JVC Auto Calibration - Page 31 - AVS Forum | Home Theater Discussions And Reviews
 228Likes
post #901 of 928 Old 10-31-2019, 08:54 PM
Quoted: 5033 Post(s)
Liked: 1940
Originally Posted by atabea View Post
Hi Dominic,
I was just about to order a new light meter to measure luminance. I already have Chromapure and a i1Display pro 3, which should arrive back from being re-calibrated by Tom Huffman, any day now. I wasn't aware I could measure luminance with a Colorimeter. Can you please outline the process?
There is no special process involved. The luminance is just the measured Y value of a 100% white pattern. See page 14 of the ChromaPure manual.
atabea likes this.
Dominic Chan is online now
post #902 of 928 Old 10-31-2019, 10:01 PM
atabea's Avatar
Quoted: 775 Post(s)
Liked: 668
Thanks, Dominic.
atabea is online now
post #903 of 928 Old 11-03-2019, 02:45 PM
gravi's Avatar
Quoted: 404 Post(s)
Liked: 205
Measuring it off the screen using the colorimeter is much better than measuring the lux with a light meter and doing the calculation which involves more assumptions such as the screen gain.
Can you refresh me on what is the optimal luminance target for SDR as well as HDR that is generally accepted?
gravi is offline
post #904 of 928 Old 11-03-2019, 03:17 PM
Liked: 1940
For SDR most commonly people use 50 nits (about 15 fL).
For HDR it’s hard to define what “optimal” means, but personally I would aim to get 100 nits or more for the peak white, then a custom curve to get you the preferred diffuse white level (typically around 25 nits).
post #905 of 928 Old 11-03-2019, 03:41 PM
gravi's Avatar
Quoted: 404 Post(s)
Liked: 205
Interesting. I measured off the screen using i1D3 and Chromapure and I got 73 for my RS1000 in SDR mode, zoomed to 125" diagonal scope screen, iris at -9. I remember bringing iris to -12 and it read 69. I may have to close the iris all the way down, if I am to believe the readings.
gravi is offline
post #906 of 928 Old 11-03-2019, 03:59 PM
Liked: 1940
There are some big drops beyond -12.
post #907 of 928 Old 11-03-2019, 06:54 PM
gravi's Avatar
Quoted: 404 Post(s)
Liked: 205
Will try that later tonight. One more thing I noticed after doing a color gamut measurement was that the report said it measured 94.2 of REC709 and 65.2 percent of P3. That does not make sense. Is that because I measured in SDR mode or I used REC709 patterns to measure? Thanks!
gravi is offline
post #908 of 928 Old 11-03-2019, 07:23 PM
Liked: 1940
It’s somewhat low but not totally unusual to get 94% of Rec709. That’s why I use the filter even for Rec709 (custom Rec709F profile).
To measure HDR gamut you need to use BT.2020 profile, but aim for P3 gamut.
post #909 of 928 Old 11-03-2019, 08:57 PM
gravi's Avatar
Quoted: 404 Post(s)
Liked: 205
I measured using the HDR color profile on the RS1000 and got 115 percent of Rec709 and 85 percent of P3. With a whopping delta E of 31. All this is pre-autocal. My question is whether the test patterns for color are the same as for SDR/Rec709.
gravi is offline
post #910 of 928 Old 11-03-2019, 09:13 PM
Liked: 1940
You can use the SDR patterns to measure HDR if you manually place the projector in BT.2020 mode. However, that would be measuring the BT.2020 gamut, which the projector has no hope of reaching. To measure BT.2020/P3 you need to use different patterns.
If you're doing calibration and not checking the gamut, you can use the SDR patterns but at 50% saturation and 50% stimulus level.
post #911 of 928 Old 11-04-2019, 09:19 AM
gravi's Avatar
Quoted: 404 Post(s)
Liked: 205
Thanks and I apologize for sounding a little dense as I am new to many of these concepts. I want to clarify a few things here. Let's say I just want to check gamut only for now. I should be choosing the "HDR" color profile on my RS1000 as it does not have a "BT2020" profile built in? And I can use the standard color patterns that come with Chromapure built-in generator? Do I still use 50% stimulus and 50% saturation for this exercise? If not these patterns where can I find patterns that are specifically for wide gamut?
Thanks again!
gravi is offline
post #912 of 928 Old 11-04-2019, 09:57 AM
Liked: 1940
Thanks again!
The RS1000 does not have the BT.2020 colour profile, so indeed you would use the HDR colour profile which is BT.2020 without the P3 filter.
If you're just checking the gamut (not calibrating), it's still best to use BT.2020/P3 (even though it will come out a little short, mostly in green). As mentioned previously, you can use 50% and 100% saturation, but they won't tell you much (meets 50%; fails 100% miserably).
In any case, this is starting to get off topic (JVC Autocal).
post #913 of 928 Old 11-06-2019, 01:44 PM
SirMaster's Avatar
Quoted: 808 Post(s)
Liked: 500
Does anyone know how to "reset" a custom gamma?
Does clicking the "reset" button in autocal gamma editor reset the curve to match the selected correction value?
SirMaster is online now
post #914 of 928 Old 11-06-2019, 10:10 PM
Liked: 1940
Selecting Gamma 2.2 essentially resets the custom gamma back to default value.
post #915 of 928 Old 11-14-2019, 09:20 AM
gravi's Avatar
Quoted: 404 Post(s)
Liked: 205
What is the "log only" mode in Autocal? Does it just measure using the sensor and just report current state, like a pre-calibration report? If so can you use any of the two sensors? I wonder if anyone uses this feature. Thx.
gravi is offline
post #916 of 928 Old 11-14-2019, 12:28 PM
Liked: 1940
When you run “real” calibration Autocal takes a set of readings before calibration, covering the gamma, colour temperature (at 50% and 100% inputs and a few other points), and the primary colours. It then runs the calibration and takes another set of readings showing the results of calibration.
If you select Log Only mode it takes one set of those readings and displays the results on screen, without running the calibration.
It’s the best way to determine if your projector exhibits gamma droop, and also the colour accuracy of the Spyder if you have another meter to compare with. For the latter you have to make sure the RGB gains and offsets are zeroed.
Bytehoven likes this.
post #917 of 928 Old 11-14-2019, 06:20 PM
gravi's Avatar
Quoted: 404 Post(s)
Liked: 205
Great advice, will try a log only with both Spyder X and i1pro2 first.
Real quick - I need to turn off screen adjustment code on the JVC prior to autocal? Also, I assume I can ignore screen size settings (defaults to 100") in the setup menu on software as I have a dedicated room?
gravi is offline
post #918 of 928 Old 11-14-2019, 06:36 PM
Liked: 1940
I’m not sure if Autocal ignores it, but you might as well turn it off as it should not be used after calibration.
post #919 of 928 Old 11-16-2019, 08:56 PM
sthompson's Avatar
Quoted: 104 Post(s)
Liked: 39
Couple of questions.
1) What's the appropriate thread for discussion V11/V12 autocalibration for the NX5/7/9 models? The one listed here by Manni is locked and I can't seem to find one for avs. https://discuss.avscience.com/index.php?topic=1850.630
2) I recently went through a gamma calibration for my NX9 using both the Natural and HDR pic settings. Afterwards using either of those settings when watching HDR/SDR the picture had a heavy orange/red tint to the picture. Has anyone come across this? I reset the projector back to the initial settings until I figure out what's going on.
sthompson is online now
post #920 of 928 Old 11-16-2019, 09:34 PM
Liked: 1940
Sounds like the calibration did not go well. Which meter were you using? Did the log show anything unusual?
post #921 of 928 Old 11-17-2019, 10:50 AM
sthompson's Avatar
Quoted: 104 Post(s)
Liked: 39
I was using a Spyder5 express. As in unusual are you referring to readings showing 0?
post #922 of 928 Old 11-17-2019, 12:21 PM
Liked: 1940
Readings showing 0, or the log showing non-straight line gamma, scattered colour temperatures, etc.
post #923 of 928 Old Yesterday, 04:43 AM
Franin's Avatar
Quoted: 3337 Post(s)
Liked: 2187
Hi all Ive purchased Xrite i1 basic Pro 2 and the Spyder X Elite is their a step by step guide to get me started ?
_________________________
God Bless!
Equipment: Bose Soundbar; 1951 Philco Model 50-T701 Black and White tabletop TV;Projection :HANIMEX ZOOM 8 MM PROJECTOR
Franin is offline
post #924 of 928 Old Yesterday, 10:51 PM
Franin's Avatar
Liked: 2187
Hi all
Today I’ve opened my Xrite i1 basic Pro 2 case and noticed it came with a few accessories. One of them being this 1 square table / plate type of thing. Do I need to use that ? Or plug directly into USB and off I go ?
Still waiting for Spyder to arrive before I start but I best get myself aquatinted with the meter.
Sent from my iPhone using Tapatalk Pro
God Bless!
Franin is offline
post #925 of 928 Old Yesterday, 10:53 PM
SirMaster's Avatar
Quoted: 808 Post(s)
Liked: 500
Hi all
No, that’s for print color readings.
You just need the white calibration tile holder / cradle and the tripod mount.
post #926 of 928 Old Yesterday, 11:28 PM
Franin's Avatar
Liked: 2187
Okay thank you SirMaster.
Do you only use it once for each calibration, the white calibration tile holder ?
God Bless!
Franin is offline
post #927 of 928 Old Yesterday, 11:40 PM
SirMaster's Avatar
Quoted: 808 Post(s)
Liked: 500
Yes, set the meter on the holder before you start. When you select the i1 Pro 2 in autocal to use as a meter, autocal will take a reading of the white tile for internal calibration, when it's done self-calibrating, it will switch to a white screen on the projector. That is when you can lift the meter off the holder and mount it on the tripod and face it at the screen to proceed.
post #928 of 928 Old Today, 12:14 AM
Franin's Avatar
Liked: 2187
Thank you so much. Will save this part of link
Cheers
God Bless!
Franin is offline
Jvc , Jvc Dla Rs45 Home Theater Projector 1080p Hdmi
