AVS Forum | Home Theater Discussions And Reviews (https://www.avsforum.com/forum/)
-   Digital Hi-End Projectors - $3,000+ USD MSRP (https://www.avsforum.com/forum/24-digital-hi-end-projectors-3-000-usd-msrp/)
-   -   About to make decision need opinion on Projectors (https://www.avsforum.com/forum/24-digital-hi-end-projectors-3-000-usd-msrp/1490481-about-make-decision-need-opinion-projectors.html)
LexMan 09-13-2013 09:28 AM
I think I am about to pull the trigger on a projector and have it down to the JVC RS46 or the B stock RS4800.
Price, warranty is better on 4800. Bulb appears better on 46.
If it were you money, which would you choose?
Seegs108 09-13-2013 09:35 AM
Personally I'd go with the RS46 as it's the newest generation machine and has all of the latest lightpath/LCOS chips/3D performance updates plus an updated bulb.
Drexler 09-13-2013 10:59 AM
I was in a similar situation choosing between an X35 (=RS46) and an X70 (=RS55) and went for the RS46 due to a better lamp design and better 3D. I miss out on the e-shift and slightly higher contrast, but it really gives me piece of mind not having to constanly worry that the bulb might suddenly dim or go out (JVC had huge problems with this until last years models), and I also enjoy 3D and this should be noticeably better on the RS46. So, I'm very content I made the choice I did.
LexMan 09-13-2013 11:19 AM
Thanks for your response. know the B stock projector comes with the third generation of that bulb but I still am not sure. Also there was an issue with magenta stripes showing up I believe on the previous generation JVC which has me a little concerned as well. Or am I mistaken and this won't be an issue on the 4800?
Drexler 09-13-2013 11:32 AM
I believe the magenta stripes plagued the JVCs with the older chassis (RS15/25/35) and older, but haven't seen any reports since.
JVC came out with new lamps with cooling flaps to the 2011 models, but as far as I recall they still burned out fast. The 2012 lamps though seems to be really good over the board. I haven't heard anything about any pre-mature bulb failures and they even seem to keep their brightness more than one would expect compared to other projectors. Many have reported 3-400 h and still 100% brightness, this many hours would otherwise typically show 15-30% drop in a bulb based projector.
I believe the problem of the older JVCs were a design flaw that prevented proper cooling of the lamps, which subsequently overheated. The RS46 has a completely redesigned lamp and lamp housing to allow better cooling.
dragonbud0 09-13-2013 12:02 PM
The magenta stripe issue came from the pre-3D models, such as the RS1 - RS35 series.
The RS40-45 had issues with the lamp, not sure about the RS46.
So that you know, other projectors, Sony and Epson have their own unique problems as well.
I switched between Sony and JVC models quite often in the 1080p world but only had an Epson 720p model.
LexMan 09-13-2013 02:19 PM
Thanks guys, you are leaning me back towards the 46U it seems...
Craig Peer 09-13-2013 03:15 PM
The lamp issue has been resolved. The RS46 and RS4810 are great projectors for the money.
LexMan 09-13-2013 05:00 PM
That's good to hear because I spoke to Mike and ordered the RS46! biggrin.gif
Mike Garrett 09-13-2013 05:38 PM
The version three lamp seems to have pretty much solved the lamp problem with last years projectors. The new lamp design with the new JVC's that I have not seen one single lamp issue reported on the forums. Out of the 100's that we have sold, not a single customer has come back to us with a lamp problem. In fact JVC projectors have been trouble free. Notice you don't see people talking about issues with the new projectors.
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
