Epson 6030 3D Auto mode not working, discrete 3D codes? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-22-2015, 08:53 PM - Thread Starter
Mike_Boulanger's Avatar
Quoted: 38 Post(s)
After sitting on it for months I'm finally starting to get 3D playback working well on my Epson 6030. I'm mostly going to play ripped MKV files (on a Mede8er MED600X3D if that matters).
Not sure if this is normal, but I'm finding I have to hit the 3D Format button and choose which 3D format I want to use every time (top bottom, side by side, etc.). The 3D Auto option does not seem to work. Does anyone have any similar experiences to share?
If I do have to toggle my 3D format manually it would be nice to have some discrete remote codes to use, but I cannot seem to find any in my URC IR database. Does anyone know if discrete codes exist to choose the 3D format I want?
Mike_Boulanger is offline
post #2 of 4 Old 11-23-2015, 05:57 AM - Thread Starter
Quoted: 38 Post(s)
I found some threads indicating the lack of 3D detection is due to playback of MKVs... too bad. Would love to have discrete codes kicking the projector into SBS/TOB/Auto mode though.
post #3 of 4 Old 11-23-2015, 08:21 AM
WestCDA's Avatar
Quoted: 68 Post(s)
Liked: 79
Yes, I have to manually switch into 3D when using a 3D channel on my satellite box as well - it doesn't have the appropriate signal embedded.
As for discrete IR codes, it doesn't look like they exist for changing between the 3D formats - just a toggle. Have a look at the Epson command code reference.
Epson 6030UB Downloads
WestCDA is offline
post #4 of 4 Old 11-23-2015, 08:23 AM - Thread Starter
Quoted: 38 Post(s)
Wow, thanks for the link! I did not think to look there.
