Projector offering best 3D performance, under $3000 ? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #31 of 39 Old 12-25-2013, 08:31 AM
mishari84's Avatar
Quoted: 120 Post(s)
Liked: 25
great. I think you have seen W1070 before. Would like to know if it worths the upgrade
mishari84 is offline
post #32 of 39 Old 12-25-2013, 08:39 AM
zombie10k's Avatar
Quoted: 5238 Post(s)
Liked: 5492
if you need flexible projector placement, I would be looking at the BQ W7500. The recent review on a greek site showed some nice potential over the current W7000. Faster color wheel speed and better contrast.
i'm trying to see if I can get one of these to check out soon since I had the W7000 for quite a while.
zombie10k is online now
post #33 of 39 Old 12-25-2013, 08:43 AM
mark haflich's Avatar
Quoted: 1418 Post(s)
Liked: 1014
I'm trying to see if we can get a demo of the W7500, it should be possible and will know later in the week.
ahmadka - If you weren't set on a 2 projector setup, the Epson 5030 is a great balance between 2D and 3D performance. Maybe you should considering trying it. If it doesn't meet your expectations, you can flip it for a relatively minimal loss vs. the expense of diving directly into a 2 projector setup.
If you want to do the 2 projector setup right, you may consider avoiding the low cost 3D's without lens shift and with likely rainbow effect. Even the more expensive W7000 has it but should be better with the upcoming W7500. My Sharp XV-Z30000 is the first 3 DLP I've had that is excellent in controlling RBE. it's shame that it's discontinued, but still available new for $2699. I prefer it over the W7000 because it uses RF and the perceived contrast in 3D is better than the W7000. We'll have to see how it competes with the W7500.
You mean my first 3D DLP that is excellent in controlling RBE. 3 DLP would infer 3 chip DLP which it as you know isn't. Time to edit. smile.gif
mark haflich is offline
post #34 of 39 Old 12-25-2013, 08:47 AM
kwk2293's Avatar
Quoted: 87 Post(s)
Liked: 35
Originally Posted by blee0120 View Post
Many would if it was rf, I would definitely waited for it but I just got a Mitsubishi HC8000 to do my 3D.
would be interested in mits if it could be placed center of screen for hp screen but what iv seen it cant
kwk2293 is offline
post #35 of 39 Old 12-25-2013, 09:06 AM
Deja Vu's Avatar
Quoted: 997 Post(s)
Liked: 1042
You can get very close. The trick is to to place your screen up tight to the ceiling and then use the Mits HC8000's vertical manual adjustment to fit the image into the screen. The easiest way to do this is to floor mount the projector on a table just in front of your audience and at their chest level when sitting. You may have to use a lower table depending on the size of your screen. If you're accustomed to relatively bright 3D -- in other words you have seen 3D with an Epson or the Sharp then you will be a little disappointed with the Mit's brightness unless you are prepared to use it with a smaller HP screen.
I have no interest whatsoever in watching 3D on anything but a high gain screen -- preferably a HP.
Check out the DLP projectors in this list.
http://www.avforums.com/article/the-avforums-projectors-of-2013.9675?utm_campaign=december_2013_newsletter&utm_source=Suite26&utm_medium=Email+Campaign
I think for right now the best under $3,000 3D projector is the Sharp 30000 (if you can find one).
Deja Vu is offline
post #36 of 39 Old 12-25-2013, 09:17 AM
kwk2293's Avatar
Quoted: 87 Post(s)
Liked: 35
As much as id like to not use dlp link glasses not going to sacrifice 3d brightness to do it using benqw7000 just wish benq would get their head out of their a$$ and give people option oof rf glases even ir would be better than dlp link
kwk2293 is offline
post #37 of 39 Old 12-25-2013, 10:29 AM
blee0120's Avatar
Quoted: 840 Post(s)
Liked: 543
The placement sucks, but the PQ is really good in 2D and 3D for its price
blee0120 is online now
post #38 of 39 Old 12-25-2013, 10:31 AM
blee0120's Avatar
Quoted: 840 Post(s)
Liked: 543
I would be perfectly fine with IR, its just DLP is a no go for quality 3D
post #39 of 39 Old 12-25-2013, 04:47 PM
kwk2293's Avatar
Quoted: 87 Post(s)
Liked: 35
at least with ir i could get moster ir to rf. And use optoma glasses i have for jvc rs55
kwk2293 is offline
Benq W1070 3d Ready Dlp Projector 1080p Hdtv , Benq W1500 1080p Hd Wireless Dlp Home Theater Projector Silver , Optoma Hd131xe Dlp Projector 3d , Optoma Hd25e 2800 Ansi Lumens 3d Home Theater Projector , Optoma Hd25 Lv 3d Home Theater Projector
