Wall mounted Epson 5010, 200" image! vibrating wall from HVAC. solution? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-18-2013, 05:12 PM - Thread Starter
gadgetfreaky's Avatar
Quoted: 148 Post(s)
I have a 5010 mounted in the theater in our office.. but we have an industrial size HVAC for the building that when it's on vibrates the wall thus makes a bouncing image on the projector.
It's mounted about 25' back! throwing a 200" image on dynamic, and it looks pretty damn good btw.. it's an amazing dedicated theater built by the previous tenant that we luckily inherited.
We currently have it mounted to the wall with this monoprice mount
http://www.monoprice.com/Product?c_id=109&cp_id=10911&cs_id=1091103&p_id=8804&seq=1&format=2
We didn't mount from the ceiling since it's acoustically treated paneling & didn't want to cut into it.
I read other threads & most have solutions for ceiling mounts with chief or peerless vibration isolation stuff (btw, do they work?)
But I didn't see any wall mount solutions. Should I trash the monoprice and get something else?
thanks!
gadgetfreaky is offline
post #2 of 3 Old 12-18-2013, 07:16 PM
42Plasmaman's Avatar
Quoted: 20 Post(s)
Liked: 37
Try searching for "Ceiling Vibration Isolator" and "projector ceiling mount shock absorber" in your choice of search engines.
2016
42Plasmaman is offline
post #3 of 3 Old 12-19-2013, 07:06 AM
jpmst3's Avatar
Quoted: 196 Post(s)
Liked: 314
Try making some soft rubber washers to separate the mount from making direct contact with the ceiling and the fasteners.
Joe = LFE Addict
Past Builds: 24" LMS-5400 cube, Anarchy 25Hz Tapped Horn, Danley DTS-10 kit, BFM AutoTuba, BFM THT, BFM THT-LP
Joe's LOWARHORN build, Dual LMS-5400 Ultra Endtables build
jpmst3 is offline
Epson 5010 Powerlite Home Cinema 3d Front Projector
