Official JVC RS600 / RS500 (X950R / X750R - X9000 / X7000) Owners Thread - Page 1068 - AVS Forum | Home Theater Discussions And Reviews
 84781Likes
post #32011 of 32099 Old 08-28-2019, 11:56 AM
guptown's Avatar
Quoted: 16 Post(s)
Originally Posted by Dominic Chan View Post
What do you mean by "connect through a PC"? An Ethernet cable between the PC and the projector?
Yes
guptown is offline
post #32012 of 32099 Old 08-28-2019, 12:04 PM
Quoted: 4876 Post(s)
Liked: 1840
Originally Posted by guptown View Post
Yes
Did you assign the IP addresses manually for both the PC and the projector? Also, they have to be on the same subnet, differing only in the last group of digits.
Dominic Chan is online now
post #32013 of 32099 Old 08-28-2019, 12:31 PM
guptown's Avatar
Quoted: 16 Post(s)
I can't remember if I set them manually. They do differ only in the last group of digits. If I were to set them manually, how would I go about doing that (i can re-do that step in case that is were I screwed up)?
guptown is offline
post #32014 of 32099 Old 08-28-2019, 12:56 PM
DMILANI's Avatar
Quoted: 33 Post(s)
I had a similar problem of not being able to connect to my X590R from my laptop and JVC software. Turns out it was my Control4 system that was "locking" the JVC software out and not allowing another connection. I had to go into the JVC network menu and turn off the Control4 option temporarily. Then my laptop connected right away and I was able to use the calibration software without any issues.
Maybe something similar in your case?
DMILANI is offline
post #32015 of 32099 Old 08-28-2019, 12:58 PM
Liked: 1840
If you look at the instructions for Autocal v9 it gives more details than v6.
post #32016 of 32099 Old 08-28-2019, 01:13 PM
chasiliff's Avatar
Quoted: 68 Post(s)
Liked: 32
I'm trying out an anamorphic lens tomorrow. It does not have color correction, so, if the color is off, I will use my RS500 to correct the color. The RS500 has 2 memory settings for color correction just for this reason. Nice!
Does anyone know how to get the memory to switch automatically when I switch between anamorphic and no lens? I plan to slide it in to use for 2.4 movies and out for non scope movies.
I would love to hear from anyone. If not automatable, I will have to set up a string of commands on the Harmony which will be clunky.
chasiliff is offline
post #32017 of 32099 Old 08-28-2019, 02:16 PM
guptown's Avatar
Quoted: 16 Post(s)
I'll check that out
Ok. I'll take a look at v9
Thanks guys!
guptown is offline
post #32018 of 32099 Old 08-28-2019, 03:09 PM
zombie10k's Avatar
Quoted: 5348 Post(s)
Liked: 5684
Hi, this is a guaranteed way to get a PC connected to the JVC
Direct connection with Windows 10 PC - single ethernet cable from laptop plugged directly into the JVC
lower right hand corner, right click the network icon
Click 'Open Network & Internet settings'
left hand side, Click on 'Ethernet' - right hand side, click 'Change Adapter Options'
Right click on the Ethernet connection and click 'properties'
Double click on 'Internet Protocol Version 4', set the IP info in the following screenshot - click 'ok', and 'ok' again on previous screen.
On the JVC, set the following IP address:
In the JVC Autocal software, set the following IP address and click 'Check' to verify the connection is ok.
guptown, nathan_h, mpyw and 1 others like this.
zombie10k is offline
post #32019 of 32099 Old 08-29-2019, 07:10 AM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 6668 Post(s)
Liked: 6656
Originally Posted by David Susilo View Post
I’m currently using the NX7. Although it has the best black level for a true 4K projector, the black level is not as good as the 790. I’m pretty sure I’ll be upgrading it again year after year until I’m happy with the black level.
Nothing wrong with that, I see your in the business so I am guessing it will not hurt so mush $$$ wise......
Cleveland Plasma is online now
post #32020 of 32099 Old 08-29-2019, 03:06 PM
David Susilo's Avatar
Quoted: 777 Post(s)
Liked: 664
Still it’s costing me C$1,200 after the last upgrade from 790 to NX7. (This is because I’m not a store/dealer, I just write and do calibrations)
follow my A/V tweets @davidsusilo
ISF, THX, CEDIA, Control4 & HAA certified
Reviewer for TED & WifiHifi Magazines
my (yet to be completed) BD list
my home theatre
David Susilo is offline
post #32021 of 32099 Old 08-30-2019, 04:21 AM
asharma's Avatar
Quoted: 1839 Post(s)
Liked: 576
That's it? $1200 to go from a 790 to N7? WOW...Cost me far more than that to go from my x950 to an N7...Dealer cost on the N7 must be I'm guessing somewhere around $7k (40 points margin i'm guessing) so you must have gotten out of your 790 ok...
Video:JVC N7 Sony 85” 900F Sony 55” 900F
Audio: Paradigm Prestige 95, 55C, 15b Dual JL Audio D110
Receiver/Amp: Anthem 1120, Emotiva XPA-5 Gen 2
Source: Panasonic UB820, Triple black velvet batcave
125" 2.35 Stewart Cima Neve Tab Tensioned Electric
asharma is offline
post #32022 of 32099 Old 08-30-2019, 04:33 AM
Quoted: 777 Post(s)
Liked: 664
I sold my 790 at a very good price. Last year I was so busy I only had less than 350 hours and it was only 8 months old. Plus when I sold it I also give a free calibration to that person. But yeah, I got lucky that the person actually chose the 790 because of the much better blacks (he A/B my 790 with my NX7 in my HT.)
my home theatre
post #32023 of 32099 Old 08-30-2019, 05:00 AM
asharma's Avatar
Liked: 576
In my triple black velvet batcave, the blacks are "ok" on my N7 compared to my x950...im sure a calibrators eye like yours sees a big difference with an A/B test but we don't watch movies that way...Just like I cant compare my Elunevision screen to a Stewart screen...The screen looks "fine" to me but I can't A/B test it...I watched Mortal Engines last night on my N7 and man o man, stunning jaw dropping clarity and color gamut...Do u ever make it to Nova Scotia?
asharma is offline
post #32024 of 32099 Old 08-30-2019, 05:15 AM
Quoted: 777 Post(s)
Liked: 664
I was there doing a calibration tour 2 years ago (12 people). If there are enough people for me to fly there (or the client pays just like my clients several months ago in Munich and Holland, and the upcoming one in Florida), then I’ll go again. I literally do this worldwide (well, never had client in Africa).
my home theatre
post #32025 of 32099 Old 08-30-2019, 05:34 AM
asharma's Avatar
Liked: 576
PM sent
asharma is offline
post #32026 of 32099 Old 08-30-2019, 07:36 AM
guptown's Avatar
Quoted: 16 Post(s)
@zombie10k your procedure worked!!! Thank you very, very much.
guptown is offline
post #32027 of 32099 Old 08-30-2019, 08:57 AM
zombie10k's Avatar
Liked: 5684
PSA - this is the JVC rs500/600 thread folks..
Awesome!! were you able to upload the color profile?
krichter1 likes this.
post #32028 of 32099 Old 09-01-2019, 10:24 AM
guptown's Avatar
Quoted: 16 Post(s)
I was. I'm now in UHD bliss.
Also, shout out to @Dreamliner for his 4k setup guide!
guptown is offline
post #32029 of 32099 Old 09-17-2019, 10:16 AM
AVS Spatial Member
swest's Avatar
Quoted: 234 Post(s)
Liked: 89
Originally Posted by Dreamliner View Post
I emailed JVC about the "Lamp Replacement" coming on at 3400 hours when the spec sheet says 4500 hours lamp life. This was their response:
"There isn't an exact amount of hours on a projector. There is a feature on the projector called Lamp Power pg. 43 of the manual which if set to (high) it will decrease the lamp hours. Typically the estimated amount is roughly 4500. When the lamp reaches at about 80% the message will appear for you to replace it. This is normal."
3400 is 80% of 4250 hours and I think I'll be fine going to 3800-4000 hours before replacement. I might just replace sooner and use the original as a spare. Typically when I use my projector, it's on for 6+ hours as I don't do short sessions and do not use it like a TV. I'll usually sit down and watch through a bunch of TV show episodes or a handful of movies.
I'm trying to stretch my lamp life because I want the replacement lamp to last until my next projector, so every hour I get out of my current lamp is a 'free' hour. Also, it seems like this 80% thing from JVC is kinda arbitrary, so I'm not sure I'm actually risking anything and I know my on/off cycle count is 'relatively' low for the amount of hours on the projector because of the usage pattern.
Greetings Dreamliner.
At long last my RS600 is also displaying "Lamp Replacement" (started a few days ago). I thought that I had better go ahead and put in the spare lamp I bought a while back, but while searching the Owner's Thread for info on the lamp, I have run across your post. I just checked the lamp hours and, sure enough, it says: 3416H. So, 3400 seems to be a special number.
My original reason for searching for info on the lamp was to discover what condition(s) gives rise to the "Lamp Replacement" message. So, it is strictly based on hours, right? The image my projector throws still looks great, and bright enough, so I, too, would not want to prematurely replace the lamp (and for the same reasons as you - I want my next lamp to carry me forward to my next projector in a couple of years... Also, I use my projector as you describe: Lengthy sessions, not a lot of ONs and OFFs)
So... I'm curious where you are with your lamp replacement? Still milking the original lamp? Or preemptive replacement? (I tried to search through your posts, but there's so many that I gave up and decided to just ask you directly ;-)
- s.west
"Oh, what a day. What a lovely day!"
swest is offline
post #32030 of 32099 Old 09-17-2019, 01:36 PM
Dreamliner's Avatar
Quoted: 1424 Post(s)
Liked: 753
I'm 100% certain it is an automatic message at 3400 hours. I just passed 4000 hours on the original lamp and I honestly don't have any brightness complaints at all. I actually bought a replacement lamp only from Dominic (link) and I'm going to put that in soon I think. My only actual concern would be a destructive lamp explosion. If I knew I could simply run the projector until the lamp simply burnt out, I would.
I also finally figured out how to use my AEMC CA813 light meter and took measurements of my lamp at 4000 hours (RS400, 108" 1.78:1 measured, 136" 2.35:1 screen):
Low Lamp
250 lux
23.23 ftL
846 Lumens
79.58 nits
High Lamp
342 lux
31.78 ftL
1157 Lumens
108.86 nits
CoryW likes this.
Dreamliner is online now
post #32031 of 32099 Old 09-17-2019, 02:36 PM
AVS Spatial Member
swest's Avatar
Quoted: 234 Post(s)
Liked: 89
Low Lamp
250 lux
23.23 ftL
846 Lumens
79.58 nits
High Lamp
342 lux
31.78 ftL
1157 Lumens
108.86 nits
Very helpful. And, yes, I was thinking the same thing about explosive failure and preemptive replacement.
And, yes, I also got one of those spare lamps from Dominic, so we're really on the same page here.
I may even follow your example and take a reading of my lamp...
Anyway, I think that I'm caught up now. Mainly I wanted to know the significance of the "Lamp Replacement" message, and whether the projector might be giving that warning because of some underlying condition about the state of the lamp that it was sensing. But you have confirmed that, no, it is strictly a warning based on the Hours on the Lamp.
Thanks a lot!
- s.west
p.s. While doing some of my searching I came across a number of very helpful guides that you have posted in the last couple of years. I have bookmarked them. Thanks also for those!
swest is offline
post #32032 of 32099 Old 09-17-2019, 08:44 PM
erkq's Avatar
Quoted: 746 Post(s)
Liked: 515
I too am on the original lamp on an almost 3 year old RS500. I've got under 2,000 hours on it. I wonder how you guys put so many hours on it. We watch it every night plus Sunday neighborhood Movie Nights.
I'm amazed at how stable the lamps is. Still plenty bright and I just touched up calibration after 6 months for showing Biggest Little Farm this last Sunday. 21 pt greyscale was still within 2 dE as was the color checker and luminance and saturation ramps. I tidied it up again to .5 dE just because. Once the greyscale was back, the colors tightened up to less than 1 dE without having to run a cube.
erkq is offline
post #32033 of 32099 Old 09-17-2019, 09:05 PM
Dreamliner's Avatar
Liked: 753
I use my projector for everything: movies, TV, games. I have another TV but I haven’t used it in over a year.
I also watch too much I’m sure, before I got “into movies” I watched less than 5 hours a week. I probably need to taper back.
post #32034 of 32099 Old 09-17-2019, 11:39 PM
erkq's Avatar
Quoted: 746 Post(s)
Liked: 515
The reason I'm really surprised is that almost every... single... night... my wife asks, "Wanna watch something?" She loves it! So I thought I watched a lot. Guess not...
erkq is offline
post #32035 of 32099 Old 09-18-2019, 07:44 AM
Liked: 0
Originally Posted by Manni01 View Post
I gave it a go this morning, it took about one hour to get a very decent result. This completely solves the dilemma between shadow detail or raised black floor.
I attach three screenshots showing 1) How the custom gamma curve looks like before calibration (I selected a normal preset as sadly gamma D isn't selectable as a starting point) 2) What the curve looks on the JVC Autocal after calibration and 3) What the curve looks like after the 11 point manual calibration.
Looks great and the best I've seen HDR. As you can see on the chart, no loss of detail in the low end and full native on/off contrast, unlike when using Dark Gamma above +2. Unfortunaltely this seems to be the only way to get a near perfect PQ Gamma on the JVCs.
A few things:
1) You need another meter/software to be able to do real time changes on the custom gamma curve. You change a stim value and you read using another software (I used Calman and my discus). Otherwise it's not practicle. It takes a few seconds for the change to upload, so make sure you wait until it's done before running a measurement after a change
2) If you run a JVC autocal before, it makes things much faster/simpler as you only have to worry about white gamma, the RGB balance is good (I didn't touch anything on the RGB curves)
3) I went bottom to top, and I ran a few full reads regularly. You need to lower the stim before 50% and to raise it after 50% (it's an S shape).
4) There is no roll-off in that curve: I map 1:1 from 0-200nits actual (0-1200nits on the chart), so from 0-80%, then I clip at 80% and above (content above 1200nits is clipped). Some might prefer more of a roll-off.
I tried with The Shallows, it looked great and I tried with Point Break, which is mastered to 4000nits and according to metadata has content going quite high above 1200nits, I couldn't see any obvious clipping and the picture wasn't dark in any way.
So as far as I can see, clipping content around 1200nits (JVC Contrast set to zero and bright gamma set to +2) looks fine with all titles, as expected. If you find a title for which it doesn't look good, please let us know.
This calibration is only good for my own setup (200nits peak in high lamp, iris fully open) as unfortunately it's not possible to adjust the gamma settings with a custom curve, but if some with a similar setup want to try it, let me know and I'll post the file. People with a larger screen will probably find it too dim, but as it's not possible to raise picture tone with a custom gamma, there isn't much we can do about that.
I have a x590r which doesnt have a gamma d but instead use st.2084....but i find that too dark. I was looking into doing a custom gamma, on calman which spread sheet and setting are you using...is there a way you can put a complete guide on how to do that?
Sukhwinder Singh is offline
post #32036 of 32099 Old 09-18-2019, 08:12 AM
krichter1's Avatar
Quoted: 2104 Post(s)
Liked: 2382
- s.west
If I were you guys I'd just ping Dominic Chan and buy an OEM spare bulb (he's got an ad in classified as well w/ pics on the swapout process), and throw it in your old cage... takes like 15min and saves you about 75% of list price!
zombie10k likes this.
Kevin
You only live once, but if you live it right, once is enough.
==> Our 4K/3D Immersive Theater
krichter1 is online now
post #32037 of 32099 Old 09-18-2019, 12:09 PM
zombie10k's Avatar
Liked: 5684
Those lamps are awesome..! I have enough here to last for years hope all is well! Any new 3D movies recently? Last few were Godzilla KOM 3D & Avengers End Game 3D. Alladin is next, 3D is great in this movie.
posting lamp swap info again if anyone missed it before:
Spoiler!
post #32038 of 32099 Old 09-18-2019, 12:44 PM
Liked: 1840
Spoiler!
For “newbies” it’s best to keep the lamp in the lens-down position when the retaining screws are removed; otherwise there’s a risk that some pieces, including the lens, may fall out. (It’s easy to put them back if you’re familiar with the lamp).
post #32039 of 32099 Old 09-18-2019, 01:29 PM
krichter1's Avatar
Liked: 2382
What up my brutha!
Yeah I really enjoyed Endgame in 3D (but 4K looked very good as well... it's prob one of the most enjoyable (& satisfying "OH SNAP"), superhero movies I've ever seen... I love it 3000!). After we saw it in IMAX 3D I found this little gem (above Caps shield/mask), for my theater below and just could NOT resist even tho my wife was like... "Seriously??". Was actually trying to update my theater pics on AVS since my Tennessee theater is all but complete but I keep getting an error and it won't upload my jpeg pics (BOO! . . . says something like "Unable to read the format of file: . . ." whatever the hell that means!? in case any of you smarter peoplez knowz why PM me please!)
Spoiler!
Just watched Aladdin in 4K but 3D won't be here for another week or so.
Kevin
post #32040 of 32099 Old 09-18-2019, 03:10 PM
zombie10k's Avatar
Liked: 5684
What up my brutha!
Just watched Alladin in 4K but 3D won't be here for another week or so.
The Cap shield and mask are awesome..!! I know all about 'the collecting cool stuff bug'. I've been collecting the Marvel steelbooks for years, both the 3D and UHD versions. last 3 are out 10/1 for AntMan, Dr Strange and original GOTG.
I'm looking for ideas how to display these on one of the walls in the room that leads to the HT. maybe something like a translucent shelf in the pic below:
Spoiler!
Spoiler!
jvc-rs500u synch/display issue? , RS600
