Official JVC RS600 / RS500 (X950R / X750R - X9000 / X7000) Owners Thread - Page 1066 - AVS Forum | Home Theater Discussions And Reviews
 84691Likes
post #31951 of 31979 Old 07-11-2019, 10:18 AM
DLCPhoto's Avatar
Quoted: 1560 Post(s)
Liked: 693
Originally Posted by Pip View Post
I have an RS 500 and a Harmony remote. I had the same issue and was able to add a third lens memory by adding the RS 640 as a device. I can’t remember if the 640 has three dedicated memory buttons, or if the harmony database has more memory options. But by transferring the command over from the 640, I got direct access to the third memory.
I have no idea how the C4 system works. I’m posting just in case something like this may work for you.
Good luck,
Pip
Thanks for the reply, Pip.
I have previously used a Harmony Hub/Remote, although I never found a way to add more lens memories directly.
For Control4, all I need is the actual long hex IR code that the Harmony would be emitting, and I can then manually copy/paste that code into the Control4 Program.
I'll have to see if there is a way to obtain those codes from Harmony, as that might just do the trick.
Was it only a 3rd Memory slot that using the 640 gave you, or were there more available?
JVC RS400, Marantz SR7010, Screen Innovations 160" 2.35:1 Screen
Front L/R: Duntech Sovereigns, powered by 2 bridged Adcom GFA-555
Center: Revel C208 powered by Cambridge Audio Azur 851W
Dolby Bed (4): Sony Core SS-CS5, Atmos (4): Ascend Acoustics CBM-170 SE
Subwoofer: DIY 8' sub with 4 18" SI Drivers, powered by iNuke 6000
DLCPhoto is online now
post #31952 of 31979 Old 07-11-2019, 12:25 PM
Pip
Pip's Avatar
Quoted: 217 Post(s)
Liked: 102
I don’t remember. It was a while ago and I only have three memories set up.
Pip
Pip is online now
post #31953 of 31979 Old 07-11-2019, 12:37 PM
DLCPhoto's Avatar
Liked: 693
Pip
I loaded the 640 into the Harmony App, and saw only the 3 Lens Memory slots.
So this wouldn't fully solve my problems, and I really need, if they're available, the full long hex codes for each of the 5 available Lens Memory slots for the RS400, since I do use them all at times.
post #31954 of 31979 Old 07-11-2019, 07:49 PM
Dave Vaughn's Avatar
Quoted: 1430 Post(s)
Liked: 2187
Don,
I reached out to my contact at JVC and here was his reply:
Hi David,
Memory codes are unchanged.
I'm not sure why they aren't working. Any code I've put into my URC software has always worked, but I don't use the various lens memories (I have never had a need to). Can you try one of the other codes and see if that works?
David Vaughn Blu-ray Reviewer / Technical Writer Sound & Vision Magazine (Print & Online)
For Sale: JVC X750R Projector (RS500 Equivalent) https://www.avsforum.com/forum/252-f...l#post58241092
Dave Vaughn is offline
post #31955 of 31979 Old 07-12-2019, 02:37 AM
Dreamliner's Avatar
Quoted: 1368 Post(s)
Liked: 694
I still don't know how any of you are getting pixel perfect lens memory without needing to tweak it a bit each time. I've had 3 JVC projectors and none of them have been one-touch perfect except maybe 1/10 times. This is the sole reason I still have my JVC remote sitting out, to adjust the vertical shift.
Ted99 likes this.
Dreamliner is online now
post #31956 of 31979 Old 07-12-2019, 03:24 AM
DLCPhoto's Avatar
Liked: 693
Originally Posted by Dave Vaughn View Post
Don,
Thanks for following up on this.
It is certainly possible there is user error on my part. I'm new to Control4, which is quite a bit more sophisticated, and therefore complex, than Harmony, etc. I made a similar modification to a UB-820 command, and that worked, so I think I'm doing it right, but I'll play around with it more this afternoon.
Thanks again.
Don
post #31957 of 31979 Old 07-12-2019, 06:13 AM
Mike Garrett's Avatar
Quoted: 11803 Post(s)
Liked: 9343
I have not tested the lens memory on my RS3000, but I do know that JVC has beefed up the lens supports to greatly improve the accuracy of the lens memory.
Mike Garrett is online now
post #31958 of 31979 Old 07-12-2019, 06:25 AM
Quoted: 4483 Post(s)
Liked: 1678
Just tested it out, and unfortunately, I tried the codes for both Lens Memory 3 and 4, and they didn't seem to have any effect.
That PDF shows up to 10 Lens Memory 'slots' while the RS400 (and I'm not sure what other models) only has 5. That suggests that these codes aren't necessarily going to work with this projector.
F
Has anybody successfully found and used long hex codes for Lens Memory slots other than the 1 and 2, which have dedicated buttons on the remote, in their systems?
The lens memory codes seem to be consistent between Dave Vaughn’s and Markmon1’s list.
Dominic Chan is online now
post #31959 of 31979 Old 07-12-2019, 06:45 AM
David Susilo's Avatar
Quoted: 752 Post(s)
Liked: 648
I’ve used the last 3 generations of JVC projector (people change bulb, I change projector) and other than the need to do lens shift once or twice a year, it’s been perfect.
follow my A/V tweets @davidsusilo
ISF, THX, CEDIA, Control4 & HAA certified
Reviewer for TED & WifiHifi Magazines
my (yet to be completed) BD list
my home theatre
David Susilo is offline
post #31960 of 31979 Old 07-12-2019, 08:20 AM
Quoted: 579 Post(s)
Liked: 302
I know for 100% certain you can use the JAVS curves on the UB820 with a RSx00 projector. You might have inadvertently answered my question of if the JAVS curves work on the RSx40 projectors if you already have it loaded...
Just make those changes two I mentioned above and compare HDR2020+Custom Gamma vs SDR2020+Gamma 2.4 and see what you prefer.
I had so many problems with disc-to-disc brightness differences that I went straight to SDR2020. Who knows, perhaps HDR with the secret sauce of the HDR Optimizer and the "HDR TV Type>Basic Luminance LCD and Projector" setting from my guide will be enough to make it a quality alternative.
I just know that with my recommended settings in SDR2020+Gamma 2.4 I haven't had to make a single PQ adjustment since I configured it that way almost a year ago.
Dreamer unfortunately i had to return the panasonic not because it wasn't anything as you described it, as a matter of fact it was awesome but having two projectors here in the same room was a conflict for me.. My roku was going through the oppo and into the 1080p projector but having the roku go straight into the 1080 projector the image took a dump quality... When removing the oppo the projector only accepts hd.. With oppo/roku the oppo dectect's uhd and downscales it and it looks amazing... I'm glad i was able to experience the Pani but I'm going to wait till the next round and hopefully then they will have and hdmi imput for my roku... Thanks for the help
jorgebetancourt is online now
post #31961 of 31979 Old 07-12-2019, 08:45 AM
zombie10k's Avatar
Quoted: 5235 Post(s)
Liked: 5486
keep an eye on the MadVR Envy thread, it sounds like they will demo it at Cedia this year in September.
https://www.avsforum.com/forum/37-vi...thread-10.html
This will be a game changer since the MadVR DTM excels over the custom curves, JVC ATM (4K models) or the UB820 and will allow you to keep the Roku->Oppo setup and provide DTM for all UHD sources.
zombie10k is online now
post #31962 of 31979 Old 07-12-2019, 10:04 AM
DLCPhoto's Avatar
Liked: 693
Don,
I appreciate both of you here, as well as @markmon1 who posted a simple way to get long hex codes, in the RS3000/RS2000RS1000 thread. Here's what I've discovered, using the code for Lens Memory 1 as an example:
Here is the code that I copied directly out of the Control4 Interface, again for Lens Memory 1, which I have confirmed works properly:
0000 006c 0000 0023 013f 00a0 0014 003c 0014 003b 0014 0014 0014 0014 0014 003c 0014 003c 0014 003c 0014 0014 0014 0014 0014 0014 0014 0014 0014 003c 0014 003c 0014 0014 0014 003c 0014 003c 0014 02e1 0014 003c 0014 003c 0014 0014 0014 0014 0014 003c 0014 003c 0014 003c 0014 0014 0014 0014 0014 0014 0014 0014 0014 003c 0014 003c 0014 0014 0014 003c 0014 003c 0014 02e1
Here is the code for that same Lens Memory 1, which is the same for both markmon's generator, and the JVC PDF which has been mentioned:
0000 006D 0001 0011 0141 00A0 0014 003C 0014 003C 0014 0014 0014 0014 0014 003C 0014 003C 0014 003C 0014 0014 0014 0014 0014 0014 0014 0014 0014 003C 0014 003C 0014 0014 0014 003C 0014 003C 0014 02E6
The code that is working obviously has many more numbers in it (74 groups of 4, vs 40 groups of 4, if I counted right).
This suggests some type of format difference? If so, how does one translate from one to the other? Anything else that would account for this difference?
post #31963 of 31979 Old 07-12-2019, 01:33 PM
Quoted: 579 Post(s)
Liked: 302
For sure. Cant wait1111
Sent from my SM-G930T using Tapatalk
post #31964 of 31979 Old 07-12-2019, 02:19 PM
markmon1's Avatar
Quoted: 4627 Post(s)
Liked: 2933
It looks to me like the control4 code is being sent twice which is like if you hold the remote button longer. It seems to have a header like 0000 006D 0001 0011 0141 00A0 then the part from there to the end is duplicated. I know my uutx on pc has an option to repeat 1-n times. My guess is that’s what it does when you use that. The control 4 code looks like a repeat 2.
0000 006D 0001 0011 0141 00A0 0014 003C 0014 003C 0014 0014 0014 0014 0014 003C 0014 003C 0014 003C 0014 0014 0014 0014 0014 0014 0014 0014 0014 003C 0014 003C 0014 0014 0014 003C 0014 003C 0014 02E6 0014 003C 0014 003C 0014 0014 0014 0014 0014 003C 0014 003C 0014 003C 0014 0014 0014 0014 0014 0014 0014 0014 0014 003C 0014 003C 0014 0014 0014 003C 0014 003C 0014 02E6
Looks like perhaps the equivalent. I can modify the web tool to allow for showing repeat codes.
Dave Vaughn and DLCPhoto like this.
markmon1 is offline
post #31965 of 31979 Old 07-12-2019, 03:00 PM
DLCPhoto's Avatar
Liked: 693
The Control4 software does have an option for a repeat. I think I may have tried that once, and it didn't work, but I'm not 100% sure how thorough I was.
When I saw the difference in code size/length, the repeat concept occurred to me, but I would have expected one code to be twice the size of the other. I guess it's not that simple?
Let us know when you've made the modification, and I'll give it a try! I guess one way to know before-hand, is if it spits out the code for Memory 1 that my post showed is being used by Control4.
Appreciate your efforts here!
ETA: I re-read your post, where you stated a 'header' that is 6 groups of 4 in size. The 74 - 6 is 68, and the 40 - 6 is 34, so that would be double. Is the 'header' the same for each code, or will it also vary?
post #31966 of 31979 Old 07-12-2019, 03:07 PM
markmon1's Avatar
Liked: 2933
Well plug in this for lens1 and see if it works
Video: JVC RS4500 135" screen in pure black room no light, htpc nvidia 1080ti.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, 2 sub arrays both infinite baffle: 4x15 fi audio running on behringer ep4000 + 4x12 fi audio running on 2nd ep4000.
markmon1 is offline
post #31967 of 31979 Old 07-12-2019, 03:22 PM
DLCPhoto's Avatar
Liked: 693
I tried it, but no joy. No response.
Shouldn't it be exactly the same as the sequence I copied from Control4?
post #31968 of 31979 Old 07-12-2019, 03:47 PM
markmon1's Avatar
Liked: 2933
Well we are assuming control 4 uses pronto codes since they look so similar. But the codes coming from the tool here match JVC's spec and also work when I test using UUTX. I added the repeat option to the tool.
Also this all assumes you're on remote control code A. If you're on remote control B, you should use jvcprojectorcodeb instead.
markmon1 is offline
post #31969 of 31979 Old 07-12-2019, 04:00 PM
DLCPhoto's Avatar
Liked: 693
Yes, I just confirmed Remote Code A.
This also may or may not be relevant: the only IR interface Control4 Driver for JVC was the DLA-RS1, so that's the one in use. There is a serial driver for the RS400, but it would be difficult to run another cable up there.
If you're out of ideas, I guess the next step would be for me to contact Control4 support, and see if they can clarify anything here.
post #31970 of 31979 Old 07-12-2019, 04:05 PM
markmon1's Avatar
Liked: 2933
The remote codes haven't changed since the RS1. Is your projector attached to the network? Control 4 can also send network IP commands and I think I've helped someone add those in the past so it should be more straight forward. It seems control 4 may add some sort of "room mask' to their codes. There's not any info on it that I can dig up.
You could contact control 4 and ask how you enter a pronto code into their JVC driver. I'm sure they'll tell you to contact your installer. Control 4 is not end-user friendly.
markmon1 is offline
post #31971 of 31979 Old 07-12-2019, 04:18 PM
DLCPhoto's Avatar
Liked: 693
No network connection up there, unfortunately.
I'm in a unique position here, with respect to Control4. After retiring from my medical practice a year ago, I was getting bored, and actually found a job with one of the largest Audio Video Integrators in NC/SC. We're trying to establish a market here in my area, and we're setting up my home as a quasi-showroom for potential customers.
So I can approach them both as the end-user, as well as the Installer. I've completed the Associates Certification for Control4 (not a big deal, though), and may go all the way to the full Automation specialist, as I think that could be enjoyable.
I'll post back if/when I learn what's going on here.
It's still the unchanged JVC that has to respond to the IR codes, whatever the source, so you'd think this would be straight-forward. Guess I'll find out!
Thanks again for your efforts!
Dave Vaughn likes this.
post #31972 of 31979 Old 07-12-2019, 04:19 PM
markmon1's Avatar
Liked: 2933
I think the code getting sent by the control 4 is going to match the code getting sent by the pronto code into say harmony software. But the code you input into control 4 to get to that spot is not the raw pronto code. What other functions are in that JVC driver? Do any of those match any of the codes output by the tool for the same function?
markmon1 is offline
post #31973 of 31979 Old 07-12-2019, 04:25 PM
markmon1's Avatar
Liked: 2933
Curious, but does this code do anything?
0000 006c 0000 0023 013f 00A0 0014 003C 0014 003C 0014 0014 0014 0014 0014 003C 0014 003C 0014 003C 0014 0014 0014 0014 0014 0014 0014 0014 0014 003C 0014 003C 0014 0014 0014 003C 0014 003C 0014 02E6 0014 003C 0014 003C 0014 0014 0014 0014 0014 003C 0014 003C 0014 003C 0014 0014 0014 0014 0014 0014 0014 0014 0014 003C 0014 003C 0014 0014 0014 003C 0014 003C 0014 02E6
markmon1 is offline
post #31974 of 31979 Old 07-12-2019, 04:27 PM
DLCPhoto's Avatar
Liked: 693
Cant check right now, but will let you know later on this evening.
post #31975 of 31979 Old 07-12-2019, 06:33 PM
DLCPhoto's Avatar
Liked: 693
That definitely got a response.
It looks like it triggers Lens Memory 1, even though it is different from the Code in Control4 that also seems to trigger the same.
How did you generate this, what did you think it would do, and what does this mean? Sounds like this could be promising!
post #31976 of 31979 Old 07-12-2019, 06:40 PM
markmon1's Avatar
Liked: 2933
Yea so what I did is took the repeated code off the site generator and replaced the first 6 nibbles (which are some sort of device based codes). Perhaps your control 4 uses these to route the request then replaces these when it actually sends. To use my method for control 4, simply generate codes off my site, grab the repeated 1 time code, and replace the first 6 nibbles
Replace:
With:
Then copy the new string into your control 4. It's possible you don't even need the repeated code. So just this might work:
DLCPhoto likes this.
markmon1 is offline
post #31977 of 31979 Old 07-12-2019, 06:54 PM
DLCPhoto's Avatar
Liked: 693
Replace:
With:
You are a frikkin' genius with this stuff!!
I just generated fresh codes for Lens Memory 3 through 5, replaced the first 6 'nibbles' with your string, assigned them to the Number 3 through 5 buttons on my Remote, and they worked perfectly!
This is simply amazing, and I can't thank you enough.
I have seen these questions arise periodically on various threads, so hopefully your discovery and tools will be of help to others.
Wow.
Dave Vaughn and markmon1 like this.
post #31978 of 31979 Old 07-12-2019, 07:17 PM
markmon1's Avatar
Liked: 2933
I just generated fresh codes for Lens Memory 3 through 5, replaced the first 6 'nibbles' with you string, assigned them to the Number 3 through 5 buttons on my Remote, and they worked perfectly!
Wow.
So I'm glad it's working for you. I wish I knew more about control 4 and a way to properly advise control 4 users on how to use my web tool. Do you still need the repeat 1x codes? Or do the shorter ones work using the replace method? I added a little note on the webpage for it at least.
markmon1 is offline
post #31979 of 31979 Old 07-12-2019, 07:28 PM
DLCPhoto's Avatar
Liked: 693
I used the one marked "Code: 0xDA repeated once".
For the Codes/Functions we've examined, the process as recommended in your 9:40 pm post, was comprehensive. Just plug in the appropriate 2 character code from your other page, copy/paste the 'repeated once' code, replace the first 6 'nibbles' (is that your term, or is that what they're really called?) with the string you provided, paste the resulting string into the appropriate place in the Driver, and you're good to go!
Whether this would extend to all the other JVC Commands hasn't been demonstrated, although I'd guess they would all work fine. And I have no idea if this would also work for other brand Projectors.
So we've installed Control4 light switches, door locks, thermostats, surveillance cameras, and integrated all our AV gear, using Control4 as the "universal remote." As I'm learning how it works, and how powerful it is, I am more and more impressed.
I've successfully used a Harmony Hub/Remote before, and with some effort, was able to get this working quite well. But Control4 is like Harmony on steroids!
I also added the Control4 Skill to my Amazon Echo Dot yesterday, and can very simply control what is a very complex integrated system under the hood, with straightforward voice commands. Gives me the best of both worlds!
jvc-rs500u synch/display issue? , RS600
