Official JVC RS600 / RS500 (X950R / X750R - X9000 / X7000) Owners Thread - Page 1075 - AVS Forum | Home Theater Discussions And Reviews
 84879Likes
post #32221 of 32266 Old 12-02-2019, 10:50 AM
zombie10k's Avatar
Quoted: 5452 Post(s)
Liked: 5854
quick cyber monday PSA - the river has the CyberPower CP1500PFCLCD on discount for a great price. this is one of the few UPS's with a pure sign wave output, verified by a number of folks with a waveform monitor. I just grabbed one to use with my projectors.
nathan_h and Mocs123 like this.
zombie10k is offline
post #32222 of 32266 Old 12-02-2019, 01:35 PM
Dreamliner's Avatar
Quoted: 1462 Post(s)
Liked: 773
This is a good UPS. I have my entire home theater rack on it.
Dreamliner is offline
post #32223 of 32266 Old 12-02-2019, 02:16 PM
David Susilo's Avatar
Quoted: 792 Post(s)
Liked: 670
I use that for my projector’s UPS
follow my A/V tweets @davidsusilo
ISF, THX, CEDIA, Control4 & HAA certified
Reviewer for TED & WifiHifi Magazines
my (yet to be completed) BD list
my home theatre
David Susilo is offline
post #32224 of 32266 Old 12-02-2019, 02:26 PM
coderguy's Avatar
Quoted: 2533 Post(s)
Liked: 1372
I have the same one as well, except a slightly different / older model from way back, but same readout and VA and brand.
I had to replace the batteries after 7 or so years, it worked fine after replacing the battery with 2 generic batteries from Amazon.
The generic batteries might be a bit weaker, but hard to tell since I went so overkill on the VA it won't matter either way.
I don't know if the surge protection circuitry is still that good after that long.
They say you should replace surge protectors every X years, but I think it's very highly exaggerated on how quick surge protectors (or presumably UPS) lose their protection.
I know some types of protection circuitry can last almost forever, but just varies with different types.
**Updated Projector Calculator Released NOV 2017**
-- www.webprojectorcalculator.com --
coderguy is online now
post #32225 of 32266 Old 12-02-2019, 02:47 PM
Mocs123's Avatar
Quoted: 287 Post(s)
Liked: 147
Will that run your entire rack long enough to get the projector shut down in the case of a power outage?
Also another UPS/Surge question - I currently run my sub amps (Behringer iNukes) and projector off a switched power strip (link below) so that they cut on and off when the projector does as they don't have remotes or a 12v trigger and can't be programed to my Harmony Hub. Since this power strip supposedly has surge protection does that mean that I shouldn't plug it into the UPS?
https://www.amazon.com/TrickleStar-A...4WMR5300N04812
7.4.4 Theater Room: JVC-RS500, Silver Ticket AT 2.35:1 142”, Onkyo RZ830, Anthem PVA-7, Panasonic DBT-110, JBL Studio 530’s, 4 - 15" DIY Sealed Subs
3.1 Living Room: Samsung 64” F8500 Plasma, Anthem MRX 300, Dynaudio Audience 52’s, Dynaudio Audience 122C, NHT SubOne
Mocs123 is offline
post #32226 of 32266 Old 12-02-2019, 02:50 PM
coderguy's Avatar
Liked: 1372
You definitely don't want to chain a surge protector to a UPS, get a regular power strip, they are cheap.
Doing so could interfere with the UPS protection circuitry and even cause other more serious issues, and in rare cases potential fire.
post #32227 of 32266 Old 12-02-2019, 03:30 PM
DLCPhoto's Avatar
Quoted: 1694 Post(s)
Liked: 795
I'll let the others address the other part of your question, but I have one idea for you on the iNuke amps.
I currently have a Control4 system to operate my Theater, but before this, I controlled it with a Harmony Hub, Remote and Home Extender, and faced the same issue with the iNuke 6000 I use to power my subwoofer.
I bought this SmartPlug, which I was able to incorporate into the Harmony (as I recall it goes through the Home Extender add-on). I in turn controlled the whole system with Alexa, and it worked pretty well:
GE Z-Wage SmartPlug
The iNuke switch was left in the 'On' position, and when the SmartPlug was activated via the Harmony setup, it turned on, and then back off when I was done.
JVC NX7, DCR Lens, Marantz SR7010, Screen Innovations 160" 2.35:1 Screen
Front L/R: Duntech Sovereigns, powered by 2 bridged Adcom GFA-555
Center: Revel C208 powered by Cambridge Audio Azur 851W
Dolby Bed (4): Sony Core SS-CS5, Atmos (4): Ascend Acoustics CBM-170 SE
Subwoofer: DIY 8' sub with 4 18" SI Drivers, powered by iNuke 6000
DLCPhoto is offline
post #32228 of 32266 Old 12-02-2019, 05:26 PM
Dreamliner's Avatar
Liked: 773
I also have an iNuke as well. I used to have it triggered but it was making a pop noise so now I just turn the iNuke on/off manually. Someone added a relay to trigger the iNuke through the power circuit. I can’t find it anymore though. I do use a smart power strip to trigger fans with the receiver.
On my old APC 1500, the UPS ran the whole home theater (no subs) for 20 minutes or so during a power outage to finish the Dexter finale (travesty).
Eh, not so sure about that. My rack has a SurgeX that breaks out to a couple power strips. EVERYTHING including my projector and subwoofer amplifier is connected through the SurgeX, then that is connected to the UPS.
post #32229 of 32266 Old 12-02-2019, 06:13 PM
coderguy's Avatar
Liked: 1372
You CAN do it, but it's not proper. There are all kinds of things you can do with electrical, but it doesn't mean you should.
I can smoke a cigar next to propane or while pumping gas, and 99.9999% chance it won't do anything, but I'm not going to risk it.
I can leave my phone out of airplane mode, and the chances of crashing the airplane due to interference are probably close to 0.000000000000000001% to the billionth.
However, they still say don't do it.
I would say your chances of having an electrical issue or a worn or faulty component catching on fire are many magnitudes higher than you crashing a plane with your cell phone
post #32230 of 32266 Old 12-02-2019, 08:14 PM
Mocs123's Avatar
Quoted: 287 Post(s)
Liked: 147
GE Z-Wage SmartPlug
Thank you, I'll see what I can work out something like that. I wonder if something would work with the Lutron Caseta Smartbridge? I haven't hooked it up yet but I have one with to use with a Caseta dimmer as it's supposed to work with Harmony Hub.
Mocs123 is offline
post #32231 of 32266 Old 12-02-2019, 08:16 PM
Mocs123's Avatar
Quoted: 287 Post(s)
Liked: 147
That's pretty impressive. I was planning on just hooking my projector up to it, but it sounds like it will handle more than that.
Mocs123 is offline
post #32232 of 32266 Old 12-02-2019, 08:25 PM
Dreamliner's Avatar
Liked: 773
You can definitely run your whole system on it (unless you’ve got a bunch of AB class amps or something). Let’s be honest, the real reason we’ve got a UPS is to shut down the projector with enough time to cool the lamp down. Having the whole system on the UPS and just being able to hit the power button on my Harmony is nice.
I also have my router and cable modem connected to the UPS, gets me WiFi for quite some time.
post #32233 of 32266 Old 12-02-2019, 09:13 PM
coderguy's Avatar
Liked: 1372
Just one last bit of info, this is an NFPA code violation, if something did happen, it could be grounds for your insurance company to claim negligence and not pay a fire claim, just FYI - food for thought. Although NFPA isn't strictly enforceable in the US, there are other codes that usually come into play and can cause issues.
post #32234 of 32266 Old 12-04-2019, 04:12 PM
Dreamliner's Avatar
Liked: 773
I am not too concerned about it. The risk is accidentally overloading the UPS.
My system at normal volume levels is below 700 watts (as measured by a watt meter, not the UPS). Well within the operating capacity of the UPS.
post #32235 of 32266 Old 12-04-2019, 10:07 PM
jim94025's Avatar
Quoted: 23 Post(s)
Looking to purchase a professionally calibrated JVC RS500/750, preferably by ChadB or someone equally talented.
PM me if you have a nice unit you want to sell.
Jim
jim94025 is offline
post #32236 of 32266 Old 12-05-2019, 06:09 AM
996911's Avatar
Quoted: 234 Post(s)
Liked: 170
AppleTV4K settings with the RS600?
ok so I've gone back through quite a bit of the thread and I swear I saw it somewhere but just can't locate it. Can anybody help out with this? THANKS SO MUCH!
FYI....I use my Panasonic 820 for almost ALL my streaming but having just replaced our ATVHD with the ATV4K there are a few instances where we have purchased a movie through iTunes instead of a physical disc and in the case of the 4K HDR option through iTunes we'd like to watch it but I have no clue on the ATV4K settings setup.
Cheers,
Ray
996911 is offline
post #32237 of 32266 Old 12-05-2019, 01:02 PM
Dreamliner's Avatar
Liked: 773
I seem to recall something about the ATV4K triggering Gamma D multiple times during playback on the the RSxxx projectors. You might need an HD Fury device to make the ATV4K play nice. Hopefully others will chime in.
post #32238 of 32266 Old 12-05-2019, 01:13 PM
alebonau's Avatar
Quoted: 1981 Post(s)
Liked: 1366
i was just using factory settings but had frame rate and range to match source. ie if it was HDR to display as HDR and if source SDR to display at SDR and leave frame rate alone as well. this worked fine.
you do want though check the cable test apple provide. make sure your cable is upto it. if its not you might get some funny behaviour going on
"Technology is a drug. We can't get enough of it."
Welcome to my lounge room :)
alebonau is online now
post #32239 of 32266 Old 12-05-2019, 01:22 PM
996911's Avatar
Quoted: 234 Post(s)
Liked: 170
Yup, I can already see the level of frustration shooting through the roof with this thing. Every time I moved around the menus it would keep sending a new HDR tag and switch over to D
Cheers,
Ray
996911 is offline
post #32240 of 32266 Old 12-05-2019, 01:24 PM
coderguy's Avatar
Liked: 1372
That is the easy part to avoid, but there are other issues with it.
The dangers are the two devices getting out of phase in the interrupt of the MOV, causing one to heat up too hot.
They can even get stuck in a sort of clamping loop, for lack of a better word.
This can be caused such as if your stereo were suddenly start drawing too many amps because something inside the stereo failed (it happens).
There are other things that can cause it, such as just plain surges.
Sure it's not common, but whatever the odds, the results are pretty bad.
If you've ever seen how fast an electrical fire can spread...
post #32241 of 32266 Old 12-05-2019, 01:29 PM
namirkhan's Avatar
Quoted: 64 Post(s)
Liked: 34
This is true, but especially movies with Dolby Vision.
Marantz 7702mkII
JVC RS500
Panasonic DMP-UB820
namirkhan is offline
post #32242 of 32266 Old 12-06-2019, 03:32 PM
quack724's Avatar
Quoted: 97 Post(s)
Liked: 33
can't get Roku Ultra (2019) to work with RS500
I picked up a Roku Ultra 4K (2019) from Black Friday sale. I cannot get Roku Ultra (2019) to work with the RS500. Specifically, on boot up I can see the Roku splash screen but soon after the screen goes black such that it doesn't even make it to the Display type set up screen to Auto detect or manually select resolution.
My chain : Panasonic UB900 --> Monoprice High Speed HDMI cable #1-- > HD Fury Linker --> Monoprice High Speed HDMI #2 --> Marantz 8802A --> HDMI cable --> JVC RS500.
With this set up, I have been able to play back UHD discs on the UB900 ok (4K HDR 4:2:2 at 24fps) and has been stable for > 1 year.
What I have tried
1) Put Roku in place of UB900
2) Put Roku in other HDMI input of Marantz using same HDMI cable paired with UB900 (no Linker). I confirmed this other HDMI input worked fine with UB900 first.
3) Bypass Marantz 8802A by plugging Roku directly to RS500 using same HDMI cable already connected to RS500 as shown in chain above.
4) Checked CMD was off on RS500.
5) Connect Roku to 1080p Panasonic plasma TV (and it works perfectly with the 1080p TV i.e. can set up ) --> Roku Advanced display settings --> Auto-adjust display refresh rate to "Enabled" and HDR subsampling to 4:2:0
6) Tried another Roku (exact same model , used on different 1080P TV)
7) Roku SW ver 9.2.0, build 4750
Just wondering if anyone has been successful in pairing 2019 Roku Ultra with RS500 and what settings did you use on both the Roku and RS500?
Thanks in advance !
quack724 is offline
post #32243 of 32266 Old 12-06-2019, 04:00 PM
Quoted: 5204 Post(s)
Liked: 2050
What I have tried
Thanks in advance !
Can you not set up the Linker to force the Roku to 1080p initially, and go from there?
JVC DLA-NX7; Denon AVR-X3400H; HD Fury Vertex; ATV4K; Fire TV Cube
JVC Projector Bright Curves; Optimizing HDR;
Creating a basic HDR curve using Arve’s Tool;
Replacing JVC Bare Bulbs
Dominic Chan is offline
post #32244 of 32266 Old 12-06-2019, 04:01 PM
bwillcox's Avatar
Quoted: 963 Post(s)
Liked: 566
What I have tried
Thanks in advance !
I had a similar issue with my 2019 Rokus with my TVs (didn't notice it with my projector). I power cycled the Rokus (unplugged and replugged) and then went to the Display setting on the Roku and set it to 4K HDR 30Hz. Not sure the display setting had anything to do with it, but since then I haven't seen the issue.
1) JVC DLA-NX7 & Sony 65Z9D, Yamaha CX-A5200, Outlaw Audio 7900 & 7700, UDP-203, DP-UB9000, UBP-X800M2, Roku Ultra
2) Sony 75Z9D, Yamaha RX-A3080, 2xOutlaw Audio 2200s, UDP-203, UBP-X800M2, Roku Ultra
3) Sony 75X940E, Yamaha RX-A2080, UDP-203, UBP-X800M2, Roku Ultra
bwillcox is offline
post #32245 of 32266 Old 12-06-2019, 10:20 PM
nathan_h's Avatar
Quoted: 2752 Post(s)
Liked: 1963
There was a time when the ATV4K did some funky stuff with with metadata. Do you use a custom gamma curve for HDR or Gamma D? If the latter, you probably don't need to worry. If the former, I assume you are using something like the Vertex to manage it?
In terms of settings, after much experimenting, I settled on:
Default: SDR 4k
Match Dynamic Range: on
Match Frame Rate: off (this last setting is more about how the Vertex handles it, in combo with my receiver and RS500, than anything else)
That is: I have found that match frame rate (on the ATV) fed through a vertex, sometimes causes lip sync issues, but that sending everything at 60hz (ie, match frame rate off) works better.....and the JVC performs inverse telecine on content that was originally 24hz very well.
On the other hand, match dynamic range is really nice.
So I like to set the default ATV output to 4k SDR. So SDR content from unsophisticated apps looks right. And then when anything is HDR, the ATV will "match" the dynamic range and send HDR.
But really the question is what kind of gamma curve you are using for HDR content.....and whether you have a Vertex (or similar)..... and those factors will influence the rest.
nathan_h is offline
post #32246 of 32266 Old 12-07-2019, 08:42 AM
StevenC56's Avatar
Quoted: 586 Post(s)
Liked: 206
Our X750R has developed a clicking/snapping type noise that happens a few times when we are watching a movie. Anybody else experience this? Any idea what it is, and if I should take any measures to correct it? It's not a huge annoyance, but it's there never the less.
JVC X750R Projector,Yamaha CX-A5200 Pre-Pro, Yamaha RX-Z11 Receiver, (Amps Only) Yamaha MX-D1 Power Amps x 2, Yamaha RX-Z1 (L&R Surround Channel Amp), Oppo BDP-103D BR, Panasonic DP-UB820 UHD, Pioneer Elite CLD-99 LD, Definitive Tech BP7000SC Mains, CLR3000 Center, BPVX Surround Sides&Backs, BPX F&R Presence, Martin Logan Abyss Front L&R Subs/Dynamo L&R Rear Surround Channel Subs, Infinity SSW-210 Center Channel Sub.
StevenC56 is offline
post #32247 of 32266 Old 12-08-2019, 07:09 AM
996911's Avatar
Quoted: 234 Post(s)
Liked: 170
Thanks for input!
Current setup:
ATV4K —> Integra Receiver —> RS600
*no vertex or similar*
RS600 is running custom curves from Chad B calibration.
I have no problem adding a vertex or similar but would prefer avoiding the requirement to add a device just to keep Gamma D from kicking on. But if I can’t watch 4K Apple content, then it really feels like a waste of having the ATV4K and will have to consider it.
Cheers,
Ray
996911 is offline
post #32248 of 32266 Old 12-08-2019, 07:31 AM
nathan_h's Avatar
Liked: 1963
So you manually select your custom Chad curve at the start of every HDR movie, after the projector has tried to go into Gamma D?
At a minimum that would be necessary when watching HDR on the AppleTV4k. (If you are just watching 4k but not HDR that of course that is. It the case.)
I don’t know whether the metadata changes within programs anymore because I use a vertex....not jut to avoid gamma D. It it also automatically selects the gamma on the projector based on the source content.
Sorry I can’t be more definitive. Luckily Apple has a decent return policy afaik just in case.....
Thanks for input!
Current setup:
nathan_h is offline
post #32249 of 32266 Old 12-08-2019, 07:41 AM
996911's Avatar
Quoted: 234 Post(s)
Liked: 170
Yup, I load my custom 4K HDR curve and start watching. Never an issue but should it ever kick over to D then I know immediately and can switch back to my Chad curve easily. It’s a rare thing and never happens during physical media playback, and only if I jump out to menus streaming HDR content from Netflix. Hence the reason I have never added a vertex. Maybe Ill look into adding a vertex but I hate adding a 3-400 piece of equipment to lock in a setting on the projector.
Cheers,
Ray
996911 is offline
post #32250 of 32266 Old 12-08-2019, 07:51 AM
nathan_h's Avatar
Liked: 1963
I agree that if you are happy with your current process a vertex is overkill.
Try the ATV without it and see?
nathan_h is offline
jvc-rs500u synch/display issue? , RS600
