AVS Forum | Home Theater Discussions And Reviews (https://www.avsforum.com/forum/)
-   Digital Hi-End Projectors - $3,000+ USD MSRP (https://www.avsforum.com/forum/24-digital-hi-end-projectors-3-000-usd-msrp/)
-   -   X500R feature's greyed out (https://www.avsforum.com/forum/24-digital-hi-end-projectors-3-000-usd-msrp/2152169-x500r-features-greyed-out.html)
MarkGats 09-29-2015 04:45 AM
Hi
I just purchased a brand new JVCX500R , but I am unable to select a number of controls from the menu's.
Example, both the Keystone and the Pin cusion are greyed out (I know they are mutually exclusive) , The Env.setting button does not bring up the Environment setting menu etc.
JVC UK have told me to try a factory reset (Not tried that yet as I,m still at work) but its out of the box , 10 minutes old!
They also said to try a standard 1080i signal.. Cant I set the unit up without any input? Just using the test facilities.
Has anyone else had similar issues or know what may be causing this.
Any help is appreciated.
thanks
Mark.
Seegs108 09-29-2015 05:02 AM
What type of input signal are you feeding the projector? 720p? 1080p? 4K? UHD? What's the refresh rate of the signal? 24p? 25? 30p? 50/60p?
Mike Garrett 09-29-2015 05:49 AM
Originally Posted by MarkGats (Post 37651185)
Hi
thanks
Mark.
The problem is, no input being feed to the projector. Feed an input to the projector and then you should be able to select those controls. Nothing wrong with the projector.
rboster 09-29-2015 06:00 AM
Hi
thanks
Mark.
For great information on your projector we have the owner's thread for your model. It's a terrific resource
https://www.avsforum.com/forum/24-dig...rs-thread.html
MarkGats 09-30-2015 12:01 AM
Hi All
Thanks for your replies.. I tried without any input and the env.settings produced the menu as expected, So as you have pointed out to me, It does depends on the signal source as to what menus are available. Thanks
I also listened to the other threads that say its a no no to even consider Keystone correction. So I reset the projector to dead flat and used the lens shift function.. Perfect !
So I now have an amazing picture in the correct position on the screen, I even managed to get the 3D working ok.
So thanks again for all your help.. I take note and will join the dedicated forum for this projector
Regards
Mark.:):):)
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
