Is lamp flicker still an issue on current Sonys ? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 7Likes
post #31 of 41 Old 07-03-2019, 04:23 AM
Archibald1's Avatar
Quoted: 1855 Post(s)
Liked: 1020
Originally Posted by markmon1 View Post
This won't help much. All it will do is wear out your bulb that much faster. Sony just has the worst bulbs.
Do they actually have the worst *bulbs* (they use Philips which are very good) or is actually their power supply circuitry and ballasts that are the weak link?
MOberhardt likes this.
“Remember to look up at the stars and not down at your feet. Be curious. And however difficult life may seem, there is always something you can do and succeed at. It matters that you don’t just give up."
Stephen Hawking.
Archibald1 is offline
post #32 of 41 Old 07-03-2019, 04:26 AM
MOberhardt's Avatar
Quoted: 701 Post(s)
Liked: 293
Originally Posted by rwestley View Post
Replacing a Sony bare bulb is really easy. There are instructions in the 285es thread somewhere. You can get bare bulbs direct from China at really low prices depending on the model projector you have.
Thanks! I'll see if I can locate the post.
I have a 550es/675, same as you had!
So just Ali Express or eBay?
MOberhardt is offline
post #33 of 41 Old 07-03-2019, 04:28 AM
MOberhardt's Avatar
Quoted: 701 Post(s)
Liked: 293
So the ballast resistor is in the projector somewhere, not the lamp housing or bulb? You'd think replacing that would be easy.
post #34 of 41 Old 07-03-2019, 04:34 AM
Archibald1's Avatar
Liked: 1020
Yup. In my experience it is fairly hit and miss if you get a good one or not.
As an aside, Sony told me to use a new bulb for the first 100 hours out of the box in high mode and it would mitigate the flickering thereafter.
I never got a chance to test that out. Shame they didn't put that advice in the manual...…..
Stephen Hawking.
post #35 of 41 Old 07-03-2019, 06:27 AM
markmon1's Avatar
Quoted: 4627 Post(s)
Liked: 2933
So are you better off with a cheaper non OEM bulb?
I've never swapped a bulb or full lamp housing., Getting a bulb for say 150 and getting 1000 hours is probably fine for me. The full Sony lamp replacement less palatable...
Anyone know if it is hard to do just a bulb? Risk of damage to housing?
PS - the shorter lamp life on high has never been a consideration with me. I like the light level an more importantly the noise level on low...
Just make sure you get the right bulb. There are 4 brands that make compatible bulbs and only 1 actually lasts and works well. I had it documented but must have cleaned it off when I sold my sony.
Video: JVC RS4500 135" screen in pure black room no light, htpc nvidia 1080ti.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, 2 sub arrays both infinite baffle: 4x15 fi audio running on behringer ep4000 + 4x12 fi audio running on 2nd ep4000.
markmon1 is offline
post #36 of 41 Old 07-03-2019, 06:28 AM
markmon1's Avatar
Liked: 2933
Yea honestly it's probably that. And also they drive the bulbs lower than JVC drives them on low, so it might cause the flicker more.
markmon1 is offline
post #37 of 41 Old 07-03-2019, 12:17 PM
MOberhardt's Avatar
Quoted: 701 Post(s)
Liked: 293
Ugh... Philips isn't it???
Yes it is idiotic they don't [ut that in the manual. Unbelievable
post #38 of 41 Old 07-03-2019, 12:46 PM
Quoted: 175 Post(s)
Liked: 59
Did this on a Benq and still got flickering to the point that after a 400 hour stay on Normal the flickering is still there. Maybe it would have been worse if I didn't .
noob00224 is offline
post #39 of 41 Old 07-03-2019, 03:38 PM
MOberhardt's Avatar
Quoted: 701 Post(s)
Liked: 293
Could it have been Lutema? Does that ring a bell? I've been searching online and this sounds good.
post #40 of 41 Old 07-03-2019, 03:56 PM
markmon1's Avatar
Liked: 2933
No, as @Archibald1 said above, it's Phillips.
markmon1 is offline
post #41 of 41 Old 07-03-2019, 03:59 PM
MOberhardt's Avatar
Quoted: 701 Post(s)
Liked: 293
OK thanks. I'll just search for those then.
Cheers
