The Blacker the Theater, The Better the Image - Page 208 - AVS Forum | Home Theater Discussions And Reviews
 2953Likes
post #6211 of 6653 Old 06-16-2019, 02:48 PM
coderguy's Avatar
Quoted: 2455 Post(s)
Liked: 1324
The posters are not inside the HT, I have a room outside the HT with different movie items.
i'm glad you like them, I think it turned out great.
I do like them, must be nice having a pre-theater room and a theater room.
I think you are the first person I've known to have a pre-theater room, haha.
**Updated Projector Calculator Released NOV 2017**
-- www.webprojectorcalculator.com --
coderguy is offline
post #6212 of 6653 Old 06-16-2019, 03:19 PM
Killroy's Avatar
Quoted: 539 Post(s)
Liked: 434
This weekend I found a great use for my extra protostar material. I've been building poster lightboxes for the area just outside the theater.
Spoiler!
I tried painting the outer frame wood with the Rosco but the protostar looks much better and sticks to the wood with no problem.
Spoiler!
Does the protostar stick well to MDF? I was thinking about doing this on my TV mounted poster wall and instead of using a fancy casing I could use MDF if the protostar sticks well.
Killroy is online now
post #6213 of 6653 Old 06-16-2019, 03:37 PM
We're Nuts About AV
ARROW-AV's Avatar
Quoted: 4111 Post(s)
Liked: 6641
Meet the second person:
Craig Peer and nofire like this.
ARROW-AV is offline
post #6214 of 6653 Old 06-16-2019, 03:39 PM
We're Nuts About AV
ARROW-AV's Avatar
Liked: 6641
Spoiler!
Spoiler!
The results are awesome
Spoiler!
Looks great!
I've gone for a slightly different approach... The movie posters fit tightly into black frames without any gap and are illuminated by lighting that only lights up the posters
ARROW-AV is offline
post #6215 of 6653 Old 06-16-2019, 04:29 PM
Javs's Avatar
Quoted: 6926 Post(s)
Liked: 6635
Arent you moving to the US though? Why are you building this in the UK if so? Or is this room in the US?
JVC X9500 (RS620) | 120" 16:9 | Marantz AV7702 MkII | Emotiva XPA-7 | DIY Modular Towers | DIY TPL-150 Surrounds | DIY Atmos | DIY 18" Subs
MadVR Settings | UHD Waveform Analysis | Arve Tool Instructions + V3 Javs Curves
Javs is online now
post #6216 of 6653 Old 06-16-2019, 05:07 PM
We're Nuts About AV
ARROW-AV's Avatar
Liked: 6641
I started building this home theater at my home in the UK before I made the decision to move to the United States. Now I am finishing it as part of readying my house for sale
It is very nearly completed by the way
I will be building a new home theater in my house in the US after I purchase one
smitty likes this.
ARROW-AV is offline
post #6217 of 6653 Old 06-19-2019, 02:11 AM
markmon1's Avatar
Quoted: 5232 Post(s)
Liked: 3400
I assume Fidelio is made by Sony and Whaleys is made by JVC
Video: JVC RS4500 135" screen in pure black room no light, htpc nvidia 1080ti.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, 2 sub arrays both infinite baffle: 4x15 fi audio running on behringer ep4000 + 4x12 fi audio running on 2nd ep4000.
markmon1 is offline
post #6218 of 6653 Old 06-19-2019, 03:30 AM
Luminated67's Avatar
Quoted: 683 Post(s)
Liked: 382
On this forum you are definitely right.
Dave Vaughn likes this.
Epson EH-TW9400 - QualGear Fixed Frame 100” - Sony x700 BRP & Panasonic 420 BRP - Sony 1080 AVR - IPL Acoustics M1TLs & IPL Acoustics AVC Pro Centre, Four KEF surrounds & 2 Sub boxes (10” Sub + 10” Passive Radiator)
Luminated67 is offline
post #6219 of 6653 Old 06-19-2019, 04:03 AM
We're Nuts About AV
ARROW-AV's Avatar
Liked: 6641
ARROW-AV is offline
post #6220 of 6653 Old 06-25-2019, 01:31 PM
We're Nuts About AV
ARROW-AV's Avatar
Liked: 6641
This is with respect to replicating the light source direction and viewing position that you would experience in a home theater. In other words, all the velvet fabrics, which are all directional, are positioned with light sources eminating from in front, washing across the fabric, with you perceiving from the rear; which is essentially what will be happening with projected image, walls/ceiling, and viewing position:
In this regard the WHALEY'S very slightly outperforms the TRIPLE BLACK VELVET, the both of which outperform the FIDELIO
And here's the comparative performances when viewed head on perpendicular, with an additional light source positioned in front:
In this instance, the WHALEY'S very, very slightly outperforms the FIDELIO, the both of which outperform the TRIPLE BLACK VELVET.
ALL of these materials have a sheen, but it is directional, so is typically on visible when viewed from the 'wrong direction'. It is therefore very important to position the fabric in the 'right direction'. The Fidelio is the least prone with respect to a sheen.
Whilst the Triple Black Velvet performs almost as good as the Whaley's when used for side walls and ceilings, it does not perform as good as either the Whaley's or the Fidelio when viewed head on perpendicular, wherein you can see its sheen a bit as well, so personally I would not choose to use it for the front wall, screen frame, or screen masking; where I would use either the Whaley's for Fidelio for this instead. And in fact, due to fact it is least prone with respect to a sheen, and performs almost the same as the Whaley's when viewed perpendicularly head on, I consider the Fidelio the best material of choice for screen frames and non-acoustically transparent screen masking. The Whaley's has good acoustical transparency and is the only of the three fabrics to do so.
The Triple Black Velvet is excellent for side walls and ceilings and I really think that in the darkened environment of a home theater you won't be able to perceive any difference as compared with the Whaley's; but if used for the front wall, screen frame, or screen masking you will
Consequently, I rank the performance of these materials with respect to home theater usage as per follows:
SIDE WALLS AND CEILINGS:
1st = WHALEY'S
2nd = TRIPLE BLACK VELVET
3rd = FIDELIO
FRONT WALL:
1st = WHALEY'S
2nd = FIDELIO
3rd = TRIPLE BLACK VELVET
SCREEN FRAME AND NON-ACOUSTICALLY TRANSPARENT MASKING:
1st = FIDELIO
2nd = WHALEY'S
noob00224 likes this.
ARROW-AV is offline
post #6221 of 6653 Old 06-25-2019, 03:19 PM
coderguy's Avatar
Liked: 1324
Are you guys sure Fidelio != Flocked Velvet?
Is the Fidelio kind of stiffer than the Triple Black Velvet?
I'm happy with the TBV, close enough for my budget
coderguy is offline
post #6222 of 6653 Old 06-25-2019, 03:44 PM
We're Nuts About AV
ARROW-AV's Avatar
Liked: 6641
The Fidelio is a thicker heavier fabric material than the Whaley's and Triple Black Velvet.
Also, with respect to the performance that matters and is most applicable to home theater environment the Whaley's and the TBV are very close
ARROW-AV is offline
post #6223 of 6653 Old 06-26-2019, 07:41 AM
ScottAvery's Avatar
Quoted: 697 Post(s)
Liked: 204
Thanks for the review. Combining this with the comments above that indicate Whaley's is acoustically transparent (or close enough) I think I will have some strategic uses of it around speakers. It costs 5 times as much to import, so I will probably still have a bit of triple velvet, of which I have 15 yards left allocated for ceiling.
edit: any comments on sheen for the Whaley's? with black triple velvet as a screen mask I can see reflections of very bright highlights near the edge of screen.
ScottAvery is offline
post #6224 of 6653 Old 06-26-2019, 08:00 AM
We're Nuts About AV
ARROW-AV's Avatar
Liked: 6641
Yes, the Whaley's is without a doubt the most acoustically transparent.
I just updated my review, which now covers this information
ARROW-AV is offline
post #6225 of 6653 Old 06-28-2019, 06:02 AM
evanft's Avatar
Quoted: 76 Post(s)
Liked: 35
I ended up just buying some black velvet from ebay that came to about $4.50/yd to cover my ceiling tiles. I'm sure there's blacker fabric, but frankly I think there's a serious point of diminishing returns that you can get to very quickly.
evanft is offline
post #6226 of 6653 Old 06-28-2019, 11:03 AM
ScottAvery's Avatar
Quoted: 697 Post(s)
Liked: 204
It's like, how much more black could this be? and the answer is none. None more black.
post #6227 of 6653 Old 06-28-2019, 01:00 PM
coderguy's Avatar
Liked: 1324
This is just IMO and experience...
The most important is the sidewalls and ceiling+floor if the walls are close, otherwise it's the immediate framing of the screen that matters most, but the actual area on the front wall farther from the screen, it really doesn't reflect that much light. I have some brown leather on the front wall, whereas had pure TBV before, cannot even tell the difference to be honest. I'm just experimenting with aesthetic improvements to the room.
coderguy is offline
post #6228 of 6653 Old 06-28-2019, 03:07 PM
ScottieBoysName's Avatar
Quoted: 1276 Post(s)
Liked: 430
What’s everyone’s take on covering up white carpet?
ScottieBoysName is online now
post #6229 of 6653 Old 06-28-2019, 03:46 PM
Buddylee123's Avatar
Quoted: 904 Post(s)
Liked: 622
Buy black rugs or go to a carpet store and by some carpet and have it made into a rug if you want a really big one. Going from dark brown to black made a good difference in my room
Buddylee123 is offline
post #6230 of 6653 Old 06-29-2019, 05:57 AM
Liked: 430
I’ve been messing around with black exercise mats with limited success. They still have a sheen to them. It’s better than white carpet though.
post #6231 of 6653 Old 06-29-2019, 11:36 AM
coderguy's Avatar
Liked: 1324
Safavieh rugs on Overstock or Amazon have been mentioned many times, as they are good quality for the price, just not sure how dark their black rugs are, but I assume not too bad. I have some of their rugs for other rooms in the house, and they still look pretty much new almost 5 years later. I don't know if the quality changed over the years though, but the ones I have are much much higher quality than similar ones you would find at Target or Walmart.
coderguy is offline
post #6232 of 6653 Old 07-05-2019, 09:00 AM
SuperMiguel's Avatar
Quoted: 173 Post(s)
Good morning all, I'm in the process of convincing my wife on darkening our home theater room 16x12 room upstairs with 3 windows. Walls are light color and ceiling is white. (See attached Pic)
So i guess Paint or get some fabric? My wife is very picky and im worry that she wont like the fabric joints.. i guess i can use some wood with fabric around it to cover the fabric joints to make it look good... but then again not sure it it will look as nice as regular paint. I think ill have higher approval chances going with paint
If i do go for paint, can you recommend a color and brand that i can get at homedepot/lowes?
SuperMiguel is offline
post #6233 of 6653 Old 07-05-2019, 10:01 AM
skylarlove1999's Avatar
Quoted: 920 Post(s)
Liked: 646
Sherwin Williams Tricorn Black 6258 at lowes . Rosco Black Velour is available online. Paint is still reflective. Plus not sure how happy wife will be with black. You can make black velvet curtains for side walls. Ceiling you could make black velvet panels that secure to the ceiling but can be easily taken down.
Sent from my SM-G965U using Tapatalk
skylarlove1999 is online now
post #6234 of 6653 Old 07-05-2019, 10:20 AM
Quoted: 173 Post(s)
Reading that this thread, as me worried about the amount of work to make velvet look good and make wife happy, How bad of an idea would be to paint the room, and the just add Tripple Velvet curtains for side walls walls and some panels for ceiling instead of the entire room... that way everything will be kinda dark and match? I feel like doing the entire room on Velvet is alot of work, and i wouldnt like to the the front with velvet and leave half of the room white
Just to be sure The SW 6258 is Flat sheen right? and that can be on the Emerald Interior paint right i have a SW store by my house, but they have few brands to pick from
https://www.sherwin-williams.com/arc...orType=PALETTE
post #6235 of 6653 Old 07-05-2019, 10:31 AM
Quoted: 920 Post(s)
Liked: 646
I can't imagine a wife being happy about a room being painted black. But you need to figure out what is best for you and your room and your wife. I would say let your wife choose the room color and then you address the room reflections with velvet where has been suggested.
post #6236 of 6653 Old 07-05-2019, 10:35 AM
Quoted: 217 Post(s)
Liked: 94
The idea of doing something that makes the husband happy already makes the wife unhappy. They're not content unless their men are treated like dogs and servants.
markmon1 likes this.
wookiegr is offline
post #6237 of 6653 Old 07-05-2019, 10:42 AM
Quoted: 904 Post(s)
Liked: 622
Married man here, you have been spending time with the wrong women
post #6238 of 6653 Old 07-05-2019, 10:53 AM
Quoted: 173 Post(s)
But as far as paint goes "black' is best right??
Sent from my SM-N960U using Tapatalk
post #6239 of 6653 Old 07-05-2019, 10:54 AM
Quoted: 217 Post(s)
Liked: 94
Not me. Almost every thread online about wanting a new home theater or even a basic 2 channel stereo, men are being victimized by ruthless women that refuse to allow such things albeit speakers are too big, not the right color, in the wrong location... don't claim you don't see men complaining about all the restriction on them when they want to embrace this hobby. You would be a liar if you do.
wookiegr is offline
post #6240 of 6653 Old 07-05-2019, 11:05 AM
Quoted: 920 Post(s)
Liked: 646
Honestly any dark matte or flat paint it's going to give the same reflection as black. So if you are definitely going the paint route which I understand due to aesthetic concerns I wouldn't be so obsessed that it has to be black.
Epson 5020ub Powerlite Home Cinema 3d Front Projector , Mitsubishi , Panasonic Blu Ray Disc Player Dmp Bd30k
