my wife ), to create an enviroment where a white screen worked as well or better than my Firehawk. When I reached the point where a StudioTek 130 G3 sample looked as good on really dark scenes as my Firehawk did, I decided to pull the trigger and replace my Firehawk. That required painting my ceiling very dark gray, painting my light gray walls darker gray, totally covering the beige carpet with a wall to wall black rug ( s ), and a few other tricks.
The new StudioTek 130 G3 screen looks absolutely outstanding ! Watched Flight on it Wed. night after installing it. It was almost like looking out a window at the real world. With the Lumis the picture is just top notch. Thank you for inspiring me to get back to work improving my theater. The payoff is more than worth the effort and expense !! Craig smile.gif
PS - the moral of the story is you don't necessarily have to go 100% black - depending on the room, very dark grey flat paint in various shades can work too ( with black velvet around your screen ). You can make a room work and have some WAF too!
GrandPixel, LDizzle and Scott 44 like this.
post #59 of 7605 Old 03-29-2013, 10:16 AM
joerod's Avatar
Liked: 1384
Yes, up on top and then I pulled the sides and used the adhesive for the edges. Here's the adhesive I am using...
joerod is offline
post #60 of 7605 Old 03-29-2013, 10:20 AM
joerod's Avatar
Liked: 1384
joerod is offline
Epson 5020ub Powerlite Home Cinema 3d Front Projector , Mitsubishi , Panasonic Blu Ray Disc Player Dmp Bd30k
