6030, HW55 or X55R for 10.5' diag screen? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 02-20-2014, 07:19 PM - Thread Starter
trans_lux's Avatar
Quoted: 119 Post(s)
Liked: 165
Have a friend who is looking to buy something soon.
I will have a couple of these in my possession for eval in the near future but he can't wait.
Has a 10.5' diagonal 16:9 Stewart StudioTech 130 screen.
Room is large roughly 30'long x 17'wide x 10'ceilings
Room is painted very dark with excellent light control.
Also a very long throw distance-nearly 25'
HD from DTV is the majority of viewing with the occasional BD.
3D is low on the list.
Budget is no more than $5k
My current recommendation is the Sony HW55 given its high calibrated brightness.
Anything else he should look at?
Looking forward to your feedback...
TL
trans_lux is offline
post #2 of 11 Old 02-20-2014, 07:47 PM
Mike Garrett's Avatar
Quoted: 12501 Post(s)
Liked: 10123
Has a 9' diagonal 16:9 Stewart StudioTech 130 screen.
Also a very long throw distance-nearly 28'
TL
If he has to stick with the 28' throw, then do not bother recommending the Sony HW55ES. Even with a conversion lens, you are not going to be able to reduce the image that small from 28 feet.
Mike Garrett is online now
post #3 of 11 Old 02-20-2014, 07:53 PM - Thread Starter
trans_lux's Avatar
Quoted: 119 Post(s)
Liked: 165
Hum don't have a throw calc handy.
How close roughly would the lens need to be?
post #4 of 11 Old 02-20-2014, 07:59 PM
Liked: 10123
Around 16'-6" max throw distance, if you do not use a conversion lens.
post #5 of 11 Old 02-20-2014, 08:18 PM - Thread Starter
trans_lux's Avatar
Quoted: 119 Post(s)
Liked: 165
Wow I guess I didn't realize the limitations of the zoom lens.
Looks like a 6030 then...
post #6 of 11 Old 02-20-2014, 08:58 PM
Seegs108's Avatar
Quoted: 5167 Post(s)
Liked: 2594
The Epson won't work at 28' feet either. The farthest for that size screen would need the lens at 22.48 feet from the screen.
Seegs108 is offline
post #7 of 11 Old 02-20-2014, 10:01 PM - Thread Starter
trans_lux's Avatar
Quoted: 119 Post(s)
Liked: 165
Thanks for the info, need to do some more measurements and calculations....
post #8 of 11 Old 02-21-2014, 07:05 PM - Thread Starter
trans_lux's Avatar
Quoted: 119 Post(s)
Liked: 165
Ok went and measured myself.
Screen is 10.5' diag 16:9
Trow distance from lens to screen is 25'
Looks like the Epson will work.
post #9 of 11 Old 02-21-2014, 07:15 PM
Seegs108's Avatar
Liked: 2594
If you could get the projector back about a half of a foot more, then you can make the JVC work too and that would be the better choice regarding picture quality.
Seegs108 is offline
post #10 of 11 Old 02-22-2014, 04:49 AM
Liked: 10123
With a 10.5' diagonal 16:9 screen, the JVC can be a max throw of 25'-8". The Epson can be 26'-4". Both work at the available throw. The only projector that will not work of the three is the Sony.
post #11 of 11 Old 02-22-2014, 07:48 AM - Thread Starter
trans_lux's Avatar
Quoted: 119 Post(s)
Liked: 165
Do you think there will be enough light output given the screen size and throw?
Sony Vpl Hw55es 3d Projector , Jvc Dlax55rbu 3d Full Hd Front Projector , Epson Powerlite Pro Cinema 6030ub 3d 3lcd Projector With A Pair Of 3d Glasses
