Thread Tools |
in my first attempt, i selected gamm+color in the autocal software, but i wasn't pleased with the colors afterwards.
so i loaded the backup file back into the PJ and selected then gamm only (33 steps).
the result was a fixed gamma and good colors (colors judged by what i can see on the screen)^^
i'm going to buy a xrite i1display pro and use HFCR to check the my PJ, because all the calibration stuff is kinda cool
Sponsored Links | |||
Advertisement |
Quoted: 30 Post(s)
Liked: 2
here's a translated article with many screenshots from a german forum^^
https://translate.google.com/transla...-text=&act=url
enjoy
edit: he uses a spyder 4, but the xrite i1display sensor works too
enjoy
Quoted: 255 Post(s)
Liked: 176
Advertisement |
Quoted: 5215 Post(s)
Liked: 2053
It doesn't need to be a Pro, any version of Spyder 4 will work.
JVC DLA-NX7; Denon AVR-X3400H; HD Fury Vertex; ATV4K; Fire TV Cube
JVC Projector Bright Curves; Optimizing HDR;
Creating a basic HDR curve using Arve’s Tool;
Replacing JVC Bare Bulbs
Quoted: 255 Post(s)
Liked: 176
Express is a different meter. It doesn't have the ambient light sensor, which might be the only difference. Though I dunno if JVC's software might balk at that as they only list Pro and Elite versions for their SW.
In any case, likely I'd have to buy a used meter off ebay, putting the 'luck of the draw' into an even more precarious situation.
Liked: 2053
Elite is more $$. Only difference is software though.
Quoted: 255 Post(s)
Liked: 176
Ok thanks, I'll keep an eye out for those too....
Quoted: 88 Post(s)
Liked: 38
Exactly. As I said, the content he's watching is not actually 50 or 60p a 4K. There is some kind of pulldown happening, which means he should try and output to the projector at the native refresh rate of the content. If he does this it should unlock the projector and allow for more options in the menu to be used. I had an X500 for 2 years and feeding the projector a 4K/24p image does not have the same limitations.
Liked: 2053
It will do the same thing with directv 4k feed has anyone tried feeding projector 4k/60signal while doing jvc autocal
The instruction specifically says "Make sure to input video signals (1080 or 720) when the calibration software is running. Calibration does not work with 4K input."
Quoted: 30 Post(s)
Liked: 2
Can you point me to some of those 'good' step by step manuals?
https://www.avsforum.com/forum/24-dig...l#post39729050
Quoted: 28 Post(s)
HI
Was wondering if someone can help me out here. I am on the JVC site and want to download just the bt2020 color profile but for the life of me i cant open it. It says i need net framework four and I have that installed.
Anyone else have trouble downloading this?
Quoted: 5167 Post(s)
Liked: 2594
HI
Quoted: 28 Post(s)
Liked: 2594
Quoted: 28 Post(s)
Liked: 2053
I have to run my TV box at 1080p as the 4K mode is unusable. I can run 4K on my Fire TV box, but the content is at 24p while the menu etc are at 30p. Every time it goes from one to the other the screen blacks out for about seconds while the projector is re-syncing. Very annoying. Hopefully the newer models don't have this issue.
Quoted: 88 Post(s)
Liked: 38
Quoted: 24 Post(s)
DLA-X500R Waring Indicator
Hoping someone can help, have about 2000 hours on the original bulb in my 3-year old projector.
A week ago, got the attached warning indicator with the outside lights red and middle light orange and blinking. Can't find this indicator in the manual.
Thinking it was the bulb, ordered and installed the new one and fired it up. Also recleaned the filter. Beautiful image for 3 minutes, then back to dark screen and the same warning indicator.
Any ideas before I resign myself to sending in for service? Thanks...
John
John
"What happens in Vegas..."
Quoted: 87 Post(s)
Liked: 40
Hello all. I have the X500R and use an UHD player with the HD Fury integral to output 4k. My question is, how can I now connect my new 4K DIRECTV box to my JVC? The 4K box also requires HDMI 2.0 and HDCP 2.2 compliance. My AVR is HDCP 2.2 compliant. Can I just run the 4K box through the Integral as well? If so, what settings do I need to change on the Integral? If not, do I need a new and separate Integral?
Quoted: 155 Post(s)
Liked: 48
John
John
I had a similar experience with my rs57 although I cant remember the exact warning indicator pattern. I also changed the bulb with results similar to yours. Turns out that the ballast was bad and had to be replaced. It's been working great since the repair.
JVC RS640; RUIPRO 10m HDMI cable; Marantz AV7704; Lumagen Pro 4240; Oppo BDP-203;Triad Silver LCR, Onwall Bronze Surround, Inwall Bronze Omni, KEF Inceiling Ci 160QR x 4; Dual RSS460HO-4 18" SWs
Quoted: 24 Post(s)
Is the ballast user replaceable or did you send it in for service?
John
Liked: 2053
Is the lamp cover in place?
Quoted: 155 Post(s)
Liked: 48
Thanks for the feedback. The strange thing is, my fault/warning indicator in the row of 3 lights (outer two are solid red, the middle light is orange and blinks twice), doesn't appear in the manual. My dealer is investigating, I'll post his findings.
John
John
Quoted: 24 Post(s)
Did you reset the lamp hours after changing the bulb?
Thanks for your thoughts...
John
Quoted: 147 Post(s)
Liked: 83
I have not reset the lamp hours, with both old and new bulb image is only there for 60 seconds or so before it goes dark and warning indicator lights up. This happened both with old bulb and after installation of new one. Projector is on shelf, hasn't moved or been touched since I last cleaned the filter a year ago so don't know how lamp cover could have come loose. I tightened it carefully when new bulb was installed.
John
John
Changing your HDMI cable might be something to try before shipping your projector in for repairs.
Duane
Quoted: 24 Post(s)
My 4910 started acting up about 3 weeks ago, but not similar to what you are experiencing. Mine was taking the left half of the image and displaying it on the right half, but stretching it across 3/4 of the screen and putting the right half of the image on the left side of the screen and stretching it across 3/4 of the screen so i was seeing a double overlapped image. No warning lights while it was running (I had about 3300 hours on the bulb and had been getting a orange warning light when the projector was off since 3000 hr). I replaced the bulb, but this didn't solve the problem. Then I replaced the HDMI cable between my receiver and my projector and this has solved it so far. Don't know why the HDMI cable would suddenly go bad when I hadn't touched it in at least a year.
Duane
Duane
John
how much a new bulb brighter than 400h old, how long on old bulb did you feel darker? thanks.
Liked: 3
getting bt2020 with philips player
I am running into a problem getting SDR, BT2020 to my X500. I am borrowing my dads philips 5502 and with that to the linker then to the projector I cannot seem to make it work. When I set the linker to any of the settings that have hdr in the title (2, 6, 8), I get BT2020 to the projector but the HDR is coming along with it and its washing everything out. When i set the EDID to 10 or 12, it sends 709. The settings in the philips do not allow a forced HDR, only auto and off. Im thinking that is the issue. From what Ive read in the forum I am supposed to set the HDR to on, but I do not have that option. Anyone else run into this issue? I thought about leaving the HDR on and importing a custom gamma curve, but I can only get around 30 ftL with my lamp on high so its just not bright enough for my setup.
Quoted: 34 Post(s)
Liked: 2053
Did you use th "2014" version of the Arve Tool?
Advertisement |
Tags |
Jvc , X500 |
Thread Tools | |
Posting Rules | |
