JVC Auto Calibration - Page 25 - AVS Forum | Home Theater Discussions And Reviews
 219Likes
post #721 of 806 Old 11-28-2018, 08:02 AM
faiz's Avatar
Originally Posted by Dominic Chan View Post
Autocal is not perfect, but definitely fixes gamma droop. The only other option is to “hand craft” 3 custom curves, assuming 3 is enough in your setup to cover SDRas well as HDR.
Noted , will try the auto cal and report back here , is there any manual calibration combination of s/w and hardware combo that you can recommend in small budget for beginners like me to tinker with
Storm I.ISP 3D.16.12.ELITE , Jvc X7900be , cxuhd bluray player And PSB speakers Dolby Atmos 11.4
faiz is offline
post #722 of 806 Old 11-28-2018, 08:45 AM
Quoted: 4496 Post(s)
Liked: 1684
For “manual” calibration I highly recommend HCFR. You can use it with the Spyder5, or i1Display3 if you want more accurate colours.
Dominic Chan is online now
post #723 of 806 Old 11-28-2018, 11:28 PM
faiz's Avatar
Thanks once again Dominic , is this the correct model X-rite i1 Display Pro EODIS3 (2018 Edition) as thats what is available here , in the meanwhile will download HCFR and familiarize myself with work flow and see if i can manage it
faiz is offline
post #724 of 806 Old 12-02-2018, 02:24 AM
faiz's Avatar
Think age is catching up with me , as in 2014 i had purchased the calman 5 and the c6 and calibrated my then 1080p projector and completely forgot about it.
I revisited the calman 5 its version still is the 2014 as i had not updated , but this version has colorspace target for
1) D65,HD Rec.709 and 2) ITU-R Rec 2020 among others but non for HDR (which is a non isssue for me as of now as )
Since i have the calman S/ware and if i purchase the i1 Display Pro EODIS3 hopefully it will be compatible would this be a better way to calibrate as against the Jvc autocal with the spyder5?
faiz is offline
post #725 of 806 Old 12-02-2018, 04:39 PM
Liked: 1684
If you already have C6 you don’t need to buy the i1D3. They are essentially the same meter.
post #726 of 806 Old 12-02-2018, 07:11 PM
faiz's Avatar
It been 4 years , I was just concerned that there may be Color drift in the c6 and me being a relative novice in video calibration , wanted to lower the chance of things going down side due to a hardware issue
faiz is offline
post #727 of 806 Old 12-02-2018, 07:20 PM
Liked: 1684
It’s your money.
post #728 of 806 Old 12-02-2018, 07:28 PM
faiz's Avatar
It’s your money.
Thanks Dominic , I will give it a go with the c6 and see how it turns out
faiz is offline
post #729 of 806 Old 12-03-2018, 12:27 AM
panman40's Avatar
Quoted: 336 Post(s)
Liked: 144
Dominic,
Going back to my red tint in black issue with the quality 33 steps, is this fairly common or could my Spyder be off ?.
I ran colour and gamma for HDR without filter last week and having watched a couple of uhd blu rays I think it looks great to the point I don't see a need to check anything with my i1D3.
What do you think ?.
JVC DLA-X7900 3D Projector, Sapphire 106" Electric screen, Sony KDL-55W905 3D TV, Pana TX-L37LZD80, Panasonic UB820, UB700, BDT-380 MZ, Panasonic DMP-BD60, Sky Q 2TB, Fire TV 4K, Marantz SR7012, 7.1.2, SVS PC2000 Sub, Kef Q600C Centre, Q300 fronts, Ci160QR Ceilings, CA SX60 Surrounds, Harmony 950+hub.
panman40 is offline
post #730 of 806 Old 12-03-2018, 06:15 AM
Liked: 1684
Originally Posted by panman40 View Post
Dominic,
It’s hard to generalize. If 20 steps give you good results there no reason to use 33 steps.
HDR black clipping patterns (around code level 100 and below) can often reveal calibration issues.
post #731 of 806 Old 12-03-2018, 06:21 AM
panman40's Avatar
Quoted: 336 Post(s)
Liked: 144
Dominic,
Ok thanks, I do seem to have reasonable results so may just leave it alone.
panman40 is offline
post #732 of 806 Old 12-10-2018, 04:12 PM
faiz's Avatar
Hi Dominic
I managed to do the autocal with the spyder5 ,my calibration with the standard profile the gamma was pretty good however when i try to calibrate the HDR profile i get a bad gamma curve, i have done this a few time with the same results ,have attached a pic herein below .
also i have noticed that my unit displays a lot of green in the projected image this is pre and post the calibration , is there some way to check if my unit is faulty for the excessive green , or any solution for the same
I have done around 40 hours on the lamps, and have followed the instructions properly for the autocal
ID:	2494830   Click image for larger version
faiz is offline
post #733 of 806 Old 12-10-2018, 04:47 PM
Liked: 1684
Why do you think it’s a bad gamma curve? ST2084 is supposed to look like that.
You can temporarily switch HDR Picture Mode to use Normal gamma for the calibration; that way it’s easier to see if the calibration is successful (straight line for gamma).
Since you have CalMAN it should be easy to check that out using the i1D3.
post #734 of 806 Old 12-10-2018, 05:36 PM
faiz's Avatar
Thank you Dominic for clearing that out for me , is it ok that I used 2.2 gamma for the hdr calibration ,
I will be getting my i1d3 next week , will try and see what I can achieve with it .
But you have been great help
Thank you
faiz is offline
post #735 of 806 Old 12-12-2018, 10:11 AM
faiz's Avatar
Hi dominic,
Sorry to bother you , but i have just re calibrated and in both HDR and Natural while the calibration was on i noticed that in both the calibration the color level signal the value of Z was 0, attached herein bellow is the pic as well as the final result of the natural mode calibration.
Is this normal , if not what could be the issue any input from you will be much appreciated
ID:	2495738   Click image for larger version
ID:	2495746   Click image for larger version
faiz is offline
post #736 of 806 Old 12-12-2018, 02:37 PM
Liked: 1684
Hi dominic,
I think a zero value for Z is normal, especially when the results are fine.
post #737 of 806 Old 12-12-2018, 02:56 PM
faiz's Avatar
Thanks Dominic
Also when I changed the position of the probe I started getting some value on the Z for the red Color though a very low number
Tonight I noticed that when the spyder was placed in a way that it’s shadow fell in the mid point centre of the screen , PQ is the best I have seen
I get a lot of green tint in HDR and it becomes even more stronger in the darker screens
I hv mission impossible fallout. , the punisher 2 ,Marrawbone, mother in UHD and they all display the above mention characteristic
If anyone here that have the same movies could pls confirm this
faiz is offline
post #738 of 806 Old 12-12-2018, 03:10 PM
Liked: 1684
Does that show in the CalMAN grey scale?
post #739 of 806 Old 12-13-2018, 11:20 AM
faiz's Avatar
Hopefully will receive my i1d3 by the 20th post which I will update and revert
faiz is offline
post #740 of 806 Old 12-13-2018, 02:04 PM
Liked: 1684
Have you not tried CalMAN with the C6?
post #741 of 806 Old 12-28-2018, 11:03 AM
faiz's Avatar
Sorry Dominic for the late response but had met with a small accident and broke my toe , however was able to try the calibration today with the new i1d3 and Calman set to REC 709 and continuously hit a very abnormal low read of the gamma 0.39 at 60% and as well as on the 10 point 10% step 10-100% I did this a few times with similiar abnormal results
I was using the “Natutal mode “ and it’s default settings
Have attached the pics, also have attached the pic of the actual grey 60% pattern which looks very greenish as well as a still pic from the movie “the greatest showman”
Just to make sure the i1d3 or my calbration set up was not faulty , I connected my standby projector and got normal gamma read after which I did a factory reset on the JVC , and when connected it back to the Jvc I got the similiar abnormal readings
Any idea what could be wrong is it a hardware or software issue , please do share your thoughts
ID:	2501940   Click image for larger version
ID:	2501942   Click image for larger version
ID:	2501944   Click image for larger version
faiz is offline
post #742 of 806 Old 12-28-2018, 12:40 PM
Liked: 1684
Sorry but I'm not familiar with CalMAN. I was only asking about it to see if it confirmed the greenish tint that you noticed.
post #743 of 806 Old 12-28-2018, 07:34 PM
faiz's Avatar
The next measurement was of the green colour space and it was way off towards the left from the green target box after which point I did not continue , should I post this issue in a new thread as it’s not jvc autocal issue
faiz is offline
post #744 of 806 Old 12-31-2018, 05:25 PM
smitty's Avatar
Quoted: 750 Post(s)
Liked: 988
I'm planning on getting one of the new JVC native 4k projectors, and have been reading the manuals for the Auto Cal software. I'm afraid I have a few questions, which are probably stupid newbie questions, but for someone not familiar with calibration (I usually adjust my displays with Avia or the AVSHD 709 disk), the JVC manual leaves a lot to be desired. What I mean is, it assumes a certain mount of knowledge, whereas one or two sentences or a brief paragraph introduction in some parts of the manual would help, I think.
Anyway, in reading the latest manual, which I think is for version 11 of the software (and the versions don't seem to have changed much recently), I'm good until I get to around page 10 or so where it talks about creating a Color Profile, and then about Gamma Adjustment.
What would be the purpose of creating your own color profile? Why wouldn’t you use one of the color profiles that are pre-set for the picture mode?
If you create and import a color profile that you created, do you need to run the calibration again for image quality and distortions – since when you run the calibration, one of the things you do is select a color profile?
And what is the purpose of the gamma adjustment procedure? When would you want to use it? Doesn't the auto-cal procedure fix issues with the gamma?
Thanks in advance for any help.
smitty is online now
post #745 of 806 Old 01-03-2019, 09:09 AM
Liked: 1684
With the native 4k models most people would not need to create custom profiles. Surprising, up to and including the latest e-shift models Rec709 was not included as a preset profile.
Custom profiles have also been used to fine-tune the colour accuracy (to correct the inaccuracies of the Spyder), but most users do not get into that.
Theoretically yes, although some colour profiles share the same calibration.
Again, that’s for fine-tuning, to reduce any residual errors from autocal.
For further details you can read the 4000 posts here
https://www.avsforum.com/forum/24-di...500-rs600.html
post #746 of 806 Old 01-03-2019, 10:12 AM
smitty's Avatar
Quoted: 750 Post(s)
Liked: 988
Thanks Dominic. i'll start reading.
post #747 of 806 Old 01-03-2019, 10:57 AM
Liked: 1684
I was kidding about the 4000 posts. The main ones are on the first page.
post #748 of 806 Old 01-03-2019, 11:17 AM
smitty's Avatar
Quoted: 750 Post(s)
Liked: 988
I have, in fact, read quite a few pages already of this thread and some other calibration threads just to try to obtain some general knowledge. I've even read some of the manuals for things like ChromaPure. The problem is that most of the threads and posts, as well as the JVC Auto-Cal manual and other manuals, assume a certain amount of knowledge.
It's like, as an attorney, if I'm talking to another attorney, we speak in a certain language and have a base of knowledge that we both use as a foundation. So we can speak in shortcuts and skip some basic stuff because we know what we're talking about. You see the same kinds of things on threads like these, and quite naturally so.
It's too bad that there is not a basic "beginner's calibration thread" with basic information about gamma, and color profiles, and white points, etc. for folks just trying to understand what you guys do and what you're talking about.
Anyway, I appreciate your response to my question.
post #749 of 806 Old 01-03-2019, 01:40 PM
Liked: 1684
You may find this useful:
http://www.curtpalme.com/forum/viewtopic.php?t=10457
I decided to respond after you reworded your question
post #750 of 806 Old 01-03-2019, 06:55 PM
smitty's Avatar
Quoted: 750 Post(s)
Liked: 988
Thanks. I started reading that a couple of weeks ago, but then saw there was an updated thread, and I jumped to that one. But the old thread does indeed have a good deal of helpful basic information that isn't in the updated thread.
Jvc , Jvc Dla Rs45 Home Theater Projector 1080p Hdmi
