Official JVC DILA-X500R / RS49U / RS4910U Owners Thread - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 2142Likes
post #61 of 6358 Old 12-17-2013, 07:32 PM
StevenC56's Avatar
Quoted: 565 Post(s)
Liked: 201
Originally Posted by SOWK View Post
The lumen output.
I would hope so for that kind of $.
JVC X750R Projector,Yamaha CX-A5200 Pre-Pro, Yamaha RX-Z11 Receiver, (Amps Only) Yamaha MX-D1 Power Amps x 2, Yamaha RX-Z1 (L&R Surround Channel Amp), Oppo BDP-103D BR, Panasonic DP-UB820 UHD, Pioneer Elite CLD-99 LD, Definitive Tech BP7000SC Mains, CLR3000 Center, BPVX Surround Sides&Backs, BPX F&R Presence, Martin Logan Abyss Front L&R Subs/Dynamo L&R Rear Surround Channel Subs, Infinity SSW-210 Center Channel Sub.
StevenC56 is offline
post #62 of 6358 Old 12-18-2013, 01:20 AM
Qualunquemente's Avatar
Quoted: 52 Post(s)
I wonder if RS57 really has double the contrast then the RS49 ...
Qualunquemente is offline
post #63 of 6358 Old 12-18-2013, 02:41 AM - Thread Starter
Home Theater Enthusiast
SOWK's Avatar
Quoted: 1373 Post(s)
Liked: 2137
Only if you have a small enough screen or high enough gain to close the iris all the way. And probably not even then.
Wisconsin Home Theater Enthusiasts Meet: Main Thread l Gear For Sale
SOWK Home Theater
SOWK is online now
post #64 of 6358 Old 12-18-2013, 05:02 AM
blee0120's Avatar
Quoted: 840 Post(s)
Liked: 543
If you need lumen output to be higher than 700 lumens, you are going to get close to the same contrast numbers on all JVCs. The get those numbers on the higher models, you need to close the iris down. For instance, if you was running a rs49 with the iris open, you should get close to 25000:1, and on the RS57, you should get 30,000:1, then on the RS67 about 35,000:1. Those are not very noticeable for the amount of money. But if you close them half way, its a difference but you get maybe 500 lumens at max. If you close the iris, you get about 250 lumens
blee0120 is offline
post #65 of 6358 Old 12-18-2013, 03:27 PM
Bardia's Avatar
Quoted: 222 Post(s)
Liked: 133
I was thinking About getting this but I'm pretty happy with my RS4810
I'll wait for true 4K to become common and I will upgrade then. Along with a bigger screen
Bardia is offline
post #66 of 6358 Old 12-19-2013, 07:11 AM
Quoted: 52 Post(s)
I made some calculations based on my screen (Black Diamond 110" 21:9):
With 900 calibrated lumens I should get 60 cd/mq white so, yes, I will need Iris fully open or ... use the new dynamic iris function but i wonder if it really does make sense to use dynamic iris on a jvc : when a particular scene will make the iris fully close down blacks will probabibly became better then an Oled but whites should be like 7-8 cd/mq (in my case) like a grey 35 ire ... -__-
So I think I'd go for fixed iris fully open and so, as you say, an RS49 would be a wise choise.
Maybe rs57 is better in some other department then rs49 ? lens quality is the same ?
Another question : I have a RGB-LED vpr and never had a JVC : how muh cd/mq loss should I expect as lamp ages to the end ? half ? or even less ?
post #67 of 6358 Old 12-19-2013, 03:57 PM
blee0120's Avatar
Quoted: 840 Post(s)
Liked: 543
they are using the same lens. I have no idea about the lamp
blee0120 is offline
post #68 of 6358 Old 12-19-2013, 04:29 PM
larryep's Avatar
when jvc goes to true 4k projectors do you guys think they will have 4th gen. 8k eshift?
larryep is offline
post #69 of 6358 Old 12-19-2013, 04:38 PM - Thread Starter
SOWK's Avatar
Liked: 2137
Not right away, that's my thought.
SOWK Home Theater
SOWK is online now
post #70 of 6358 Old 12-19-2013, 04:44 PM
Seegs108's Avatar
Quoted: 5167 Post(s)
Liked: 2593
They need something for people to upgrade to the year after. 4K first then they'll add the eshift the following year.
Seegs108 is offline
post #71 of 6358 Old 12-19-2013, 04:54 PM
blee0120's Avatar
Quoted: 840 Post(s)
Liked: 543
They are going to have to do some type of gimmick because I don't know if they can get a bright, sharp image like Sony has been doing. They can't come with a 800-900 max lumen 4K projector. If they had eshift 8K, even though it will be all gimmick, they will have something to compete. Unless that do something to make it much less. I think they will impress a lot of people if they can get a 4K unit with 1200 calibrated lumens with their native contrast.
blee0120 is offline
post #72 of 6358 Old 12-19-2013, 05:00 PM
mbw23air's Avatar
Quoted: 206 Post(s)
Liked: 177
I would think JVC's first true 4k projectors would have to be brighter to accommodate the larger screens that 4k is meant for. 1200 calibrated lumens minimum with the same native contrast we are used to now would be an awesome start.
JVC RS600(Fantastically calibrated by ChadB), Stewart Cima Neve 2.35 115" diagonal screen, Darbee Darblet, Denon AVR-X7200WA(7.6.4), M&K Speakers, 6 ported 18" subs powered by 3 inuke 6000dsps, 2 Behringer B1200D Mid Bass Modules, Buttkicker transducer, Oppo BDP-93 blu-ray player
mbw23air is offline
post #73 of 6358 Old 12-19-2013, 05:23 PM - Thread Starter
SOWK's Avatar
Liked: 2137
Do we still not have an owner?
SOWK Home Theater
SOWK is online now
post #74 of 6358 Old 12-19-2013, 05:29 PM
StevenC56's Avatar
Quoted: 565 Post(s)
Liked: 201
post #75 of 6358 Old 12-19-2013, 05:29 PM
cardoski's Avatar
Quoted: 2530 Post(s)
Liked: 2808
I have been told there is a very good chance I will get it before Christmas. In fact they said they would air ship on their dime. This extra time has given me a chance to hang more triple velvet and a few other little improvements.
Listening with Focal Elex headphones, Topping DSD Dac, SENCUN-audio tube preamp with tone control and Little Dot hybrid tube amp with GE tubes.
Watching in a room ensconced in velvet.
cardoski is offline
post #76 of 6358 Old 12-19-2013, 05:33 PM
mbw23air's Avatar
Quoted: 206 Post(s)
Liked: 177
My dealer today said his distributor would have the new JVC's tomorrow. So, I will not get my X700R before Xmas but I am hopeful for before the first of the year.
Mike
mbw23air is offline
post #77 of 6358 Old 12-19-2013, 10:04 PM
StevenC56's Avatar
Quoted: 565 Post(s)
Liked: 201
Mike
That's what my dealer is being told by his distributor as well, so hopefully some of us will soon have nothing but positive reports on these new models.wink.gif
post #78 of 6358 Old 12-22-2013, 12:07 PM
Sailor Bill's Avatar
I'm also waiting with all of you. In anticipation, I need to modify my DIY mount. I think I have found the proper locations for my attachment but does anyone know what the thread size is? I want to have the proper hardware and I can buy a new piece of 1/4" plexiglass (or maybe 3/16" aluminum since this JVC is heavier than my old Ae900.) Thanks.
Sailor Bill is offline
post #79 of 6358 Old 12-23-2013, 06:58 AM
pottscb's Avatar
Quoted: 307 Post(s)
Liked: 123
OK, the first person who receives this PLEASE post your initial impressions of the dynamic iris on a dark movie like Harry Potter Deathly Hallows 2. If it doesn't pump this should be an untouchable image...
pottscb is offline
post #80 of 6358 Old 12-23-2013, 07:00 AM - Thread Starter
SOWK's Avatar
Liked: 2137
or the intelligent Iris doesn't work, one of the two... lol.
(from what I read, the Iris is not in "real" time, and will cause gamma shifts near black when in use. This is what I would call un-usable if it is the same in final retail product.)
Although even if it doesn't work, the JVC's native is so good it wont really matter anyhow.
SOWK Home Theater
SOWK is online now
post #81 of 6358 Old 12-23-2013, 07:21 AM
seanbryan's Avatar
Quoted: 279 Post(s)
Liked: 172
So IF JVC sh*t the bed with their DI implementation, what are the chances there could be a software upgrade at some later point?
Hopefully it will be better than that early preproduction review we are concerned about. Isn't there an option to run the DI with no gamma manipulation as well?
seanbryan is offline
post #82 of 6358 Old 12-23-2013, 07:44 AM
cardoski's Avatar
Liked: 2808
Dam, won't be getting my PJ tomorrow. Originally it was going to be air shipped today. I guess there is an Ice storm down south and it has delayed the shipments. Further more my guy can't get a hold of JVC.
cardoski is offline
post #83 of 6358 Old 12-23-2013, 10:52 AM
noah katz's Avatar
Quoted: 1819 Post(s)
Liked: 631
Got a link?
I missed any mention of issues with the DI; in fact people wondered if it wasn't even turned on in the show samples.
Noah
noah katz is offline
post #84 of 6358 Old 12-23-2013, 12:36 PM
pottscb's Avatar
Quoted: 307 Post(s)
Liked: 123
Just talked to Mike at AVS and purchased the pre-order! (today's the last day FOR SURE as he said they got a pallet with 100 or so 4910's so the deal is off at COB today) He also said his shipping guys were working like crazy to get every single pre-order out today (except mine, as I requested special shipping instructions due to living in the stix-Pony Express!). Anyway, this is my most expensive pj purchase yet and I hope it lasts me until 4K gets super cheap. I'm excited about every single new feature on this pj...I hope the e-shift3 makes it close to as sharp as my past 3 DLPs (optomaHD30, infocus8602, Sim2HT3K), even if not, I only watch movies so the huge bump in contrast should FAR outweigh the difference in sharpness...lets hope! Wondering if anyone who gets theirs first and does the auto-calibration could post their experienes as this will probably be the route I go.
cardoski likes this.
pottscb is offline
post #85 of 6358 Old 12-23-2013, 12:48 PM
seanbryan's Avatar
Quoted: 279 Post(s)
Liked: 172
Originally Posted by noah katz View Post
Got a link?
From the "new range" thread
https://www.avsforum.com/t/1486011/new-range-jvc-2014/2340#post_24102132
post #86 of 6358 Old 12-23-2013, 01:13 PM
StevenC56's Avatar
Quoted: 565 Post(s)
Liked: 201
post #87 of 6358 Old 12-23-2013, 01:54 PM
noah katz's Avatar
Liked: 631
Thanks, Sean, somehow I missed that.
Noah
post #88 of 6358 Old 12-23-2013, 04:53 PM
seanbryan's Avatar
Quoted: 279 Post(s)
Liked: 172
Originally Posted by StevenC56 View Post
What's with the "roll eyes"? I said it was a preproduction unit.
And several reliable forum members saw the JVCs at CEDIA and did not see any problems with the iris. So yes, hopefully the implementation is better on release units than from the preproduction review.
post #89 of 6358 Old 12-23-2013, 06:13 PM
StevenC56's Avatar
Quoted: 565 Post(s)
Liked: 201
Sorry. Thought you were dooming the iris already. My bad. I have a X500R on order, so I'm being optimistically defensive..smile.gif
post #90 of 6358 Old 12-23-2013, 06:43 PM
Seegs108's Avatar
Liked: 2593
Even if it doesn't function ideally you can disable it and still get reference level contrast and black levels. Unlike every other digital front projection technology that relies on a DI to simply compete with JVCs native contrast and black level you don't have to be depent upon it performing optimally to get a great looking image.
Though it would be nice for it work as well as a Sony/Sim2/Planar/Runco implementation. tongue.gif
Seegs108 is offline
Jvc , X500
