What glasses are compatible with the Panasonic PT-AE8000U? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 11-07-2013, 11:11 AM - Thread Starter
dvdchrisc's Avatar
Also I read that the The AE8000's glasses have a 3D-to-2D function, which allows a user to watch in 3D but someone else in your household prefers 2D.
Are there glasses like this?
dvdchrisc is offline
post #2 of 13 Old 11-08-2013, 03:11 AM
EddieLomax's Avatar
You will want the Panasonic TY-EW3D3 glasses (3rd gen IR), they come in small, medium and large (TY-EW3D3S, TY-EW3D3M, TY-EW3D3L), and then there are three regions for them which adds a C (China), U (US) and E (Europe) to the end of them (e.g. TY-EW3D3ME are the european medium glasses).  Doing a seach for EW3D3 on ebay is good enough.
You can use any region with any projector, so its all done for sales reasons as far as I can see.  I believe the small and large sizes have been discontinued (but can be found on sites like ebay still), although even though I have a slightly larger head ( :) well one size fits all baseball caps are not a good fit for me ), the medium fits me fine so I guess they decided these were all that was needed, they also fit over glasses okay.
There is also a 2nd Gen set floating around, the TY-EW3D2 which should also be compatible, they are heavier though and let slightly less light through according to Panasonic.
I've been gathering glasses up for my new projector myself and it seems that the consensus is that the Panasonic glasses are the most comfortable out there, and seem to perform as well as or better than the alternatives (tempted to try the Sony BR250's to see if they work though, also interested in trying the PS3 glasses too - but only if I can get a cheap pair from ebay).
Will see this weekend if the Samsung SSG-2100's will work with the PT-AT6000E, I have heard really old Samsung IR glasses were incompatible, but did work if you turned them upside down :)
Enjoy the 3D!
Edit : (a running summary of everything I find)
Can confirm that the SSG-PT2001XT/XC do not work with this projector.
TY-EW3D10 (battery non-rechargeable type) work with this projector
EddieLomax is offline
post #3 of 13 Old 11-08-2013, 11:05 AM
TomKarelis's Avatar
Thank you for the question and the answer!
Receiver: Onkyo TX-NR818 --> Dead
Blu-Ray: Oppo BDP-103
Projector: Panasonic PT-AE8000
Speakers: Martin Logan Motion 30 - Center
Martin Logan Motion 40 on left and right
Martin Logan FX on the sides & Martin Logan 4 for back channels
TomKarelis is offline
post #4 of 13 Old 11-08-2013, 03:25 PM
EddieLomax's Avatar
Your welcome, and just a bit more updated information, I've tested the Samsung SSG-PT2001XT/XC and they do not work, I'll update the first answer with all the info I can get (I've looked everywhere and no one seems to have a definitive list of glasses vs projectors...).
I can also add the following to the list of glasses that work with the PT-AT6000/PT-AE8000
As detailed in Panasonics documentation
post #5 of 13 Old 12-27-2013, 12:36 AM
DXR313's Avatar
any updates on this? I just picked up this projector and a pair of used ew3d3 glasses for pretty cheap. the 3d to 2d works great. wanting to add to my 3d glasses collection but they can get expensive. even the ew3d10 are pricey. any good universal ones??
DXR313 is offline
post #6 of 13 Old 12-27-2013, 01:51 AM
EddieLomax's Avatar
I have stopped collecting at 5 sets for the moment, definitely plenty and all sourced cheaply from ebay, if you enjoy the hunt that's the best place to go.  There are a lot of generic ones you can go for, but I've not heard any reviewers praising them over the Panasonics (I'd like to try out the Sony ones some point, but only if they are very cheap).
post #7 of 13 Old 12-27-2013, 01:14 PM
DXR313's Avatar
ahh, so which ones did u go with? all of yours ew3d3s?  i was gonna give these a shot:
http://www.ebay.com/itm/221059771377
and report back on them.  it's funny because projectors aren't listed on there so I did some cross referencing and my old KDL-46HX800 is listed as a compatible TV... if that's the case, will my Sony 3D glasses from it work with my panny??
DXR313 is offline
post #8 of 13 Old 04-14-2014, 02:39 PM
Archaea's Avatar
Quoted: 4328 Post(s)
Liked: 4168
any update to this? I have two of the Sony active 3d glasses - will they work with the panasonic? If so those are often only $20 on sale at slickdeal.net.
Archaea's 9.8.4 Home Theater Room
208, 1" tweeters | 52, 5" woofers | 8, 18" subwoofers
Archaea is online now
post #9 of 13 Old 04-14-2014, 09:26 PM
Archaea's Avatar
Liked: 4168
Confirmed Sony ps3 glasses work with ae8000u
post #10 of 13 Old 04-15-2014, 10:21 AM
BishopLord's Avatar
I ordered a couple of these from Amazon yesterday. Won't be able to test them until the PJ arrives next week though. If they work, I'll purchase a few more, just in case for company. If they don't work, then I'm only out $25.90 (for 2), however, Amazon does have an easy return policy. Amazon Link
By the way, someone is selling "refurbished" PS3 3D glasses for less than $10. I almost pulled the trigger on them, but decided against it. (just checked again, looks like he sold out. Had them for $9.95 Prime).
Edit -
Confirmed that they work great! Can't believe they're $13 and I was spending anywhere from $40 to $120 on Nvidia 3D Vision and DLP glasses a few years back!
BishopLord is offline
post #11 of 13 Old 07-24-2014, 04:00 PM
Archaea's Avatar
Liked: 4168
The incrediview glasses listed in the post above are blurry on fine lines like the parachute cords in Gravity when compared to the Sony PS3 glasses. I have two of each. It might not be noticeable when you don't compare back and forth - but every guest I've had says the Sony PS3 3d glasses for $20 are better video quality. However probably the majority of my guest prefer the incrediview for comfort over the Sony's.
post #12 of 13 Old 07-24-2014, 06:49 PM
Liked: 0
great,It might not be noticeable when you don't compare back and forth - but every guest I've had says the Sony PS3 3d glasses for $20 are better video quality. However probably [IMG]http://*******/WNKpGN[/IMG]the majority of my guest prefer the incrediview for comfort over the Sony's.
yenturewite is offline
post #13 of 13 Old 05-20-2015, 04:57 AM
djfranks's Avatar
Liked: 0
Hi
Do you have any expreience with TY-ER3D5MA ? I tried to sync then by holding power button for 2 sec and looks like they just blink mulitple times and shut down...regardless trasnmitter strength..
djfranks is offline
Panasonic Ptae8000u Hd Projector
