Official JVC DLA-X700R / RS57U Owners Thread - Page 76 - AVS Forum | Home Theater Discussions And Reviews
 35Likes
post #2251 of 2272 Old 11-03-2018, 05:19 PM
mskreis's Avatar
Quoted: 157 Post(s)
Liked: 48
Originally Posted by JohnLew View Post
After replacing it did it work fine? I'm considering replacing the ballast myself, would like to get a couple more years out of this PJ and then upgrade.
-jl
It’s still working fine - the ballast was replaced close to 3 years ago.
JVC RS640; RUIPRO 10m HDMI cable; Marantz AV7704; Lumagen Pro 4240; Oppo BDP-203;Triad Silver LCR, Onwall Bronze Surround, Inwall Bronze Omni, KEF Inceiling Ci 160QR x 4; Dual RSS460HO-4 18" SWs
mskreis is offline
post #2252 of 2272 Old 11-16-2018, 09:57 AM
JohnLew's Avatar
JVC RS57U Ballast Replacement Issue
So I had the flashing lights indicating a likely ballast failure on my RS57U. 4-5 years old but very light usage.
Decided to replace it myself, ordered a new ballast, took apart the PJ last night, installed the new ballast. Let the unit sit overnight and turned it on today, the ballast issue seems to be solved - the unit powers up, stays on without automatically shutting down, light from the iris, etc. Seems to be operating normally but...
There is no picture being projected! I can see the light in the iris and if I put something close to the lens then I see light being reflected off it, but there is nothing being projected out to the screen.
Before I take it apart again to go back through the connections and make sure I fully seated everything, etc., does anyone have any ideas on what specifically could be causing this? Up until I had the ballast failure everything worked fine. I tried a new lamp, just in case, but no joy there either.
JohnLew is offline
post #2253 of 2272 Old 11-17-2018, 07:49 AM
edfowler's Avatar
Quoted: 349 Post(s)
Liked: 188
Did you try both hdmi inputs with a source playing?
Sent from my SM-G950U using Tapatalk
Chad B calibrated JVC RS600, 112" wide 2.35 DaLite 2.8 High Power Screen (395 calibrated nits baby!!), 7.5.4 Yamaha RX-A3050, Yamaha RX-Z9, Aerial Acoustics Model 6, Model 5, CC3, Def Tech UIWBP/A, 4-15" Infinite Baffle Sub + 15" Velodyne Sub Near-field, OPPO 203, Panasonic UC420, Geek Pulse DAC, Nvidia Shield. Lots of iFi and Furman power filters which made my computer audio listenable.
edfowler is offline
post #2254 of 2272 Old 11-18-2018, 08:33 PM
edfowler's Avatar
Quoted: 349 Post(s)
Liked: 188
Have you disengaged the external inertial dampener?
edfowler is offline
post #2255 of 2272 Old 11-20-2018, 05:44 PM
JohnLew's Avatar
Love it
Got it sorted out. There is a connector on the underside of the third board you remove while replacing the ballast. It's not as apparent as the others. Forgot to connect it when reassembling.
Got it reconnected and everything seems to be working fine now.
JohnLew is offline
post #2256 of 2272 Old 11-20-2018, 05:57 PM
edfowler's Avatar
Quoted: 349 Post(s)
Liked: 188
Glad you got it sorted out. I would not want you to think that I was not taking the simulation, I mean situation, seriously.
edfowler is offline
post #2257 of 2272 Old 01-28-2019, 07:38 AM
JDEATON's Avatar
Quoted: 171 Post(s)
Liked: 99
May I ask if anyone has a preferred source for high quality reasonably priced replacement lamps?
Yesterday I installed a PK-L2312UP lamp assembly with a Ushio bulb from Projector Lamp Source. Their website says, “Genuine Original Lamp with Housing”. It cost about $205, fit perfectly and the picture looks great, much brighter.
If you read between the lines, I think they are stating the assembly has the original Ushio bulb but is not necessarily an OEM housing/assembly. Is there any reason not to use this type of replacement lamp?
John
Audio: Classé SSP-800 Pre-Pro, Classé CA-5300 Amp, 2-Classé CA-M600 Mono Amps, Mytek Brooklyn DAC, Roon, Tidal, MQA Usher Audio CP-8571 LR, BE-616 C, S520 S, SVS SB16 Ultra X 2
Video: JVC DLA RS-6710 Projector, Oppo BDP-105D, Roku Ultra, DirecTV Genie,
Other: APC H15 Power Conditioner, Dedicated 20 Amp 10 Ga Romex Circuit, eero Pro WiFi System with Actiontec Bonded MoCA Ethernet
JDEATON is offline
post #2258 of 2272 Old 04-11-2019, 06:41 PM
jschefdog's Avatar
Problems connecting to Sony UBP-X700
I just got a new Sony UBP-X700 4K Ultra HD Blu-ray player. It works fine with my LG UHD TV, but when I tried connecting it to my RS57 with the output resolution set to Auto, the image on the screen blacks out and comes back every few seconds.
When I first turn on the player the screen displays "HDMI1 4K/2K" in the upper right corner, so the RS57 seems to detect a 4K signal, but then the black outs start. If I force the player to output 1080P the black outs stop.
If I try playing a 4K disc with Auto resolution, the player displays this message:
For optimal picture quality, connect
your 4K Ultra HD Blu-ray player to a
television that supports 4K Ultra HD
with High Dynamic Range.
So it does not seem to recognize the RS57 as supporting 4K. Then it switches the output to 1080P and the movie plays fine.
I tried two different HDMI cables which are supposed to support 4K and which work fine with my TV, but the problem occurs with both cables.
Has anyone encountered a problem like this?
John S
jschefdog is offline
post #2259 of 2272 Old 05-14-2019, 06:15 PM
Liked: 3
This happens because RS57 does not support HDCP 2.2. It is possible to send 4K resolution to the projector, but 4K content, which is protected with HDCP 2.2, will not play due to copy protection.
You need something like an HDfury Linker to play 4K content, and even then you'll need to use 4K SDR, because RS57 does not support HDR.
tom0 is offline
post #2260 of 2272 Old 05-14-2019, 08:00 PM
Liked: 3
John
All of this you probably already know.
There is a reason to prefer new OEM lamps from authorized dealers: you know what you are buying. With "high quality" or "replacement" lamps, or lamps from other sources, you usually don't. You are playing the replacement lamp lottery. Such lamps could be significantly dimmer, or they could die more quickly, or they could be just as good as a new OEM lamp. Even if it looks good when you first install it, there is no way to know how good it will be in the long run.
tom0 is offline
post #2261 of 2272 Old 05-15-2019, 06:50 AM
JDEATON's Avatar
Quoted: 171 Post(s)
Liked: 99
Thanks for the reply. I guess I’m just a died in the wool bargain hunter. The lamp I referred to above is still going strong with no issues. So, I purchased another as a backup.
Just for fun, today I searched on PK-L2312UP and ran across this site https://www.jaspertronics.com/produc...nt=40303643724. They boldly claim “Original Ushio PK-L2312UP Lamp & Housing for JVC Projectors – 240 Day Warranty” $100.99 with free shipping. So, I ordered one. I know I’m living dangerously; later today I may even attempt running with scissors.
My experience with lamp-based projectors is the lamps don’t provide truly satisfying brightness for more than roughly half of the stated life. I’ve become tired of nursing an old lamp while wishing the image looked like it did when the lamp was new.
Thus, until laser projectors become mainstream and affordable, I think I’ll just continue to buy cheap replacement lamps.
JDEATON is offline
post #2262 of 2272 Old 05-15-2019, 07:19 AM
Quoted: 6154 Post(s)
Liked: 2563
This is true of the older lamps, but many users of the recent model JVC lamp PK-L2615U report minimal dimming (around 20%) even at 3000 hours.
JVC DLA-X550R; Denon AVR-X3400H; HD Fury Linker / Vertex 2; ATV4K; Sony UBP-X700
JVC Curves; Optimizing HDR;
Creating a basic HDR curve using Arve’s Tool;
Replacing JVC Bare Bulbs
Dominic Chan is online now
post #2263 of 2272 Old 05-15-2019, 02:39 PM
jschefdog's Avatar
Thanks tom0 for the answer. I have not been burned by HDCP issues in a long time so this never occurred to me. I knew the RS57 does not support HDR, but could not figure out why the player would not just output 4K SDR from 4K discs. Thanks for the tip on HDfury Linker. I will have to decide if it is worth the price.
John S
post #2264 of 2272 Old 05-15-2019, 04:43 PM
Liked: 3
I am also a bargain hunter. I would not say that I am opposed to buying non-original lamps, and JVC lamps in particular are quite expensive.
That said, I think it is important to be aware of potential issues with non-original lamps, because the market is not buyer friendly. Often, sellers use the manufacturer's name, do not openly say that their product is not OEM, and people might buy such a lamp without knowing that, possibly even paying a price similar to price of a new OEM lamp from an authorized dealer.
Since all replacement lamps are sold as "no-name", in most cases you cannot be sure what you are getting, where the parts are from, and if they were previously used. There are few incentives for sellers to sell a quality product, other than making sure it actually works when first installed. Most people will not measure how bright the lamp is when they install it and how much it is dimming over time. Even if it works well when you first install it, if it fails after 500 hours and 2 years of use, there is nothing you can do. If it damages your projector. there is nothing you can do.
Some people had a bad experience buying non-original lamps, including projector damage.
https://www.avsforum.com/forum/24-di...l-housing.html
https://www.avsforum.com/forum/68-di...termarket.html
https://www.avsforum.com/forum/68-di...ufacturer.html
https://www.avsforum.com/forum/68-di...ment-lamp.html
I hope that you won't have any issues with your lamp, and it would be interesting to hear how many useful hours it was good for once it inevitably fails or becomes too dim.
Earlier this year, when I was deciding to purchase the Epson 5040UB, cost of replacing the lamp was something I thought about. With new OEM lamps in $200-$300 range, buying one every 2 or 3 years did not seem too expensive. If I used it a lot more, buying a bare bulb and reusing the housing seemed like a reasonable alternative to save money. However, at the rate I use the projector I'd only save about $50 per year, and only if the bare bulb worked as well as a new OEM lamp.
tom0 is offline
post #2265 of 2272 Old 05-16-2019, 09:10 AM
JDEATON's Avatar
Quoted: 171 Post(s)
Liked: 99
Thanks again for your insight and examples Tom. I do appreciate it. This JVC 6710 is my third projector since about 2004. I think it is a 2014 model year device. I purchased it used in late 2015. It had roughly 200 hours use and came with a spare lamp. While it is a pixel shifter, its not truly 4K compliant from an HDMI/HDCP perspective; it’s about 5 years old and has a resale value of very little. That said it still works very well, and from my viewing position with my eyesight I don’t think I would see a resolution difference if I had a 4K machine. What I am missing is the expanded color gamut and pop of HDR. I have been following the Epson 5050 / 6050 anticipation and owner’s threads and can’t help but think for a reasonable amount of money I may be able to buy a projector l like better than my JVC. I really think I’m more into brightness and pop than I am shadow detail and dark scenes.
So, while I don’t want to blow my projector up with a bad bulb, if the old thing breaks down, well then it may be time for a new Epson, or maybe that BenQ 5550, or maybe by then there will be affordable laser alternatives.
JDEATON is offline
post #2266 of 2272 Old 02-17-2020, 06:37 AM
frozenkuku's Avatar
guys i need help
today sudeenly projector cannot boot
bugged screen like this
it's not HDMI cos i cannot even call projector menu
it was working fine yesterday
frozenkuku is offline
post #2267 of 2272 Old 02-17-2020, 08:49 AM
frozenkuku's Avatar
I have replaced new lamp, and not working, so it's not a lamp issue.
it cannot display anything even the logo.
sometimes the screen only display few small white dots
post #2268 of 2272 Old 02-21-2020, 08:14 AM
PanzerFreak's Avatar
Hi,
I have a JVC RS56U (close enough to 57U haha) that I purchased used back in 2013 or 2014. The other day I turned the projector on without issue but it would not pick up a signal from my receiver. I ended up powering down the projector, and then unplugged it. When I plugged it back in the standby, and lamp lights were solid and the warning light was blinking. The warning light is blinking 6 times which is not mentioned in the manual (it only lists reasons / steps for up to 5 flashes).
Do anyone know what may have caused this? I had an issue years ago with 3 lights flashing and then the projector didn't turn on again until I replaced the bulb. That bulb lasted for around 1,400 hours, this one has just under 1,000. Would it be worth it to try replacing the bulb again or is this likely unrelated? I'm curious how much it may set me back to send the projector into JVC and have it fixed if I go that route.
Thank you
PanzerFreak is offline
post #2269 of 2272 Old 05-19-2020, 07:52 PM
JVC DLA-X700R randomly turning off, bad bulb or ballast?
Hi,
I've been trying to troubleshoot this issue for a few weeks and it's starting to drive me a bit crazy. I bought a used JVC DLA-X700R on Ebay that the seller claimed just needed a new bulb. I ordered the OEM bulb below from Jaspertronics.
https://www.jaspertronics.com/produc...BoCAl8QAvD_BwE
After installing the new bulb the projector worked perfectly without issue for maybe the first 5-10 hours or so. I then noticed the projected image starting to flicker. I researched turning the lamp from low to high and back to low. This briefly resolved the flicker issue but would also typically result in the projector turning off (just from switching from low to high lamp power or vice versa) and displaying several flashing lights. As time has gone on the projector will turn off randomly after being on for only a few minutes, I also noticed it turning off after simply switching inputs on my audio receiver (very strange).
Below is a video of the behavior when the projector randomly turns off as well as when I've changed inputs on my audio receiver (switching from an Apple TV to Blu Ray player for example). I can't find the light pattern below in the manual.
The second video displays the lamp light flashing after the behavior in the video above lasted for a few minutes. I just noticed this behavior for the first time tonight after the projector turned off after being only for just 5 minutes.
I did attempt to replace the ballast board only to find out I ordered the wrong board...ugh. The JVC X700R uses an MPL3120E ballast board, whereas slightly older models use a RPB-0526GA board. I ordered the RPB-0526GA part which isn't the correct part. I've heard the newer ballast boards are more reliable so maybe it's not the ballast board after all? All I know is it was a pain to get down to the ballast board and then reassemble anything (thank you labeling and pictures haha). Is it possible that the new bulb is bad?
Any advice is really appreciated!
Thank you
post #2270 of 2272 Old 05-20-2020, 04:13 AM
This morning I attempted to test for continuity on the bulb. Here's a video of the test, not sure if I did this right or if this type of test can be done with these bulbs. I initially get a value but then it quickly drops to 0 as seen in the video, same with the opposite connection. I receive no value between the two connector leads that attach to the projector.
https://youtu.be/6F2Bw074NY8
post #2271 of 2272 Old 05-20-2020, 08:32 AM
Dennis Moore's Avatar
Quoted: 119 Post(s)
Liked: 24
I just purchased another X500 that is apparently behaving similarly to yours in the first video, PanzerFreak. The seller sent me a video showing it projecting a BR menu, and stated that whenever she would press a button or interact with the input in anyway, the thing would shut down. The video shows a solid standby light and a flashing warning light, with the lamp light flashing twice as well. Exactly like yours.
I won't have the projector for a few days, but am curious to follow your progress... just from initial reading, it doesn't seem like a ballast issue?
Dennis Moore is offline
post #2272 of 2272 Old 05-23-2020, 10:23 AM
Quoted: 119 Post(s)
Liked: 24
Just got it in the mail... plugged it in, turns on. I switch it from Ceiling to Front and it looks good. Then the lamp shuts off and the lights start flashing. It's flashing twice on the Lamp light and the Warning is either six, or constant.
Did you make any progress with yours?
I am thinking I will try to replace the lamp and update the firmware?
Jvc Dla X700r
