Replacing JVC Ballast - Page 5 - AVS Forum | Home Theater Discussions And Reviews
 18Likes
post #121 of 136 Old 09-30-2019, 08:41 PM
Quoted: 82 Post(s)
Liked: 26
Originally Posted by jsmith967 View Post
I've read this thread about repairing JVC ballasts and wondered if you all could help me out. My projector powers on for a minute and then goes off, showing these codes (in pic). It could be a lamp or could be a ballast issue, what do you all think?
What are the "codes" ?? The photo shows solid lights. To understand the problem, you need to know the error code. How much, in what order, which diodes are blinking.
If your projector is running for a minute, the lamp lights up, then the problem may not be in the ballast. Many possible problems are possible. But for the search you need to know exactly which and in what order the diodes, bulbs are lit.
Possible options: 1) bad lamp, 2) temperature sensor, 3) control board, 4) processor board. And many more options. To limit your search, tell me more about lights.
Can you record video problems? Put it on YouTube and give the link here.
Slonopot is online now
post #122 of 136 Old 09-30-2019, 08:48 PM
Quoted: 82 Post(s)
Liked: 26
Originally Posted by descalabro View Post
That’s the X500 I’ve seen at least 2 with the ballast issue. If I had to bet, I’d say the lamp is ok and the is indeed the ballast. But let’s hear some more opinions on this thread.
Hello!
Usually, if the ballast is bad, then the lamp will not light up. There is a lot of voltage on the ballast, and if the ballast has any problem, it will not light the lamp. Absolutely.
post #123 of 136 Old 10-01-2019, 04:28 AM
descalabro's Avatar
Quoted: 433 Post(s)
Liked: 165
Originally Posted by Slonopot View Post
Hello!
Hello
Thanks for the information. I thought that ballasts could act this way before dying completely. I have deleted my post to avoid confusion.
descalabro is offline
post #124 of 136 Old 10-02-2019, 02:20 PM
Mr J's Avatar
Hello!
Do you believe it is possible for the ballast to have a partial degradation during maybe 3 or 4 Days? My X30 went from working fine, to shutting itself off faster all the time, to not starting at all even after using "Power cut-reset lamp timer trick" in a period of 4 Days. I also have the 2 solid red status lights and the middle one blinking continously yellow.
Mr J is offline
post #125 of 136 Old 10-02-2019, 08:35 PM
Quoted: 82 Post(s)
Liked: 26
Have you tried to connect a new lamp? If it does not help, then the problem is ballast.
post #126 of 136 Old 10-03-2019, 12:26 AM
Mr J's Avatar
Can a lamp fail that gradually? I thought they were fully working (albeit dim) or totally shot. I have an old JVC HD350 as well, but I guess it is not possible to fit the lamp from that one in my x30?
I am a bit hesitant buying a new lamp and then find out it might be the ballast board, which both together might be something like $800-900 when I can get a second hand X35 or something similar for $750 which, as you have said, have less ballast problems. I guess I could buy the cheapest noname bulb I could find just for testing.
Mr J is offline
post #127 of 136 Old 10-03-2019, 03:55 AM
descalabro's Avatar
Quoted: 433 Post(s)
Liked: 165
It's not possible to use that older lamp.
Let's suppose the problem really is the ballast, what will you do: replace it yourself, as intended on this thread, or get the X35? If you're able to remove the ballast yourself, getting it corrected by @Slonopot will be much cheaper than those values you mentioned (send him a PM). And, since the fault is very likely the ballast, I'd say it's worth a try. Worst case scenario, you'll end up with a corrected ballast which is more reliable than a new one sold by JVC, which you can then sell.
Slonopot likes this.
post #128 of 136 Old 10-03-2019, 01:23 PM
Mr J's Avatar
Let's suppose the problem really is the ballast, what will you do: replace it yourself, as intended on this thread, or get the X35? If you're able to remove the ballast yourself, getting it corrected by slonopot will be much cheaper than those values you mentioned (send him a PM). And, since the fault is very likely the ballast, I'd say it's worth a try. Worst case scenario, you'll end up with a corrected ballast which is more reliable than a new one sold by JVC, which you can then sell.
Yes, replacing it myself is what I was hoping for. Although, I think it might be hard to resell the corrected ballast considering where I am located, if it turns out there was some other component that was broken.
Anyway, I do not have the ability to send PMs yet, it supposedly takes 15 posts to be able to do so. Even though I have been a member since 2004 and been reading unregistered even longer, I just havent had that much to say. Hopefully Slonopot reads this and sends me a PM, I would hope it is possible to answer those at least. Just got a message that it is not even possible for me to quote your post verbatim, since it contains a link… stringent rules indeed...
Mr J is offline
post #129 of 136 Old 10-03-2019, 05:18 PM
descalabro's Avatar
Quoted: 433 Post(s)
Liked: 165
Where are you located?
I wasn’t aware of those rules. Don’t worry, he’ll read. I have made a guide to remove the ballast on an X70, I will post it here too.
post #130 of 136 Old 10-04-2019, 07:55 AM
Quoted: 82 Post(s)
Liked: 26
[QUOTE=descalabro;58640888 I have made a guide to remove the ballast on an X70, I will post it here too.
Sent from my iPhone using Tapatalk[/QUOTE]
Have you seen the photos taken apart by the X5000-9900? Any of these patterns. You can 400-640. No difference. I want to see the cooling system and ballast of these projectors.
post #131 of 136 Old 10-05-2019, 02:37 PM
Mr J's Avatar
Hi Slonopot, I just wanted to let you know I have recieved your PM. Unfortunately, I cannot answer as of now since my post count is too small. I guess I will have to go around spamming some other forum sections and get back to you in a few days. I have read this forum for maybe over 20 years now, so it is a bit ridiculous, but it is what it is.
Mr J is offline
post #132 of 136 Old 10-08-2019, 12:19 PM
Mr J's Avatar
Hello Slonopot, since I can not send PMs, I thought I would try to email you my PM answer to the yandex.ru email adress you supplied for payment. Hope this is ok, please let me know if there is some other adress I should use.
Mr J is offline
post #133 of 136 Old 10-08-2019, 08:38 PM
Quoted: 82 Post(s)
Liked: 26
Responded to email
post #134 of 136 Old 10-09-2019, 07:27 AM
SAHIHE's Avatar
Do you need to repair and fix your faulty ballast? Send your ballast to me for repair. Write in private messages for details (price, address, delivery).
Got your PM, thanks. I tried to respond to to it but am running into the low post count limit. I mailed out the ballast to your address yesterday.
Please PM me you email address so I can reach out using that.
SAHIHE is offline
post #135 of 136 Old 10-09-2019, 08:17 AM
Quoted: 82 Post(s)
Liked: 26
I answered you in a private message.
post #136 of 136 Old 10-12-2019, 09:19 AM
descalabro's Avatar
Quoted: 433 Post(s)
Liked: 165
I have only seen the ads of those projectors on sale, and 2 of them said they were sent to a repair shop and that the ballast was the problem. However, the ballast was not replaced, so I’m not sure if that’s really the issue.
