The Blacker the Theater, The Better the Image - Page 243 - AVS Forum | Home Theater Discussions And Reviews
 3343Likes
post #7261 of 7292 Old 03-16-2020, 12:17 PM
Liked: 0
Is it pitch black
Jay_514 is offline
post #7262 of 7292 Old 03-16-2020, 12:31 PM
Moderator
rboster's Avatar
Quoted: 1729 Post(s)
Liked: 2527
Originally Posted by Jay_514 View Post
Is it pitch black
Those pictures are from this weekend, so you can see I don't have a projector or screen mounted...it's hard for me to comment on room performance without those items.
rboster is online now
post #7263 of 7292 Old 03-16-2020, 01:40 PM
Liked: 0
Your screen to wall ratio is small....so wont make a big difference my screen covers my entire wall so the side walls floor ceiling reflection is alot
Jay_514 is offline
post #7264 of 7292 Old 03-16-2020, 03:46 PM
Moderator
rboster's Avatar
Liked: 2527
What size of screen are you using?
post #7265 of 7292 Old 03-16-2020, 06:40 PM
Mike Garrett's Avatar
Quoted: 13494 Post(s)
Liked: 11128
A lamp and hand puppets on the wall.
Mike Garrett is online now
post #7266 of 7292 Old 03-16-2020, 07:13 PM
dbpaddler's Avatar
Quoted: 173 Post(s)
Liked: 116
That is cheap. It's $6.65 right now with the clippable 50% off. Could tack that up on the ceiling.
Sent from my SM-N975U1 using Tapatalk
dbpaddler is offline
post #7267 of 7292 Old 03-16-2020, 07:20 PM
Liked: 0
135 inch you?
Jay_514 is offline
post #7268 of 7292 Old 03-17-2020, 05:20 AM
Moderator
rboster's Avatar
Liked: 2527
135 inch you?
125" Diagonal 2.35:1 Scope screen
Image Dimensions: 115" x 49"
Outside Dimensions: 122" x 56"
post #7269 of 7292 Old 03-17-2020, 06:21 AM
Rob-Houston's Avatar
Quoted: 145 Post(s)
Liked: 98
THAT looks like a post I would have made!!!!
rboster and Mike Garrett like this.
Rob-Houston is offline
post #7270 of 7292 Old 03-17-2020, 09:54 AM
Liked: 0
You think microvelvet 5000 which is polyestor will absorb light as much as triple velvet from syfabrics?
Jay_514 is offline
post #7271 of 7292 Old 03-17-2020, 10:54 AM
Quoted: 159 Post(s)
Liked: 59
Have you tried a sample of both? I don't recall hearing about micro velvet 5000. Polyester you would think doesn't work as well but maybe try it out.
Hawks07 is offline
post #7272 of 7292 Old 03-17-2020, 12:15 PM
Liked: 0
I did small piece is triple velvet
Jay_514 is offline
post #7273 of 7292 Old 03-24-2020, 04:49 PM
Liked: 0
So I've been trying to research this as I'm at the step in my home theater build where I want to attach velvet/make room treatments. I read most of this thread and looked elsewhere but I still don't understand, is there basically a compromise that has to be made between making sound absorption treatments and making the room as dark as possible? I already ordered a 30 yard bolt of triple black velvet from syfabrics. I am planning to put a black rug down on top of the laminate in my room, but I can't simply put acoustic panels on my drywall on the side/front/ceiling and then cover them in velvet right? The velvet will block some of the absorption? So is the only optimal thing to do is to cover the walls with velvet, then just deal with the panels by nature being less dark? If that's the case, what's the darkest ready made panel? I'm not very diy handy so I'd rather just purchase them if possible. Also, if I staple the velvet I bought to the drywall, will that be adequate or will there possibly be mold?
vrtuazoso is offline
post #7274 of 7292 Old 03-24-2020, 08:40 PM
ScottAvery's Avatar
Quoted: 856 Post(s)
Liked: 247
Frankly, you can cover the panels in velvet and it will still sound better than without, but if you want a more ideal solution you have to pay 3-4 times the price for acoustically transparent velvet, only available for import:
https://www.whaleys-bradford.ltd.uk/...-black-devore/
If you can staple velvet on a wall you can staple it on a diy panel.
ScottAvery is offline
post #7275 of 7292 Old 03-26-2020, 05:49 PM
tonybradley's Avatar
Quoted: 549 Post(s)
Liked: 231
Velvet is fine. You do not need acoustically transparent fabric for Absorption Panels. You need that when covering speakers. Velvet will absorb really high frequencies before the sound is absorbed by the Fiberglass Panel. With Acoustically Transparent Fabric, it won't, but will once it hits the Panel. So it's a wash. You just don't want to use fabric that is reflective. Velvet is just fine. I use it in my room. No difference than when I originally had Acoustically Transparent fabric covering them.
tonybradley is offline
post #7276 of 7292 Old 03-29-2020, 08:15 PM
It looks really cool, black panels make image more clear.
Vankyo is offline
post #7277 of 7292 Old 04-02-2020, 11:25 AM
Quoted: 95 Post(s)
Anyone have experience with the triple black velvet being sold on Amazon right now by seller luvfabrics? The other option is FABRIC BRAVO but their approval rating on Amazon is only 82%.
Considering both of these as well as SyFabrics (more expensive but the most proven, it seems) as well as ifabric.com.
Pioneer SC-LX801 | Xbox One X | Rega P3 Turntable | Anthony Gallo Reference 3.1 L/R, Reference Strada C | RSL CG3 surrounds | 4x RSL C34E Atmos in-ceilings | HSU VTF-3 MK5 subwoofer | Panasonic PT-AE3000U projector | Elite Screens 120" drop-down | Pioneer Kuro KRP-500m
Northern_Lights is offline
post #7278 of 7292 Old 04-02-2020, 11:39 AM
Quoted: 159 Post(s)
Liked: 59
Fabric Bravo is the one you want from Amazon. I as well as many others here have bought from them with great success.
Hawks07 is offline
post #7279 of 7292 Old 04-02-2020, 12:13 PM
lizrussspike's Avatar
Quoted: 1446 Post(s)
Liked: 2162
Ditto to what @Hawks07 said. Works great in my room.
Northern_Lights likes this.
lizrussspike is offline
post #7280 of 7292 Old 04-03-2020, 06:37 AM
bungi43's Avatar
Quoted: 72 Post(s)
Liked: 31
If you go back to the quote I linked above you'll see before and after photos of the room. All the paint is from Benjamin Moore. The front wall uses their Century paint which is high end and matte finish in black. All other walls are gray BM regal paint. The doors and baseboard uses Scuff X in black. The ceiling is painted with BM Waterbourne in flat black. I have not incorporated black velvet yet, as I did in the previous HT/Home. At this point, I don't plan on it. When we do the full build out in 12-24 months, the room will incorporate black fabric panels on all the walls and a front false wall.
This iteration of the theater is all DIY, so the LCR speakers will stand in front of the screen wall (vs behind a false wall). The side speakers will in in-wall with black grills. All acoustic panels will be in black and mounted on the walls/corners/ceiling vs the build out will have acoustic treatments behind the black fabric panels.
When you get to your full build out, with your previous water issues, are you going to address those?
I don't know the dimensions of your basement, but I had similar issues. I had water once from a sump pump issue (which I address), but then I had it a second time as seepage. And unless you address that issue, it will never get better on its own, only worse.
While it wasn't cheap, I ended up trenching my basement 4 years ago. Best money I spent on my house. I've not had a drop of water since. I don't worry about my HT stuff any longer.
bungi43 is online now
post #7281 of 7292 Old 04-03-2020, 06:52 AM
Moderator
rboster's Avatar
Liked: 2527
That maybe the next step we take. Here's what we did:
Six inch gutters and larger down spouts
Gutter covers (not mesh, but actually covers-no issues with leaves during fall of the covers)
French drains at least 15ft from the house
Regrading the entire back yard (biggest diff)
Upgraded sump pump (the builder grade one wasn't even piped away from the house ...so water pumped right back to just outside the foundation)
trenched along the back of the house where the real issues were happening
Pond lined landscaping around the house with river rock vs mulch for ground cover with shrubbery.
For the theater side, we had two places where water was trickling in. This issue was a result of gutters being full of leaves and water over flowing to those two points at the two corners in the front of the house. We hadn't moved into the house but had ownership...so once I cleaned the gutters we haven't had any issues (we expanded those gutters, french drains, gutter covers and pond lined landscaping along the front of the house any way).
But, as you can see in the area where the trickles happened, instead of carpet, I covered the floors in black epoxy. For comfort, design and acoustical concerns; I have area rugs over the epoxy floors. If the same issue arose on that side, I'd be dealing with drying out the area rug(s) and cleaning the epoxy floor. Additionally, we use PVC baseboards too.
My reason for saying a build out in a year or more is we want to have at least two seasons under our belt before we invest in the build out. That being said, you maybe right and we add the cost of trenching around the entire house or at least the front side.
Dave Vaughn likes this.
post #7282 of 7292 Old 04-03-2020, 10:08 AM
biglen's Avatar
Quoted: 687 Post(s)
Liked: 136
I used the one from luvfabrics. I'm VERY happy with it. The reviews are great too. Is this the one from Fabric Bravo?
https://www.amazon.com/dp/B0759QS16T..._x92HEbQK67PB1
I'm not seeing any reviews that talk about using it for their movie room. The one from luvfabrics has a ton of reviews about using it for a movie room.
Sent from my SM-N975U using Tapatalk
biglen is offline
post #7283 of 7292 Old 04-04-2020, 10:09 AM
Quoted: 95 Post(s)
Based on the responses from the other posters, I bought the one from Fabric Bravo. I looked at some of their recent negative reviews; most involved shipping times and were crossed out by Amazon saying that the problem was not the fault of the seller. Those reviews are for all the fabrics they sell though, so here's hoping that I get what I'm expecting.
post #7284 of 7292 Old 04-04-2020, 10:25 AM
biglen's Avatar
Quoted: 687 Post(s)
Liked: 136
Did you order the velvet that is in the link I provided? It just says black velvet, not triple black velvet. Good luck though!
biglen is offline
post #7285 of 7292 Old 04-04-2020, 05:52 PM
skylarlove1999's Avatar
Quoted: 1710 Post(s)
Liked: 1446
Fabric Bravo. Sometimes they don't ship when they say they should which is the reason for the 82 but the velvet is triple black at a great price.
Sent from my SM-G965U using Tapatalk
Tristan Jones
skylarlove1999 is online now
post #7286 of 7292 Old 04-04-2020, 10:45 PM
Quoted: 95 Post(s)
Nope, bought it at this link https://www.amazon.com/Black-Triple-...6065516&sr=8-1
post #7287 of 7292 Old Yesterday, 05:22 AM
biglen's Avatar
Quoted: 687 Post(s)
Liked: 136
That's the luvfabrics that I bought. I thought you wanted the Fabric Bravo?
biglen is offline
post #7288 of 7292 Old Yesterday, 09:03 AM
Fredstwofeet's Avatar
Quoted: 31 Post(s)
Liked: 9
Send a message via AIM to Fredstwofeet
The velvet on the walls is from Joann Fabric https://www.joann.com/royalty-3-velv...velvet&start=1. For reference the corner bass traps are painted with Rosco video paint. The velvet around the screen is Infinite black (Seymour)
ID:	2706146   Click image for larger version
Fredstwofeet is offline
post #7289 of 7292 Old Yesterday, 09:08 AM
pitchcut29's Avatar
Quoted: 27 Post(s)
Liked: 38
Great work! What screen do you have? Are those manual or motorized masking panels?
Main: 3 x JTR 212RT | Surrounds: 2 x JTR 210HT | Subwoofer: 1 x JTR Captivator 4000ULF-LP
Amplifier: DAC 5-Cherry | Processor: Emotiva XMC-1 | Projector: JVC DLA-NX7 | PJ Screen: SeymourAV 150" 16:9 Center Stage XD
pitchcut29 is online now
post #7290 of 7292 Old Yesterday, 11:09 AM
Quoted: 95 Post(s)
I changed the seller to Fabric Bravo.
biglen likes this.
Epson 5020ub Powerlite Home Cinema 3d Front Projector , Mitsubishi , Panasonic Blu Ray Disc Player Dmp Bd30k
