The Blacker the Theater, The Better the Image - Page 214 - AVS Forum | Home Theater Discussions And Reviews
 2868Likes
post #6391 of 6532 Old 08-22-2019, 11:42 AM
Quoted: 207 Post(s)
Liked: 79
Originally Posted by ARROW-AV View Post
There's a big problem with Vantablack... You can't / mustn't touch it
People shouldn't smoke.. but they do anyways.
wookiegr is online now
post #6392 of 6532 Old 08-22-2019, 12:07 PM
We're Nuts About AV
ARROW-AV's Avatar
Quoted: 4002 Post(s)
Liked: 6510
ARROW-AV is offline
post #6393 of 6532 Old 08-22-2019, 12:13 PM
Quoted: 207 Post(s)
Liked: 79
Except you aren't 100% guaranteed to drop dead immediately after smoking your first cigarette...
It would be exciting to have to sign a disclaimer and wear a radiation suit to enter ones home theater. It would likely be the very last "Home Theater of the Month" awarded from AVS Staff.
post #6394 of 6532 Old 08-22-2019, 12:32 PM
We're Nuts About AV
ARROW-AV's Avatar
Liked: 6510
Sorry, to clarify I am not saying that Vantablack is toxic... One touch and it is ruined. So whilst all well and good for coating the insides of telescopes and the like, unfortunately it is not suitable for use with respect to exposed surfaces.
I know this because I actually contacted the manufacturer to inquire as to whether I could use it in home theater builds
ARROW-AV is offline
post #6395 of 6532 Old 08-22-2019, 12:50 PM
Kelvin1965S's Avatar
Quoted: 350 Post(s)
Liked: 254
I (still) haven't fully finished my room treatment, but I had some visitors recently and they wanted to watch a film on my projector. I've got 3 metre deep Devore side curtains, a Devore cover for the area immediately below my screen (which is light oak). Also a lift up 'door' above the screen with Devore lining on the underneath. This door is only 30cm deep, but still helps with the initial off ceiling reflection: Further plan is a width of Devore that will clip to the door and cover approx 1.5 metre out across the ceiling, creating a Devore 'tunnel'.
Even as it stands my guests were impressed with the image quality and commented about how the curtains helped them focus on just the screen and blotting out the rest of the room. Seeing as non of them are AV fanatics, it was good to hear their views on the impact of the Devore.
I've seen some comments elsewhere that Devore is reflective and not as good as some more recent options available on eBay or similar, but I have no issues and can't 'see' the material even on very bright scenes. Interesting to see Arrow's testing and comments too.
Thumbnail sized picture attached to this post as I can't do a full size one: The first one is a view in daylight with it set up for projection viewing. The other one is my normal TV viewing mode, with the Devore pushed back to the sides, the top door closed and the below screen cover removed. The TV goes up and down on an electric lift.
Name:	Projector mode less top sheet.jpg
ID:	2605998   Click image for larger version
Name:	Finish door closed.jpg
notfastenough and howiee like this.
"Don't believe everything you read on the internet". William Shakespeare 1615
Kelvin1965S is offline
post #6396 of 6532 Old 08-22-2019, 12:57 PM
ScottAvery's Avatar
Quoted: 672 Post(s)
Liked: 192
Originally Posted by Kelvin1965S View Post
Also a lift up 'door' above the screen with Devore lining on the underneath. This door is only 30cm deep, but still helps with the initial off ceiling reflection.
That is really clever! Theatrical curtains to cover the projection screen when using the TV would improve performance of the TV and protect the screen from prying hands.
Kelvin1965S likes this.
ScottAvery is offline
post #6397 of 6532 Old 08-22-2019, 01:05 PM
Quoted: 350 Post(s)
Liked: 254
I find the neutral background for the TV (with the downlights set to suitable level) works really well. Curtains* would cover the LCR speakers too (it's Seymour XD AT material), which are slightly above where the TV is. I had ideas to try to disguise the screen more, but we've got used to seeing it that it's kind of 'hiding in plain sight'.
*The price of the other curtains in the room would have made a drop down AT screen seem cheap...I let my wife deal with that though, I just did the work on the room.
post #6398 of 6532 Old 08-22-2019, 01:21 PM
sage11x's Avatar
Quoted: 2725 Post(s)
Liked: 2706
Yes, I'm realizing that the sarcasm/humor didn't come through in my post. I figured when the narrator of the video mentioned that it was extremely dangerous to inhale the stuff and with all the scientists holding it with robber gloves and masks and applying it in clean boxes that that point would come across but... apparently not. The internet has ruined subtlety.
ARROW-AV likes this.
What to do if you find yourself stuck with no hope of rescue:
Consider yourself lucky that life has been good to you so far. Alternatively, if life hasn't been good to you so far, which given your present circumstances seems to be more likely, consider yourself lucky that it won't be troubling you much longer...
-- Excerpt from the Hitchhiker's Guide to the Galaxy.
sage11x is offline
post #6399 of 6532 Old 08-22-2019, 03:40 PM
We're Nuts About AV
ARROW-AV's Avatar
Liked: 6510
OK so I have completed my evaluation of the ROSCO TOUGH PRIME vs ROSCO SUPERSAT vs VIDEO TV PAINT and here are the results
This is with respect to the home theater environment, wherein the light source is the video display / projected image, the viewing position is the seating positions, and the painted surfaces are the ceiling and/or side walls
LEFT SIDE WALL - VIEWED FROM CENTRE OF SEATING ROW:
LEFT SIDE WALL - VIEWED FROM LEFT SIDE OF SEATING ROW:
LEFT SIDE WALL - VIEWED FROM RIGHT SIDE OF SEATING ROW:
In short, the ROSCO VIDEO TV PAINT behaves similar to the TOUGH PRIME however with respect to the lighting and viewing positions associated with home theater environments slightly outperforms it
wwtech and Gilmour like this.
ARROW-AV is offline
post #6400 of 6532 Old 08-22-2019, 04:19 PM
farsider3000's Avatar
Quoted: 1482 Post(s)
Liked: 870
Thank you! I was waiting for your test before I ordered my paint.
Sent from my iPhone using Tapatalk Pro
7.4.6 system: Processors:Marantz 8805 || Xilica XP4080 Amps: Parasound A31 and ATI AT528NC & AT526NC n-core ||Speakers: Procella P8 LCR, Procella P5 for surround & ceiling
Subs: JTR Captivator subs: One S2, Two RS2, One S1, 2 Seaton Submersive (FOR SALE)
Screen: 2.40:1 Seymour XD Acoustically Transparent, 128" diagonal / 118" wide || Projector: JVC X570/RS420
farsider3000 is offline
post #6401 of 6532 Old 08-22-2019, 06:07 PM
skylarlove1999's Avatar
Quoted: 610 Post(s)
Liked: 431
Thank you doing this. I assume velvet is still best and the Rosco TV paint being a bit further back in reducing light reflections onto the screen.
Sent from my SM-G965U using Tapatalk
skylarlove1999 is online now
post #6402 of 6532 Old 08-22-2019, 06:28 PM
Liked: 870
Velvet is still orders of magnitude better than paint.
coxy2416 and ARROW-AV like this.
post #6403 of 6532 Old 08-22-2019, 06:30 PM
Quoted: 610 Post(s)
Liked: 431
100% agree I went dark black triple velvet two years ago. Best thing I ever did for my viewing experience.
post #6404 of 6532 Old 08-23-2019, 12:55 AM
Liked: 0
In terms of a anti reflective ceiling solution for a general purpose room, i wonder why no one has marketed or adapted one of these(outdoor retractable awning) ? A light weight version that’s black .. would this work ?
Was thinking of buying a cheap awning and adapting it with black fabric and installing it indoors over the screen? Retracted when not in use but some can extend this to 3mtrs up front?
Partner that with drop down blinds for your light coloured walls too ?
With this all electric and controlled by remote would look pretty cool!
Ps new account can’t post examples or links yet to show
Wil Wong is offline
post #6405 of 6532 Old 08-23-2019, 01:03 AM
Quoted: 610 Post(s)
Liked: 431
Look a couple pages back. Someone in this thread already uses a similar setup to what you described. Pretty ingenious.
Wil Wong likes this.
post #6406 of 6532 Old 08-23-2019, 02:58 AM
We're Nuts About AV
ARROW-AV's Avatar
Liked: 6510
In terms of performance VELVET > FLOCKING > PAINT
ARROW-AV is offline
post #6407 of 6532 Old 08-23-2019, 04:09 AM
lizrussspike's Avatar
Quoted: 1182 Post(s)
Liked: 1762
I am glad that I caught onto this thread, as going black triple velvet has not only increased my viewing experience, but also lets me enjoy flicks from my home!
Thanks to all in this thread for keeping the dream alive.
llang269 likes this.
lizrussspike is offline
post #6408 of 6532 Old 08-23-2019, 04:11 AM
Quoted: 610 Post(s)
Liked: 431
Amen to that brother. Welcome to the dark side.
lizrussspike likes this.
post #6409 of 6532 Old 08-23-2019, 09:28 AM
Quoted: 596 Post(s)
Liked: 321
@arrow -71
Do you still have to dilute the video tv paint.. I still have no idea how to dilute them.. say i was to buy a gallon of this how much water would it use per gallon?
Once it dries can you touch it or does it leave a mark like other flat black paints..
jorgebetancourt is offline
post #6410 of 6532 Old 08-23-2019, 06:58 PM
monstosity12's Avatar
Quoted: 34 Post(s)
Yes, it's very good. In case you missed it here's my evaluation and review of the top 3 velvet materials, wherein with respect to the primary application of side walls, ceilings, and speakers etc. (which is the first / top photo below) the Whaley's and the Triple Black Velvet are very very close in performance
Which Whaley’s velvet are you referring to on their website (when you were comparing Fidelio and triple black velvet).
Want to order some whaleys. Thanks
Edit: is it the devore
monstosity12 is offline
post #6411 of 6532 Old 08-24-2019, 08:25 PM
Liked: 870
It's listed as "Silk/Viscose Velvet Black (Devore)" according to the link Arrow had in one of his posts.
post #6412 of 6532 Old 08-25-2019, 02:43 AM
We're Nuts About AV
ARROW-AV's Avatar
Liked: 6510
https://www.whaleys-bradford.ltd.uk/...t-black-devore
ARROW-AV is offline
post #6413 of 6532 Old 08-25-2019, 06:33 AM
Luminated67's Avatar
Quoted: 664 Post(s)
Liked: 374
I don’t know if others agree but my experience was that getting the ceiling done had the greater affect on contrast. Would be more difficult for you though with a vaulted ceiling.
Epson EH-TW9400 - QualGear Fixed Frame 100” - Sony x700 BRP & Panasonic 420 BRP - Sony 1080 AVR - IPL Acoustics M1TLs & IPL Acoustics AVC Pro Centre, Four KEF surrounds & 2 Sub boxes (10” Sub + 10” Passive Radiator)
Luminated67 is offline
post #6414 of 6532 Old 08-25-2019, 06:38 AM
Mike Garrett's Avatar
Quoted: 12291 Post(s)
Liked: 9915
It depends on which surfaces are closest to the screen. I have a white ceiling in my family room and it does not hurt the image too much, even though it is a flat ceiling. That is because the ceiling is 17' up.
Mike Garrett is online now
post #6415 of 6532 Old 08-25-2019, 06:59 AM
Quoted: 664 Post(s)
Liked: 374
Agreed proximity is key.
post #6416 of 6532 Old 08-25-2019, 09:19 AM
Quoted: 350 Post(s)
Liked: 254
The plan is to add another width of Devore to the bottom edge of the 'door' and use press studs to hold the other ends up (attached to the underside of the pelmet).
The edited picture shows what I mean by the location of the yellow line. This way there would be close to 2 metres of Devore above the screen.
I did a test using drawing pins as shown in the second picture and this really improved the immersion as it covered the white trim on the edge of the 'door' as well as the white curtain tracks/pelmet each side of the screen. I'm sure it increased contrast too, though I didn't measure it. This is how it should look once I've properly attached the section of Devore to the bottom edge of the door. The hardest part is finding a way to tuck it all out of sight when the door is closed for day to day use.
I sometimes lay another piece of black material across the front piece of the oak flooring too, but I don't find this too distracting at the moment. Perhaps once the ceiling is sorted out properly I will...
Name:	Devore diagram.jpg
ID:	2606958   Click image for larger version
Bluescale and ARROW-AV like this.
post #6417 of 6532 Old 08-25-2019, 09:00 PM
Quoted: 207 Post(s)
Liked: 79
Sorry if this was detailed already I missed it. What's the best way to attach velvet to the ceiling? I plan to paint the room black but attach the velvet to the ceiling and side walls at the screen. I was going to apply adhesive to the primed drywall and use a roller to apply preasure on the fabric to the wall. Not liking the idea of pushpins or staples.
post #6418 of 6532 Old 08-25-2019, 11:28 PM
Bluescale's Avatar
Quoted: 808 Post(s)
Liked: 393
I don’t think you’ll be very successful with that tactic. It’ll result in wrinkles galore. When I attached velvet to my ceiling, I bought Elmer’s lightweight foam board sheets, and wrapped those in velvet. I was able to make them very clean, and redo any mistakes. Unfortunately, I wasn’t able to attach them to the ceiling permanently. Despite being lightweight, they kept falling off after a month or two when I used sticky tac or staples.
I didn’t spend too much time messing with it, though. I just painted the ceiling black and was done with it. I plan to revisit, as the black paint isn’t really black enough for my taste.
Bluescale is offline
post #6419 of 6532 Old 08-26-2019, 06:19 AM
Quoted: 207 Post(s)
Liked: 79
That's why I'm asking for advice on this, your method didn't work either.
post #6420 of 6532 Old 08-26-2019, 06:27 AM
Moderator
rboster's Avatar
Quoted: 1610 Post(s)
Liked: 2203
This is a pretty common question in this thread. Go to the top of (any) page and you'll see a search window for the thread. Use Ceiling as your search word and you'll find a number of members solutions.
rboster is offline
Epson 5020ub Powerlite Home Cinema 3d Front Projector , Mitsubishi , Panasonic Blu Ray Disc Player Dmp Bd30k
