The Blacker the Theater, The Better the Image - Page 240 - AVS Forum | Home Theater Discussions And Reviews
 3731Likes
post #7171 of 7688 Old 02-22-2020, 08:47 AM
tebling's Avatar
Quoted: 200 Post(s)
Liked: 320
I just painted my room with Behr Marquee Flat Black. I tried the Rosco TV Black, and even with a healthy proportion of Rosco acrylic glaze mixed in, the scuffing was just too much. It's quite a small room, so I expect a lot of inadvertent bumping into walls. The Behr is certainly more reflective, but color wise it's very close to the Rosco and doesn't scuff nearly as easily.
I'll eventually do velvet panels near the screen, and expect that to get close to the point of diminishing returns.
More details and photos in this post on my build thread.
tebling is offline
post #7172 of 7688 Old 02-22-2020, 08:59 AM
Buddylee123's Avatar
Quoted: 926 Post(s)
Liked: 631
Originally Posted by rboster View Post
I'm in the same boat and agree with your take on Century paint. I have a couple of gallons. I'll be painting my screen wall with Century.
What are member's thoughts on using Century for baseboards and doors? I'll be painting the ceiling with Benjamin Moore Waterbourne Ceiling paint in black and BM interior in gray for the other walls.
Benjamin Moore Century in Obsidian for trim/doors?
I definitely would not do baseboards in the Century, they receive too much abuse. The door you might get away with but it’s really not recommended either. My baseboards are wood so I used some black stain on them and they are as dark as my black ceiling and front wall. They are more shiny but where they are located and due to their size they don’t cause any problems and they look great.
rboster likes this.
Buddylee123 is online now
post #7173 of 7688 Old 02-22-2020, 09:33 AM
skylarlove1999's Avatar
Quoted: 2276 Post(s)
Liked: 2431
Originally Posted by Rob Greer View Post
I just want you guys to know that after finally “finishing“ my home theater I found this thread. And so I started over. You guys are costing me a **** ton of money and time. Thanks so much. Not really.
Benjamin Moore Obsidian coming soon to a theater near you.
I looked really hard at velvet, but because of acoustical concerns, fit and finish concerns, and cost concerns to do it right (velvet wallpaper), I felt that painting was my best option.
I've heard fantastic things about the obsidian paint can't wait to see yours I'm sure it will be so worth it
Sent from my SM-G965U using Tapatalk
skylarlove1999 is offline
post #7174 of 7688 Old 02-22-2020, 12:39 PM
Moderator
rboster's Avatar
Quoted: 1836 Post(s)
Liked: 2776
I've been following the Little Black Box build thread. Really terrific job. I'm taking notes.
tebling and skylarlove1999 like this.
rboster is online now
post #7175 of 7688 Old 02-22-2020, 02:03 PM
blake's Avatar
Quoted: 1036 Post(s)
Liked: 155
I am painting everything - walls , ceiling , baseboard , door trim with BM Century Obsidian.
blake is offline
post #7176 of 7688 Old 02-22-2020, 03:13 PM
tebling's Avatar
Quoted: 200 Post(s)
Liked: 320
Thanks Ron, this made my day! Ceiling speaker update coming soon
tebling is offline
post #7177 of 7688 Old 02-22-2020, 05:01 PM
Dave Vaughn's Avatar
Quoted: 1930 Post(s)
Liked: 2955
I wouldn't recommend the doors and trim. It's very close to a flat finish, which doesn't perform well on those substrates. I'd use a satin sheet at a minimum.
David Vaughn Blu-ray Reviewer / Technical Writer Sound & Vision Magazine (Print & Online)
Dave Vaughn is online now
post #7178 of 7688 Old 02-22-2020, 06:25 PM
blake's Avatar
Liked: 155
So satin on the door itself (as well as casings around it ) and baseboards?? What do you mean flat wouldn’t perform well on these areas ?
blake is offline
post #7179 of 7688 Old 02-22-2020, 10:21 PM
Liked: 2955
Flat paint (sheen wise) burnishes easily. Doors are considered "medium abuse" substrates and should have a more durable finish on them such as a satin or semi-gloss trim paint. Given it's a theater, the lower the sheen the better, hence the satin sheen. Benjamin Moore's Scuff-X Satin works great...it's what I have in my house on doors and trim. The store should be able to match the Obsidian to get it pretty close to the factory color (although not exact). Given the sheen difference between the two, that shouldn't matter too much.
post #7180 of 7688 Old 02-22-2020, 11:59 PM
blake's Avatar
Liked: 155
I see Scuff-X also comes in “matte”. Would this be better than satin for a theater, or are you sacrificing the durability with matte ? (It’s still called Scuff-X though !)
blake is offline
post #7181 of 7688 Old 02-23-2020, 09:29 AM
Liked: 2955
The matte would be more durable than the Century, but less durable than the satin. What you'll get mostly is fingerprints in the paint (the most common abuse of doors), that don't clean off as easily on a lower sheen product. When you go to wipe them off, it "may" burnish. In order to make a flatter finish, you need to scatter the light coming in, so if you look under a microscope at a flat (or matte) paint, the film looks like a mountain range with lots of peaks and valleys. So when dirt or grime gets on the substrate and you go to wipe is off (or scrub it!), you end up removing the peaks causing it to burnish and it raises the side-sheen of surface.
A higher sheen product doesn't have as vast of difference between the peaks and valleys, which is why they clean easier and have better scrub resistance. High gloss products look like the salt flats of Utah
Hopefully this helps.
rboster likes this.
post #7182 of 7688 Old 02-23-2020, 12:23 PM
blake's Avatar
Liked: 155
Super helpful, thanks. Do you think baseboard and doors in a (fully light controlled) theater with Scuff X satin will raise the light floor (from generalized reflection of ambient screen light ? )
blake is offline
post #7183 of 7688 Old 02-23-2020, 12:25 PM
Liked: 2955
Not by any appreciable measure. I do have my front wall covered in velvet to cover the paint My ceiling is black (same product as Rbooster) and while it isn't as dark as the velvet, it's far removed from my screen so the reflections are minimal.
post #7184 of 7688 Old 02-23-2020, 06:21 PM
Mike Garrett's Avatar
Quoted: 14011 Post(s)
Liked: 11684
Two reasons:
1) Cost
2) Next year or the year after, I'll be building a false wall for the screen and fabric panels for the other walls...so saving up and this will be a short term version of the theater.
Since selling our previous home (with the HT), I've been without a theater for a year...so I want to get it up and running with a 1.0 version. 2.0 will have a professional build out based on plans prepared by Shawn Byrne of Quest Acoustics.
A year without a theater. I am sure you are itching to get up and running again.
Mike Garrett is online now
post #7185 of 7688 Old 02-23-2020, 06:54 PM
Moderator
rboster's Avatar
Liked: 2776
I'm a rudderless ship. I'll be calling to tomorrow to set my ship ashore.
Mike Garrett likes this.
post #7186 of 7688 Old 02-26-2020, 06:45 PM
blake's Avatar
Liked: 155
Just got word from my painter that Benjamin Moore Century line of paints is discontinued in Canada because of “cost and durability” issues. So no Obsidian for the HT as planned (walls, ceiling).
So my next choice will probably be Rosco Video Black. I will have to accept how easily is scuffs. I am a little worried because it seems complicated to apply (based on reading this thread!) and I doubt my painter has experience with it. You don’t just roll it on from the can ? Dilute with water ? What ratio ? There doesn’t seem to be consensus.
blake is offline
post #7187 of 7688 Old 02-26-2020, 06:56 PM
Liked: 2431
Sorry to hear this Blake. That really stinks. @jorgebetancourt maybe you could help Blake with some tips for Rosco TV Black. Thanks in advance for your expertise. @Killroy did an amazing job with Rosco TV Black as well. Maybe he could share some best practices. Thanks in advance for your time.
post #7188 of 7688 Old 02-26-2020, 08:15 PM
Killroy's Avatar
Quoted: 779 Post(s)
Liked: 763
I did mine in Rosco Super Sat.
Killroy is offline
post #7189 of 7688 Old 02-26-2020, 08:33 PM
dlinsley's Avatar
Quoted: 706 Post(s)
Liked: 566
Similarly I used Benjamin Moore Advance Black (already black in the can) in satin finish for my baseboards, and they've taken a good beating from the vacuum cleaner but still look perfect six months later: https://www.avsforum.com/forum/19-de...l#post58524506
dlinsley is online now
post #7190 of 7688 Old 02-26-2020, 09:57 PM
Liked: 2955
That's a great choice as well. It is a little harder to apply (have to wait about 18 hours for the second coat, but it's very durable.
post #7191 of 7688 Old 02-27-2020, 04:26 AM
Quoted: 830 Post(s)
Liked: 441
give me a few hours and I'll reply
Sent from my SM-G930T using Tapatalk
jorgebetancourt is online now
post #7192 of 7688 Old 02-27-2020, 05:17 AM
Liked: 2431
Thank you both. Greatly appreciated
post #7193 of 7688 Old 02-27-2020, 12:26 PM
Quoted: 830 Post(s)
Liked: 441
Hi Blake..
I don't regret mines one bit but I do take care of the room and I do tell the kids to take care of the walls.. Anyhow I did the ceiling and the back of the screen straight from can but make sure to blend the cans good their can be some clumping on the bottom from sitting too long on the shelves.. Crawn molding can be straight from can but baseboards and doors do need to be semigloss or eggshell..
For the side walls I believe I mixed 6 cups of clear acrylic flat per gallon of tv black but u can do 4 cups.. Once u paint the back wall behind the screen then you'll see how cool this paint is.. it's absolutely amazing..
For scuffs it's not that bad now.. the trick is to use a damp towel and just tap it or a dry paint brush and brush them away.. The dry paint brush works perfectly..
I'll call my painter in a few and get back on how to paint but it wasn't difficult at all..
post #7194 of 7688 Old 02-27-2020, 12:39 PM
Quoted: 830 Post(s)
Liked: 441
Ok I just spoke to the painter. He says cut one wall at time and do paint one wall at a time from one side to the other without stoping.. Meaning, dont stop for half and hour and come back or you will see a streak when it drys. You do have to paint fast as it drys fast but do not worry is not hard you will figure it out after your first wall.
He said to buy a thick roller he's was 3/4 so it can hold lots of paint.
Again finish one wall before moving on to the next.. Your going to love it, I know black is a scary at first but when you finish you'll have the dopest room around..
post #7195 of 7688 Old 02-27-2020, 02:43 PM
Liked: 2431
Hi Blake..
Thank you as always. I greatly appreciate your participation and knowledge in this thread especially when it comes to painting.
post #7196 of 7688 Old 02-28-2020, 12:47 AM
blake's Avatar
Liked: 155
Thanks for that ! I have forwarded to my painter ! Not sure I will add the acrylic though.. do you think you can carefully clean off scuff marks from the pure TV Black paint?
blake is offline
post #7197 of 7688 Old 02-28-2020, 05:38 AM
JamesVG81's Avatar
Quoted: 127 Post(s)
Liked: 78
Wondering if any one has a recommendation for carpet? I’m going to velvet walls and ceiling for the first 9-12 foot of the theater. If need be I’ll do the first few feet of the floor also with something I can move if I need to work on something. Seen people wrap the those foam work out tiles with velvet. My old theater I had done the first 6 foot with velvet ceiling and walls. I want to go far enough back that it takes up the first rows line of sight. Trying to find some decent carpet that doesn’t cost an arm and a leg. Thanks for any help.
JamesVG81 is offline
post #7198 of 7688 Old 02-28-2020, 02:29 PM
dbpaddler's Avatar
Quoted: 200 Post(s)
Liked: 130
My room is 12x12. I picked up a black shag carpet on overstock. It does the trick. Seems wall to wall width wise and stops at the back of my sofa. I don't think people are as picky with carpet as they are about their velvet.
On a side note, Sherwin Williams has 30% off right now with a $10 off 50 coupon too.
https://www.sherwin-williams.com/hom...es-and-coupons
https://www.sherwin-williams.com/spe...special-offers
Forget what paint people recommended from there, but I wanted to throw it out there.
Sent from my SM-N975U1 using Tapatalk
JamesVG81 likes this.
dbpaddler is offline
post #7199 of 7688 Old 02-28-2020, 03:19 PM
descalabro's Avatar
Quoted: 524 Post(s)
Liked: 216
I don’t have an actual carpet, I use a roll of black felt with some kind of rubber on the underside. Does the job, easy to move and easy to vacuum clean. Also relatively cheap.
4,3 x 2,8m semi-blacked out media room | 2010 MacMini > Pioneer VSX-520-K > JVC RS50 (X7) > 107", 1.1 gain, white screen | JVC X30 (RS45)
descalabro is offline
post #7200 of 7688 Old 03-02-2020, 08:30 AM
Nexgen76's Avatar
Quoted: 821 Post(s)
Liked: 235
Okay, I just wanted to know how these would work verse using staples adding velvet to my front stage?
https://www.amazon.com/decotacks-Bla...DN9P3A9054KA1Z
JVC NX5 | Panasonic UB420| PC Madvr
Elite Screens Aeon Series 135 inch CineWhite
Aggressive 1299 L/C/R/ |JBL 8350 surrounds x 4 |JBL SCS8 Atmos x 4
Anthem AVM 60| Crown XLS 1502 X 2| Crown XLS 1002 x 4
GSG Devastator x 3 | Sinbosen FP20000q
Nexgen76 is offline
Epson 5020ub Powerlite Home Cinema 3d Front Projector , Mitsubishi , Panasonic Blu Ray Disc Player Dmp Bd30k
