Official JVC RS600 / RS500 (X950R / X750R - X9000 / X7000) Owners Thread - Page 242 - AVS Forum | Home Theater Discussions And Reviews
 84782Likes
post #7231 of 32099 Old 02-25-2016, 08:17 AM
Mike Garrett's Avatar
Quoted: 12502 Post(s)
Liked: 10128
Originally Posted by krichter1 View Post
I think you mean not every thread (I'm scared of your bithead 7200/DTSx ones!). This might have just as much to do with the JVC as it does the 7200 (so I posted here in case some like me had this setup in order to get feedback on my issue; and of course deep color is off ).
There are a lot of people using the 7200 with one of the new JVC's. Craig uses it also.
Mike Garrett is online now
post #7232 of 32099 Old 02-25-2016, 08:22 AM
Craig Peer's Avatar
Quoted: 6962 Post(s)
Liked: 8225
I just downloaded the DTS:X firmware last night in fact !
[email protected] JVC RS4500, Lumagen Radiance Pro, Panamorph Paladin DCR lens, Stewart Luxus Model A ElectriScreens - 128" diagonal 2.35:1 ST130 & 122" diagonal 16:9 Cima Neve, Denon X8500, Parasound A 52+ amp, Martin Logan Motion series 9.4 speakers, four SVS subs, Panasonic UB820, Oppo 203, PFP M1500 UPS
Craig Peer is online now
post #7233 of 32099 Old 02-25-2016, 08:36 AM
Manni01's Avatar
Quoted: 5430 Post(s)
Liked: 5623
I was just teasing, and practicing short answers (I'm very bad at that). Forget about the DTS:X thread, but there is very good support for X7200WA owners in the X7200W thread from people (owners like myself and very experienced audio guys like JDSmoothie, Batpig and others) who know these models inside out but are unlikely to ever visit this thread. Just saying it would be a good habit for you to ask non JVC related questions there, no one will bite you
There is no issue between the X7200WA and the JVCs. It's your cable. The bandwidth is likely going from 10.2 gb/s to 18gb/s because the X7200WA supports 18Gb/s. You didn't have the issue before because both the AVR and the rs57 were limited to 10.2gb/s. Then you replaced the PJ with the rs500 which support 18Gb/s, but as your AVR was still limited to 10.2gb/s, the cable still worked. When you replaced the AVR, that was the last bottleneck in the chain, so your cable had to deal for the first time with 18gb/s and it's not up to it.
While you're waiting for a better cable (check the HD fury thread, there are very few compatible cables depending on the length), you can use your HD Fury set to a 300Hz mode to force 10.2gb/s. As long as the faulty cable is AFTER the HD Fury, that should do it for a while. You'll be limited to 4K30p until you get a better cable.
See why I tried to keep it short?
billqs likes this.
Manni01 is online now
post #7234 of 32099 Old 02-25-2016, 08:44 AM
bwillcox's Avatar
Quoted: 929 Post(s)
Liked: 537
Originally Posted by Manni01 View Post
I was just teasing, and practicing short answers (I'm very bad at that). There is no issue between the X7200WA and the JVCs. It's your cable. The bandwidth is likely going from 10.2 gb/s to 18gb/s because the X7200WA supports 18Gb/s. You didn't have the issue before because both the AVR and the rs57 were limited to 10.2gb/s. Then you replaced the PJ with the rs500 which support 18Gb/s, but as your AVR was still limited to 10.2gb/s, the cable still worked. When you replaced the AVR, that was the last bottleneck in the chain, so your cable had to deal for the first time with 18gb/s and it's not up to it.
I had a similar problem when I replaced my Yamaha CX-A5000 with a CX-A5100 last year. The cables that worked fine with the 5000 created all sorts of strange HDMI handshake problems and bad images on the X750 with the 5100 (they were Redmere active cables). I replaced them with ethereal MHX passive cables certified at 18Gbs (by DPL Labs) and the problems went away.
1) JVC DLA-NX7 & Sony 65Z9D, Yamaha CX-A5200, Outlaw Audio 7900 & 7700, UDP-203, DP-UB9000, UBP-X800M2, Roku Ultra
2) Sony 75Z9D, Yamaha RX-A3080, 2xOutlaw Audio 2200s, UDP-203, UBP-X800M2, Roku Ultra
3) Sony 75X940E, Yamaha RX-A2080, UDP-203, UBP-X800M2, Roku Ultra
bwillcox is online now
post #7235 of 32099 Old 02-25-2016, 09:02 AM
kkpro's Avatar
Quoted: 196 Post(s)
Liked: 92
Is this the reason the projector takes so long in locking onto a signal? I am not running 4k either.
kkpro is offline
post #7236 of 32099 Old 02-25-2016, 09:13 AM
Liked: 10128
Yes, this has something to do with it.
post #7237 of 32099 Old 02-25-2016, 09:16 AM
kkpro's Avatar
Quoted: 196 Post(s)
Liked: 92
Where is the link to which cables will work the best?
kkpro is offline
post #7238 of 32099 Old 02-25-2016, 09:28 AM
jh901's Avatar
Quoted: 739 Post(s)
Liked: 288
What about the situation where the video signal only is being passed directly to the projector- would you expect audio and video to lock at the same time? How can I tell if the video bandwidth is 18gb/s?
HT: Panasonic DP-UB820 | JVC RS600 | 106" x 45" Stewart ST 100 | Cary Audio Cinema 12 | NAD M27 | Elac Uni-Fi UF5, UC5, Debut F5/B6; Focal CMS Sub
STEREO: [Shunyata Denali] Playback Designs MPS-5 (fully upgraded) | Cary Audio SLP-05 tube line level | Cary Audio SA-200.2 ES | Focal Diablo Utopia III DEN: 60" Panasonic VT60
jh901 is offline
post #7239 of 32099 Old 02-25-2016, 10:33 AM
Roger Mathus's Avatar
Quoted: 97 Post(s)
Liked: 51
Samsung has updated the 8500 firmware to 1003 as of today. Not sure what it fixes? Still no menu on JVC upon start-up.
Roger Mathus is offline
post #7240 of 32099 Old 02-25-2016, 10:44 AM
Quoted: 743 Post(s)
Liked: 123
I am confused with the model name, RS600, X950R, RS600U etc? Could someone clarify it ? Is RS600 the same as X950R? Sorry for silly question. Thanks.
Roudan is offline
post #7241 of 32099 Old 02-25-2016, 10:51 AM
jh901's Avatar
Quoted: 739 Post(s)
Liked: 288
DLA-RS600U
RS600
DLA-X950R
X950
DLA-X9000
X9000
Same projector. Flagship of JVC's Reference line.
I wonder if JVC will drop e-shift once they introduce full 4K. If not, then that will really create confusion!
Roudan likes this.
jh901 is offline
post #7242 of 32099 Old 02-25-2016, 11:15 AM
Ron Jones's Avatar
Quoted: 985 Post(s)
Liked: 993
FYI - I'm using the Denon X6200W with by JVC RS600 and Samsung K8500 and that combo works well (or at least as well as can be expected). Just got my DTS-X firmware update for the X6200W last week, but even without that update it appears the inputs/output were HDMI 2.0a compliant as they already handled HDR from the K8500.
By the way I got a firmware update to the K8500 today. It doesn't appear to address any of the additional menu options (e.g., user choice of 4:2:0, 4:2:2 in addition to 4:4:4 or the ability to turn HDR off) that we have been asking for.
krichter1 and MJV29 like this.
Ron Jones
Blog + Reviews + Articles: projectorreviews.com
Ron Jones is offline
post #7243 of 32099 Old 02-25-2016, 11:18 AM
promike's Avatar
Quoted: 113 Post(s)
Liked: 102
Originally Posted by napa_newbie View Post
hello - I bought the rs-232 cables. What OS will be compatible with the firmware update?
Windows 7 is what I have read.
Speakers: Klipsch RF-7II(2), RC-64II, RS-62II(2), RP-160M(2), Velodyne HGS-15, HSU VTF-15H, Atlantic Technology IC-6-OBA(4)
AVP: Yamaha CX-A5100, BJC certified cables
Amps: Emotiva XPA-5(2), XPA-3
Oppo UDP-203, Roku Ultra, Nvidia Shield, Sony UBP-X800
JVC DLA-RS540K, (132" screen), Vizio P75-C1 and Vizio SB4551-D5 Soundbar
promike is offline
post #7244 of 32099 Old 02-25-2016, 11:55 AM
Moderator
rboster's Avatar
Quoted: 1627 Post(s)
Liked: 2234
I used to have issues with my JVC 57 not being able to sync with my redmere cable. Since that time I've been using the following combo:
658 Commercial Silver Series High Speed HDMI® Cable, 6ft Black 1
10225 HDBaseT™ Extender Kit 1
3660 Commercial Silver Series High Speed HDMI® Cable, 15ft Black 1
5906 Cat6A 24AWG STP Ethernet Network Patch Cable, 75ft Blue
I purchased this from Monoprice. I've not had any issues syncing with my RS500.
Ron
rboster is offline
post #7245 of 32099 Old 02-25-2016, 12:04 PM
Liked: 10128
Ron
I agree. No one should be having sync issues with the new JVC's, other than slow to sync. If you are losing sync, then you most likely need to be looking at your cables.
post #7246 of 32099 Old 02-25-2016, 01:04 PM
Dave Vaughn's Avatar
Quoted: 1465 Post(s)
Liked: 2285
The HDBaseT won't work with 12bit 4:4:4 signals though, so it won't synch with the Samsung menus.
David Vaughn Blu-ray Reviewer / Technical Writer Sound & Vision Magazine (Print & Online)
Dave Vaughn is offline
post #7247 of 32099 Old 02-25-2016, 02:13 PM
ohioratrodder's Avatar
Quoted: 23 Post(s)
Liked: 0
How much noticeable will the black levels be on the rs500 vs rs400 in a blacked out light controlled room. I am coming from a vw500es and that's about my only reference for black level. I thought I was going to get a rs500 till it seems like uhd blu ray may need another year or so and with dsl Internet only I won't be streaming 4k any time soon. So I have been thinking about getting a rs400 instead and upgrading again in a year or 2 but don't know if that will be a huge leap over the vw500es
ohioratrodder is offline
post #7248 of 32099 Old 02-25-2016, 02:15 PM
alebonau's Avatar
Quoted: 1889 Post(s)
Liked: 1290
visiting a friends who also has an x7000 and running an older integra pre pro/older oppo combo....I noticed a much delayed synch. so do thing source / whats feeding perhaps related to the synch time. its definitely slower than the two generation older jvc I had....but this is later hdmi spec so am not sure if supposed to go with the territory but not something bothered me too much as usually takes me a little time after switch on to get settled.
"Technology is a drug. We can't get enough of it."
Welcome to my lounge room :)
alebonau is offline
post #7249 of 32099 Old 02-25-2016, 02:18 PM
Liked: 10128
Black level on the 400 is better than the VW500. Black level on the 500 is quite a bit better than the 400. At times with my 600, it is hard to tell if the masking is in place or not.
post #7250 of 32099 Old 02-25-2016, 02:31 PM
SherazNJ's Avatar
Quoted: 1210 Post(s)
Liked: 145
I migrated from VW600ES to RS500 and am very happy. No comparison of black levels b/w the two (IMHO). To me, RS500 is miles ahead. Can't say much about rs400 though since I have never seen it.
SherazNJ is offline
post #7251 of 32099 Old 02-25-2016, 02:45 PM
Ed Weinman's Avatar
Quoted: 83 Post(s)
Liked: 39
Originally Posted by Craig Peer View Post
WCG = wide color gamut. HDR ( High Dynamic Range ) is seemingly better used on 4K HDTV's that are much brighter than projectors. HDR from the Samsung seems to want to put the JVC in high lamp. What is being said is that we would like more control over exactly what is being sent from the 4K player, to better match the capabilities of our projectors. There is quite a bit of fine tuning to be done in the industry regarding 4k capable projectors and 4K UHD players. At least that's the best I can explain it on my first cup of coffee this morning.
Thanks, Craig
(Have a second cup on me....not literally!)
Ed Weinman is offline
post #7252 of 32099 Old 02-25-2016, 02:46 PM
Moderator
rboster's Avatar
Liked: 2234
I didn't think so...I suggested it only because the member said they weren't sending 4k to the projector. I don't think HDBaseT has developed anything that can handle 4k?? If so, I assume that's not to far down the road for them?
rboster is offline
post #7253 of 32099 Old 02-25-2016, 02:49 PM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 6668 Post(s)
Liked: 6658
Originally Posted by RigorousXChris View Post
Anyone use Chad B's calibration service? I'm debating waiting for him vs. going with a ISF guy locally.
Guy below just got his done a few days back, wonder how his went ???
Originally Posted by SherazNJ View Post
on 23rd. Will update either tomorrow or day after.
Cleveland Plasma is online now
post #7254 of 32099 Old 02-25-2016, 03:03 PM
SherazNJ's Avatar
Liked: 145
Yep. He was at my place on 23rd. He came in around 5. I had a lot of questions for him which cause a delay for him to start but I think he started calibration around 5:30. It took a while before he was done. He left my place at 3 a.m. Chad is very thorough with his process. If he's not happy with the result, he'll just keep on working. Even this late at night, after he was done calibrating, he spent time fixing my screen/projector to make sure they are 100% aligned. He also took care of sharpness/convergence for me for both 16:9 and 2.40 aspects.
I'd recommend him. He's a great video calibrator and won't leave until results are satisfactory.
krichter1 and emergetech like this.
SherazNJ is offline
post #7255 of 32099 Old 02-25-2016, 03:05 PM
Carrick's Avatar
Quoted: 466 Post(s)
Liked: 65
Want to know if I should get a K8500 before ChadB gets to my home in April? Does he need it or will his calibration work whether or not I have a UHD player?
Carrick is offline
post #7256 of 32099 Old 02-25-2016, 03:16 PM
Liked: 2285
They can handle 4K, but it depends on the bitrate. I have an Atlona AT-UHD-EX-70-2PS, which can do the following resolutions:
4096×[email protected]/25/30/50*/60Hz*, 3840×[email protected]/25/30/50*/60Hz*, 2048x1080p, [email protected]/24/25/29.97/30/50/59.94/60Hz, [email protected]/59.94/60Hz, [email protected]/59.94/60Hz, 576p, 576i, 480p, 480i
But notice the *, that's because * 4096×[email protected]/60Hz & 3840×[email protected]/60Hz supported @ chroma subsampling 4:2:0 8-bit only
So the menus from the Samsung won't work at all, since they are 12 Bit 4:4:4. The chips haven't been released yet that can handle full 4:4:4 RGB...we'll probably see them sometime this year. It's why I also have another HDMI cable run and may even run one more through my chain as a backup.
HDMI sucks!
rboster likes this.
post #7257 of 32099 Old 02-25-2016, 04:15 PM
millerwill's Avatar
Quoted: 614 Post(s)
Liked: 382
....At times with my 600, it is hard to tell if the masking is in place or not.
Same with me, Mike. The black level is so good that I'm getting lazy, and unless it something special I often don't bother putting in my manual masking panels when switching to a 2.35 pic from 16x9. (This was not the case with my Sony1100.)
millerwill is offline
post #7258 of 32099 Old 02-25-2016, 04:21 PM
Liked: 10128
I am not that lazy yet. I still push the button.
R Harkness likes this.
post #7259 of 32099 Old 02-25-2016, 06:30 PM
Blu-ray Reviewer
Moderator
Ralph Potts's Avatar
Quoted: 1679 Post(s)
Liked: 6106
Greetings,
Well that was with the FW released for the last series two years ago now. Let's hope that they test with a newer OS than that. I no longer own any Win 7 machines.
Tom Bley likes this.
Ralph C. Potts
Blu-ray Reviewer
My Home Theater
Follow me on Twitter @RalphAVSreviews
Ralph Potts is offline
post #7260 of 32099 Old 02-25-2016, 06:34 PM
Tom Bley's Avatar
Quoted: 916 Post(s)
Liked: 893
Originally Posted by Ralph Potts View Post
Greetings,
Same here. I'm at 8 and want to go to 10 sometime in the near future.
Tom Bley is online now
jvc-rs500u synch/display issue? , RS600
