The Blacker the Theater, The Better the Image - Page 200 - AVS Forum | Home Theater Discussions And Reviews
 2957Likes
post #5971 of 6672 Old 03-30-2019, 05:58 AM
Quoted: 55 Post(s)
Originally Posted by Spaded21 View Post
Got the felt tape on the track. Tried to get pics in various brightness levels. Can't wait to finish the rest the area in front of the screen. There's a soffit after the 4th row of tiles so I will be stopping there.
Wow! What a difference that made. It looks very nice! Nice work.
Rick
JVC DLA-X590R Projector, Oppo UDP-203, Denon AVR-S940H, 125" Milliskin Silver/White Spandex AT Screen, Black Velvet on hung ceiling
rdlohr is offline
post #5972 of 6672 Old 03-30-2019, 06:02 AM
Quoted: 55 Post(s)
Here is how mine ended up. Very happy with it.
I posted a full build thread here to make it easy for anyone to repeat:
https://www.avsforum.com/forum/24-di...l#post57827354
Rick
descalabro and howiee like this.
rdlohr is offline
post #5973 of 6672 Old 03-30-2019, 06:07 AM
tonybradley's Avatar
Quoted: 532 Post(s)
Liked: 220
Looks great.
tonybradley is offline
post #5974 of 6672 Old 03-30-2019, 01:28 PM
WisconsinEric's Avatar
Quoted: 111 Post(s)
I have seen that with the triple black from Joannes. Try rotating it, you should see a difference.
Yep, that was it. I had no idea the velvet was directional in appearance. Thanks!
zombie10k likes this.
WisconsinEric is offline
post #5975 of 6672 Old 03-30-2019, 04:16 PM
coderguy's Avatar
Quoted: 2455 Post(s)
Liked: 1324
Here is the black 'flock velvet tape' I used from Ebay, this stuff can come in handy to cover things like projector screen cases, A/C vents, smoke detectors, or even ceiling fan blades (do at your own risk). I covered my WHITE electric projector screen, my ceiling fan blades, and a smoke detector. The ceiling fan still works, though I rarely use it. It helped a ton turning my ugly white case into a black velvet case, it's invisible now when watching content unless the lights are on in the room.
It's not quite as dark as the Triple Black Velvet from Fabric Outlet, but it's darker than the felt tape I originally tried.
Not sure though, some sellers might be selling the flock tape and calling it felt, some might be selling felt and calling it flock...
I've seen some of the tape be too grayish looking from one seller, but 2 out of 3 of sellers the tape was fine.
Here are a couple different sellers, you can also find it in 1" or 1/2" width sometimes.
https://www.ebay.com/itm/ProScreens-...sAAOSwm8VUtWP8
https://www.ebay.com/itm/4-5-x-25-Ro...MAAOSwLVZV50Pj
cemo62 likes this.
**Updated Projector Calculator Released NOV 2017**
-- www.webprojectorcalculator.com --
coderguy is offline
post #5976 of 6672 Old 03-30-2019, 04:50 PM
coderguy's Avatar
Liked: 1324
I made one masking panel by just tacking magnets directly to the triple velvet material, but definitely go with cardboard or foamboard for masking panels.
It works using direct fabric, but it gets too wrinkly. It looks the same in the dark though if someone wants a quick and dirty solution.
As noted earlier, I have a 106" electric 16:9 that drops down in front of my 125" CIH blackout cloth screen. Again, the blackout cloth screen looks virtually identical to the electric screen from my seating position in both color and texture, the electric might be 10% brighter (not sure hard to tell by eye). I originally thought blackout cloth didn't focus as tightly, but it appears to focus the same compared to the Draper.
coderguy is offline
post #5977 of 6672 Old 03-31-2019, 06:33 AM
Tweakophyte's Avatar
Quoted: 94 Post(s)
Liked: 49
Does anyone have a link to the correct Joann Fabrics velvet?
Thx
Panny UB820, Denon X6300H in 6.1.4 mode, Epson 5040UB, SVS PCUltra paired with a MiniDSP HD and BEQ (of course!)
Working on making things blacker...
Tweakophyte is offline
post #5978 of 6672 Old 03-31-2019, 07:51 AM
Quoted: 55 Post(s)
Thx
I didn't try the Joann, but here is the Bravo:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Once there, make sure you press the button to see all the vendors and get Fabric Bravo.
Rick
Name:	Fabric Bravo.JPG
ID:	2546842   Click image for larger version
Name:	Top Listing.JPG
Mikenificent1 and scottyroo like this.
rdlohr is offline
post #5979 of 6672 Old 03-31-2019, 07:52 AM
djb61230's Avatar
Quoted: 36 Post(s)
Liked: 64
Thx
The Royalty 3 Black Velvet is what I used:
https://www.joann.com/royalty-3-velv...elvet%20Fabric
djb61230 is offline
post #5980 of 6672 Old 03-31-2019, 08:58 AM
Spaded21's Avatar
Quoted: 84 Post(s)
Liked: 39
Thx
I used the Premier because it was the first one I found in the store and I didn't realize there was another kind. It's expensive so I only bought it when there were 40-60% off coupons. I am going to stop at Hobby Lobby (ugh) today (edit: not today since they're closed 🙄 ) with a piece of the Joann Premier to see how it compares since it's way cheaper. I will probably end up sticking with the Premier so my ceiling is uniform though. Wish I would have just bought a bolt of the Bravo stuff from Amazon.
https://www.joann.com/premier-velvet/9055674.html
https://www.hobbylobby.com/Fabric-Se...ric/p/80818350
7.2.4 BenQ/Marantz/HTD/Micca/SVS/Dayton
Spaded21 is offline
post #5981 of 6672 Old 03-31-2019, 11:58 AM
smitty's Avatar
Quoted: 763 Post(s)
Liked: 1015
I want to put some velvet on my the side walls of my theater room, and am probably thinking about having them extend out 4 to 5 feet from the screen and extending back into the room. From reading some of this thread and considering the various options, the one that seems easiest and most practical and economical for me is to get some 1/2" foam insulation from Home Depot, and then to cover the panels with adhesive velvet from ProtoStar or McMaster-Carr, and then to fasten the panels to my drywall somehow.
With respect to fastening, I am thinking of glueing magnets to the rear of the foam insulation boards and then attaching magnets to the wall with screws. (Somebody posted a link earlier to a product on amazon that was a magnet with countersunk holes). I guess the other option would be to nail or screw the insulation board to the walls with screws or end cap nails, but then I'd have to paint the screws or nails black. It seems to me that the magnets would at least make the velvet look neater, and the panels would be easier to remove if I wanted to temporarily change the look of the room (sometimes it can double as a bedroom).
Anybody have any suggestions, tips, potential problem areas, or better alternatives? I want to do something that looks good and is somewhat economical, but something that is also not too permanent.
Thanks for any suggestions. This thread is a wealth of information, but sometimes just reading all the suggestions and alternative installation techniques gets a bit overwhelming.
smitty is offline
post #5982 of 6672 Old 03-31-2019, 04:01 PM
coderguy's Avatar
Liked: 1324
You are going to spend way more getting the self adhesive stuff, buy the Fabric Bolt from Amazon instead and glue it or staple it to the boards, and attach magnets if you like.
If you make panels, they will look pretty much perfect. Even just using staples (no glue) I was able to make perfect looking panels out of foam board for masking, not sure tiles or wall panels would be any different unless you are working with real large pieces. So if you are using much larger pieces, you may need to use glue as well (not sure as I have never tried very large pieces with only stapling to a board).
Just buy the bolt, get 1 panel, and test it, see if you like it. Not that hard, otherwise trying to decide without testing you will just keep going in circles.
You're overthinking this, it's not as hard as it sounds.
coderguy is offline
post #5983 of 6672 Old 03-31-2019, 04:11 PM
smitty's Avatar
Quoted: 763 Post(s)
Liked: 1015
You are going to spend way more getting the self adhesive stuff, buy the Fabric Bolt from Amazon instead and glue it or staple it to the boards.
Thanks for the input coderguy. My wife had the same suggestion after I told her about the adhesive stuff, and since she made the suggestion, I can probably get her to help with the construction. She's good at that kind of stuff.
smitty is offline
post #5984 of 6672 Old 03-31-2019, 05:26 PM
coderguy's Avatar
Liked: 1324
Video of electric 16:9 Draper going up over the 2.35 blackout cloth (homemade screen).
Top screen is Draper, bottom is blackout cloth.
Taken with my phone, so not perfect looking.
So all you have to do is lower the screen, then put up the side panels.
coderguy is offline
post #5985 of 6672 Old 03-31-2019, 05:47 PM
smitty's Avatar
Quoted: 763 Post(s)
Liked: 1015
Video of electric 16:9 Draper coming down in front of 2.35 blackout cloth (homemade screen).
It says the video is being blocked on copyright grounds.
smitty is offline
post #5986 of 6672 Old 03-31-2019, 06:17 PM
coderguy's Avatar
Liked: 1324
Fixed now, wow the copyright police sure are active these days to block a 1 minute video
Patriot666 likes this.
coderguy is offline
post #5987 of 6672 Old 03-31-2019, 07:03 PM
smitty's Avatar
Quoted: 763 Post(s)
Liked: 1015
/\ That's awesome!
smitty is offline
post #5988 of 6672 Old 04-01-2019, 02:42 PM
Patriot666's Avatar
Quoted: 134 Post(s)
Liked: 89
Guys I took down my theater and now I have a lot of Joanne Royalty 3 black velvet I have no use for. I have at least 20, maybe 30 yards. Mostly in about 11 ft sections but other various sized pieces too. I'll hook someone up for a good price on the lot. PM me if interested. I'm in Crown Point, IN.
Patriot666 is offline
post #5989 of 6672 Old 04-03-2019, 10:21 AM
Spaded21's Avatar
Quoted: 84 Post(s)
Liked: 39
The light bulbs were really bothering me, sticking out against all the velvet. So I came up with an idea and it actually worked really well: Plasti Dip.
The 3rd pic is the light on at 100%, 4th one is 10%
ID:	2548488   Click image for larger version
ID:	2548490   Click image for larger version
ID:	2548492   Click image for larger version
ID:	2548494   Click image for larger version
jh901 and Patriot666 like this.
Spaded21 is offline
post #5990 of 6672 Old 04-03-2019, 12:29 PM
scottyroo's Avatar
Quoted: 616 Post(s)
Liked: 819
So the light is actually able to cut through the plasti dip without a noticeable drop in brightness?
"The Bunker" | Dedicated Theater Build Under Suspended Slab Garage
Testing: BenQ HT5550 | Epson 5050UB | 160" Dragonfly™ Fixed AT Screen
Denon X6300H | 9.4.4 (7.2.4 Discrete) | 9x Episode 900 Series LCR/Surrounds | 4x Episode 1700 Series ATMOS Heights | 4x Episode 12" Evo Subs
Sony X700 | Xbox One X | NVIDIA Shield TV
scottyroo is offline
post #5991 of 6672 Old 04-03-2019, 01:14 PM
Spaded21's Avatar
Quoted: 84 Post(s)
Liked: 39
Not noticeable to me. Maybe if you measured with a light meter it would show a drop but I don't use these very often anyway. I got the idea when I saw people were using it on their tail lights. And since it's Plasti Dip, you can just peel it off if you don't like it.
Spaded21 is offline
post #5992 of 6672 Old 04-03-2019, 02:27 PM
Quoted: 646 Post(s)
Liked: 352
That's crazy.. the plastic doesnt melt?
Sent from my SM-G930T using Tapatalk
jorgebetancourt is online now
post #5993 of 6672 Old 04-03-2019, 02:33 PM
Craig Peer's Avatar
Quoted: 6996 Post(s)
Liked: 8292
Or catch on fire. Maybe a light dimmer instead ?
Killroy likes this.
[email protected] JVC RS4500, Lumagen Radiance Pro, Panamorph Paladin DCR lens, Stewart Luxus Model A ElectriScreens - 128" diagonal 2.35:1 ST130 & 122" diagonal 16:9 Cima Neve, Denon X8500, Parasound A 52+ amp, Martin Logan Motion series 9.4 speakers, four SVS subs, Panasonic UB820, Oppo 203, PFP M1500 UPS
Craig Peer is online now
post #5994 of 6672 Old 04-03-2019, 02:34 PM
dbpaddler's Avatar
Quoted: 141 Post(s)
Liked: 84
Plasti Dip can resist temperatures up to 200°F, and has been known to handle the heat and abuse produced at racing or rally car events.
Sent from my SM-N960U1 using Tapatalk
dbpaddler is offline
post #5995 of 6672 Old 04-03-2019, 02:40 PM
Spaded21's Avatar
Quoted: 84 Post(s)
Liked: 39
And they are LED bulbs
This is the blackout thread. The Plasti Dip is for hiding the bulbs when they are off. But I can dim them as I mentioned in my post. One picture is at 10% brightness and one is at 100%.
Spaded21 is offline
post #5996 of 6672 Old 04-03-2019, 02:49 PM
Craig Peer's Avatar
Liked: 8292
My ceilings are taller I guess - I don't notice my recessed can light bulbs at all during a movie.
post #5997 of 6672 Old 04-03-2019, 02:50 PM
dlinsley's Avatar
Quoted: 556 Post(s)
Liked: 441
Finally making some real progress!
Only 21 panels to go! I added the top row at the back this morning before work, but the second off top row on the back wall was what really made the room darker with content - my front wall is already JR3 and GoM black.
Craig Peer and Spaded21 like this.
Last edited by dlinsley; 04-04-2019 at 07:13 AM. Reason: Photo stopped showing - the URL changed somehow!
dlinsley is online now
post #5998 of 6672 Old 04-03-2019, 03:18 PM
BrandonH's Avatar
Quoted: 97 Post(s)
Liked: 112
Thanks for all of the great responses. I think I am going to need to do more ceiling treatment than I previously thought. The screen reflection comes pretty far back from normal viewing distance.
I started with my LED light trims last night and painted a flat black. They turned out alright.
I painted my lights using the exact same method just before getting the HT3550. That and my Atmos ceiling speakers and the vents. It all turned out better than I expected.
Sent from my SM-G965U using Tapatalk
BrandonH is offline
post #5999 of 6672 Old 04-03-2019, 03:31 PM
Quoted: 646 Post(s)
Liked: 352
How hot can the bulbs get?
post #6000 of 6672 Old 04-03-2019, 03:34 PM
Quoted: 646 Post(s)
Liked: 352
How hot do u think the led lights can get? I have no clue..
Epson 5020ub Powerlite Home Cinema 3d Front Projector , Mitsubishi , Panasonic Blu Ray Disc Player Dmp Bd30k
