JVC RS-1 "How To" Invert Picture - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-27-2013, 04:38 PM - Thread Starter
wmaden's Avatar
I have been using an RS-1 for about 3 years that I bought from a store that is no longer in business.
It has always been ceiling mounted, so in actuality the picture is inverted, lately I have been experiencing short
life hours from the lamps, and have found out from a local repair shop who contacted JVC and they told the shop
that if it runs in the "Inverted" mode it DOES have tendencies to "Trip" the heat sensor, which is apparently the
problems I am now experiencing. My most "Recent" lamp(an OEM model) lasted only 1 hour, and the machine shut off.
My question is: What is the process to "Re-invert" it back to regular mode so it can be "shelf mounted"
ANY help[ will be greatly appreciated.
Wayne
wmaden is offline
post #2 of 3 Old 11-27-2013, 04:43 PM
Seegs108's Avatar
Quoted: 5167 Post(s)
Liked: 2594
http://www.projectorcentral.com/pdf/projector_manual_3588.pdf
Seegs108 is offline
post #3 of 3 Old 12-02-2013, 08:36 AM - Thread Starter
wmaden's Avatar
Thank you very much. I now have that manual....Wayne
wmaden is offline
Jvc Dla Rs1 Projector
