Official JVC RS600 / RS500 (X950R / X750R - X9000 / X7000) Owners Thread - Page 1083 - AVS Forum | Home Theater Discussions And Reviews
 84967Likes
post #32461 of 32501 Old 02-14-2020, 06:12 AM
markmon1's Avatar
Quoted: 6238 Post(s)
Liked: 4331
Originally Posted by p.laver View Post
Hi, I need some help, I have JVC X9000 projector that is just under 4 yrs and it has developed the following fault:
Out of the 4 installation modes, the projector works OK on the 2 upright modes, and exhibits the fault on both the inverted positions (Installation setting)
This needs the main PCB board & DD PCB, X9000 replaced Part numbers
XD1-0155-50 & XD1-0175-50 at a cost of just under $1800 AUD.
I consider this a major failure. I have emailed customer service/Support here Australia last Monday and informed them about the failure and would they consider this an acceptable failure for such a high value product and would they consider and 'Gesture of Goodwill' repair through the JVC repair centre they recommended I use when I first contacted them ab out the fault.
To-date I haven't received a response not even an acknowledgment of the receiving the email. This isn't unusual for Australian based companies. That said I would like to try escalate this within JVC.
This is reason for posting here to gauge whether I'm being unreasonable or not and if anyone here has another contact email address for JVC as it seem a pointless trying again through the JVC Australian Support.
How have you determined that you need a new board from just this? I think it's a far jump from seeing these symptoms to knowing which part you need unless you've done a lot of deep dive troubleshooting that you didn't list here. Personally, I think it is unreasonable to expect JVC to replace (for free) a part for a projector after the warranty period. For one thing, its unlikely they even have these parts any longer. Part of the reason warranties are limited is so that companies can move forward and not stockpile every part they ever made forever etc.
I think if this were my projector, I'd find a way to use it in a way that it works. For example, if it works right-side-up only, I'd make my ceiling mount right side up and be done. (See my avatar picture).
rossandwendy and Mike Garrett like this.
Video: JVC RS4500 135" ST130 G4 screen in batcave, htpc nvidia 1080ti madVR.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, Infinite Baffle Subs 4x15 fi audio running on behringer ep4000 + 2x12 fi audio mounted in main chair firing into back.
markmon1 is offline
post #32462 of 32501 Old 02-18-2020, 05:32 PM
Liked: 0
Originally Posted by ScottAvery View Post
I can't speak to what they will do for you. I assume your warranty was only 3 years for that? Did you happen to purchase with a credit card that extends your warranty? Here in the US some cards offer that service. My AmEx adds 1 year and Citi card adds 2 years.
Is your projector actually inverted when it is failing for you or are you just cycling the modes and it fails in that mode regardless of physical orientation? I ask only because my first projector, from years ago, had the same fault but it was the bulb starting to fail. It would operate upright but fail when inverted.
No I paid cash, the inverted failure is all the time. if I switch to table-top install it fine.
p.laver is online now
post #32463 of 32501 Old 02-18-2020, 05:42 PM
Liked: 0
The projector has being fully inspected by JVC authorized repairer. He's identified the inverter driver has failed. The fix is a new PCB. JVC have the parts and they more than willing to ship over from Japan. This is a high end projector and manufactures know how long there products will last because they are tested. The JVC contact I finally spoke with yesterday agreed that he would not expect this type of failure during the time period I've mentioned which is backed up by the hours usage etc. that he did offer 10% off the price of PCB
I do have the option of flipping the wall bracket so that I can use the table-top installation.
post #32464 of 32501 Old 02-18-2020, 06:30 PM
Squidjammer's Avatar
Quoted: 130 Post(s)
Liked: 41
If it is only 4 years old you may be covered by Australian consumer guarantees so if JVC Australia are not helpful (I would be surprised if they were) I would contact them and see what they have to say.
I also have the contact number of the Australian JVC sales and service co-ordinator but I think you probably have already spoken to him as he seems to be the only contact we have here in Australia and in short he is pretty much useless. Let me know and I can PM you his details.
Squidjammer is offline
post #32465 of 32501 Old 02-18-2020, 07:10 PM
Mike Garrett's Avatar
Quoted: 13494 Post(s)
Liked: 11128
Projector is four years old and works if right side up. I would just shelf mount it, like markmon suggested earlier.
Mike Garrett is online now
post #32466 of 32501 Old 02-24-2020, 06:24 PM
Dreamliner's Avatar
Quoted: 1519 Post(s)
Liked: 800
I just reached 4501 hours on my original lamp. My usage is mostly low lamp. 3D is always high lamp, HD is always low lamp. 4K was usually high lamp before SDR2020, now it’s usually low lamp. I honestly still have zero brightness complaints with HD or SDR2020 and would gladly keep going if I was 100% certain a lamp failure would not harm the projector. At this point I'm going to call it on this lamp (but I'll keep it as a spare). I bought a brand new genuine JVC replacement lamp from another forum member (projector died) and also got his original lamp with about 2000 hours on it. Before I open a sealed replacement, I'll run the numbers up on this "used" ~2000 hour lamp...it still has 2000+ hours of life left!
I think the lesson to learn here is these lamps can go quite a bit further than originally thought. I know JVC rates them for 4400 hours but I've seen posts from people looking for replacement lamps when they barely have 1000 hours on the projector. Even the automatic "replace lamp" warning comes on at only 3400 hours. My suggestion: keep running your lamps until they hit 3400 hours at minimum, but join me in the 4000+ hour club!
I've tried a few other lamps but I'm now fully convinced Genuine JVC is the only way to go.
Here are the numbers:
4501 Hours:
Low Lamp
223 Lux
754 Lumens
22.79 ftL
78.08 Nits
High Lamp
307 Lux
1039 Lumens
31.38 ftL
107.51 Nits
Replacement Genuine JVC Lamp with about 2000 Hours:
Low Lamp
250 Lux
846 Lumens
25.55ftL
87.54Nits
High Lamp
345 Lux
1167 Lumens
35.26 ftL
120.80 Nits
Craig Peer likes this.
Dreamliner is offline
post #32467 of 32501 Old 02-24-2020, 06:44 PM
zombie10k's Avatar
Quoted: 5619 Post(s)
Liked: 6087
That's awesome on the lamp life! i'm only at 2600 hours and have plenty to go on this lamp.
now for something to really get excited about, start thinking about setting up that HTPC to check out MadVR and check out some real tone mapping
every time I watch an HDR movie, it's hard to believe this has been the same projector for the last few years. I went back to some of the custom curves and fired up the UB820, there is really no comparison and wouldn't bother with HDR as much if it wasn't for what MadVR is capable of today. Now I can't wait to see what it's going to do for the next movie! an amazing product, honeymoon is nowhere near over, it's just getting started.
zombie10k is online now
post #32468 of 32501 Old 02-24-2020, 07:21 PM
Dreamliner's Avatar
Liked: 800
I have the gear (except a 4K drive to rip). I should probably poke around and find a fool-proof A-to-Z DIY guide for setting it up.
post #32469 of 32501 Old 02-24-2020, 08:11 PM
zombie10k's Avatar
Liked: 6087
it's pretty straight forward. Nvidia drivers get installed, I'm using latest version.
baseline version of MadVR is installed http://madshi.net/madVR.zip
then updated with latest build (take updated files, overwrite existing files in MadVR folder)
http://madshi.net/madVRhdrMeasure113.zip
LAV filters need to be installed and configured.
https://www.videohelp.com/download/L...-Installer.exe
LAV video settings:
LAV audio settings:
Using MPC-HC latest build here for the media player:
https://www.videohelp.com/software/M...ic-Home-Cinema
madVR baseline settings. On the projector, set it to 2.4 gamma and the BT2020 color profile.
In MadVR HDR settings - Display peak luminance is the actual NITS you have in your environment / screen set. tweak the dynamic target nits to your brightness preference. I keep it at 100 with the HP screen but would lower it if I had a lower gain screen.
I use Kodi with MPC-HC + MadVR configured as the back end player and navigate the Kodi user interface with a microsoft media center remote control.
Control J while playing back will display the real time data on what's happening on a frame by frame basis. I am guilty of watching 1/2 a movie with this turned on just to see what's happening in the background.
post #32470 of 32501 Old 02-24-2020, 09:57 PM
Rengozu's Avatar
Quoted: 206 Post(s)
Liked: 288
So I'm still running the RS:600 with Panamorph Paladin lens with the Panasonic 9000. Guess I'm still happy with it as I haven't really seen better in person with the new stuff that's out there, but was wondering where the sweet spot for an upgrade would be. Would there be enough wow factor to go up to the RS2000?
JMAX Home Theatre
Spoiler!
Rengozu is offline
post #32471 of 32501 Old 03-05-2020, 06:23 PM
Sg13's Avatar
Please help troubleshoot
I have JVC RS500 which I bought brand new in 01.2016 here on AVS dealer.
It has 3500 hours and last month it started showing low lamp life. I thought I could wait another month or two before ordering replacement.
Starting today it started showing the image like attached here, sometimes going back and forth between normal picture and bad one. If I turn off the projector or receiver (Pioneer SC-95), it corrects the image before going back to bad image.
This is happening in both HDMI 1 and 2. I tried to reseat the HDMI's, tried switching between more than one device (a blu ray player, Dish cable box) but see same results.
It's working okay for now but was bad just a couple mins back. Seems to me that its an HDMI issue but how can both HDMI cables (for HDMI1 and 2) can go bad at the same time is I can't understand.
Screen seems to have half normal and half upside down, with washed out colors.
What does it look like to you guys? Bad lamp doing this or something else?
Thanks in advance!
Sg13 is offline
post #32472 of 32501 Old 03-07-2020, 11:45 AM
zombie10k's Avatar
Liked: 6087
Thanks in advance!
Hi, that issue isn't related to the lamp, it's an HDMI sync glitch. Have you tried bypassing the Pioneer SC-95 and plugging the bluray player directly into the JVC and see if you can repeat the issue?
krichter1 likes this.
post #32473 of 32501 Old 03-07-2020, 11:41 PM
Sg13's Avatar
Lightbulb
So I
1. Swapped the HDMI with premium certified cable from Monoprice and still saw the problem.
2. Then I connected the hdmi directly from projector to the blu ray and dish cable box separately from each input from projector, but still saw same problem.
3. I even removed both HDMIs from the rear of the projector and the projector menu still showed same problem.
See attached images.
Seems like it’s the projector. So I guess I have to contact JVC support and ship it to time for troubleshoot and possible repair? It’s just an year out of warranty and had about $7K tag
ID:	2694912   Click image for larger version
Sg13 is offline
post #32474 of 32501 Old 03-08-2020, 09:26 AM
zombie10k's Avatar
Liked: 6087
So I
Does the projector do this booting up with nothing plugged into the HDMI port? Does it happen if you take the projector down from the ceiling mount and try it in table mode?
For the repair estimate, you can save some time by going directly to JVC's authorized repair facility Mendtronix. They have 2 locations to ship the projector to in the US depending on your location. Do not ship it in the original box if you still have it, they won't return it.
https://mendtronix.com/projector-and...panel-service/
post #32475 of 32501 Old 03-08-2020, 11:29 PM
Sg13's Avatar
Yes it still shows same issues.
Thanks for the info, its already unmounted and ready to go this week.
Sg13 is offline
post #32476 of 32501 Old 03-10-2020, 12:00 PM
Liked: 0
Lightbulb RS600 display metrics and measurement code
We're publishing a journal article with display metrics for JVC RS600, including peak contrast measurements depending on average display luminance and other factors.
The link is here, broken into words because I'm not allowed to post links until I have at least 5 posts (can someone else fix this in their reply?) www sciencedirect com slash science slash article slash pii slash S0165027020301060 ? via % 3 Dihub
MATLAB code for doing your own measurements is available at:
If you find these useful, please cite as:
Hung CP, Callahan-Flintoft C, Walker AJ, Fedele PD, Fluitt KF, Odoemene O, Harrison AV, Vaughan BD, Jaswa MS, Wei M, (2020) A 100,000-to-1 high dynamic range (HDR) luminance display for investigating visual perception under real-world luminance dynamics, Journal of Neuroscience Methods.
Cheers,
Chou
chouhung is offline
post #32477 of 32501 Old 03-10-2020, 09:05 PM
Quoted: 5830 Post(s)
Liked: 2342
Cheers,
Chou
Here’s proper link:
https://www.sciencedirect.com/scienc...060?via%3Dihub
kwk2293 likes this.
Dominic Chan is online now
post #32478 of 32501 Old 03-11-2020, 03:11 PM
Sg13's Avatar
I think I replied too early. It only shows the issue while it’s upside down (ceiling mount), not a standard table top position. Still needs to go out but worth mentioning if you guys have nay idea.
Sg13 is offline
post #32479 of 32501 Old 03-11-2020, 03:36 PM
zombie10k's Avatar
Liked: 6087
Hi, I asked this earlier because I've seen a number of reports of different projectors (not just JVC) that have issues in 1 mounting position and not the other. What this likely means is that there is a PCB or edge connector that is misbehaving due to the stresses internally in the ceiling mount position. It only takes a fraction of an inch of a wiring harness not fully seated to cause the issues you are seeing.
I take projectors apart all the time and have solved similar issues like this with my old JVC RS55 by re-seating several wiring connectors. It's obviously not for everyone who doesn't like to tinker so i'd recommend documenting that scenario for Mendtronix and maybe it will help them hone in on the issue faster. they would likely have tested in table top mode and sent it back with 'no issues found'.
Spoiler!
post #32480 of 32501 Old 03-11-2020, 03:43 PM
Sg13's Avatar
Spoiler!
Thank you, will do so!
Sg13 is offline
post #32481 of 32501 Old 03-11-2020, 06:18 PM
nathan_h's Avatar
Quoted: 2846 Post(s)
Liked: 2033
Thanks for sharing.
Seems like the projector is not a great tool for vision research? Does that mean flat panel displays like OLED are better for research?
Cheers,
Chou
nathan_h is online now
post #32482 of 32501 Old 03-12-2020, 07:47 PM
Quoted: 40 Post(s)
I haven't tried the latest, but will it work for 3D (MVC or MK3D)? I use MPC-BE as it can parse ISO (my 1:1 3D bluray storage) and 425.31 drivers.
vjforum is offline
post #32483 of 32501 Old 03-12-2020, 08:20 PM
zombie10k's Avatar
Liked: 6087
I don't use the HTPC for 3D, I use the M9702 media player for my 3D BD ISO's. Some people are hacking the 3D drivers into later Nvidia drivers, give it a shot and see if you can get it working.
https://www.nvidia.com/en-us/geforce...-to-be-played/
post #32484 of 32501 Old 03-14-2020, 02:47 PM
dreyfusfabrini's Avatar
Hello!
I really could use some help on a problem: I currently have a RS600 projector and a Marantz AV8005 processor. It turns out that, what I enter the Marantz setup and switch the 4K output signal from standard to enhanced (which allows 10bit, 4:4:2 and 4:4:4 signals), the projector screen goes black. I’ve already tried to restart the projector and the AV processor, with no success. I have an OLED Lg TV connected to the processor, which accepts the signal with no problem (and its HDMI cable is longer).
Could someone shed some light on that matter?
Thank you in advance!
dreyfusfabrini is offline
post #32485 of 32501 Old 03-14-2020, 03:25 PM
So, through the TV, I switched to 8bit output and the image returned. Should I assume that the RS600 is NOT COMPATIBLE with 10bit signal?
post #32486 of 32501 Old 03-14-2020, 03:52 PM
Liked: 2342
It’s the cable.
nathan_h likes this.
post #32487 of 32501 Old 03-27-2020, 11:17 AM
W0000's Avatar
Liked: 0
Hallo!
I'm beginner in projector calibration.
Have some experience in monitor calibration but it's another, different story. That's why I couldn't even start.
Have bought used X7000, i1 Display Pro and Spectracal DPG-1400 (pattern generator) and trying use it in Calman Ultimate 5.6.1.2238.
I can connect meter and generator, but not X7000 in aplication. In pop-up menu Direct Display Control I couldn't find my type of projector. Have tried every variants (LAN, RS-232 crossed and not, every projector available on list).
Only one combination (RSx6 Series set to Ethernet) show me any usefull information in alert: ”Display model is not supported”. This is the only one where I could establish Ethernet connection. Any other generates alert: ”Display not found”.
Autocal JVC app detect correct LAN connection. So my computer see projector in net.
How could I connect X7000 to Calman in Direct Display Control? Need I any software plugin? Maybe different cable? Some computer adjustment?
Hope, someone will help me.
ID:	2702338   Click image for larger version
ID:	2702340   Click image for larger version
ID:	2702342   Click image for larger version
ID:	2702344   Click image for larger version
ID:	2702348   Click image for larger version
ID:	2702354   Click image for larger version
ID:	2702356   Click image for larger version
ID:	2702360   Click image for larger version
Video: JVC DLA-X7000, Pioneer Kuro LX5090H, Samsung UBD-M9500
Audio: Mac Mini, C.E.C. DA53, M2Tech HiFace Evo, AVM Evolution V2, Audionet AMP I, Audio Physic Tempo 25, Onkyo TX-SR875, Wharfedale Diamond+PowerCube DX12+.
All conected together.
W0000 is offline
post #32488 of 32501 Old 03-27-2020, 11:47 AM
Liked: 2342
I believe you need to use manual calibration in CalMAN for all the recent JVC projector.
post #32489 of 32501 Old 03-27-2020, 12:02 PM
W0000's Avatar
Liked: 0
Any hope? Is anyone who conected recent JVC to calman? Do You know why?
W0000 is offline
post #32490 of 32501 Old 03-27-2020, 12:17 PM
erkq's Avatar
Quoted: 748 Post(s)
Liked: 515
Oooooooh... that would be terrible. Auto-calibration is so fast and good. I use a Lumagen so projectors can come and go. But it is keeping me from 4k content because I don't want to pay fo a 4k capable Lumagen and I prefer the calibrated 1080 to uncalibrated 4k. And a projector doesn't have a 3D saturation/lumenance/hue LUT anyway.
erkq is offline
jvc-rs500u synch/display issue? , RS600
