Epson 4K (enhancement) e-shift laser projector....!!!!!! - Page 164 - AVS Forum | Home Theater Discussions And Reviews
 1597Likes
post #4891 of 4897 Old 04-11-2019, 12:42 PM
7theye's Avatar
Quoted: 13 Post(s)
Quick question - trying to watch golf and wanted to be brighter (like the sports setting on a TV). Any preset way to do this or need to manually change everything ? Thanks
7theye is offline
post #4892 of 4897 Old 04-12-2019, 01:13 AM
Agenor's Avatar
Quoted: 24 Post(s)
Originally Posted by RTFM66 View Post
I have recently bought an Epson LS 10000
It has firmware version V119 installed.
I believe V131 is the latest.
Does anyone know what improvements there are in 131?
I’m very weary of uploading new firmware in case the projector locks up and I can’t use it.
Thanks in advance for any help and advice.
As far as I know, the Dynamic Contrast has been improved from v.1.30 to v.1.31.
Originally Posted by cronos64 View Post
I have recently bought this second-hand projector: LS10000
with Epson LS10000 ¿Is it possible play 4K with 10bits from Panasonic DMP-UB900EGK?
When I try to play a Blu ray 4K, in LS10000, not appear 10bits, only appear "--". Is it 8bits??
And when I put input signal 4K in LS10000, supRES/4K option is disable in the menu. Is it normal?
I only can see 10-12bits in the LS10000 when I play a BluRay 1080p but never when I play a Bluray 4K. Is it normal?
With a oppo 203 ¿is it possible see 4K with 10bits in my LS10000?
Thank you masters!!
To my knowledge the LS10000 is limited to 8bit Output, thus forcing everything other (10/12bit) will not work.
There is no preset for that. To gain the highest lumen output or get a brighter picture at the LS10000 you should choose following settings:
- color mode without a filter (Natural, THX?, Dynamic?),
- lens iris = 0,
- Power consumption = high
- if possible without crushing blacks: set brightness up
- if possible without loosing details on brighter scenes: set gamma to a higher value
Setup: NAD T758v3 + NAD M25: 7x Jamo D500 + 2x Jamo SUB660 + 4x Jamo IC206 / Epson LS-10000 / Panasonic UB9004 / 2x Quake Q10b: Earthquake XJ-700R / Behringer DCX2496
Agenor is offline
post #4893 of 4897 Old 04-12-2019, 11:06 AM
AmigoHD's Avatar
Quoted: 66 Post(s)
Liked: 41
- lens iris = 0,
LS10k is limited to 8bit (dithering) with 4K input. but it accepts 10bit or 12bit signals.
Dynamic preset is the brightest out of the box and fine for sports.
Epson EH-LS10000, madVR on GTX 1080, Oppo UDP-203, Oppo BDP-EU93, Toshiba HD E1, Dreambox 900 ultraHD, Xodiac masked, AT, 3m scope (2.40:1), Marantz SR7011
3x Klipsch PRO-7800-L-THX, 6x Klipsch PRO-7800-S-THX (Dolby Atmos setup, 5.2.4)
2x Velodyne SC-600IW, Velodyne SC-602
Middle Atlantic Rack, RTI XP-6 control processor, RTI T2x remote, LUTRON Graphics Eye QS
AmigoHD is offline
post #4894 of 4897 Old 05-13-2019, 10:33 AM
Quoted: 14 Post(s)
Liked: 8
I already asked this question in the LS10500 thread, but have gotten no response, so I figured I would give this thread a try since both projectors should be the same in this context.
At what distance is the screen door effect visible with the LS10500; i.e. at what seating distance is the SDE no longer visible?
Merlin GS is offline
post #4895 of 4897 Old 05-14-2019, 07:06 AM
Gary Lightfoot's Avatar
Quoted: 1294 Post(s)
Liked: 1043
It depends on your screen size - a bigger screen will have larger visible pixels from a fixed distance than a smaller screen.
My screen is 104" wide and I sit 7.5ft back and I can't see them. Maybe from around 2 or three feet but that's a guess. My UF screen material has a far more visible texture to it up to around 5 feet or six feet and that's a fixed visibility as the texture size remains the same regardless of screen size.
Not much help but I think you won't see anything from normal seating distances.
Merlin GS likes this.
Originally Posted by elmalloc
Who says Cameron is "right" and why do we care about him so much - lol!
I trust Gary Lightfoot more than James Cameron.
Gary Lightfoot is offline
post #4896 of 4897 Old 05-14-2019, 09:08 AM
Quoted: 14 Post(s)
Liked: 8
Yes, my question should probably have been better worded, I should have asked distance to height sitting ratio. 104" wide and you sit 7.5ft back, does that include the use of an anamorphic lens with a 2.35:1 screen or is that in reference to the projector without a lens? If the latter, then that means even a 1.5 ratio for distance to height should not be an issue (I think my sitting ratio is 2 to 1).
Very helpful, thanks.
post #4897 of 4897 Old 05-14-2019, 09:33 AM
Liked: 1043
It was initially zoomed onto a spandex screen, and I never had any pixel visibility issues. The screen is 16:9 but masked to 2.40 and I only remove the top and bottom masks for IMAX content. For scope I'm at 2xSH back but as you rightly say is 1.5xSH for 16:9 and more of the truth with respect to the actual display.
Later I added a lens which of course further improved the pixel density for scope.
You're very welcome.
