Official JVC RS600 / RS500 (X950R / X750R - X9000 / X7000) Owners Thread - Page 1090 - AVS Forum | Home Theater Discussions And Reviews
 85136Likes
post #32671 of 32812 Old 05-19-2020, 07:32 PM
nathan_h's Avatar
Quoted: 3053 Post(s)
Liked: 2132
Very similar. Same generation just refined for two more years?
My current setup.
Recommended podcasts: The Next Picture Show, the /filmcast, AV Rant.
nathan_h is offline
post #32672 of 32812 Old 05-19-2020, 07:34 PM
zombie10k's Avatar
Quoted: 5684 Post(s)
Liked: 6274
QUESTION:
Is the RS600 still the highest native contrast consumer (or at least JVC) projector produced?
I've kept mine and only dipped in to threads occasionally over the years and from what I've seen the following models - laser based and/or true 4K - had to take a back-step in native contrast. Have I missed anything?
I'm still not chomping at the bit for another projector - it would be very hard for me to give up the contrast/black levels I'm used to.
imo it still is. I recently calibrated and measured the contrast with a Minolta T10
wide open iris Native 48K:1 and 500K+:1 with the DI. When I had the RS2000 here, the DI was in the ~220K:1 range, the dynamic iris doesn't close as much as the RS600 (by quite a bit) and left me wanting more in the low and very low APL scenes. The reduced clamping of the DI in the native models was done to reduce pumping but I don't have any concerns with the RS600 DI and use it all the time with SDR and HDR content. It digs down deep when it needs to for a convincing black floor in the very low APL scenes.
This is still one of my favorites over the years and picked up a low hour spare in case something happens to it.
There are many years of life left in these projectors
zombie10k is offline
post #32673 of 32812 Old 05-19-2020, 08:17 PM
Dennis Moore's Avatar
Quoted: 127 Post(s)
Liked: 24
Wow, so is that significantly more than the 500?
Dennis Moore is offline
post #32674 of 32812 Old 05-19-2020, 08:55 PM
zombie10k's Avatar
Liked: 6274
hi, not really, i've seen RS500's in the 40K-43K:1 range and ~430-450K:1 DI. It really depends on the sample quality of the specific unit which can vary quite a bit sometimes.
These RS600's are very nice copies. excellent focus across the entire screen, no convergence corrections needed and very good panel uniformity.
nathan_h and Mike Butny like this.
post #32675 of 32812 Old 05-20-2020, 11:28 AM
R Harkness's Avatar
Quoted: 2908 Post(s)
Liked: 2885
Thanks zombie, that's what I figured.
I love the automatic iris on the RS600. I can certainly see it working in certain conditions, especially some credits, but otherwise it does a really nice job. If you have a night scene with some high contrast elements the contrast effect makes the black level appear deep. Then if that's followed by a low APL night shot, the lack of contrast without a dynamic iris reveals higher black levels to the eye. But with the dynamic iris, it closes down making the black levels deeper again. The effect is that deep black levels appear more consistent across varying scenes, with an over all impression of better black levels. I watch lots of sci-fi and horror movies, so the contrast and dynamic iris of the RS600 reap very nice benefits.
R Harkness is offline
post #32676 of 32812 Old 05-20-2020, 05:54 PM
jimmyp1974's Avatar
Quoted: 229 Post(s)
Liked: 25
So I was debating too weather ‘upgrade’ to a RS500 from a 420. In a not dedicated room with white walls but completely dark what difference I would definitely see between the two let’s say when both properly calibrated and with the lens wide open in both? I am trying to understand weather keep the 420 or try the 500. Any suggestions? Thank you very much. Ps. I am not a gamer and I can calibrate the projector
jimmyp1974 is offline
post #32677 of 32812 Old 05-20-2020, 06:06 PM
nathan_h's Avatar
Liked: 2132
Which has more hours on it? Any repairs on either? How much to upgrade?
What are the trade offs?
What other upgrades are on the table? Paint? A second sub? Room treatments?
It’s not a big upgrade so there are possibly far more impactful ways to spend a thousand dollars.
My current setup.
nathan_h is offline
post #32678 of 32812 Old 05-20-2020, 07:15 PM
jimmyp1974's Avatar
Quoted: 229 Post(s)
Liked: 25
The 500 has almost 600 hours on the original first lamp. It has also custom curves upload in. But since I am using a Panasonic player 420 I don’t plan to use the high lamp on the jvc. In this way I could only keep lens wide open but in low lamp for SDR2020 ‘mapped’ by the player. In other words I think I may have much more contrast even in a living room environment. The point is will I notice this difference? Of course not switching on HDR mode high lamp on the 500 will exclude also the filter which is actually one of the pros of the 500 compared to the 420
post #32679 of 32812 Old 05-20-2020, 08:49 PM
Quoted: 127 Post(s)
Liked: 24
It's weird to me to again hear this... just going by the stated specs, it should be a significant improvement in picture quality.
post #32680 of 32812 Old 05-20-2020, 10:25 PM
nathan_h's Avatar
Liked: 2132
Custom curves are great. But the curve that works best in one room, for one screen size and one particular amount of gain, and even one particular amount of white ceilings, is going to be different than the curve that works in another room, with a different screen size, with a different screen gain, etc. and it drifts over the life of the bulb (gamma droop).
And of course if you map to SDR then you won’t use the custom curve, you’ll just use a regular SDR gamma like 2.4 or 1886 etc.
And if you want to use low lamp mode then my experience, even with a professional calibration, is that rec2020 is not worth shooting for.
Maybe buy the second projector and try it out and sell one of them?
My current setup.
nathan_h is offline
post #32681 of 32812 Old 05-20-2020, 10:27 PM
nathan_h's Avatar
Liked: 2132
Hopefully some other folks will chime in.
Early in this thread I believe some folks shared impressions and measured results....or maybe that was in the RS400 thread?
My current setup.
nathan_h is offline
post #32682 of 32812 Old 05-21-2020, 11:07 AM
jimmyp1974's Avatar
Quoted: 229 Post(s)
Liked: 25
Hi just a quick question: is the filter automatically enabled switching to high lamp only with HDR or with all other picture modes too? Thank you
post #32683 of 32812 Old 05-21-2020, 12:47 PM
Quoted: 6294 Post(s)
Liked: 2652
The filter has nothing to do with lamp power. It is engaged automatically when a colour profile requires it is selected.
JVC DLA-X550R; Denon AVR-X3400H; HD Fury Linker / Vertex 2; ATV4K; Sony UBP-X700
JVC Curves; Optimizing HDR;
Creating a basic HDR curve using Arve’s Tool;
Replacing JVC Bare Bulbs
Dominic Chan is online now
post #32684 of 32812 Old 05-27-2020, 11:55 PM
Quoted: 24 Post(s)
Does the JVC x9000 have a debanding filter? I was watching the Meg in 3D last night and the underwater scenes had lots of banding. That's in the original Blu-ray and on a HTPC I get rid of it with MadVR's debanding. But I was using a Popcorn Hour VTEN for playback so hoping that the PJ has a built in banding filter in one of the noise controls. Anyone know which?
dush is offline
post #32685 of 32812 Old 05-28-2020, 07:08 AM
jimmyp1974's Avatar
Quoted: 229 Post(s)
Liked: 25
Hi what color profiles enable the filter? To be more explicit will the BT2020 enable the filter or only HDR profile? Thank you
post #32686 of 32812 Old 05-28-2020, 08:02 AM
Liked: 2652
It depends on the projector model.
As I mentioned previously, the BT.2020 profile on the x570 doesn’t use the filter as the projector doesn’t have one. On the x770 and x790 the BT.2020 profile uses the filter; the x790 also has the HDR profile which does not use the filter.
post #32687 of 32812 Old 05-28-2020, 08:56 AM
jimmyp1974's Avatar
Quoted: 229 Post(s)
Liked: 25
Thank you Dominic. And what about RS500 and 520? Do they automatically use the filter with BT2020 profile? Is it possible to enable the filter once automatically switched on? And how much of the light output will be absorbed by the filter once active? Thank you for your help
post #32688 of 32812 Old 05-28-2020, 09:13 AM
jimmyp1974's Avatar
Quoted: 229 Post(s)
Liked: 25
I meant is it possible to DISABLE the filter once automatically switched on?
post #32689 of 32812 Old 05-28-2020, 09:14 AM
Liked: 2652
The RS520 is the same as the x770.
As mentioned previously, the filter is engaged automatically when the profile requires it.
post #32690 of 32812 Old 05-28-2020, 04:11 PM
Quoted: 74 Post(s)
Liked: 83
Question from a newbie:
I have an rs600 paired with a denon 6500 and a panny ub820. I’d like to start watching some of our 4K movies. Do I need to set the projector on certain settings or can I just pop in the 4K disc and let the ub820 do everything for me? Thanks for the help!
woodboss83 is offline
post #32691 of 32812 Old 05-28-2020, 04:22 PM
Liked: 2652
If you have not loaded any custom curves for the RS600, the easiest setup would be to have the UB820 output SDR/BT2020, with the RS600 matching it (Gamma 2.4, Colour Profile BT2020).
nathan_h likes this.
post #32692 of 32812 Old 05-28-2020, 04:27 PM
Quoted: 74 Post(s)
Liked: 83
Thank you! No custom curves here. Just trying to figure out how to run this HT. This is our first projector and I’m impressed with the picture every time we watch a movie.
post #32693 of 32812 Old 05-28-2020, 05:47 PM
jimmyp1974's Avatar
Quoted: 229 Post(s)
Liked: 25
Again another/same doubt: does the 500/520 automatically activate the filter when set on BT2020 picture mode? And if so: is it possible to disable it once active? Thank you
post #32694 of 32812 Old 05-28-2020, 06:06 PM
Liked: 2652
Already replied multiple times. Some profiles require the filter, some don’t. You can “force” the filter On/Off manually using RS232 or IP control, but the profile will no longer be correct when you do that.
Originally Posted by Dominic Chan View Post
On the x770 (RS520) and x790 the BT.2020 profile uses the filter; the x790 also has the HDR profile which does not use the filter.
post #32695 of 32812 Old 05-29-2020, 02:09 PM
Quoted: 832 Post(s)
Liked: 444
Have dominic guide u and buy yourself a vertex to get Dolby Vision.. you have no clue how much better it gets.
Sent from my SM-G930T using Tapatalk
jorgebetancourt is online now
post #32696 of 32812 Old 05-29-2020, 02:38 PM
swest's Avatar
Quoted: 236 Post(s)
Liked: 90
Originally Posted by Dreamliner View Post
I'm 100% certain it is an automatic message at 3400 hours. I just passed 4000 hours on the original lamp and I honestly don't have any brightness complaints at all. I actually bought a replacement lamp only from Dominic (link) and I'm going to put that in soon I think. My only actual concern would be a destructive lamp explosion. If I knew I could simply run the projector until the lamp simply burnt out, I would.
I also finally figured out how to use my AEMC CA813 light meter and took measurements of my lamp at 4000 hours (RS400, 108" 1.78:1 measured, 136" 2.35:1 screen):
Low Lamp
250 lux
23.23 ftL
846 Lumens
79.58 nits
High Lamp
342 lux
31.78 ftL
1157 Lumens
108.86 nits
Originally Posted by swest View Post
Very helpful. And, yes, I was thinking the same thing about explosive failure and preemptive replacement.
And, yes, I also got one of those spare lamps from Dominic, so we're really on the same page here.
I may even follow your example and take a reading of my lamp...
Anyway, I think that I'm caught up now. Mainly I wanted to know the significance of the "Lamp Replacement" message, and whether the projector might be giving that warning because of some underlying condition about the state of the lamp that it was sensing. But you have confirmed that, no, it is strictly a warning based on the Hours on the Lamp.
Thanks a lot!
- s.west
p.s. While doing some of my searching I came across a number of very helpful guides that you have posted in the last couple of years. I have bookmarked them. Thanks also for those!
Greetings again Dreamliner,
FYI, it is now late May, 2020 and we last communicated about the RS600 lamp back in September of 2019. I finally decided to quit my risky behavior and replace my out-of-ours lamp. I'd only gotten it up to about 3900 hours, but since I have one of Dominic's replacement bulbs, I figured it was time to dispense with the risk.
Anyway, using the pictures that you, and Dom, had provided at various times, I managed to do a successful replacement. I reset the hours and all is well. And, yes, I see now that even after 3900 hours the lamp had not dimmed significantly. I didn't take actual measurements, which I really should have, but just eyeballing it I can see that, while it is brighter, it is not remarkably so.
Bottom line: All is well, and hopefully I will get another five, quality, years from this projector.
I think I will, almost certainly, order a new replacement bulb, so that I have a spare on hand at all times. I looked at Dom's thread where he has those bulbs, and I think that they are currently available. So, that's my next stop.
Hope all is well with you and that you have weathered the covid-19 storm, as it were.
Cheers,
- s.west
Kerlucun likes this.
"Oh, what a day. What a lovely day!"
swest is offline
post #32697 of 32812 Old 05-29-2020, 04:23 PM
claw's Avatar
Quoted: 2951 Post(s)
Liked: 2832
Back when Manni used an RS500 he created REC2020 color profiles; a filter version and a no-filter version. This was before JVC released an official BT.2020 color profile.
To load Manni's no-filter version go to this page, and scroll down to the REC2020 heading for the zip file link.
https://www.avsforum.com/forum/24-di...500-rs600.html
3) Rec2020: these profiles were created using standard rec-2020 coordinates, as rec2020, unlike DCI-P3, isn't an option in the software. [EDIT: there is now an official BT2020 profile from JVC, see link to HDR settings and f/w update at the top of the post. It should be identical to mine but I haven't checked yet.] [EDIT2: confirmed, they are identical]
Same, pick up the version you want to use depending on whether your model has a filter or not. You can also select a version without the filter to use in a model with the filter if you want to try to reach as far as possible without losing too much brightness.
REC-2020F (with filter):
REC-2020NF (no filter):
I haven't done extensive tests with this one but it seems to be working fine.
Like the rec-709 profiles, this profile tracks better if you autocal it after importing it.
As Manni mentioned you might want to calibrate with Autocal after importing the no-filter color profile. I found that blues tended towards purple in my RS500 without recalibration.
CJ
JVC RS500 | LG B7A OLED | Denon X6400H (7.2.4) | X4200W | Panasonic UB820 | Two Oppo 203 | Samsung K8500 | Apple TV 4K | Amazon Fire TV Stick 4K | HDfury Diva/Vertex/Linker/Integral | MadVR with EVGA RTX-2080 Ti
claw is offline
post #32698 of 32812 Old 05-29-2020, 04:48 PM
Dreamliner's Avatar
Quoted: 1526 Post(s)
Liked: 816
Dominic's bulbs were the brightest of the generics I tried. I ultimately decided to go back to the genuine lamps as the were the brightest and most stable. I lucked out and got one with only 2000 hours on it (from someone on this forum who's projector died) and have been running that since January. I have two genuine lamps sealed in a box but cannot get myself to open them, I just might end up with an N7 before I ever need to...
I need to sit down one of these days and figure out the best way to calibrate this projector. I wrote a guide about it but when I did it recently the before/after pic I took of a test image were 100% identical, even though the calibration showed the drooping blue line...
Dreamliner is offline
post #32699 of 32812 Old 05-29-2020, 06:45 PM
jimmyp1974's Avatar
Quoted: 229 Post(s)
Liked: 25
I think I am missing an essential detail. I am sorry for being very naive but don’t 500/600 include in their default/factory settings BT2020 color profile? Or you have to upload them ? Just know. I was thinking about switching from a 420 to a previous 500 but that could impact my decision. Thank you
post #32700 of 32812 Old 05-29-2020, 06:52 PM
Liked: 2652
The earlier models didn’t have it and the user had to load it (Manni’s or JVC’s). The newer models came with it pre-loaded. They are identical, as claw said.
jvc-rs500u synch/display issue? , RS600
