The Blacker the Theater, The Better the Image - Page 219 - AVS Forum | Home Theater Discussions And Reviews
 3050Likes
post #6541 of 6811 Old 09-26-2019, 07:43 AM
lizrussspike's Avatar
Quoted: 1265 Post(s)
Liked: 1894
Thanks @GPBURNS, I have black velvet draped over my speakers. I think that will help my situation.
GPBURNS likes this.
lizrussspike is offline
post #6542 of 6811 Old 09-26-2019, 01:36 PM
Charles R's Avatar
Liked: 828
Originally Posted by Bytehoven View Post
I say aesthetically because the main reason I blacked out my room, was for immersion that comes from only seeing the screen, with no other visual distractions.
I try to (within my reason) keep down reflections and at the same time I haven't worried about "blacking out" the room visually. I never watch anything that doesn't grab my attention... if it didn't I wouldn't watch it. In reality unless I did a crazy "profession" job of hiding everything I would be more bothered by knowing how it looks than any distraction. I guess once I "know" the room it disappears and only the experience is left. Now I understand others may not have such tunnel vision however at times I think they may focus more on the room's experience than the presentation itself.
Bytehoven likes this.
125" Projection | 5.2.4 Audio | Shield TV | LibreELEC/ODROID-C2 Kodi Media Client | Ubuntu/ODROID-XU4 NAS/Server | 65" LG OLED TV | TiVo | Shield TV |
| Water cooled Threadripper & Radeon VII, NVMe PC - 43" 4K IPS Panel |
Charles R is offline
post #6543 of 6811 Old 09-26-2019, 04:52 PM
NIN74's Avatar
Liked: 24
Any suggestion of a really good triple black velvet that have a width of 200cm (78") or more?
Sound and video is not magic, it is pure physics. Physics that can be magical
NIN74 is offline
post #6544 of 6811 Old 09-26-2019, 05:03 PM
biglen's Avatar
Quoted: 560 Post(s)
Liked: 101
When I was looking for Velvet, I never saw anything that wide. It usually comes in a roll that's anywhere from 40-48" wide. The roll I bought from Amazon, was 40" wide, and I needed to make a curtain to cover a 100" long wall. I bought this tape, and used it to join 3 panels together. This stuff is stronger than sewing it together. I messed a piece up, and had to try and pull it apart. The Velvet actually ripped before the tape came separated.
Therm O Web PeelnStick Fabric Fuse Tape 5/8 Inch x 20 Feet (3346) https://www.amazon.com/dp/B0018BVNIS..._WluJDbJE31KBM
Here's the Velvet I bought. You won't find 30 yards any cheaper. That's a little less than $6/yard, and most places are $8-$10/yard.
45" Black Triple Velvet-30 Yards Wholesale by the Bolt https://www.amazon.com/dp/B00EEJSG90..._KmuJDb9F8RDFD
Sent from my SM-N975U using Tapatalk
biglen is online now
post #6545 of 6811 Old 09-27-2019, 02:05 AM
Luminated67's Avatar
Quoted: 730 Post(s)
Liked: 402
Regarding light getting reflected back to the screen, you might have covered enough to make a big difference.
Regarding what is observable in your field of view during movie viewing, you kinda have to go far enough to eliminate any sheen reflections from the ceiling, floor or side walls.
I was going to say the same thing, I bought the self-Adhesive Velour to covered all my walls and ceiling back about 6ft which I did and like you said this was far enough I felt for improving contrast levels on the screen itself, not says more or in fact the entire room doesn't make a difference as I'm sure it does but unlike the first 6ft these improvement after that amount to a few percent improvement at most. As I had enough to take back a further 3.5ft all over I did and what I found was it give no distractions from the reflections coming off the walls that weren't covered originally after the first 6ft and in my peripheral vision.
My vision is now locked solely on the screen.
Epson EH-TW9400 - QualGear Fixed Frame 100” - Sony x700 BRP & Panasonic 420 BRP - Sony 1080 AVR - IPL Acoustics M1TLs & IPL Acoustics AVC Pro Centre, Four KEF surrounds & 2 Sub boxes (10” Sub + 10” Passive Radiator)
Luminated67 is offline
post #6546 of 6811 Old 09-27-2019, 06:25 AM
biglen's Avatar
Quoted: 560 Post(s)
Liked: 101
Here is my room, and where I have the velvet. I hung a velvet panel to cover the media closet door, but I didn't do the wall where I noted in the layout. Do you guys agree that it wasn't worth doing that wall, because the media closet wall blocks out any reflection?
post #6547 of 6811 Old 09-27-2019, 08:03 AM
farsider3000's Avatar
Quoted: 1620 Post(s)
Liked: 1008
I just bought some of this Black 3.0 to see how black it is. The Black 2.0 was not any darker than other black paint so we will see. I doubt it’s as black as Rosco Video Paint TV Black (which is darker than Rosco Supersaturated and has 3% reflectance). I will report back with results.
Black 3.0 info:
Sent from my iPhone using Tapatalk Pro
Craig Peer, cemo62 and Buddylee123 like this.
7.4.6 system: Processors:Marantz 8805 || Xilica XP4080 Amps: Parasound A31 and ATI AT528NC & AT526NC n-core ||Speakers: Procella P8 LCR, Procella P5/P5 in-wall
Subs: JTR Captivator subs: One S2, Two RS2, One S1
Screen: 2.40:1 Seymour XD Acoustically Transparent, 128" diagonal / 118" wide || Projector: JVC X570/RS420
farsider3000 is offline
post #6548 of 6811 Old 09-27-2019, 08:55 AM
Buddylee123's Avatar
Quoted: 906 Post(s)
Liked: 622
Nice , looking forward to the report
Buddylee123 is online now
post #6549 of 6811 Old 09-27-2019, 11:58 AM
ScottAvery's Avatar
Quoted: 720 Post(s)
Liked: 209
I personally would not be too concerned about that wall, given the distance and the media closet. How's the ceiling treated?
ScottAvery is offline
post #6550 of 6811 Old 09-27-2019, 12:09 PM
biglen's Avatar
Quoted: 560 Post(s)
Liked: 101
The ceiling has 3' of black velvet, from the screen wall.
post #6551 of 6811 Old 09-27-2019, 12:21 PM
ScottAvery's Avatar
Quoted: 720 Post(s)
Liked: 209
Sounds like a good place to be. I, too, stopped at about that point. Obviously many in this thread take it to extremes. The ceiling area between that edge 3 feet from your screen and the projector is probably the biggest reflection point left now, depending on your projector position of course. Also, does your projector leak light out of the vents? My first projector did that -- lit up the back wall. Velvet around the projector area would help there as well, in such case.
post #6552 of 6811 Old 09-27-2019, 12:46 PM
biglen's Avatar
Quoted: 560 Post(s)
Liked: 101
I have the Epson 5050ub, and I built a nice sized box in the back wall, that the projector sits in. No light leakage from the vents. The inside of the box is painted black.
post #6553 of 6811 Old 09-30-2019, 01:53 PM
DavidinGA's Avatar
Quoted: 404 Post(s)
Liked: 135
I finally got my multi-use (compromised to keep the wife happy room) done.
I went with triple black velvet off Amazon and made some simple curtains using hot glue. Tacked fabric to the ceiling in-line with my wall changes. Attaching the fabric to my drop-down attic access door was a pain and made it all take way longer than it should, but the end results are great!
Here is a quick before and after.
ID:	2621836   Click image for larger version
Source: HTPC w/madVR, Video: Epson 5040, 150" 16:9, Audio: Onkyo RZ 830 avr, 5.1.4 Atmos setup. 5 speaker Energy C Series: L/R C300's, C C-C100, SR/SL C50's, 4 in-ceiling Micca R-8c. Subwoofer: MiniMarty um18 w/NX3000D.
DavidinGA is offline
post #6554 of 6811 Old 09-30-2019, 02:26 PM
ScottAvery's Avatar
Quoted: 720 Post(s)
Liked: 209
Looks great! How is your viewing experience, before and after? Do you have a scrap of fabric left to try covering the area below the screen to see if it makes a significant difference? Or to wrap the cabinet of the center speaker?
post #6555 of 6811 Old 09-30-2019, 02:33 PM
DavidinGA's Avatar
Quoted: 404 Post(s)
Liked: 135
It definitely improved my contrast and makes the image float. I had to recalibrate my contrast & brightness settings after I got it all put up
I'm debating on covering that little bottom strip yet. I don't really notice it much with a movie on as my screen is so low to the ground, but I may still cover it.
I do have plenty of fabric left! I might drape the front set of speakers too!
Now I'm wishing I had a way to do a full-out bat cave with this room, but I enjoy being married, so it's doubtful...
post #6556 of 6811 Old 09-30-2019, 02:34 PM
skylarlove1999's Avatar
Quoted: 1032 Post(s)
Liked: 720
That looks really great. I know covering the ceiling is a royal pain in the butt. It does make quite a bit of difference. It will be worth the work.
Sent from my SM-G965U using Tapatalk
jorgebetancourt likes this.
skylarlove1999 is online now
post #6557 of 6811 Old 09-30-2019, 02:34 PM
DavidinGA's Avatar
Quoted: 404 Post(s)
Liked: 135
Also, my acoustic panels now appear to be covered in dark grey fabric instead of black next to the triple black velvet; ugh...lol
post #6558 of 6811 Old 09-30-2019, 02:36 PM
DavidinGA's Avatar
Quoted: 404 Post(s)
Liked: 135
Ya I had to cover this access door - not so fun, but it's done with now!
farsider3000 likes this.
post #6559 of 6811 Old 09-30-2019, 02:42 PM
Liked: 720
That looks great. Nice work!!! I bet your wife noticed the picture quality difference.
DavidinGA likes this.
post #6560 of 6811 Old 09-30-2019, 02:46 PM
ScottAvery's Avatar
Quoted: 720 Post(s)
Liked: 209
It might be worth experimenting with attaching a strip of fabric to the weight bar of the screen to ride down when the screen comes down, then it won't look odd when the screen is up.
post #6561 of 6811 Old 09-30-2019, 05:04 PM
WisconsinEric's Avatar
Quoted: 112 Post(s)
We recently had a minor flooding issue in our basement that has our home theater room out of commission. Fortunately nothing damaged other than the carpet!
But with all the flooring tore out and the room emptied I think I want to take advantage of the opportunity to repaint the room. Currently it is beige and white (remnants of being a multi-person room for the previous owners). I think I will do a grey carpet, grey walls, and a black ceiling.
Any reason NOT to do a matte finish on the ceiling? Doesn't seem like it would get much contact so there shouldn't be too much in the way of hard-to-remove dirt or scratches that typically plague matte finishes.
WisconsinEric is online now
post #6562 of 6811 Old 09-30-2019, 05:41 PM
Liked: 1008
You definitely want a matte finish on the ceiling. Rosco Video Paint is currently the “most black” paint for this application. Just painted 9ft of my 23.5’ room walls with it and wow what a difference:
post #6563 of 6811 Old 10-01-2019, 03:34 PM
fatherom's Avatar
Quoted: 480 Post(s)
Liked: 208
Has anyone who has stapled velvet to a ceiling had any issues with dimples from the staple being visible on the velvet's surface (when light reflected from the screen shines on the velvet). I plan to use black staples, I just don't know if the "depression" caused by the staple will be visible.
Theater 1: LG OLED55E6P 4K TV, Oppo UDP-203, Apple TV 4K, Dune HD Solo 4K
Theater 2: Sony VPL-VW885ES, Seymour Premier 16:9 128", Lumagen 4242, Oppo 103D (CFW) / 203, Sony MDR-DS7500 Wireless Surround Headphones & Denon AVR-X6500H (7.1.4)
fatherom is offline
post #6564 of 6811 Old 10-01-2019, 03:46 PM
ScottAvery's Avatar
Quoted: 720 Post(s)
Liked: 209
Search this thread for discussion of a stapling method where you staple through the back and then fold it over. The staples do not have to be visible at all. Start at one edge stapling the back to the ceiling while the good side of velvet hangs down the wall, then stretch it over and staple in place, then add the next layer wrong side up (down, actually, since it is on the ceiling) along that edge, covering those staples, then fold over again, across. make sense?
If you do find yourself stapling through the front, a light touch with a fabric brush would probably hide the staple in the velvet pile.
post #6565 of 6811 Old 10-01-2019, 04:05 PM
fatherom's Avatar
Quoted: 480 Post(s)
Liked: 208
sorry for being dense, but i cant envision your method based on the description.
That being said, I'm only attaching one single piece (44" wide and 120" long) in one single strip across the ceiling above my screen. So i think stapling through the front is the only option, no?
thanks
fatherom is offline
post #6566 of 6811 Old 10-01-2019, 05:14 PM
Liked: 1894
@DavidinGA , that is what I did with some of my fabric, placed some over the top of the speakers and subs, so they disappear.
post #6567 of 6811 Old 10-01-2019, 07:51 PM
ScottAvery's Avatar
Quoted: 720 Post(s)
Liked: 209
thanks
You could put a piece of trim across the edge to cover the staples, in that case.
search the thread, I am sure more than one person has explained folding velvet over the staples.
fatherom likes this.
post #6568 of 6811 Old 10-01-2019, 07:56 PM
Liked: 1008
@Chad B
Like I mentioned in my earlier post I just blacked out my theater with Rosco Video Paint. Looking forward to your upcoming calibration tweak at my house on October 22!
Chad B likes this.
post #6569 of 6811 Old 10-01-2019, 08:07 PM
Liked: 1008
Okay there is now a paint that is darker than Rosco Video Paint. Black 3.0... but it is very expensive ($22.00 plus shipping for a tiny bottle of unknown volume ... 4.5 inches tall by 1.5 inches in diameter). It’s made for artists.
I painted a patch over the Rosco and it’s visibly darker and reflects even less light.
A 5 liter size will sell for 350 British pounds ($430) plus shipping !!!
ARROW-AV likes this.
post #6570 of 6811 Old 10-01-2019, 08:38 PM
Quoted: 906 Post(s)
Liked: 622
You know we want them pictures
Epson 5020ub Powerlite Home Cinema 3d Front Projector , Mitsubishi , Panasonic Blu Ray Disc Player Dmp Bd30k
