The Official Sony VPL-VW300ES/VW350ES Owners Thread - Page 44 - AVS Forum | Home Theater Discussions And Reviews
 806Likes
post #1291 of 2650 Old 04-20-2015, 09:05 AM
Craig Peer's Avatar
Quoted: 6612 Post(s)
Liked: 7676
Originally Posted by George Kouzev View Post
I posted that link and observed the same with my unit. With very long throw, I was not able to discern individual pixels one the very left of the screen while center and right were easily visible. Shortening the throw by under two feet in my case made a difference to the point pixels on the left are now also visible.
max90034 throw distance at the moment is much bigger relatively speaking (and according to PC calculator out of optimal range, assuming it is accurate?) than I initially had, so I can see how this can lead to softness.
My advice - go with bigger screen if you can , not just for that reason. Craig or Mike gave me that same advice, go as big as you can afford, a month or so ago, I followed and would never look back.
" Size Matters " !
Craig Peer is online now
post #1292 of 2650 Old 04-20-2015, 01:45 PM
Liked: 1
Anamorphic Lenses
I know this topic has been discussed many times before, but they are with 1080p projectors. I would like to know directly from people that are owners of these Sony 4K projectors or have seen these lenses in action. How does the picture quality compare to the lenses in use versus zooming. I have a Panamorph Cinevista Lens on back order, should I keep or cancel the order? BTW, I am tired of zooming back and forth and having to refocus, but at the same time, I rather zoom back and forth and refocus if the image quality of this lens degrades the image to a magnitude of it looking like and image between 4k and 1080p.
Ob1kob is offline
post #1293 of 2650 Old 04-20-2015, 02:52 PM
Craig Peer's Avatar
Liked: 7676
If it were me I would not use a Cinevista lens with a Sony 4K projector. One of the better lenses, maybe.
post #1294 of 2650 Old 04-20-2015, 03:47 PM
Mike Garrett's Avatar
Quoted: 11806 Post(s)
Liked: 9345
The image would be very sharp using the CineVista, but the CineVista does not have CA correction. It is designed to stay in front of the projector lens, all the time. You use the zonal pixel adjustment in the projector to correct for CA caused by the lens. So if this lens stays in front all the time, then you will not be using the full panel, when watching 16:9 content. Also the CineVista is designed with a max focal length of around 17'. Max screen height, before pincushion is considered too big is going to be around 55" high, which is about 130" wide. This is the long version of what Craig said. I would use a different lens.
Mike Garrett is offline
post #1295 of 2650 Old 04-20-2015, 08:14 PM
Liked: 1
My throw is at 14 feet and my screen is a 125 inch 2.35:1 curved, so I don't think pincushion will be an too much of an issue. I also plan on leaving the lens in place, since most of the movies I watch are 2.35:1 anyway. If it makes a 2:35.1 movie look better than zooming with a push of a button, then I'll be happy. But doesn't the VW350ES have an A and B memory setting so you can save the different zonal pixel adjustments, so when you remove the lens you can put the zonal pixel adjustment back to before you adjust it with the lens in place?
Ob1kob is offline
post #1296 of 2650 Old 04-20-2015, 10:06 PM
max90034's Avatar
Quoted: 25 Post(s)
George, You mentioned seeing pixels on the screen. Are you referring to those dotted lines on the focus screen or actual individual pixels? I believe dots are few pixels in diameter. I do not think I can resolve individual pixels anywhere on the green focus screen, left or right.
max90034 is offline
post #1297 of 2650 Old 04-21-2015, 05:23 AM
George Kouzev's Avatar
Quoted: 240 Post(s)
Liked: 66
There is a Test Pattern menu item which you can set to Off, in which case you will not see the green lines/dots but instead the projected source image while doing your focus adjustment. I put a bright static picture on the screen and then use the pup up menu letters that come up while adjusting focus to judge center focus. Then you can move away from the center to see the sites. I am able to see those tiny-tiny individual pixels. This is also how you can see how important it is to have your last step for adjusting size being an enlargement - just see how well you can adjust focus looking at the small pop-up menu letters/arrows in the center in either case. Pay attention to halos around the letters as well as how well you can see the pixels.
George Kouzev is offline
post #1298 of 2650 Old 04-21-2015, 05:53 AM
Liked: 9345
With 14' of throw and a curved screen, then I would use an A-lens. The CineVista will work in your setup, since you said you plan to use a fixed lens. I am pretty sure that you can't save two different zonal pixel adjustments.
post #1299 of 2650 Old 04-21-2015, 12:36 PM
Liked: 1
I played with the menu screen for a while last night and you are right, there is no feature to save two different settings for the zonal pixel adjustment. I was debating on wether to do a CHS with a lens or a CWS with horizontal masking, but I like how 1.78:1 movies look better with the CHS setup more since it's not too overbearing to my eyes, plus it will be brighter.
Another question. To maximize brightness (for 3D mostly), am I able to move my projector closer, like a 10 feet throw (zoom out the lens completely), and get a 100 inch 16:9 image, then use the A-LENS to stretch out the image to fill the width of my 2.35:1 screen?
Ob1kob is offline
post #1300 of 2650 Old 04-22-2015, 03:36 AM
Gary Lightfoot's Avatar
Quoted: 1302 Post(s)
Liked: 1053
You might find that if the image is zoomed too large, the image may not pass unobscured through the A lens. You'll have to try by testing, or see what the minimum throw of the A lens is to be sure.
Gary
Originally Posted by elmalloc
Who says Cameron is "right" and why do we care about him so much - lol!
I trust Gary Lightfoot more than James Cameron.
Gary Lightfoot is offline
post #1301 of 2650 Old 04-27-2015, 05:13 AM
chicago66's Avatar
Quoted: 69 Post(s)
ok.. when watching a blue ray.. I am unable to turn off reality creation? I use the remote button designated for such. It comes up. however, when I toggle down to the "off" and then hit enter nothing happens.
Is this correct? on other note is there a soft ware upgrade?
chicago66 is offline
post #1302 of 2650 Old 04-27-2015, 05:25 AM
Quoted: 240 Post(s)
Liked: 66
You should not have to hit enter - as soon as you go to Off, it should be off. To get rid of the menu, press the dedicated RC button again.
Can you turn on/off from the main menu?
post #1303 of 2650 Old 04-27-2015, 06:01 AM
chicago66's Avatar
Quoted: 69 Post(s)
Tried that also. is not going off. seams strange to me.. I thought perhaps it was limited to the blue ray input.. but same on other inputs.
post #1304 of 2650 Old 04-27-2015, 11:34 AM
Quoted: 240 Post(s)
Liked: 66
That is odd. The only case were I do not see difference between RC on and off is when I feed 4K signal.
post #1305 of 2650 Old 04-27-2015, 11:38 AM
cdnscg's Avatar
Quoted: 586 Post(s)
Liked: 119
Try the RC 'test' option
cdnscg is offline
post #1306 of 2650 Old 04-27-2015, 12:37 PM
chicago66's Avatar
Quoted: 69 Post(s)
ok wait that might be it.. the blue ray I think is upconverting.. its a sony 6200 blue ray.. so perhaps the option to turn off reality creation is not available on 4k or sources which are upconverted to 4k ?
post #1307 of 2650 Old 04-27-2015, 12:51 PM
Quoted: 240 Post(s)
Liked: 66
Very likely the case. The RC on/off is still available as an option, which suggests that some processing takes place if ON, but I personally saw no difference. Perhaps there will be some difference if I bumped RC sharpening/filtering params up but I would not go there. I believe I have it set to Off for 4k signals.
post #1308 of 2650 Old 04-28-2015, 05:26 AM
chicago66's Avatar
Quoted: 69 Post(s)
ok./.. so for those newbies with this unit.. I think I understand and perhaps the rest of you can confirm. when you hit the RC button on the remote and toggle down to "off" the check or arrow does not move to the off line so I thought the RC was still in on position.. however,, after going to the "off" line and entering the enter button.. I then hit menu and saw all the options.. which showed RC "Off".
Stange thing is when the units is not accepting a signal and I use simply the RC button on the remote rather than the menu button and toggle to the line for RC is does ...show it as off right away.. I know this is sounds confusing..
I too noticed no difference with RC on or off.
post #1309 of 2650 Old 04-28-2015, 05:51 AM
Liked: 9345
Up the setting for RC and then try it. You should be able to see a difference. Make sure you are looking at a static image or a test pattern. That will make it the easiest to see.
post #1310 of 2650 Old 04-28-2015, 07:38 AM
Skrill's Avatar
Quoted: 282 Post(s)
Liked: 79
Doh .. .wrong thread.
Skrill is offline
post #1311 of 2650 Old 04-28-2015, 04:44 PM
shoresidehd's Avatar
After a long wait, my 350ES has finally arrived. I got my unit from [email protected]
I ordered mine early on with the Sony special introductory pricing and he took great care
of me. There was a delay which was not his fault but he kept me updated throughout
the process. Thanks again to Craig for the great hookup,nice guy and company to
deal with. Now i will hook it up and enjoy 4k
shoresidehd is offline
post #1312 of 2650 Old 04-28-2015, 05:39 PM
Quoted: 240 Post(s)
Liked: 66
Here is a taste of true 4k resolution on the VW300 - Switzerland of course. I just paused one of the 4k clips downloaded from youtube and took pictures.
First picture is of the entire screen. The second one is a close up on a small bottom-middle section so that one can see the real on-screen resolution. Note that the facebook.com letters are about one pixel thick, and so are the pols by the railroad on the second picture. These are visible from regular viewing distance.
ID:	691914   Click image for larger version
post #1313 of 2650 Old 04-29-2015, 07:05 AM
Liked: 9345
Yep, looks like looking out a window, rather than an image on a screen.
post #1314 of 2650 Old 04-29-2015, 09:29 AM
JeffNebraska's Avatar
Quoted: 127 Post(s)
Liked: 27
I have a gaming laptop with HDMI out. I take it for granted that I cannot pass 4K from YouTube or any other source, but, out of curiosity, how do I confirm this? What video card feature is required to pull this off?
Jeffnebraska
Reaching for the Next Level With a Sony 350ES and a 133" 2.35 AT Screen
JeffNebraska is offline
post #1315 of 2650 Old 04-29-2015, 09:39 AM
Quoted: 240 Post(s)
Liked: 66
I coughed for the Sony FMP-X10 player. Not sure what HTPC specs would work but in any case I would download first and then play. There is a free Windows app called 4k Downloader (I am not home to confirm exact name) where you just paste the youtube URL and it does the rest.
I download to my laptop first, transfer to memory card and then transfer/use on the x10.
post #1316 of 2650 Old 04-29-2015, 09:40 AM
Craig Peer's Avatar
Liked: 7676
What source device are you using? If you mentioned it I missed it. Thanks.
We have several VW350's in stock by the way ( in case anyone is looking for one ) !
post #1317 of 2650 Old 04-29-2015, 09:57 AM
Gil Arroyo's Avatar
Quoted: 87 Post(s)
Liked: 33
Originally Posted by Michael9009 View Post
Upscaling cannot be disabled. Otherwise, different resolution sources will be projected with different sizes on the screen, depending on the number of pixels. All you can do, though, is changing the method of upscaling:
a. With the Reality Creation set to Off - i.e. pixel doubling - the picture looks similar to a 1080p image; or
b. With the Reality Creation set to On (minimum settings recommended) - i.e. pixel interpolation - the picture interpolates the additional pixels from a 1080p image, making it look closer to real 4k resolution. This is the setting to be used.
I am using the SONY VPLVW350ES with both a 1080P output from a SONY BDP790 BluRay player and the SONY FMP-X10 UHD/4K Media Player. The SONY Entertainment Center provides many UHD feature films (@$30 purchase and $8 rental, plus many 4K/UHD demo films (some free).
The media player also delivers UTUBE 4K films transferred via flash drives from an on-line computer.
The reason for this post is to advise you lucky 350 owners that although the Media Player to a 120 inch screen is superb, so is the 1080P output
from the BluRay player upconverted by the 350 is just about indistinguishable. The 350 upconversion from 1080P is excellent, sometimes preferable to native 4K, and the 350 also beats other upconverting sources (like the SONY BDP6200) from 1080P to 2160.
cdnscg and DavidHir like this.
Gil Arroyo is offline
post #1318 of 2650 Old 04-30-2015, 08:52 AM
Craig Peer's Avatar
Liked: 7676
from the BluRay player upconverted by the 350 is just about indistinguishable. The 350 upconversion from 1080P is excellent, sometimes preferable to native 4K, and the 350 also beats other upconverting sources (like the SONY BDP6200) from 1080P to 3840.
Thanks for the observations Gil. I have certainly been impressed with current Blu Rays on my VW600. Your comparison of upscaled 1080p to 4K is interesting, as I don't have any 4K sources at the moment.
post #1319 of 2650 Old 05-01-2015, 09:19 PM
Michael9009's Avatar
Quoted: 342 Post(s)
Liked: 87
Indeed, the up-converters in the Sony 4K projectors are superb. However, the reason you say that up-converted 1080p is sometimes preferable to native 4k is that, most of the time, streamed content is compressed much, much more than Blu-ray content, so the benefits of the higher resolution are all but negated.
George Kouzev likes this.
Michael9009 is offline
post #1320 of 2650 Old 05-02-2015, 01:29 PM
Gil Arroyo's Avatar
Quoted: 87 Post(s)
Liked: 33
4k uhd when and where?
Yes, 4K/UHD from a streaming SONY source and then copied to hard drive may be compromised and not classified as the real 4K/UHD.
We may have to wait until delivered via shiny silver discs.
Broadcast 4K/UHD is a murky (what codec are you using) status with "unlikely" in the title. The UTube videos may be closer to the real stuff (Native), but....
Anyone have any good ideas on how to acquire 4K?
software , sony projector , sony vpl 350 , VPL-VW350ES , VW300ES
