Official Epson EH-TW 9200 5030UB Owners' Thread - Page 134 - AVS Forum | Home Theater Discussions And Reviews
 397Likes
post #3991 of 6195 Old 11-01-2014, 01:23 PM
jayteez's Avatar
Quoted: 35 Post(s)
Originally Posted by Raven0215 View Post
Yeah those will work just fine I ordered one for mine about 6 months ago and it has been working fine.
awesome..thanks.
jayteez is offline
post #3992 of 6195 Old 11-01-2014, 07:44 PM
DarkScreen's Avatar
Originally Posted by jayteez View Post
I need to purchase 2 more pairs of 3d glasses for my 5030ub. Does anyone know if these glasses will work with our projectors?
http://www.amazon.com/Samsung-SSG-51...ct_top?ie=UTF8
My only issue with these is that the arms tend to pop out of the snaps... it may just be my fat head.
jayteez and mumbleypeg like this.
DarkScreen is offline
post #3993 of 6195 Old 11-02-2014, 02:23 PM
jayteez's Avatar
Quoted: 35 Post(s)
picture in picture question...whenever I turn on picture in picture, the sub-screen comes up blank. does the projector have to have a separate signal input for this? I searched the manual but it isn't clear how this is done. thanks.
jayteez is offline
post #3994 of 6195 Old 11-02-2014, 02:39 PM
WestCDA's Avatar
Quoted: 68 Post(s)
Liked: 79
Seems fairly clear in the manual?
Using Picture in Picture
You can use the Picture in Picture mode to view two image sources simultaneously.
Note: You can only display HDMI or WirelessHD video sources when Picture in Picture mode is active.
2. Press the P-in-P button on the remote control.
The second HDMI video source appears as a sub-screen in the corner of the image.
WestCDA is offline
post #3995 of 6195 Old 11-03-2014, 10:27 AM
hmunster2's Avatar
Quoted: 98 Post(s)
Liked: 33
Please give me detailed enhancement
I am ( as usual ) slightly confused about the v111 firmware upgrade. I did it and it went without a hitch. My question is this: after reading peoples comments I am getting the impression that the super resolution setting is behaving the same until you slide it up to number 4, and then it has this " detail enhancement " feature. Is this correct, or is this detail enhancement functioning throughout the range of the super Rez settings? And I have looked at it and see subtle changes, but not drastic, until I get to 4 o5 and then it just seems sort of grainy looking.
hmunster2 is offline
post #3996 of 6195 Old 11-03-2014, 10:41 AM
Keith Mickunas's Avatar
Quoted: 120 Post(s)
Liked: 83
No, it's been improved throughout the scale with the upgrade. Most people seem happiest at 2 or 3, after that it can appear a bit drastic.
Keith Mickunas is offline
post #3997 of 6195 Old 11-03-2014, 11:06 AM
Mike Garrett's Avatar
Quoted: 12819 Post(s)
Liked: 10461
A little birdie told me that there will be some news on the 5030 tomorrow.
Mike Garrett is online now
post #3998 of 6195 Old 11-03-2014, 11:16 AM
rprice54's Avatar
Quoted: 308 Post(s)
Liked: 172
I knew I should have waited... Always a better deal around the corner :stuck_out_tongue_winking_eye:
rprice54 is offline
post #3999 of 6195 Old 11-03-2014, 11:52 AM
NickTheGreat's Avatar
Quoted: 522 Post(s)
Liked: 399
Regarding?
NickTheGreat is offline
post #4000 of 6195 Old 11-03-2014, 01:00 PM
mylan's Avatar
Quoted: 232 Post(s)
Liked: 207
Originally Posted by NickTheGreat View Post
Regarding?
It's going back on sale again soon.
NickTheGreat likes this.
mylan is online now
post #4001 of 6195 Old 11-03-2014, 03:34 PM
gec5741's Avatar
Quoted: 230 Post(s)
Liked: 102
I'll be calling ya tomorrow then for the 411
gec5741 is offline
post #4002 of 6195 Old 11-03-2014, 03:37 PM
Craig Peer's Avatar
Quoted: 7223 Post(s)
Liked: 8652
The 5030UB is on sale right now !
Craig Peer is online now
post #4003 of 6195 Old 11-03-2014, 04:13 PM
gec5741's Avatar
Quoted: 230 Post(s)
Liked: 102
So makes this news tomorrow all the more interesting!
Or is that the news? I'm confused but I guess I'll find out tomorrow.
gec5741 is offline
post #4004 of 6195 Old 11-03-2014, 04:47 PM
Liked: 1
According to Epson the detail enhancement kicks in from 4. Up to 3 it is Super Resolution which have also benefited from the upgrade. I usually keep at 4 and I like the clean crisp image it provides for blu rays. For DVDS and other lower inputs I keep SR at zero and increase the sharpness. This seems to remove all artifacts. Hope this helps.
Quo Vadis is offline
post #4005 of 6195 Old 11-03-2014, 05:02 PM
hmunster2's Avatar
Quoted: 98 Post(s)
Liked: 33
Thank you
post #4006 of 6195 Old 11-03-2014, 05:11 PM
mcmountainman's Avatar
Quoted: 24 Post(s)
Moving up from 8350 ? ? ?
OK lots of comparisons between the Sony 40es etc... but is the 5030 worth the upgrade from a 8350 ? A lot better or just a subtle difference trying to decide which to upgrade my 7 yr old 42 in plasma or a new projector (3D) . Ive got a 100 in screen in a totally light controlled room if that helps at all . Can only afford one upgrade leaning towards the 5030 since its on sale again with an extra lamp too ! Just dont want buyers remorse .
Let me know your thoughts and thanks in Advance !
Tom O.
mcmountainman is offline
post #4007 of 6195 Old 11-03-2014, 05:29 PM
Kilgore's Avatar
Quoted: 729 Post(s)
Liked: 441
I just upgraded from an 8350 to a 5030UB last week, so I am qualified to say that, yes indeed, it's worth the upgrade. MUCH better contrast, more detailed and sharper. Overall, just a deeper, richer image. On very bright scenes, you may think there isn't much difference, and this is true to a point, but with the 5030UB there's just that much more "pop". There are similarities, to be sure, but the 5030 is just that much more vivid. In dark scenes, there is no comparison. Plus, the 3D on this thing is spectacular. Personally, I'm totally satisfied, and wouldn't hesitate to say that it's a worthwhile upgrade.
AlexanderDelarg likes this.
Kilgore is offline
post #4008 of 6195 Old 11-03-2014, 05:35 PM
jayteez's Avatar
Quoted: 35 Post(s)
i am still in awe at the performance of this projector. The 3d is absolutely an immersive experience. I just wish more 3d content was available!
jayteez is offline
post #4009 of 6195 Old 11-03-2014, 05:47 PM
Liked: 1
I agree. In the theaters I never liked 3D. But with Epson I have been enjoying the 3D experience.
post #4010 of 6195 Old 11-03-2014, 06:46 PM
Liked: 2
Anyone know of any good Black Friday deals coming up for this projector? I am looking at probably getting the 6030UB but if this would have a black friday that makes more financial sense I would go this route then.
proboller86 is offline
post #4011 of 6195 Old 11-03-2014, 07:21 PM
Hammer578's Avatar
Quoted: 70 Post(s)
Liked: 46
Another Upgrade?
Hammer578 is offline
post #4012 of 6195 Old 11-03-2014, 07:35 PM
Jeffg8's Avatar
Quoted: 147 Post(s)
Liked: 76
I was pleased I had resisted the temptation to change to the Sony 55es or even the 40 during the recent price reduction. I have a 6010 that will be 3 next month, just recently re lamped. I thought 4K would have dropped more this past Cedia, but no. Now with the 5030UB getting a little cheaper with a spare lamp....minus what I might could get for mine...."there practically giving em away".. You know the drill. Only problem is the 5030 is white... ceiling is white...have gotten used to the black....however quite a bit more for the 6030. Wife might notice white projector as well...usually try to keep all upgrades black. Less conversations that way.
Jeffg8 is offline
post #4013 of 6195 Old 11-03-2014, 08:09 PM
WestCDA's Avatar
Quoted: 68 Post(s)
Liked: 79
Originally Posted by Jeffg8 View Post
Only problem is the 5030 is white... ceiling is white...have gotten used to the black....however quite a bit more for the 6030. Wife might notice white projector as well....
White on white - maybe she won't even see it ...
Seriously, I thought the white color would be a bigger deal for me, but I've grown quite attached to it. For the difference in price, I thought I could always get some vinyl and wrap it if I found it bothersome - but I prefer it white now, has a sleek look to it. The important part that faces/reflects the screen is still black ...
WestCDA is offline
post #4014 of 6195 Old 11-03-2014, 08:39 PM
Quoted: 120 Post(s)
Liked: 83
The case on the two projectors is similar, perhaps you can swap the two. Then she'll never know.
post #4015 of 6195 Old 11-04-2014, 01:36 AM
jayteez's Avatar
Quoted: 35 Post(s)
im curious here..has anyone tried the various calibration discs with the 5030? if so, which one and how did it come out after calibration?
jayteez is offline
post #4016 of 6195 Old 11-04-2014, 11:20 AM
gec5741's Avatar
Quoted: 230 Post(s)
Liked: 102
So is the current deal going on the sale price plus a spare bulb? Or is there more that came out today? Also does anyone know how long this deal may be going on for? This may be the month I get approval from the boss to pull the trigger but I have to wait till around the 18th to pay cash!
gec5741 is offline
post #4017 of 6195 Old 11-04-2014, 12:10 PM
Liked: 10461
Originally Posted by Hammer578 View Post
Another Upgrade?
Sale price on 5030 with spare lamp and the two pair of glasses.
post #4018 of 6195 Old 11-05-2014, 12:02 AM
Quoted: 27 Post(s)
Liked: 0
Does anyone know when the 5030 will start shipping with the new firmware upgrade already installed? Oh, and how long will this new sale last?
jasenkent is offline
post #4019 of 6195 Old 11-05-2014, 05:45 AM
JamesVG81's Avatar
Quoted: 106 Post(s)
Liked: 63
I would say it will be at least 2-3 months before these start shipping with the new firmware if not longer. Every one is going to have to sale out of current stock and Epson is going to have to sale out of all there stock also.
JamesVG81 is offline
post #4020 of 6195 Old 11-05-2014, 06:11 AM
rprice54's Avatar
Quoted: 308 Post(s)
Liked: 172
The update is quick and easy. esp if you can do it before it goes up.
rprice54 is offline
Epson 5030ub 2d 3d 1080p 3lcd Projector
