Official JVC RS600 / RS500 (X950R / X750R - X9000 / X7000) Owners Thread - Page 1052 - AVS Forum | Home Theater Discussions And Reviews
 84954Likes
post #31531 of 32458 Old 01-26-2019, 10:51 AM
nathan_h's Avatar
Quoted: 2844 Post(s)
Liked: 2031
Originally Posted by StevenC56 View Post
I thought the iris worked on the JVC's using an 820 and SDR.2020 conversion?
Yes. The iris works on all generations of this family (500, 520, 540) when displaying SDR content....whether that content originated as SDR or was converted to SDR by the source device.
The difference is that the 500, and I think the 520, don’t use the iris on HDR signals whereas I recall that the 540 does.
nathan_h is offline
post #31532 of 32458 Old 01-26-2019, 10:54 AM
nathan_h's Avatar
Liked: 2031
Originally Posted by sjschaff View Post
The gamma I'd calibrated before Chad arrived he discovered was far higher than target. Unless it changes quite a bit over time, I've got to blame the Spyder.
From personal experience I know it’s possible to get gamma wrong even with a good spyder.....
nathan_h is offline
post #31533 of 32458 Old 01-26-2019, 11:00 AM
Quoted: 5539 Post(s)
Liked: 2233
Yes, but the log should be able to show that.
Dominic Chan is offline
post #31534 of 32458 Old 01-26-2019, 11:03 AM
Clark Burk's Avatar
Quoted: 741 Post(s)
Liked: 685
If you select a gamma of 2.4 is it likely to get a gamma that is greatly different? I always thought JVCs were close to target with new bulbs and the gamma drop was corrected by the auto calibration after a few hundred hours. Does auto calibration really help if the projector is relatively new?
Clark Burk is offline
post #31535 of 32458 Old 01-26-2019, 11:36 AM
Liked: 2233
Depending on what you consider “relatively new”. I’ve seen noticeable gamma droop on projectors less than one year old, 200 hours of usage.
If you run Autocal with the Log only option, it will show you whether the projector has gamma droop, without changing anything.
post #31536 of 32458 Old 01-26-2019, 12:22 PM
nathan_h's Avatar
Liked: 2031
And there is no guarantee. I actually had what could be called gamma rise, based on what Chad measured, after 1000 hours on a bulb / system he had previously calibrated 14 months prior (and no adjustment by me in between). Unless this "rise" is what people are calling "droop"?
Name:	Screen Shot 2019-01-26 at 11.22.05 AM.png
DVD MAN likes this.
nathan_h is offline
post #31537 of 32458 Old 01-26-2019, 11:35 PM
JMAX2016's Avatar
Quoted: 92 Post(s)
Guys, question for you.
The RS500 (which I own) is amazing in every aspect to me. However I'm seeing a lot of 4k projectors coming out. For example, the benq 2550 (only $1400) 4k projector.
In every aspect, the JVC would dominate it, but what about resolution?
Would the benq appear to have better resolution? (I know technically it does, but what does it look like?)
Yamaha Aventage 3060, 7.2.4
Goldenear Triton 1's, Supercenter XXL, 4-MPX, 4-652
2-SVS PB-16's
JVC RS500 Pro, Panasonic DP-UB820 UHD Blu-Ray Player
137" wide 16:9 V6 AT Screen
JMAX2016 is offline
post #31538 of 32458 Old 01-27-2019, 03:52 PM
stevenjw's Avatar
Quoted: 670 Post(s)
Liked: 899
JVC resolution is very good with eShift. Think of it as 3K. Resolution is just one aspect of PQ and one that really depends on how close you sit. I don't have the exact distance, but at some point, you won't even notice the difference. Of course, like Queen sang, I want it all and I want it now.
krichter1 and waleed like this.
...Steve
"Opinions are like orgasms… mine matters most and I really don’t care if you have one or not." ;)
My HT gear
stevenjw is offline
post #31539 of 32458 Old 01-27-2019, 06:01 PM
zombie10k's Avatar
Quoted: 5528 Post(s)
Liked: 5979
We watched Bohemian Rhapsody last night and thought it was excellent from beginning to end.
After it was over, we cranked up their Live in Montreal concert (1981) which I think is one of their best overall performances. It was a great movie / concert night
zombie10k is online now
post #31540 of 32458 Old 01-27-2019, 06:43 PM
EastMo40's Avatar
Quoted: 27 Post(s)
Liked: 7
As someone who just switched to a used RS600 from a BenQ 2550 let me tell you the 2 don't even come close in comparison. JVC is far superior. The BenQ does have a better, more watchable native HDR mode but with the ability to create custom Gamma's you can correct that. My used 600 came with custom curves already loaded and I have been using them. I honestly would never switch back. But that's just my opinion.
Sent from my SM-N950U using Tapatalk
DVD MAN likes this.
EastMo40 is offline
post #31541 of 32458 Old 01-28-2019, 12:35 AM
AidenL's Avatar
Quoted: 674 Post(s)
Liked: 310
We did the same,but followed up with Live Aid!
dlinsley and DVD MAN like this.
Display : JVC X7000 Projector | SE 103" Enlightor 4k | LG 65B6 OLED |
Sources : Panasonic UDP 700 & Vertex| Apple TV4k | HTPC | Sky Q UHD Satellite | Sonos Connect | Synology 24Tb |
Audio : Marantz 8802A | Genelec 8050 LCR | Monitor Audio IDC Sides & Rears | Seaton Sub Master/Slave |
AidenL is offline
post #31542 of 32458 Old 01-29-2019, 12:12 PM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 7138 Post(s)
Liked: 7180
Originally Posted by 996911 View Post
Mine is a RS600 and was calibrated in June 2017. I'm not sure what the differences are between the 500 and 600 but I'm guessing they are negligible?
Agreed. I've an RS500 and Chad came by last Monday, and even with a lamp that's halfway through it's scheduled life, did his magic -- and it made a world of difference. He uncovered a big problem with my gamma (and as I figured, based on Manni's statements in the past re: the consistency of the Spider, which was likely the culprit), as well as the actual light output of the projector at this stage. Still I've enough light to view SDR and even HDR on my ST 130 100" diag. screen from 12 feet without going up to the higher lamp power setting. He did a great job pulling in dark detail without adversely affecting the detail in bright images. Worth every penny!
Just thought of something today, I wonder if we should have Chad sign calibrated units
It is also one of the least important factor's after you at least have HD.
DVD MAN likes this.
Cleveland Plasma is offline
post #31543 of 32458 Old 01-29-2019, 12:15 PM
996911's Avatar
Quoted: 250 Post(s)
Liked: 178
haha, agreed. He should have stickers or plates that he adheres to the projector that states "Professionally Calibrated by Chad"
namirkhan likes this.
Cheers,
Ray
996911 is offline
post #31544 of 32458 Old 01-30-2019, 10:04 AM
Erod's Avatar
Quoted: 1340 Post(s)
Liked: 851
Something I'm happy to report on these projectors (I have the rs620, but it's the same in this regard).
At 2,096 hours, I decided to replace the bulb. Still had a great picture, but I thought perhaps I'd lost more punch than I's realized over that time. I've never waited that long to change bulbs because I've always had more degradation than this over that much time.
It turns out that the original bulb had barely dimmed, as I had hoped and expected. Yes, broadcast television looks a bit brighter, but blu ray and streaming look pretty much the same as before.
Once I get 100 hours on this bulb, I expect that difference to shrink further.
The point is, these bulbs hold up very well over time. Now, I have a brand new bulb, and another one in a box with significant life still in it as a backup.
Dave Vaughn and EastMo40 like this.
Video: JVC RS620/X9500 projector, Stewart ST130 screen, Panasonic ub820 UHD player
Audio: Anthem AVM60 preamp, Anthem MCA525 amp, B&K Reference 125.7 amp
Subs: dual SVS PC-12 cylinders
Speakers: RBH SV-661R and SV-661CR fronts, Jamo 626k4 side/rear surrounds, DefTech DI6.5R heights
Erod is offline
post #31545 of 32458 Old 01-30-2019, 09:04 PM
DVD MAN's Avatar
Quoted: 244 Post(s)
Liked: 126
Hello All,
? My RS500 has been most consistent lamp projector that I have ever owned. This March Will be three years that I have owned the projector. The lamp in the projector is the 2nd and it has 3000hrs it is still outputting 18FL at -13 on the iris in low lamp. 100” screen.
Is this unusual?
Should I replace it?
Is it still safe to keep it in the pj? I belive the bulb has a 5000hrs life span.
DVD MAN is offline
post #31546 of 32458 Old 01-31-2019, 01:39 AM
IMDave's Avatar
Quoted: 137 Post(s)
Liked: 158
What I see reflected in these "lamp hour" discussions is very interesting.
My theory is that those that use their projectors multiple hours per day ( like 1000hrs per year + ) are capable of getting 2500 - 3000 hrs out of a lamp.
I also see a couple of "low use" owners ( I include myself here : Nov 2015 - Jan 2019 ......890 hrs ) that are seeing their lamps losing lumens . For HDR I have had to move from low lamp( 0 iris ) to high lamp ( -4 ) to achieve 90 Nits. For bluray I have progressively moved from low lamp -11 upon purchase to 0 to achieve 50 Nits ( 15ftL on my screen ) a couple of weeks ago.
I have purchased a new globe with the expectation that I will need to replace the original sooner rather than later.
I have no delusion I will get 2500 hrs out of MY lamp. That would mean close to 9 years!!!!!!!!
IMDave is online now
post #31547 of 32458 Old 01-31-2019, 05:06 AM
markmon1's Avatar
Quoted: 5849 Post(s)
Liked: 3923
Originally Posted by Erod View Post
Just my opinion.....
I like to wait until the second version of a new class comes out. I sat out the rs400/500/600 round and let everyone here pound on JVC for the Gamma D and latency issues. The next round, I jumped on the rs620, which tightened up those items and had fewer overall issues to deal with.
Likewise, you'll see a dog pile soon on JVC for the issues with this next step up to native 4K. When the second round of these come out, that'll be my time to seriously consider an upgrade. Or, if JVC deals with the initial issues with a firmware update (which may require mailing the unit in), then I may consider in a few months when I can get a unit delivered already "fixed".
There are already delivered reports of pixel alignment issues with some of the new projectors. Let that get sorted out.
What we have right now is throwing a great picture. So good that the difference wouldn't be that noticeable in the immersion of a movie anyway.
Upgrade-itis is a real thing, and I have to fight it every time.
This round, firmware updates are simple USB updates on the new line's USB port. No mailing anything in. Some owners already updated from 1.16 to 1.17 and commented on how easy it was.
Video: JVC RS4500 135" screen in pure black room no light, htpc nvidia 1080ti.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, Infinite Baffle Subs 4x15 fi audio running on behringer ep4000 + 2x12 fi audio mounted in main chair firing into back.
markmon1 is offline
post #31548 of 32458 Old 01-31-2019, 05:11 AM
markmon1's Avatar
Liked: 3923
Originally Posted by DVD MAN View Post
Hello All,
Is this unusual?
Yea keep running it until it looks too dim for your eyes. If you run on low, you can easily get another 500-1000 hours on that bulb if all goes well. Then when it dims too much for you, kick it into high for the rest of the life of the bulb until it's also too dim then
markmon1 is offline
post #31549 of 32458 Old 01-31-2019, 05:50 AM
Clark Burk's Avatar
Quoted: 741 Post(s)
Liked: 685
As long as JVC is willing to pass along fixes and improvements with firmware updates instead of saving them as new features for next years models. Owners of the x00 series should be familiar with that......
claw, stevenjw and Ted99 like this.
post #31550 of 32458 Old 01-31-2019, 07:44 AM
Erod's Avatar
Liked: 851
That's interesting. I never really thought of a bulb aging without being used. I wonder if that's true.
I'd always heard that leaving a projector on for more than 4 hours continuously is hard on the bulb, which is problematic for me because mine is on much longer than that if I'm watching football all day on a Sunday. I've never seen any real evidence of additional wear, and on this 620, it didn't seem to have much of a negative impact at all.
Again, I think ventilation is key. Mine hangs from a 3 foot steel pipe with a Chief mount.
A great deal of heat comes out of the front vents of my projector, so if it didn't have room to breath, I think it would have a negative impact on performance overall and the bulb life.
Erod is offline
post #31551 of 32458 Old 01-31-2019, 10:18 AM
nathan_h's Avatar
Liked: 2031
Lamps age -- in large measure -- due to the number of power ups and power downs, as well as ambient temps, how good airflow is (clean you filter lately?) and other stress factors as much as based on total hours.
In fact, traditional wisdom is that a light bulb (NOT YOUR PROJECTOR! DO NOT TRY THIS) left on continuously 24 hours a day will last longer (total number of days, not total number of hours of "on" time) than a bulb turned off for 12 hours a day. That may just be internet urban legend, but it drives home the point that a power cycle is very stressful, and diminishes lamp life.
There is also probably unit to unit variation that impacts life as well.
nathan_h is offline
post #31552 of 32458 Old 01-31-2019, 06:51 PM
IMDave's Avatar
Quoted: 137 Post(s)
Liked: 158
Yes, those were my thoughts as well.
My X7000 has had a hard life of power ups and power downs. All the early learning experiments with the AutoCal program and the Arve Curves and the Vertex has probably taken up at least 25% of my lamp usage ( ie 200hrs+).
Anyway I only bought a replacement globe rather than the entire lamp, so $A250 for 3 years use is ok by me. Who knows, I may still get another year before I need to swap over.
Just got to keep monitoring with the lightmeter.
When I can't get 80Nits in High lamp with the iris wide open, that will be the time to change.
post #31553 of 32458 Old 02-02-2019, 06:04 AM
tanwn1's Avatar
Quoted: 124 Post(s)
Liked: 46
Test
tanwn1 is offline
post #31554 of 32458 Old 02-02-2019, 08:38 AM
996911's Avatar
Quoted: 250 Post(s)
Liked: 178
Best place currently to get a GENUINE replacement lamp for the RS600? I don't want aftermarket, OEM, eBay, etc, and don't want a bare bulb. Thanks!
Cheers,
Ray
996911 is offline
post #31555 of 32458 Old 02-02-2019, 11:22 AM
StevenC56's Avatar
Quoted: 632 Post(s)
Liked: 242
Don't count out eBay. A bunch of us here purchased a genuine JVC bulb with housing from an eBay seller a couple months ago for a great price.
Ted99 likes this.
JVC X750R Projector,Yamaha CX-A5200 Pre-Pro, Yamaha RX-Z11 Receiver, (Amps Only) Yamaha MX-D1 Power Amps x 2, Yamaha RX-Z1 (L&R Surround Channel Amp), Oppo BDP-103D BR, Panasonic DP-UB820 UHD, Pioneer Elite CLD-99 LD, Definitive Tech BP7000SC Mains, CLR3000 Center, BPVX Surround Sides&Backs, BPX F&R Presence, Martin Logan Abyss Front L&R Subs/Dynamo L&R Rear Surround Channel Subs, Infinity SSW-210 Center Channel Sub.
StevenC56 is offline
post #31556 of 32458 Old 02-03-2019, 04:53 AM
sotwell's Avatar
Quoted: 220 Post(s)
Liked: 55
When using the jvc with roku ultra and Netflix the projector has major delays when scrolling through the menus. I assume it from some previews in 4K and some is sd? Is there any kind of setting to make for a seamless experience with scrolling through Netflix menu?
sotwell is offline
post #31557 of 32458 Old 02-03-2019, 06:04 AM
Clark Burk's Avatar
Quoted: 741 Post(s)
Liked: 685
Other than setting the Roku to output 1080p when looking through previews then switching back to 4k when you make your choice I can’t think of anything.
Clark
post #31558 of 32458 Old 02-03-2019, 08:31 AM
DVD MAN's Avatar
Quoted: 244 Post(s)
Liked: 126
When the Roku switches from the menu to the video trailers within the menu it switches from 24hz to 60hz causing the blanking delay.
If you keep it at 60hz you won’t have a delay.
Home Theater: Stewart -100” 4 Way Sreenwall Electric Masking, JVC-DLA-NX9 Tivo Vox, Oppo-UDP-205, Roku 4K Ultra, Apple TV 4K, Panasonic UB9000 , Marantz AV8802A-7.1 SSP, Ayre K5 MP Stereo Pre Amp, Clearaudio Concept Turntable, Schitt Audio Phono Pre Amp, Rotel RB-1070, Rotel RMB-1095, Rotel RB-933, Ayre-V5xe,Vandersteen-3A Signature-Front LR, Vandersteen-VCC-5-Center, Vandersteen-VSM-Surrounds and Atmos, Dual SVS PB16 Ultras Subwoofers.
DVD MAN is offline
post #31559 of 32458 Old 02-03-2019, 09:28 AM
sotwell's Avatar
Quoted: 220 Post(s)
Liked: 55
I have the roku set to 4K HDR 60hz. Is there something else I should try?
sotwell is offline
post #31560 of 32458 Old 02-03-2019, 09:52 AM
DVD MAN's Avatar
Quoted: 244 Post(s)
Liked: 126
Disable the 24 Hz setting in the advance video settings menu.
DVD MAN is offline
jvc-rs500u synch/display issue? , RS600
