Official JVC DILA-X500R / RS49U / RS4910U Owners Thread - Page 104 - AVS Forum | Home Theater Discussions And Reviews
 2142Likes
post #3091 of 6358 Old 01-02-2015, 02:50 AM
Liked: 0
Hi, has anyone had any experience with this PJ/or any JVC for that matter and more specifically importing from Japan to country with 230v mains supply? I am in Japan just now and the unit itself states that the voltage is 100v but i can't help but feel that JVC wouldn't use a 100v supply for home/domestic PJ's and a 100-230v switching supply for the rest of the world?
osmononame is offline
post #3092 of 6358 Old 01-02-2015, 04:17 AM
cischico's Avatar
Quoted: 128 Post(s)
Liked: 96
Sony does the same thing. It should be auto range like all other non Japanese models.
At first I thought it was 100V, but I have personally confirmed it working on 120 and 240V. Japanese companies traditionally only mark 100V on their products in their own market.
cischico is offline
post #3093 of 6358 Old 01-02-2015, 08:01 AM
beastaudio's Avatar
Quoted: 5507 Post(s)
Liked: 5324
Originally Posted by coolrda View Post
I have a black line down the middle of screen while on. Is this in demo mode or an issue with projector. I don't know how that came up or how to shut it off. Any ideas?
are you running a darbee? It could be stuck in demo mode as well where it puts a black line down the middle.
beastaudio is offline
post #3094 of 6358 Old 01-02-2015, 05:20 PM
Liked: 0
Lens memory in JVC RS49u
Couple of my friends have Panasonic AE8000u projector and there is feature in panny's that I like. If you have lens memory saved the projector detects the source and image (16:9 or 2.35:1) and adjusts the projector according to the image and fills out the screen. The projector does this automatically whereas I could not find this feature in JVC. Am I missing something or is this feature not there in JVC RS4910/49U.
foolzrule is offline
post #3095 of 6358 Old 01-02-2015, 05:25 PM
Dave Vaughn's Avatar
Quoted: 1430 Post(s)
Liked: 2187
So you're saying you want to lost the side information from the movie because zooming in a 2.35:1 movie to "eliminate" the black bars will project the sides of the image outside of your screen.
David Vaughn Blu-ray Reviewer / Technical Writer Sound & Vision Magazine (Print & Online)
For Sale: JVC X750R Projector (RS500 Equivalent) https://www.avsforum.com/forum/252-f...l#post58241092
Dave Vaughn is offline
post #3096 of 6358 Old 01-02-2015, 05:29 PM
ScottJ's Avatar
Quoted: 319 Post(s)
Liked: 162
No, he's saying he wants the PJ to switch lens memories based on the content, like the Panny does.
I don't think the JVCs have any auto-detection like this. You have to manually switch lens memories.
ScottJ is offline
post #3097 of 6358 Old 01-02-2015, 10:33 PM
Liked: 0
Thanks, I thought as much and am willing to take the risk. Next question - does anyone have the dimensions of the box?
post #3098 of 6358 Old 01-03-2015, 02:26 AM
cischico's Avatar
Quoted: 128 Post(s)
Liked: 96
No problem,
23 x 14 x 22.5 Are the box dimensions
cischico is offline
post #3099 of 6358 Old 01-03-2015, 03:03 AM
Liked: 0
No problem,
Great, just need to look for a suitcase that will be big enough to hold one although I think I might struggle on that front!
post #3100 of 6358 Old 01-03-2015, 05:38 AM
coolrda's Avatar
Quoted: 1388 Post(s)
Liked: 1503
That was my best guess as I've seen that at trade show. Fixed it by cycling the Oppo. I don't have darbee.
coolrda is offline
post #3101 of 6358 Old 01-03-2015, 06:50 AM
stef2's Avatar
Quoted: 483 Post(s)
Liked: 282
The JVC doesnt have that feature.
stef2 is offline
post #3102 of 6358 Old 01-03-2015, 06:21 PM
Gooddoc's Avatar
Quoted: 3687 Post(s)
Liked: 3284
Watching football and I start noticing that there is pulsating of colors. Nauseating actually. I had to turn the projector off and watch the plasma.
At first I thought it might be the lens aperture, but I changed it to manual and still had the problem.
I took some video of it, I'll see if I can figure out how to post it. Anyone ever see this happen and a cause?
Edit: The bumper on the car and the bow are pulsating.
Gooddoc is offline
post #3103 of 6358 Old 01-03-2015, 07:08 PM
seanbryan's Avatar
Quoted: 279 Post(s)
Liked: 172
http://youtu.be/gz5BlrBCOOY
I don't know what might be going on, but does it also do it when you pause the image?
seanbryan is offline
post #3104 of 6358 Old 01-03-2015, 07:58 PM
Gooddoc's Avatar
Liked: 3284
No, doesn't do it when paused.
Gooddoc is offline
post #3105 of 6358 Old 01-03-2015, 08:02 PM
Seegs108's Avatar
Quoted: 5167 Post(s)
Liked: 2593
Do you have eshift enabled? Do you have the MPC controls turned up/on? Note that even when you have e-shift off the MPC controls are still in effect. Do you have CMD on (smooth motion)? If so, I would turn each one off systematically to see what's causing the issue.
Seegs108 is offline
post #3106 of 6358 Old 01-03-2015, 11:23 PM
seanbryan's Avatar
Quoted: 279 Post(s)
Liked: 172
Also, are you using any other kind of video enhancement from the source (BD player, DVR, AVR, etc...)?
I once found some weird artifacts when I was using the detail enhancement of a Sony BD player along with the JVC's e-shift. But that was present in motion and when paused.
I'm not sure what's going on, but if it doesn't do it when paused but does in motion that has to be significant in figuring out what is causing it. Definitely try disabling all video and motion enhancement features and see if there is any change.
post #3107 of 6358 Old 01-04-2015, 01:30 AM
Gooddoc's Avatar
Liked: 3284
Thanks Seegs. I didn't realize that MPC was still in effect when e-shift was off.
I turned everything off and it stopped. I'll systematically turn things back on. My bet is on MPC, but I'll report back.
Gooddoc is offline
post #3108 of 6358 Old 01-04-2015, 01:34 AM
Gooddoc's Avatar
Liked: 3284
No other processing in this particular chain of components and I as mentioned above turning everything off in the 4910 solved it. So it's something there.
Gooddoc is offline
post #3109 of 6358 Old 01-05-2015, 07:22 AM
beastaudio's Avatar
Liked: 5324
I noticed this once on directv as the source. I have never seen in on any movie or concert disc I had in there, and changing the channel even took care of it. Matter of fact, the pulsating I saw was actually during football. I assumed it was something to do with the satellite, and didn't mess with any of the settings.
post #3110 of 6358 Old 01-05-2015, 08:06 AM
afss's Avatar
Quoted: 25 Post(s)
Any workarounds for the CMD banding ?
I love my 4910, but the CMD banding has been bothering me a lot on low light movies/scenes.
Is there any workaround anybody found, besides turning CMD off ?
Thank you all !
afss is offline
post #3111 of 6358 Old 01-05-2015, 08:21 AM
jjcook's Avatar
Quoted: 463 Post(s)
Liked: 188
Thank you all !
Impossible to completely avoid I'm afraid short of disabling CMD. Here is what I've done to mitigate it, in part as discovered by others:
Turn off Clear Black. Input a 10- or 12-bit deep color HDMI signal. Lastly, use the JVC autocal to calibrate the gamma.
These three things in order from least to most effective have greatly mitigated the CMD banding for me. Others have reported this didn't help at all, but it doesn't hurt to try.
jjcook is offline
post #3112 of 6358 Old 01-05-2015, 08:48 AM
afss's Avatar
Quoted: 25 Post(s)
Thanks for the prompt reply !
afss is offline
post #3113 of 6358 Old 01-06-2015, 01:49 AM
sterlingma1's Avatar
Quoted: 21 Post(s)
I am going to need a 20-25ft power cable to replace the one that comes with the 4910 projector to reach my Panamax. Monoprice sells both 16AWG and heavier 14AWG of these. Found a 18AWG on C2G site. Which is needed? What AWG is the one included with the projector?
sterlingma1 is offline
post #3114 of 6358 Old 01-06-2015, 07:43 AM
stef2's Avatar
Quoted: 483 Post(s)
Liked: 282
The question may be stupid, but yesterday, I was looking for the sharpness control on my JVC projector and could not find it.
The only mention of sharpness in the manual is in the MPC control menu (Enhance: enhances the sharpness of the image...)
So, my conclusion is that the sharpness control is called enhance on this projector.
Am I right?
If so, since I have always left that control untouched, I would like get some input from fellow users...
At what level is your sharpness (enhance) control?
How did you adjust it?
Just curious as how to make this incredible PJ even better!
stef2 is offline
post #3115 of 6358 Old 01-07-2015, 12:03 PM
Liked: 0
I will apologize in advance if I'm posting this out of turn, etc. but I just recently purchased a refurbished (long story) JVC DILA-RS49U. I was coming off the RS15, which I absolutely loved! I have to say, I'm extremely dissatisfied with the picture, mostly due to a "washout" effect I'm getting. Anything bright looks blown out! Best way I can describe it is, it's as if everything were shot with a consumer video camera. Detail in anything bright is completely gone. Has anybody else had this problem? I've tried making adjustments, but nothing that makes any kind of significant change. I appreciate any help.
ransomcosper is offline
post #3116 of 6358 Old 01-07-2015, 01:55 PM
jjcook's Avatar
Quoted: 463 Post(s)
Liked: 188
This sounds like your "Input Level" setting may be incorrect. For video levels (16-235), it should be set to Standard and for PC levels (0-255) it would typically be set to Enhanced. The setting defaults to Automatic. Try switching between these two forced settings and see if the problem persists.
jjcook is offline
post #3117 of 6358 Old 01-07-2015, 04:48 PM
Sparkygod1's Avatar
Quoted: 39 Post(s)
Liked: 37
I saw the X500 last year at CEDIA and installed one for a customer two weeks ago..I'm all in. The problem I have is I haven't settled on a screen yet. I liked The SI Slate screen I saw but I wanted an acoustical for my new HT ver4.1 Atmos. So excited! Any ideas?
Sparkygod1 is offline
post #3118 of 6358 Old 01-07-2015, 09:00 PM
blipszyc's Avatar
Quoted: 153 Post(s)
Liked: 78
Finally got a chance to spend some time with the 4910. There is a humming noise that seems to go away when I turn off e-shift. Is this normal? I also notice the same humming when the unit is switching from 1080p60 to 1080p24. With e-shift on it was constant, with it off, it's only when switching video modes.
Visit the Lipszyc Home Theater! 1.0
2.0 done and finally posted! - Theater 2.0
And now...The Queen City Theater (3.0)
4.0 - TBD
blipszyc is offline
post #3119 of 6358 Old 01-07-2015, 09:52 PM
seanbryan's Avatar
Quoted: 279 Post(s)
Liked: 172
Yep, it's normal. E-shift makes noise, and this is also heard when switching video modes as you described.
post #3120 of 6358 Old 01-08-2015, 06:57 AM
beastaudio's Avatar
Liked: 5324
Can't say enough good things about my Falcon Screens Horizon 4K material. It is just rock-solid on anything I have thrown at it. I watched ender's game last night which has a lot of space scenes and it was just unreal There is a little wait time right now as Rich at falcon is getting inundated with orders, but the wait is well worth it, the frame is easy-peasy to install and rugged as all get-out, and you can easily do it all within 30-45 minutes by yourself
Sparkygod1 likes this.
Jvc , X500
