Just HDMI to projector ??? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 12-09-2013, 06:22 PM - Thread Starter
randyc1's Avatar
Quoted: 249 Post(s)
Liked: 42
Are there any other important cables needed to projector other than HDMI ?
I have a SC65 Reciever , but should i still add another HDMI?
Do i need PC cable if i wanted to play movies from PC ?
What is (RS232) ?
Wiring will be difficul so i dont want to forget anything !!
randyc1 is offline
post #2 of 14 Old 12-10-2013, 05:06 AM
Audiojan's Avatar
Quoted: 30 Post(s)
Liked: 34
Best way to future proof is to run about 5 strings in a 2" PVC pipe. That way you can always pull through whatever cable you might need in the future.
To watch movies from a computer, you need the correct cable for your PJ and computer… if you have an HDMI out on the computer, by all means, use that. If not, then yes, you will need a cable to connect your computer to the PJ.
RS232c is a connection for hardwired system remotes. You may or may not have one now, but I would run that anyways. When you're already at it, also run a network cable to the PJ. More and more, that is the new standard for connecting a systems remote to the PJ, so that way, you're already set if you ever need it.
Otherwise, a single HDMI cable would be sufficient. Make sure you get a cable that can handle the run length you need and is 4K compatible for the future. I order my HDMI cables (and most other cables) from www.monoprice.com , their HDMI with Redmere works really, really well and they just released a new high-speed/bandwidth cable. To boot, they're quite affordable as well (and no, no affiliation other than a happy customer)
"Suddenly the thought struck me, my floor is someone elses ceiling" - Nils Ferlin
Audiojan is offline
post #3 of 14 Old 12-10-2013, 07:14 AM
Mike Garrett's Avatar
Quoted: 12501 Post(s)
Liked: 10123
Best to just run one string and have a second string to pull through, when ever you pull a new wire. Re-use the first string the next time. That way, you keep a pull string in place all the time. If you have five pull strings in place, you are likely to get them tangled with each other.
Mike Garrett is offline
post #4 of 14 Old 12-10-2013, 07:20 AM
jpmst3's Avatar
Quoted: 196 Post(s)
Liked: 314
+1
Joe = LFE Addict
Past Builds: 24" LMS-5400 cube, Anarchy 25Hz Tapped Horn, Danley DTS-10 kit, BFM AutoTuba, BFM THT, BFM THT-LP
Joe's LOWARHORN build, Dual LMS-5400 Ultra Endtables build
jpmst3 is offline
post #5 of 14 Old 12-10-2013, 10:20 AM - Thread Starter
randyc1's Avatar
Quoted: 249 Post(s)
Liked: 42
Thanks Audiojan and everyone else for answering !!!
randyc1 is offline
post #6 of 14 Old 12-11-2013, 02:44 PM
tbirdman's Avatar
This might be too oblivious rbut a power cable.
tbirdman is offline
post #7 of 14 Old 12-11-2013, 04:44 PM - Thread Starter
randyc1's Avatar
Quoted: 249 Post(s)
Liked: 42
...Well im sure it's happened before !
randyc1 is offline
post #8 of 14 Old 12-16-2013, 01:05 AM
larryep's Avatar
3.5 mm ir cable. that has been my means of controlling projector.
larryep is offline
post #9 of 14 Old 12-16-2013, 07:34 AM - Thread Starter
randyc1's Avatar
Quoted: 249 Post(s)
Liked: 42
Not sure what that is excactly ?
randyc1 is offline
post #10 of 14 Old 12-16-2013, 08:41 AM
Liked: 10123
Just a mono male plug. A Google search will show you lots of choices. :https://www.google.com/search?q=3.5+mm+ir+plug&oq=3.5+mm+ir+plug&aqs=chrome..69i57.7275j0j4&sourceid=chrome&ie=UTF-8#q=3.5+mmmono+plug
post #11 of 14 Old 12-16-2013, 02:21 PM
larryep's Avatar
the jvc 4810 has a ir window on front and back. It also has the ir 3.5 mm plug in. I use the ir window on back so I can still use jvc remote firing at screen. many devices that have a ir 3.5mm input being used will cancel out the ir signals from a remote. at least that is what I came across with sanyo plv70,oppo and the jvc projector.
here is my remote screen
thanks Mike
larryep is offline
post #12 of 14 Old 12-16-2013, 02:30 PM
stevenjw's Avatar
Quoted: 640 Post(s)
Liked: 833
LOL, that was my first thought after reading the OP.
...Steve
"Opinions are like orgasms… mine matters most and I really don’t care if you have one or not." ;)
My HT gear
stevenjw is online now
post #13 of 14 Old 12-16-2013, 03:04 PM
tbirdman's Avatar
What was interesting was this weekend I'm shopping for a electrical box and cover for one power outlet and one HDMI connection for my projector. Home Depot had a dual gang AC plus low voltage box but no covers for it. The other usual suspect Lowes didn't have any. I was trying to avoid installing to single boxes. I ended up finding this one from Datacomm Electronics via Adoroma for $14. Lowes came close with a power plus coaxial. Both had power and USB chargers. The Datacomm is not exactly what I want, but close enough.
I would think a power outlet and a HDMI cable would be a common application. I plan to do any HDM switching with the AVR so need for multiple HDMI cables. The other option started a $42+ from Hubbell.
tbirdman is offline
post #14 of 14 Old 12-26-2013, 01:14 PM
programmergeek's Avatar
On my installs I always run a HDMI and 2 cat6 wires wheatear it be for future balms, ir bugs or trigger wires. Can't run poser by code you need an outlet near the projector but if you can use some sort of power link that is better to get it on the same surge and ground as the rest of your equipment.
But +1 on a empty pvc chase.
programmergeek is offline
Lg 47 Inch Hdtv Rs 232c
