The Blacker the Theater, The Better the Image - Page 225 - AVS Forum | Home Theater Discussions And Reviews
 3228Likes
post #6721 of 7112 Old 11-05-2019, 02:57 PM
descalabro's Avatar
Quoted: 500 Post(s)
Liked: 193
Originally Posted by andyng View Post
Yes. Where do you think I should put the rod to make it look good on this.
thanks
I'm not seeing the whole wall, but I would probably make it like this (see attached image), with the rod supports installed on the oblique section of the ceiling. This way, the rod won't interfere much visually with the columns and lights (you can even look for a rod with a color similar to the gray of the ceiling), and the curtain can open half for each side.
andyng likes this.
4,3 x 2,8m semi-blacked out media room | 2010 MacMini > Pioneer VSX-520-K > JVC RS50 (X7) > 107", 1.1 gain, white screen | JVC X30 (RS45)
descalabro is offline
post #6722 of 7112 Old 11-05-2019, 02:58 PM
andyng's Avatar
Quoted: 44 Post(s)
@descalabro
Thanks. I get what you suggest. I will attempt to try that as soon as I get my hands on 30 yards of velvet that I ordered off amazon.
I want to keep the room simple with velvet curtain tied when not watching movie and when we do, just untie it to cover the whole wall without much work.
descalabro likes this.
andyng is offline
post #6723 of 7112 Old 11-06-2019, 05:37 AM
audioguy's Avatar
Quoted: 5238 Post(s)
Liked: 4158
I built some velvet covered panels for the sides of my speakers but, like the rest of the velvet I used, it has stretched (a bunch) and now looks quite unsightly. I would like to find some velvet that has NO stretch and, it does not need to be acoustically transparent.
Any recommendations? Was it Sy Fabrics?
audioguy is offline
post #6724 of 7112 Old 11-06-2019, 08:30 AM
coxy2416's Avatar
Quoted: 771 Post(s)
Liked: 455
Would Triple Black Velvet work? I don’t think it is stretchy and works better then anything that I have seen for absorbing light.
coxy2416 is offline
post #6725 of 7112 Old 11-06-2019, 09:05 AM
ereed's Avatar
Quoted: 2386 Post(s)
Liked: 1674
I use triple black velvet from Hobby Lobby, the non stretch kind and works great. Make sure you go to website and print the 40% off coupon before going there!
Theater room: Sony 45es | 120" screen | Panasonic BDT500 | Rotel RMB-1077 | Outlaw Audio 976 | Klipsch RP-280F/RP-450C/RP-160M | Funk Audio subs | MiniDSP 2x4HD | Crowson Tech MAs | Surgex XR 315 | GIK room treatment
TV Room: Panny 60 inch | Rotel RMB-1075 | Rotel RSP-1068 | Axiom Audio M60/VP150/QS8 |
ereed is offline
post #6726 of 7112 Old 11-06-2019, 10:09 AM
audioguy's Avatar
Liked: 4158
Do they have triple black that is stretch and non stretch?
audioguy is offline
post #6727 of 7112 Old 11-06-2019, 10:29 AM
ereed's Avatar
Liked: 1674
The black triple velvet is non stretch which is 45 inches wide (which I use to drape over speakers like you do). They do have stretch black velvet but not sure of the exact name. There are few diff types of black velvet at the store last time I was there.
ereed is offline
post #6728 of 7112 Old 11-06-2019, 10:55 AM
audioguy's Avatar
Liked: 4158
Thanks. I actually don't drape it over the speakers. I cut some wood panels the exact size of the size of the side of the speakers and attached with some "sticky stuff" that won't mar the finish of the speaker.
I will go online and buy some of that fabric and thanks again.
audioguy is offline
post #6729 of 7112 Old 11-06-2019, 11:04 AM
ScottAvery's Avatar
Quoted: 772 Post(s)
Liked: 223
Depending on how much you need you may get a better deal buying in 30 yard bolts from Amazon. Vendor "Fabric Bravo - Better Service!"
ScottAvery is offline
post #6730 of 7112 Old 11-06-2019, 11:06 AM
ScottAvery's Avatar
Quoted: 772 Post(s)
Liked: 223
@descalabro
If it were my room I would not cover up the columns. I would build fabric panels between the columns and if you want to reduce the glare of the columns, wrap them too, perhaps in a complementary color for some contrast.
post #6731 of 7112 Old 11-06-2019, 11:08 AM
audioguy's Avatar
Liked: 4158
Thanks but I need very little. While the velvet on the ceiling has stretch a bunch, it is not noticeable. I just need a couple of yards for the two front speakers.
@ereed . Is THIS the non stretch velvet you used?
audioguy is offline
post #6732 of 7112 Old 11-06-2019, 11:38 AM
bungi43's Avatar
Quoted: 64 Post(s)
Originally Posted by sddawson View Post
I have done a lot of searches on this thread to try to get definitive answers to my concerns, but still feel the need to post!
I want to wrap my room in the equivalent of triple black velvet (double black in Australia). That means ceiling, some parts of the side walls and rear wall in velvet-wrapped panels, and most of the side walls in velvet curtains (because that's an easy way to cover some doors and cupboards).
I'm wondering how this will affect acoustics in the room. I do have an Anthem AV receiver, so can run some EQ. But would, say, acoustic panels at first reflection point still be a good idea, and if so, would they be OK behind the curtains? There are currently some panels on the rear wall (pic attached). Those outside diffuser panels, according to a flashlight test, throw way too much light back on to the screen. The rectangular peaks are quite reflective. So should I just get rid of those panels altogether, or just build a frame around them covered in velvet? The seats will be replaced with new black ones.
Secondly, I'd like to double check the best way to install velvet with regard to sheen. Is the idea, with the projector displaying something bright, to install the velvet so that I can't see sheen from the seating position? Presumably that means that if I stand at the screen looking back towards the seating position, I will see the sheen, meaning that some light will be reflecting back on to the screen. Which way is best?
Thanks for any tips.
I bit off topic...do you like your HT seats with the "love seat" in the middle?
My HT room isn't super wide, and to go 4 seats and have some room I think that's the option I"ll have to go (I have 3 seats now). Thanks!
bungi43 is offline
post #6733 of 7112 Old 11-06-2019, 11:50 AM
farsider3000's Avatar
Quoted: 1642 Post(s)
Liked: 1033
I have four seats but I shifted the seats against the right wall so that the second seat from the left is directly centered on my screen. Steps down to the first row area are on the left side of the room and my room really isn’t wide enough for four seats as the rightmost seat is slammed against the wall.
I would not want to have four seats if no seat is in the exact center listening / viewing position.
Sent from my iPhone using Tapatalk Pro
7.4.6 system: Processors:Marantz 8805 || Xilica XP4080 Amps: Parasound A31 and ATI AT528NC & AT526NC n-core ||Speakers: Procella P8 LCR, Procella P5/P5 in-wall
Subs: JTR Captivator subs: One S2, Two RS2, One S1
Screen: 2.40:1 Seymour XD Acoustically Transparent, 128" diagonal / 118" wide || Projector: JVC X570/RS420
farsider3000 is offline
post #6734 of 7112 Old 11-06-2019, 12:03 PM
bungi43's Avatar
Quoted: 64 Post(s)
It's funny. I have my 2nd seat dead center, but I find myself now sitting on the end. Only time I have to be in the middle is when gaming.
bungi43 is offline
post #6735 of 7112 Old 11-06-2019, 12:17 PM
coxy2416's Avatar
Quoted: 771 Post(s)
Liked: 455
I have four seats but I shifted the seats against the right wall so that the second seat from the left is directly centered on my screen. Steps down to the first row area are on the left side of the room and my room really isn’️t wide enough for four seats as the rightmost seat is slammed against the wall.
That’s why I went with a 3 seater.
bungi43 and farsider3000 like this.
coxy2416 is offline
post #6736 of 7112 Old 11-06-2019, 12:19 PM
bungi43's Avatar
Quoted: 64 Post(s)
Dude...I love that. Do you have a front shot of your room?
I'm guessing my room is slightly wider than yours, but not much.
But again, if I have the "love seat" in the middle of the row of four.
I love that black paint.
bungi43 is offline
post #6737 of 7112 Old 11-06-2019, 12:22 PM
bungi43's Avatar
Quoted: 64 Post(s)
Mine setup is a bit different as it's a sports room too (the bottom TV int he middle does not stay, the 2 on each side of my projector are mounted, but covered during movie times with black curtains)
But yeah, I am gonna take the tiles down and drywall, and go all black now I think.
coxy2416 likes this.
bungi43 is offline
post #6738 of 7112 Old 11-06-2019, 12:22 PM
coxy2416's Avatar
Quoted: 771 Post(s)
Liked: 455
That’️s why I went with a 3 seater.
Thanks! It’s nothing fancy but works great.
ID:	2637230   Click image for larger version
chadsmith013 and bungi43 like this.
coxy2416 is offline
post #6739 of 7112 Old 11-06-2019, 12:23 PM
bungi43's Avatar
Quoted: 64 Post(s)
Nice. I have that same star wars poster in my HT room.
bungi43 is offline
post #6740 of 7112 Old 11-06-2019, 12:27 PM
coxy2416's Avatar
Quoted: 771 Post(s)
Liked: 455
Thanks! It’️s nothing fancy but works great.
Good eye. I have a Back to the Future poster as well. Two great movies!
This is the outside of my theatre.
coxy2416 is offline
post #6741 of 7112 Old 11-06-2019, 12:32 PM
audioguy's Avatar
Liked: 4158
Mine is the same way (shifted left). NO ONE should be allowed to post on AVS if there is not a seat in the sweet spot!
farsider3000 likes this.
audioguy is offline
post #6742 of 7112 Old 11-06-2019, 12:34 PM
bungi43's Avatar
Quoted: 64 Post(s)
Dude...nice. Is that a Pioneer Plasma?
I have a BttF Poster as well, but I rotate mine out. It's currently covered up by "The Watchmen"
bungi43 is offline
post #6743 of 7112 Old 11-06-2019, 12:39 PM
coxy2416's Avatar
Quoted: 771 Post(s)
Liked: 455
That is a pioneer plasma.
coxy2416 is offline
post #6744 of 7112 Old 11-06-2019, 01:01 PM
biglen's Avatar
Quoted: 588 Post(s)
Liked: 109
You should try moving that sub to the corner. I'd be willing to bet it will hit harder in the corner.
Sent from my SM-N975U using Tapatalk
biglen is offline
post #6745 of 7112 Old 11-06-2019, 02:00 PM
ereed's Avatar
Liked: 1674
Your link doesn't take me to direct product. Here is the item. https://www.hobbylobby.com/Fabric-Se...Fabric/p/45441
I also attached the product info that came with my velvet.
ereed is offline
post #6746 of 7112 Old 11-06-2019, 02:28 PM
sddawson's Avatar
Quoted: 291 Post(s)
Liked: 49
Yes, I do like it. Like you, it’s the only way I can get 4 seats across the room. Yes, it means you can’t sit right in the middle, but it doesn’t bother me.
sddawson is offline
post #6747 of 7112 Old 11-06-2019, 02:40 PM
Quoted: 89 Post(s)
Liked: 37
Rosco Video Paint TV Black on the right and Sherwin Williams Flat Tricorn Black on the left:
Gave my painter 3 Gals of Rosco Black TV Paint (900 SF of coverage) for him to paint the ceiling and soffits (~ 535 SF). He calls me to tell me he ran out of paint and still needs to do the bottom of the soffits (~160 SF). I know I should have stayed home...
Despite his claims of 30 years experience.....He didn't even bother reading the instructions in the can.....and didn't dilute the paint at all. I see some of you are diluting up to 1:1. Instructions call for up to 10% water. He went all in with a spray gun .
Don't get me wrong....the ceiling looks fantastic. But it seems like this was the equivalent of 3 coats if he had rolled it... Had to order 3 more gallons just in case.....For 535 SF, we are going to go through 5 Gallons of paint.....is it just me or this seems a little ridiculous?
Speakers: L/C/R: Ascend Sierra Towers (Raal) / Ascend Horizon (Raal) Subwoofers: 2 x JTR Captivator 2400ULF Surrounds: Revel S16(4) / Atmos: RSL C34e (4)
Video: JVC RS2000, Lumagen 4444, 132.8" SeymourAv 2.40:1 with dual roller masking to 16:9
Other: Anthem AVM60 / DSonic M3a 2800-7 / Crown XLS 1002 (2) / Kaleidescape Strato S, XBOX One X, ATV4k, UB820, Elan G1, 2x GC-100-18R
crg28 is offline
post #6748 of 7112 Old 11-06-2019, 02:59 PM
descalabro's Avatar
Quoted: 500 Post(s)
Liked: 193
That could look nice, and for contrast on the columns the velvet could be placed in the opposite direction so it would reflect a different shade of gray. But covering the walls and wrapping the columns is a lot of hard work and you really need to do it skillfully to avoid having it look like an amateur's work. With curtains, you get evenly black walls with much less effort and you can leave the walls untouched to use the room for other purposes.
post #6749 of 7112 Old 11-07-2019, 06:51 AM
genaccmiller's Avatar
Quoted: 795 Post(s)
Liked: 188
Folks - I am constructing an AT screen and need to do panels at top, bottom, left and right. I was recommended Spandex, GOM fr701. Any preferences based on your experiences? Is there anything additional I need to consider. The material has to be Accoustically transparent.
Sent from my Moto G (5) Plus using Tapatalk
Step by Step Theater Build - http://imgur.com/gallery/2tpaSru
My Theater Build Youtube Channel - https://www.youtube.com/channel/UCs_..._as=subscriber
My Theater Build Thread - https://www.avsforum.com/forum/19-de...ld-thread.html
genaccmiller is online now
post #6750 of 7112 Old 11-07-2019, 01:52 PM
ScottAvery's Avatar
Quoted: 772 Post(s)
Liked: 223
@genaccmiller
I have both GOM FR701 and Velvet in my current build but will be switching to Whaley's Devore which was tested by @ARROW-AV to be very transparent and just as dark as the best velvets. See his product link here:
https://www.avsforum.com/forum/24-di...l#post58469010
GOM is nice and sturdy but looks like an office cubicle wall... high end burlap. Spandex is AT but will not be attractive on its own and may be too shiny even if in matte finish.
Epson 5020ub Powerlite Home Cinema 3d Front Projector , Mitsubishi , Panasonic Blu Ray Disc Player Dmp Bd30k
