Official JVC RS600 / RS500 (X950R / X750R - X9000 / X7000) Owners Thread - Page 1094 - AVS Forum | Home Theater Discussions And Reviews
 85136Likes
post #32791 of 32810 Old 06-25-2020, 06:31 AM
zombie10k's Avatar
Quoted: 5684 Post(s)
Liked: 6274
Originally Posted by Mike Butny View Post
Do these glasses work with JVC's emitter or do you have to buy hi-shocks emitter? I wear glasses and prefer glasses that are large enough to fit over my glasses but that are still high brightness.
hi, I posted a comparison to the JVC glasses in this thread below, they work perfect with the JVC emitter. I wear prescription glasses and they fit well over the glasses.
note- the charging cable is not standard, don't misplace it!
https://www.avsforum.com/forum/24-di...l#post59002356
Mike Butny likes this.
zombie10k is offline
post #32792 of 32810 Old 06-25-2020, 01:01 PM
Mike Butny's Avatar
Quoted: 1238 Post(s)
Liked: 2938
Thanks, Jason. I just ordered a pair. This hobby is getting expensive
zombie10k likes this.
Equipment List: JVC RS500, Darbee DVP-5000S Video Processor, JKP Affinity 100 inch 16x9 .9 gain reference screen, Panasonic UB420, Marantz SR7013 Receiver, 3-Marantz Ma700 and 2-Ma6100 monoblocks, 7.4.2 Atmos, B&W Nautilus 805 front speakers, B&W Nautilus HTM2 center speaker, 2 Volt 6 Atmos Speakers, Mirage HDT-R side speakers, Jamo THX surround one rear speakers, 2 LaVoce 21inch Neo DIY subs and 2 PSA S3600I'S.
Mike Butny is offline
post #32793 of 32810 Old 06-29-2020, 05:37 PM
Dbuns's Avatar
Quoted: 37 Post(s)
Liked: 1
Hey just wondering if there is a step by step guide to JVC AutoCal for the X7900?
Looking to start reading up and finding the equipment I need.
I have also seen the Gamma Curves on here. So these curves replace the stock ones, then you do an AutoCal with these curves?
Thank you!
Dbuns is offline
post #32794 of 32810 Old 07-05-2020, 11:29 AM
claw's Avatar
Quoted: 2944 Post(s)
Liked: 2829
Thank you!
https://www.avsforum.com/forum/24-di...500-rs600.html
CJ
JVC RS500 | LG B7A OLED | Denon X6400H (7.2.4) | X4200W | Panasonic UB820 | Two Oppo 203 | Samsung K8500 | Apple TV 4K | Amazon Fire TV Stick 4K | HDfury Diva/Vertex/Linker/Integral | MadVR with EVGA RTX-2080 Ti
claw is offline
post #32795 of 32810 Old 07-05-2020, 05:17 PM
waleed's Avatar
Quoted: 20 Post(s)
hi everyone
my projector is RS500
soft ver. u83.2.
i've never update the software what's the latest update ? is it worth it?
i've seen in the thread the calibration it got me so dizzy what i understand from it that they trying to play HDR movie with this projector my screen is 135 too big .
is there is any way to do shortcut to make it work or it is too hard.
thank you all.
waleed is offline
post #32796 of 32810 Old 07-06-2020, 06:43 PM
WOKNROX's Avatar
Quoted: 549 Post(s)
Liked: 443
Given the new lower prices on the RS540, would the 540 be a worthwhile upgrade over the 500..?
Orotund Desert Theater;7.7.4,14'x20'x10',100amp service, JVC RS500,120" ATscreen, Carada Masquerade Masking, OPPO203 & Panny ub820, Anthem AVM60, Simaudio Moon Titan 7&5ch ,Crown xls2500, ACInfinity Fans, L&R Polk SDA SRStl Fully built, CC 2 Polk RTA15tl in Custom Cabinets Fully build, SS-BS Inwall Triad Silver LCR, 4 Atmos Core5, Subs-miniDSP-HD2x4, 4 HSU VTF-15H-MK2, 3 MBM, 2 Rows of 3 Seatcraft Excalibur Lx Seats & more.
WOKNROX is online now
post #32797 of 32810 Old 07-06-2020, 08:15 PM
nathan_h's Avatar
Quoted: 3052 Post(s)
Liked: 2132
Possibly, if you don’t have a good custom hdr tone map and HDFury setup on the rs500.
Otherwise it’s probably a crapshoot based on unit to unit variance.
My current setup.
Recommended podcasts: The Next Picture Show, the /filmcast, AV Rant.
nathan_h is online now
post #32798 of 32810 Old 07-06-2020, 09:42 PM
WOKNROX's Avatar
Quoted: 549 Post(s)
Liked: 443
Yeah I've been down the rabbit hole with the 500.
Just sold my 620 and was going to move to the 2000 but the issues with
it worries me a bit.
post #32799 of 32810 Old 07-07-2020, 07:33 AM
nathan_h's Avatar
Liked: 2132
So it's really about choosing between the RS540 and the RS2000?
My current setup.
post #32800 of 32810 Old 07-07-2020, 09:15 AM
WOKNROX's Avatar
Quoted: 549 Post(s)
Liked: 443
To some degree yes.
But...I really like the very low black floor of the 5xx and 6xx line and I'm pretty sensitive to lack of black levels.
Should I just hang tight with the 500 or move to the 540..? Is it worth it?
post #32801 of 32810 Old 07-07-2020, 01:17 PM
zombie10k's Avatar
Liked: 6274
Originally Posted by WOKNROX View Post
To some degree yes.
hi, if you have a nice 500 (good focus, convergence, minimal bright corners) I would consider keeping it for a while. your room looks quite dark and light treated. I had the RS2000 for a while and could definitely see the black floor difference in my room (all velvet..). most people wouldn't likely see it but for me it's there.
I recently measured my RS600 @48K:1 wide open iris and 500K:1 with the DI. on the RS2000 it's ~220K:1 which doesn't close the iris as much as the previous series. Something I hope they consider updating in the future. Maybe add Auto iris '3' as an option for those that want it to dig deep in very low APL scenes.
are you using the UB820 for HDR discs with the SDR/BT2020 modes? There are some good options for streaming with the LLDV hack + Vertex 2. I primarily watch UHD discs and use MadVR DTM on an HTPC which looks remarkable. There is many years of life left in these projectors.
post #32802 of 32810 Old 07-07-2020, 01:30 PM
Quoted: 831 Post(s)
Liked: 442
Go for the rs2000.. i doubt you will see a better picture going from a 500 to 540.. it's almost the same projector.
Now if you were to get a 640 super cheap then you could go that route as well
Sent from my SM-G930T using Tapatalk
jorgebetancourt is online now
post #32803 of 32810 Old 07-07-2020, 01:33 PM
Quoted: 831 Post(s)
Liked: 442
If you can get a 620 or 640 along with a HD Fury then you could get tone mapping and Dolby vision.. if u can get one these cheap then this might even be a better option than the new series..
post #32804 of 32810 Old 07-07-2020, 10:50 PM
nathan_h's Avatar
Liked: 2132
I get custom tone mapping and Dolby vision with my rs500. I’m not likely to upgrade until it dies or the next three year generation is released.
WOKNROX likes this.
My current setup.
post #32805 of 32810 Old 07-08-2020, 06:14 AM
WOKNROX's Avatar
Quoted: 549 Post(s)
Liked: 443
I think I'm just going to sit tight for a while as well.
I'd like to have a true 4k PJ but just don't want to sacrifice the black levels for it. I'll give it a couple more years.
Thanks for all the responses. I really appreciate it.
nathan_h and zombie10k like this.
post #32806 of 32810 Old Today, 04:38 PM
jwhart's Avatar
Quoted: 217 Post(s)
Liked: 78
Tonight I turned on my DLA-X990 and was greeted by NO picture and, on the front of the unit, solid reed lamps for standby/on and warning and a blinking orange lamp for lamp. I've attempted to navigate the warning display diagnostic information on page 79 of the owners manual but it escapes myt 70 year old brain and eyes. If anyone can interpret, I would greatly appreciate it.
jwhart is offline
post #32807 of 32810 Old Today, 04:53 PM
Quoted: 6289 Post(s)
Liked: 2648
If the Lamp blinking frequency is x1 then it indicates “Lamp does not light up and unit is unable to project”.
JVC DLA-X550R; Denon AVR-X3400H; HD Fury Linker / Vertex 2; ATV4K; Sony UBP-X700
JVC Curves; Optimizing HDR;
Creating a basic HDR curve using Arve’s Tool;
Replacing JVC Bare Bulbs
Dominic Chan is online now
post #32808 of 32810 Old Today, 04:57 PM
jwhart's Avatar
Quoted: 217 Post(s)
Liked: 78
If by "x1" you mean about once per second, that appears to be the case. Does that mean that I only need to replace my <2,000 hour lamp? Thank you, as always Dominic, you are a treasure on this forum, my friend!
jwhart is offline
post #32809 of 32810 Old Today, 05:02 PM
Liked: 2648
You can try removing the lamp and reinserting it to see if it makes any difference, but chances are the lamp needs replacing.
post #32810 of 32810 Old Today, 05:03 PM
jwhart's Avatar
Quoted: 217 Post(s)
Liked: 78
Thank you AGAIN! :-)
Can anyone please provide a link to an AVS dealer who can provide an OEM replacement?
jwhart is offline
jvc-rs500u synch/display issue? , RS600
