The Blacker the Theater, The Better the Image - Page 204 - AVS Forum | Home Theater Discussions And Reviews
 2671Likes
post #6091 of 6122 Old 05-07-2019, 07:22 AM
coxy2416's Avatar
Quoted: 557 Post(s)
Liked: 325
Originally Posted by ARROW-AV View Post
Which method did you use to attach the material?
Fabric walling [IMG class=inlineimg]/forum/images/smilies/smile.gif[/IMG]
<img src="https://www.avsforum.com/forum/images/AVSForum/smilies/tango_face_wink.png" border="0" alt="" title="Wink" class="inlineimg" />
Could you supply a link to the fabric walking that you used?
coxy2416 is offline
post #6092 of 6122 Old 05-07-2019, 07:28 AM
Mike Garrett's Avatar
Quoted: 11446 Post(s)
Liked: 9045
A lot of people use fabricmate.com
https://fabricmate.com/
coxy2416, cardoski and cemo62 like this.
Mike Garrett is online now
post #6093 of 6122 Old 05-07-2019, 09:38 AM
Maestrosc's Avatar
Quoted: 286 Post(s)
Liked: 170
ooo... i want to do this to my room instead of painting. Then I dont have to wait/pay for texturing my fresh drywall either.
How reasonably priced is this? How difficult or easy is the installation? Would love to hear from people who have worked with this stuff before.
Maestrosc is offline
post #6094 of 6122 Old 05-07-2019, 09:42 AM
Liked: 9045
Easy to install, but fabric walls are not considered cheap to do.
ARROW-AV likes this.
post #6095 of 6122 Old 05-07-2019, 10:46 AM
We're Nuts About AV
ARROW-AV's Avatar
Quoted: 3783 Post(s)
Liked: 6195
I don't have time to personally do the fabric walling for the home theaters that I design and build, so I subcontract a third party to do it who specialize in fabric walling. I have used two companies, one uses their own fixing batons, the other uses a system similar to Fabricmate
Easy to install, but time-consuming if you want to do all the walls and ceiling. There are companies that specialize in fabric-walling so if you are short on time perhaps obtain a few quotes.
Obviously how much is a kinda 'how long is a piece of string' type question in that it will depend upon how large is your room and whether you want to do all the walls and ceiling or only partial coverage.
In the UK to do an entire room, including all walls, ceiling, doors, skirtings, architraves etc. with dimensions 5.6m x 5.4m x 2.7m / 18' 4" x 17' 9" x 8' 10" costs around 15,000 bucks.
It's awesome, but not cheap. Of course, this is paying someone else to do it, so if you do it yourself you would save the labour costs
ARROW-AV is offline
post #6096 of 6122 Old 05-07-2019, 12:10 PM
Liked: 9045
Then there is the much cheaper highly labor intensive method that many on AVSF have used. Build a bunch of frames and wrap with fabric. Seems like it takes forever and a day, using this method.
post #6097 of 6122 Old 05-07-2019, 12:10 PM
coderguy's Avatar
Quoted: 2148 Post(s)
Liked: 1184
I don't blame you for contracting it out, I got a repetitive stress injury from doing it myself.
I only finished half my room because I'm waiting to go back and finish until I'm fully recovered.
I used black sheets temporarily for the other half, so it's still a bat cave though.
I was not used to those steps up and down - up and down 1000 times on the step ladder.
I didn't feel like I was overdoing it or anything, just one day --- suddenly I couldn't walk anymore
Oh the joys of getting older.
Dave Vaughn likes this.
**Updated Projector Calculator Released NOV 2017**
-- www.webprojectorcalculator.com --
coderguy is online now
post #6098 of 6122 Old 05-07-2019, 01:25 PM
Quoted: 42 Post(s)
I used the fabricmate 1/2" channels on my ceiling with GOM FR701. I can tell you that the process is not as easy as it sounds or looks. If and when i ever have to do this again i'm just going to make poplar frames, wrap them in fabric, then nail to walls/ceiling.. cheaper and easier IMHO.
coderguy, llang269 and ARROW-AV like this.
Marantz 7705 + McIntosh MC205 + McIntosh MC8207
7.2.4: (3)B&W CWM 8.3 D, (8) B&W CCM 8.5 D, (2) Hsu VTF-15H MK2
137" Seymour AV UF screen, Sony HW40es
cnebrask is offline
post #6099 of 6122 Old 05-07-2019, 02:32 PM
Liked: 9045
Ceilings are much tougher than walls. With walls, gravity works with you. On ceilings, against you.
Dave Vaughn, cemo62 and cnebrask like this.
post #6100 of 6122 Old 05-07-2019, 03:01 PM
JohnnyWilkinson's Avatar
Quoted: 305 Post(s)
Liked: 196
Illuminated LCR and subs as promised:
ID:	2563858   Click image for larger version
My build thread
JohnnyWilkinson is offline
post #6101 of 6122 Old 05-07-2019, 03:09 PM
Maestrosc's Avatar
Quoted: 286 Post(s)
Liked: 170
absolutely beautiful. Elegant and minimal but still extravagant looking.
ARROW-AV and JohnnyWilkinson like this.
post #6102 of 6122 Old 05-07-2019, 04:09 PM
We're Nuts About AV
ARROW-AV's Avatar
Liked: 6195
Mine's bigger than yours...
Incidentally, this entire home theater / cinema is going to be fabric walled in black velvet:
ARROW-AV is offline
post #6103 of 6122 Old 05-07-2019, 04:11 PM
We're Nuts About AV
ARROW-AV's Avatar
Liked: 6195
ARROW-AV is offline
post #6104 of 6122 Old 05-07-2019, 04:31 PM
Tedd's Avatar
Quoted: 1944 Post(s)
Liked: 786
The cheapest way is to build big panels and covered with speaker grill fabric, purchased by the bolt.
I'm with cnebrask, build frames, but then bolt them to Unistrut run horizontally. And not take the frames right to the floor, so I run LED lighting under the edge, and introduce some lighting flair. Nothing more elaborate then speaker grill fabric, rather inexpensive when bought by the bolt.
Tedd is offline
post #6105 of 6122 Old 05-07-2019, 05:21 PM
dlinsley's Avatar
Quoted: 476 Post(s)
Liked: 366
Ain't that the truth. 42 down and 16 to go! Plus baseboards - still don't know if I'll wrap with velvet or paint. This aspect of my build has been ongoing since September, but since I needed 2" deep panels (for the most part) I'd have needed to cut wood anyway or use $3000 of 2" track. As it is I saved about $2300, but the opportunity cost has likely been high.
Mike Garrett likes this.
dlinsley is offline
post #6106 of 6122 Old 05-08-2019, 03:37 AM
Quoted: 305 Post(s)
Liked: 196
Spoiler!
I will be disappointed if I'm not outside-guest #1 It's looking fantastic.. ;-)
Edit: I'm eager to find out whether your selected material beats the Fidelio as I'll use the same for the ceiling / screen wall / side panels of my room.
My build thread
post #6107 of 6122 Old 05-08-2019, 04:28 AM
Quoted: 542 Post(s)
Liked: 294
Holly cow!!!!
Sent from my SM-G930T using Tapatalk
jorgebetancourt is online now
post #6108 of 6122 Old 05-08-2019, 04:49 AM
DavidK442's Avatar
Quoted: 859 Post(s)
Liked: 720
"They really built this? This isn't a mock-up or anything?"
Name:	They really built this.gif
DavidK442 is offline
post #6109 of 6122 Old 05-08-2019, 05:44 AM
We're Nuts About AV
ARROW-AV's Avatar
Liked: 6195
Haha, well it's not completely finished just yet, but yes I am indeed really building this
If folks are interested when I find time I will start a new thread regarding the build. I'm also building an 'ultimate' TV & Gaming room as well. I plan on hosting some open day AV parties over the course of a number of weekends for forum members when it's all finished
BOTH rooms are going to be fully finished in black velvet, so that's all the walls, the ceiling, the ceiling bulkheads, the star ceilings, the skirtings, the architraves, the doors etc. and all door handles, door hinges, climate control grilles, sockets and switches etc. will of course be black, as will be the carpet, rugs, and seating, with the idea being to create the blackest possible environment once the lights go off and the entertainment starts
Room aesthetics will be provided via some seriously cool lighting schemes, plus the projection screen turns into an gigantic piece of artwork when the system is off that is illuminated via specialist rectangular framing projection lighting...
But I don't want to derail this thread so like I said I will start a new thread providing all the details as and when
ARROW-AV is offline
post #6110 of 6122 Old 05-08-2019, 08:31 AM
coderguy's Avatar
Liked: 1184
That is quite impressive looking, as far as all the shapes of the wood and everything.
Are you a home builder or an HT guy, make up your mind...
I wouldn't mind your job, but I have very little experience in construction.
So what I need in order to gain some experience, is for someone to volunteer their HT to me for some construction testing.
I'll bring a saw and see what I can do, I'll start with the projector first...
post #6111 of 6122 Old 05-08-2019, 08:54 AM
We're Nuts About AV
ARROW-AV's Avatar
Liked: 6195
If you want to see just how much construction has been involved with this particular project wait until you see the details when I post them in the respective build thread as and when...
...Because the entire complex is situated underground
ARROW-AV is offline
post #6112 of 6122 Old 05-08-2019, 08:55 AM
coderguy's Avatar
Liked: 1184
Hah, you are hilarious...
That might just be the best post ever in this forum...
*no sarcasm intended*
post #6113 of 6122 Old 05-10-2019, 09:44 AM
drjay71's Avatar
Quoted: 87 Post(s)
Liked: 40
Hi everyone. I have read through most of this thread and want to know if there is a next best alternative to room treatment. I don't want to change the aesthetic of my room but want a "floating picture" effect and reduce or eliminate screen reflections as much as possible. What about getting an ALR screen? I am sure it is not as good as room treatments but would at least be a 50% improvement compared to my matte white screen.
ID:	2564948   Click image for larger version
drjay71 is offline
post #6114 of 6122 Old 05-11-2019, 07:56 AM
descalabro's Avatar
Quoted: 387 Post(s)
Liked: 129
Hi,
About the ALR screen, I think you may get more optimistic replies if you ask the same question at the Screens section of the forum. If your room looks anything like those photos you've posted, then a system of black velvet curtains covering both walls and ceiling would not greatly change its aesthetics.
descalabro is online now
post #6115 of 6122 Old 05-11-2019, 10:27 PM
ScottAvery's Avatar
Quoted: 577 Post(s)
Liked: 169
Does that screen change aspect ratios by expanding vertically? What am I seeing there?
ScottAvery is offline
post #6116 of 6122 Old 05-12-2019, 07:05 AM
dan webster's Avatar
Quoted: 245 Post(s)
Liked: 224
I am also wondering. Is that 2 different screens? One thing you could do is replace the white speaker covers and vents in the ceiling to black.
Dolby Atmos 7.2.4 YamahaCX-A5200 Gemstone 200x7 Emotiva upa-500 amps
Oppo 103 Sony UBP-X800 4K Ultra HD Blu-ray Jvc RS520 projector
silver ticket 125 2.35 screen Golden Ear Triton 5 L&R
super center XXL triton 7's sides Martin logan motion 12 rears
4 RSL C34 in ceiling SVS PB2-plus sub Outlaw LFM-1-plus sub
dan webster is offline
post #6117 of 6122 Old Yesterday, 08:05 AM
SJHT's Avatar
Quoted: 1002 Post(s)
Liked: 664
And one of the speakers disappears... SJ
SJHT is offline
post #6118 of 6122 Old Yesterday, 08:52 AM
descalabro's Avatar
Quoted: 387 Post(s)
Liked: 129
Which makes me wonder if that’s not mostly a digital mock-up of some sort.
post #6119 of 6122 Old Yesterday, 01:29 PM
SJHT's Avatar
Liked: 664
Maybe one of those "spot the differences" puzzles...
SJHT is offline
post #6120 of 6122 Old Today, 06:28 PM
Gabre's Avatar
Quoted: 436 Post(s)
Liked: 71
Alr screen is junk, at least my experience with CARLs ALR
Dims the image way too much, hot spotting, sparkling, color shift, u name it
But it does work better with some ligjt in room.
Gabre is online now
Epson 5020ub Powerlite Home Cinema 3d Front Projector , Mitsubishi , Panasonic Blu Ray Disc Player Dmp Bd30k
