The Blacker the Theater, The Better the Image - Page 252 - AVS Forum | Home Theater Discussions And Reviews
 3731Likes
post #7531 of 7688 Old 05-24-2020, 06:12 AM
genaccmiller's Avatar
Quoted: 1055 Post(s)
Liked: 293
Originally Posted by dbpaddler View Post
Thinking on a ceiling it might be a nice option to just frame out the covered area and stretch it over. Would be a lot easier to work with than velvet and you wouldn't have any sag. For me, my room is 12' wide. So I could buy four yards and cover the width and go five or six feet deep with it. Could run some sort of trim piece across to make it look nice and neat.
Joann's has 60% off right now and it's 11.99 a yard at regular price. Cheapest on Amazon is 8.99/yd I believe.
Sent from my SM-N975U1 using Tapatalk
I bought psy fabrics triple black velvet. It shows at $8.50.
https://syfabrics.com/products/plush-triple-velvet1
Sent from my GM1917 using Tapatalk
Step by Step Theater Build - http://imgur.com/gallery/2tpaSru
My Theater Build Youtube Channel - https://www.youtube.com/channel/UCs_..._as=subscriber
My Theater Build Thread - https://www.avsforum.com/forum/19-de...ld-thread.html
genaccmiller is offline
post #7532 of 7688 Old 05-24-2020, 06:12 AM
robbyc30's Avatar
Quoted: 29 Post(s)
Originally Posted by genaccmiller View Post
I used spandex for my left and right panels and triple black velvet for top and bottom and two narrow lines of triple black velvet on left and right between spandex and screen so that it creates a box of black velvet. The following pictures show the screen as well as how it looks when the light is off. It is dark but not black. I have also attached some pics when light is on.
Thanks for those pics. Anybody have pics of alternate fabrics on side walls? Maybe showing screen reflectivity?
robbyc30 is online now
post #7533 of 7688 Old 05-24-2020, 06:13 AM
Liked: 293
Originally Posted by SteveCallas View Post
They make stretch velvet, I still have a small sample. If you stretch it too much though, you create voids between the threads that let light through. So you would likely have to wrap every panel twice with the fabric being stretched in a different direction on each layer.
If you pull normal velvet tight and staple it in place, you will not get any bubbles, it will stay perfectly flat and smooth. Adhesive tape will not hold velvet very taught.
Or you could wrap one layer of spandex and then wrap triple black velvet on top of it.
post #7534 of 7688 Old 05-24-2020, 06:13 AM
dbpaddler's Avatar
Quoted: 200 Post(s)
Liked: 130
Can use furring strips and fold the ends over. Use a nail gun to secure.
dbpaddler is offline
post #7535 of 7688 Old 05-24-2020, 06:23 AM
dbpaddler's Avatar
Quoted: 200 Post(s)
Liked: 130
Think the point with the spandex though is the stretch and no sag or wrinkles.
post #7536 of 7688 Old 05-24-2020, 11:46 AM
Luminated67's Avatar
Quoted: 1241 Post(s)
Liked: 1044
Not sure what velvet stuff fixed frames are covered with but I took a quick photo of my self adhesive stuff side my fixed frame screen.
I unfortunately bought the crushed finish instead of plain which based on looking what I’m seeing if I had bought the plain would look identical to the frame itself.
Btw the real black you see in the image is shadow not part of the frame.
Epson EH-TW9400 - QualGear Fixed Frame 100” - Sony x700 BRP & Panasonic 420 BRP - Sony 1080 AVR - IPL Acoustics M1TLs & IPL Acoustics AVC Pro Centre, Four KEF surrounds & 2 Sub boxes (10” Sub + 10” Passive Radiator)
Movie Image collection
Luminated67 is offline
post #7537 of 7688 Old 05-24-2020, 05:33 PM
Jive Turkey's Avatar
Quoted: 658 Post(s)
Liked: 644
I went to a Joanne's in Salinas, Ca. for the first time to see what they had in stock in velvet and spandex. They did have Royalty 3 black velvet in stock at a whopping $20/yard, didn't find any spandex.
They weren't allowing more than 20 in the store at once, and a line outside behind me developed. It was almost like the old Roach Motel commercial, they go in but don't come out!
Low Profile and BobbyColtrane like this.
See ya. Dave
"The Blues ain't nothin' but a botheration on the mind." Otis Spann
Jive Turkey is offline
post #7538 of 7688 Old 05-25-2020, 06:26 AM
dbpaddler's Avatar
Quoted: 200 Post(s)
Liked: 130
Buy it online for store pickup. They have a memorial day coupon for 50 or 60% off.
skylarlove1999 and Sekosche like this.
post #7539 of 7688 Old 05-25-2020, 06:38 AM
lizrussspike's Avatar
Quoted: 1564 Post(s)
Liked: 2421
That's what I did @dbpaddler , and got 2 yards.
lizrussspike is offline
post #7540 of 7688 Old 05-25-2020, 06:58 AM
dbpaddler's Avatar
Quoted: 200 Post(s)
Liked: 130
Nobody pays full price there. Joanns, AC Moore and the like are like Joseph A Banks where regular prices are absurd, and you only buy there with the big coupons.
post #7541 of 7688 Old 05-25-2020, 09:33 AM
Sekosche's Avatar
Quoted: 1551 Post(s)
Liked: 3954
Thanks for mentioning this! I ordered a bolt just now for only $65 after the 60% off and the 10% off for a 10 yard minimum. The SY triple black arrives tomorrow, but I can get started on a few areas today.
dbpaddler and skylarlove1999 like this.
Speakers: PSA MTM-210T x2, MTM-210C, Volt-10 x2
Subs: PSA S1812 x2; MA’s: Crowson x2
Processing: Denon X4200, MiniDSP 2x4 HD
PJ: Epson 5050UB
Screen: Silver Ticket 106" HC
Sekosche is online now
post #7542 of 7688 Old 05-26-2020, 04:40 PM
Moderator
rboster's Avatar
Quoted: 1836 Post(s)
Liked: 2776
Here's some updated photos from my Quarantine project. I've added acoustic treatments, commando cloth covered panels to the ceiling above the screen wall. I also have a second row platform. Now I just need to find some HT seating and install the second row in-walls speakers. That should cover the DIY version of the HT. Version 2 will be in a couple of years.
And.....I still have to patch the hole I created in the ceiling to run the speaker wire across the room Waiting to see if I need to cut a hole for the other speaker run as well....might as well patch two at the same time.
ID:	2732872   Click image for larger version
ID:	2732874   Click image for larger version
ID:	2732876   Click image for larger version
ID:	2732878   Click image for larger version
ID:	2732882   Click image for larger version
FS: RUIPRO 8K Fiber DisplayPort Cable 33 feet : https://www.avsforum.com/forum/211-a...d-support.html
rboster is online now
post #7543 of 7688 Old 05-26-2020, 05:17 PM
Dave Vaughn's Avatar
Quoted: 1930 Post(s)
Liked: 2956
Looks outstanding. Great work.
David Vaughn Blu-ray Reviewer / Technical Writer Sound & Vision Magazine (Print & Online)
Dave Vaughn is offline
post #7544 of 7688 Old 05-26-2020, 06:56 PM
Moderator
rboster's Avatar
Liked: 2776
Thanks Dave.
I will say one thing. I hired someone to put down a black epoxy coating on the concrete. The bad part is it shows EVERYTHING. I was reminded of that because in the first pic you can see I wet mopped that portion of the floor. I need to find something that will do a good job of cleaning the black epoxy.
post #7545 of 7688 Old 05-26-2020, 06:57 PM
skylarlove1999's Avatar
Quoted: 2276 Post(s)
Liked: 2431
Like the riser and the cool film reel side table. It all came together so beautifully.
Sent from my SM-G965U using Tapatalk
rboster and Luminated67 like this.
skylarlove1999 is offline
post #7546 of 7688 Old 05-26-2020, 07:08 PM
Moderator
rboster's Avatar
Liked: 2776
Thanks very much Sky. I made the tables. Here's a thread about the project:
https://www.avsforum.com/forum/32-th...eel-table.html
Below is a better image of the table from our previous house
Name:	Film Reel Table.jpg
post #7547 of 7688 Old 05-26-2020, 07:20 PM
Liked: 2956
Thanks Dave.
I will say one thing. I hired someone to put down a black epoxy coating on the concrete. The bad part is it shows EVERYTHING. I was reminded of that cause in the first pic you can see I wet moped that portion of the floor. I need to find something that will do a good job of cleaning the black epoxy.
Try a Swifter....no guarantee, but it's worth a shot.
rboster and skylarlove1999 like this.
post #7548 of 7688 Old 05-26-2020, 07:46 PM
Mocs123's Avatar
Quoted: 628 Post(s)
Liked: 413
Did you make or buy the five diffuser panels on the back wall?
7.4.4 Theater Room: JVC-RS500, Silver Ticket AT 2.35:1 142”, Onkyo RZ830, Anthem PVA-7, Panasonic UB420, Apple TV 4K, JBL Studio 530’s, Dual Driver VBSS
3.1 Living Room: Samsung 64” F8500 Plasma, Anthem MRX 300, Dynaudio Audience 52’s, Dynaudio Audience 122C, NHT SubOne, Roku Express (2019)
Mocs123 is online now
post #7549 of 7688 Old 05-27-2020, 01:57 AM
Moderator
rboster's Avatar
Liked: 2776
The panels on the back wall are from GIK Acoustics. They are their Alpha 6 panels with a two way dispersion plates on the front of the panel.
https://www.gikacoustics.com/product...usor-absorber/
Also In the same picture are their tri corner bass traps with internal range limiters. The GIK bass traps are on the left side.
https://www.gikacoustics.com/product...tics-tri-trap/
The two plain panels below the alphas and wall mounted near the door are bass traps from acoustimatic
I've added a picture where you a better see the tri-corner bass traps
post #7550 of 7688 Old 05-27-2020, 06:05 AM
Quoted: 34 Post(s)
Liked: 34
Nice!!
Reezepees is offline
post #7551 of 7688 Old 05-27-2020, 06:07 AM
biglen's Avatar
Quoted: 1043 Post(s)
Liked: 372
If you'd like to make your own, here's an entire thread about building them. I made 6, and they are super easy.
https://r.tapatalk.com/shareLink/top...ink_source=app
DIY Custom-Printed Movie Poster Acoustic Panels - cheap!
Sent from my SM-N975U using Tapatalk
biglen is online now
post #7552 of 7688 Old 05-27-2020, 07:57 AM
biglen's Avatar
Liked: 372
I'm slowly but surely blacking out my room. The one thing I haven't done yet, is darkening the carpet. This is the current color, so how much of a difference would a black carpet make with my Epson 5050ub? It would probably cost me around $600 to change the carpet to black. Would I see a $600 difference?
post #7553 of 7688 Old 05-27-2020, 08:03 AM
Liked: 1044
Believe it or not a huge black shag pile rug will do the same thing without replacing the carpet.
skylarlove1999 likes this.
post #7554 of 7688 Old 05-27-2020, 08:56 AM
tigerhonaker's Avatar
Quoted: 1069 Post(s)
Liked: 1321
Lightbulb
Here is what I did and it's a Major IMPROVEMENT !!!
Roll the page down ..............
https://www.avsforum.com/forum/15-ge...l#post58873896
And .................
https://www.avsforum.com/forum/15-ge...l#post58898080
Trust me it's inexpensive and WORKS .............
Terry
tigerhonaker is offline
post #7555 of 7688 Old 05-27-2020, 09:18 AM
dbpaddler's Avatar
Quoted: 200 Post(s)
Liked: 130
What luminatrd said. Keep that rug there and just get a black area rug that goes full width. Check out wayfair, overstock and the like. Use coupons too.
Right now what it's done is make reflections off of my speakers stand out. Keep forgetting to cover them. That and the ceiling are the only things left in my room to deal with.
post #7556 of 7688 Old 05-27-2020, 10:34 AM
Liked: 2431
The difference you see by adding the carpet it is in proportion to how close your images to the floor the image is close to the floor you definitely are going to see a noticeable difference I can't tell you it'll be a $600 difference but it will be noticeable
tigerhonaker likes this.
post #7557 of 7688 Old 05-27-2020, 11:39 AM
Quoted: 830 Post(s)
Liked: 441
Any black will make a huge impact.. But do it nice or you will end up upgrading a few years from now again.
Sent from my SM-G930T using Tapatalk
jorgebetancourt is offline
post #7558 of 7688 Old 05-27-2020, 11:40 AM
Moderator
rboster's Avatar
Liked: 2776
Great thread.
I will say what those GIK panels do is not the same as 2-4 inches of linacoustic (insert your fav absorption material). The Alpha panels absorb lower freqeuncy range and scatter/diffuse the upper frequencies. The goal with these panels and placement are to create a wider cleaner rear soundstage.
One could "copy" the computer generated pattern and cut it from the baltic wood for the front plate and add the appropriate amount of absorption etc. I don't have that skill set.
Dave Vaughn likes this.
post #7559 of 7688 Old 05-27-2020, 05:19 PM
stinkyonion's Avatar
Quoted: 55 Post(s)
Liked: 32
Just painted the white ceiling black (94% light absorbing) and the white walls beige (60% absorbing). Huge improvement! Still have cream carpet (thank you wife). Almost $3k to replace with black at $5/sq foot. Instead i put a coffee table in the middle off the floor with a black throw blanket over it and it is also vast improvement, at least until i replace the carpet.
stinkyonion is offline
post #7560 of 7688 Old 05-27-2020, 05:25 PM
Quoted: 55 Post(s)
Liked: 32
And to the person that asked about black gaffers tape. Dont do it. I put some on the perimeter of the window glass to reduce light escaping around blackout shades, as well as on some of the window woodwork. Worked. But 2 months later i decided to remove a strip to make sure wasnt doing damage. The fabric came up but left cement like glue residue that was very difficult to remove. Razor blades worked, everything else failed. Removed all the tape and learned my lesson. It is for short term use only.
Archibald1 likes this.
Epson 5020ub Powerlite Home Cinema 3d Front Projector , Mitsubishi , Panasonic Blu Ray Disc Player Dmp Bd30k
