The Blacker the Theater, The Better the Image - Page 227 - AVS Forum | Home Theater Discussions And Reviews
 3229Likes
post #6781 of 7115 Old 11-15-2019, 01:05 PM
audioguy's Avatar
Quoted: 5238 Post(s)
Liked: 4158
Originally Posted by coxy2416 View Post
Black velvet fixes all....but once you start it’s hard to stop. Lol
Sooo true!
audioguy is offline
post #6782 of 7115 Old 11-15-2019, 02:21 PM
ereed's Avatar
Quoted: 2387 Post(s)
Liked: 1674
Originally Posted by audioguy View Post
Sooo true!
Were you able to get the velvet from Hobby Lobby?
Theater room: Sony 45es | 120" screen | Panasonic BDT500 | Rotel RMB-1077 | Outlaw Audio 976 | Klipsch RP-280F/RP-450C/RP-160M | Funk Audio subs | MiniDSP 2x4HD | Crowson Tech MAs | Surgex XR 315 | GIK room treatment
TV Room: Panny 60 inch | Rotel RMB-1075 | Rotel RSP-1068 | Axiom Audio M60/VP150/QS8 |
ereed is offline
post #6783 of 7115 Old 11-15-2019, 03:10 PM
ScottAvery's Avatar
Quoted: 774 Post(s)
Liked: 224
Originally Posted by fatherom View Post
Not a bad idea, but it would be a challenge due to room layout (where projector is vs where my desks are, etc).
As far as that Justice League scene I mentioned, I just watched that part on my iphone, and it looks washed out there too (a bit), so I'm wondering if I'm focused on the "wrong" clip.
Is there a test pattern or certain scene in a film you all use to check to see if reflections are causing a washed-out image?
Chris
With all the trouble on that film I would not be surprised if it was just poor quality raw footage.
There is a troublesome shot in La La Land that drove me nuts trying to figure out what was wrong with my system until I finally figured out it was the film itself. When the roommates are dancing in the street singing "someone in the crowd" the streetlights cause lens flares or something as they go out of the frame. I was sure my A-lens was messed up or my masking was causing reflections.
Others have already described the test you need to do, the flashlight test. If that test shows results on an empty screen then every image is likewise impacted. You would not be able to see it in particular projected image without actually changing your room with the image on screen, which would be almost impossible to A-B test unless someone is pulling curtains back and forth for you.
I suspect the image you would want to test with would be something REALLY extreme like The Revenant, not a mixed light/dark image.
ScottAvery is offline
post #6784 of 7115 Old 11-15-2019, 03:11 PM
Killroy's Avatar
Quoted: 635 Post(s)
Liked: 509
Originally Posted by Craig Peer View Post
That carpet though - it needs to be black !
Had no idea what a difference a real black carpet would make....I will never go back to anything else.
ID:	2641574   Click image for larger version
Killroy is offline
post #6785 of 7115 Old 11-15-2019, 04:14 PM
Craig Peer's Avatar
Quoted: 7497 Post(s)
Liked: 9111
Yup! Of course once I put it in the wife said I was in charge of vacuuming up any " popcorn storms " ( at least it can look like a popcorn storm hit with some friends ).
Killroy likes this.
Craig Peer is online now
post #6786 of 7115 Old 11-15-2019, 04:20 PM
Killroy's Avatar
Quoted: 635 Post(s)
Liked: 509
LOL!!! The only thing mine told me was "Have fun vacuuming that bad boy."
Craig Peer likes this.
Killroy is offline
post #6787 of 7115 Old 11-15-2019, 04:20 PM
zombie10k's Avatar
Quoted: 5506 Post(s)
Liked: 5946
That looks great! black carpet changes the whole look of the room and completes the blackout experience. Velvet room, black carpet + high contrast projector = great viewing experience
tebling, Killroy and coxy2416 like this.
zombie10k is online now
post #6788 of 7115 Old 11-15-2019, 08:55 PM
audioguy's Avatar
Liked: 4158
I did. It arrived today. I started modifying the panels today (got rid of the super stretchy velvet) and will finish tomorrow. I have yet to take the velvet out of the shipping box but I will assume it is the non stretch version !!
Thanks for pointing me in the right direction.
Update: finished the panels today. Works perfect.
ereed likes this.
audioguy is offline
post #6789 of 7115 Old 11-16-2019, 06:56 PM
dbpaddler's Avatar
Quoted: 163 Post(s)
Liked: 98
Just picked up 10yds of JF's Royal Black and a Brother sewing machine. Plan on sewing back those gold sides and making sheets with loops at each end to run furring strips through so they'll run from the ceiling to the bottom trim. Pop a few nails through the strips and hopefully be good to go.
For now the plan is to do one width sheets to the left and right of the screen. 135" screen and a 12' width wall. With the screen down, you'll see nothing but black. If that works, I'll do the same thing to the front of the side walls.
Definitely like the black carpet idea. Could do an 8x12 that would cover the room width and just reach the sofa. Would a dark maroon or navy work well too and provide a little color when the lights are on? Thinking with dark tan walls, some navy or maroon would compliment and still darken things up.
The Pic is before the new screen and putting the center channel on a stand, moving the little console off to the side. So the drop down screen goes another 3-4 inches lower meeting the center channel on its stand. That's a 120" screen and the drop down is 135".
Sent from my SM-N975U1 using Tapatalk
dbpaddler is offline
post #6790 of 7115 Old 11-16-2019, 07:46 PM
andyng's Avatar
Quoted: 44 Post(s)
Originally Posted by biglen View Post
I have French Doors like you, so I bought the velvet, sliding curtain rod, and the fabric tape, to make a curtain to cover the doors. I seamed 3 sections of the velvet together to make one long curtain. I made a mistake with the tape, and had to pull apart 2 pieces of the curtain. That tape is so strong, the velvet ripped before the tape released. You're not going to find a better price on velvet, then you get from the link I posted. I had plenty of velvet left over to do the other side wall from the doors, and about 5 feet deep of my ceiling.
45" Black Triple Velvet-30 Yards Wholesale by the Bolt https://www.amazon.com/dp/B00EEJSG90..._ak1TDbFSQZKWP
Rod Desyne Rosen Traverse Rod, 86-120 inch, Black https://www.amazon.com/dp/B00V6641C0..._Nk1TDbSMF2PK6
Therm O Web PeelnStick Fabric Fuse Tape 5/8 Inch x 20 Feet (3346) https://www.amazon.com/dp/B0018BVNIS..._ml1TDb4DTTXHT
Sent from my SM-N975U using Tapatalk
I ordered everything in your list and just finished watching the first movie in the theater with velvet. What a big difference it made. My wife was skeptical when I put up the rods but once she came in watching the movie when it's done, she loved it.
My question is I need some extra velvet and they don't seem to sell in smaller quantity. I wonder if you have something left over that I can get off your hand and pay the shipping?
andyng is offline
post #6791 of 7115 Old 11-16-2019, 07:48 PM
ereed's Avatar
Liked: 1674
Awesome! Glad it worked out!
ereed is offline
post #6792 of 7115 Old 11-16-2019, 07:51 PM
dbpaddler's Avatar
Quoted: 163 Post(s)
Liked: 98
Now I'm wondering if I should return the sewing machine and get some of that fabric fuse.
post #6793 of 7115 Old 11-16-2019, 09:11 PM
biglen's Avatar
Quoted: 591 Post(s)
Liked: 109
Definitely don't need a sewing machine. That fabric fuse is as good as sewing, trust me.
dbpaddler likes this.
biglen is offline
post #6794 of 7115 Old 11-16-2019, 09:16 PM
biglen's Avatar
Quoted: 591 Post(s)
Liked: 109
I do have some extra. How much are you looking for?
biglen is offline
post #6795 of 7115 Old 11-16-2019, 09:36 PM
andyng's Avatar
Quoted: 44 Post(s)
I just went to the theater and did some quick calculation and I'm looking at about half the roll that they sell. Maybe 18 yards.
Thank you
andyng is offline
post #6796 of 7115 Old 11-16-2019, 10:07 PM
biglen's Avatar
Quoted: 591 Post(s)
Liked: 109
Thank you
I'm not sure if I have that much. I'll check in the morning and let you know.
andyng likes this.
biglen is offline
post #6797 of 7115 Old 11-16-2019, 10:25 PM
dbpaddler's Avatar
Quoted: 163 Post(s)
Liked: 98
To the hobby lobby it is tomorrow.
post #6798 of 7115 Old 11-17-2019, 05:48 AM
wpbpete's Avatar
Quoted: 219 Post(s)
Liked: 197
Originally Posted by SeargentPeppers View Post
I'm currently trying to tack some velvet up on the ceiling but am struggling forming straight edges given the stretch of the fabric. Any ideas?
Originally Posted by descalabro View Post
You mean you’re tacking it on the ceiling directly? If that’s the case, I think the only way to do get straight edges is if you wrap the them around some straight thin material before you tack them. Better if you sew it to said material.
I hung mine from the ceiling using cheap $2-3 curtain rods. I straightened the rod, no worries if it's not perfectly straight, glued the velvet to it and screwed it onto the ceiling.
wpbpete is offline
post #6799 of 7115 Old 11-17-2019, 06:22 AM
descalabro's Avatar
Quoted: 500 Post(s)
Liked: 193
I think the OP was talking about covering the ceiling, not hanging it to cover the sides.
4,3 x 2,8m semi-blacked out media room | 2010 MacMini > Pioneer VSX-520-K > JVC RS50 (X7) > 107", 1.1 gain, white screen | JVC X30 (RS45)
descalabro is offline
post #6800 of 7115 Old 11-17-2019, 07:23 AM
Quoted: 13 Post(s)
Liked: 4
Lightbulb
Originally Posted by twcl View Post
Looking if someone has some devore fabric left over? Want to see the difference against triple black velvet in person and if enough cover my lcr speakers behind an acoustic screen.
Willing to pay retail price and shipping.
Anyone can help?
twcl is offline
post #6801 of 7115 Old 11-17-2019, 07:58 AM
wpbpete's Avatar
Quoted: 219 Post(s)
Liked: 197
Ahh, I missed that, thanks. While I'm here, I see some of you are putting your speakers behind the velvet. I tried it and the sound is very muffled. How far behind the velvet are you getting good results?
wpbpete is offline
post #6802 of 7115 Old 11-17-2019, 08:17 AM
andyng's Avatar
Quoted: 44 Post(s)
I'm looking to put black carpet on my HT room which is 14x17.
Anyone has any recommend for a plush, good black carpet?
andyng is offline
post #6803 of 7115 Old 11-17-2019, 10:11 AM
biglen's Avatar
Quoted: 591 Post(s)
Liked: 109
Thank you
That's what I have left.
andyng likes this.
biglen is offline
post #6804 of 7115 Old 11-17-2019, 10:31 AM
andyng's Avatar
Quoted: 44 Post(s)
That may work. still better than buying a full roll.
I'm in Houston, 77407. Let me know if we can work out some arrangement.
Thanks a lot.
andyng is offline
post #6805 of 7115 Old 11-17-2019, 10:48 AM
biglen's Avatar
Quoted: 591 Post(s)
Liked: 109
Thanks a lot.
Trying to ship that on the plastic spindle, might be tough. I'm not sure how the velvet handles being folded, but if I could get it off the roll and fold it, it would be easy to get it in a box for shipping.
andyng likes this.
biglen is offline
post #6806 of 7115 Old 11-17-2019, 12:11 PM
dan webster's Avatar
Quoted: 285 Post(s)
Liked: 294
Has anyone tried black stick on carpet squares on their ceiling?
Dolby Atmos 7.2.4 Yamaha CX-A5200 Gemstone 200x7 Emotiva upa-500 amps
Oppo 103 panasonic ub820 Ultra HD Blu-ray Jvc RS3000 projector
Eulenvusion 130 2.35 screen Golden Ear Triton 5 L&R
super center XXL triton 7's sides Emotiva T1 rears
4 RSL C34 in ceiling SVS PB2-plus sub SVS PC13 ultra sub
dan webster is online now
post #6807 of 7115 Old 11-17-2019, 01:17 PM
descalabro's Avatar
Quoted: 500 Post(s)
Liked: 193
You can fold velvet, no problem at all. Mine has been folded and unfolded several times before I finally installed it.
post #6808 of 7115 Old 11-17-2019, 01:33 PM
andyng's Avatar
Quoted: 44 Post(s)
Yeah, fold it up and put in an amazon box would be the easier way. I don't think it would take much space. I can provide a mailing label.
andyng is offline
post #6809 of 7115 Old 11-17-2019, 01:40 PM
biglen's Avatar
Quoted: 591 Post(s)
Liked: 109
Let's move this chat to PM. I don't want to clog the thread with our personal conversation.
andyng and skylarlove1999 like this.
biglen is offline
post #6810 of 7115 Old 11-17-2019, 03:07 PM
Quoted: 89 Post(s)
Liked: 37
Just got a KANE Supernova Black....Oh my god....this has to be most comfortable carpet I have ever put my feet on.....Not cheap ($10-$11/sf through any dealer outside of Georgia)....but if you order from a dealer around Dalton, GA, even with shipping to your place it will end up being closer to $6.5/sf.
Speakers: L/C/R: Ascend Sierra Towers (Raal) / Ascend Horizon (Raal) Subwoofers: 2 x JTR Captivator 2400ULF Surrounds: Revel S16(4) / Atmos: RSL C34e (4)
Video: JVC RS2000, Lumagen 4444, 132.8" SeymourAv 2.40:1 with dual roller masking to 16:9
Other: Anthem AVM60 / DSonic M3a 2800-7 / Crown XLS 1002 (2) / Kaleidescape Strato S, XBOX One X, ATV4k, UB820, Elan G1, 2x GC-100-18R
crg28 is offline
Epson 5020ub Powerlite Home Cinema 3d Front Projector , Mitsubishi , Panasonic Blu Ray Disc Player Dmp Bd30k
