The cost of owning a $5k projector - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 01-16-2014, 07:11 PM - Thread Starter
Nicoff's Avatar
Quoted: 100 Post(s)
Liked: 32
Let's assume that you buy a $5 k projector and keep it for five years:
+ $5,000 initial cost
+ $300 lamp replacement (assume 1 lamp over 5 years)
- $700 residual value after 5 years
Total amount spent is $4,600 or abour $77 per month.
Let's say you keep it 2-1/2 years, replace it with another $5k projector and sell it after another 2-1/2 years:
+$5,000 initial cost
-$2,500 resale (assume 50% depreciation in 2-1/2 years)
+$5000 Buy replacement
-$2,500 resale of second projector (again assume 50% depreciation in 2-1/2 years)
Total amount is $5,000 over five years or about $84 per month
If these two scenarios are correct, then the actual cost of owning a new $5k projector every 2-1/2 years is only $7 more per month (that is $84-$77, or $420 over 5 years). That is less than the price of a single ticket at a movie theater per month.
I have been a buy-and-hold guy for many years, but it looks like the price difference is such that I should consider replacing projectors more often.
What has been your experience?
Nicoff is offline
post #2 of 8 Old 01-16-2014, 07:25 PM
Linh27's Avatar
If you buy another projector in the 2 1/2 year. Your total investment is $7500, not $5000
Linh27 is offline
post #3 of 8 Old 01-16-2014, 07:36 PM - Thread Starter
Nicoff's Avatar
Quoted: 100 Post(s)
Liked: 32
I am looking at a full 5 year cycle. You buy one projector, keep it for five years and then sell it versus you buy two projectors over the five year period. At the end of the five year period the cycle is complete: all projectors sold.
Nicoff is offline
post #4 of 8 Old 01-16-2014, 07:37 PM
Mike Garrett's Avatar
Quoted: 11822 Post(s)
Liked: 9353
His math is correct. Yes it is $7,500, but after selling the second projector, you have spent $5,000.
Mike Garrett is online now
post #5 of 8 Old 01-16-2014, 07:50 PM
Linh27's Avatar
I get it now. $2.73 a day is not bad.
Linh27 is offline
post #6 of 8 Old 01-16-2014, 08:17 PM
Trepidati0n's Avatar
Quoted: 39 Post(s)
Liked: 108
The first projector was always $5000. Each follow on projector is ~$2500. I would look at it this way. For the first 2.5 years the cost is $166/month. After that the monthly cost is 1/2 that. However, at any time you break the cycle the model breaks. So in effect, i you wish do this you need to firmly budget and execute on it otherwise the answer will be somewhere between 166 and 83 per month.
Here is the rub, you need to start budgeting early so first 2.5 years is really 166+83 effective and then 83 from then on out. Then if you get out of the game and sell you get $2500 back at the end.
In short, upgrading more often is effective if you plan on doing it for a very long time.
I must be guilty because people say I am guilty because they chose to call me guilty because they refuse to see the truth. Much easier to be part of the mob..
Trepidati0n is offline
post #7 of 8 Old 01-16-2014, 08:46 PM
rak306's Avatar
Quoted: 616 Post(s)
Liked: 252
I don't think you will get $2500 for that used projector - my guess, you'd be lucky to get $1000-$1500.
rak306 is offline
post #8 of 8 Old 01-16-2014, 09:02 PM
noah katz's Avatar
Quoted: 1819 Post(s)
Liked: 631
+1
Noah
noah katz is online now
