Official JVC RS600 / RS500 (X950R / X750R - X9000 / X7000) Owners Thread - Page 974 - AVS Forum | Home Theater Discussions And Reviews
 84796Likes
post #29191 of 32125 Old 02-18-2018, 03:32 AM
woofer's Avatar
Quoted: 1422 Post(s)
Liked: 2222
Originally Posted by Manni01 View Post
High lamp also increases the color volume (not only the color gamut) and with the DI (if you can live with the artifacts mostly during credits) the black floor is the same, so the dynamic contrast is much bigger.
Absolutely .... With my Z1/RS4500 i run HDR with "High" laser i get around 46fl ( 150nits) with my 143" scope screen , 46fl combined with the Mode 2 Dynamic Dimming colour and contrast look spectacular .
If i run on MED laser and close the iris down to get 30fl it does "look" way less contrasty and vibrant than the 46fl .
For HDR, the brighter the better..
asharma, Manni01 and BruceJK like this.
woofer is offline
post #29192 of 32125 Old 02-18-2018, 03:35 AM
asharma's Avatar
Quoted: 1839 Post(s)
Liked: 577
Also, provided you use high lamp with the iris fully open and the DI, the slightly higher black floor is rarely noticeable, while the higher ANSI contrast (compared to using the iris at a closer setting) is noticeable almost all the time. So unless you have a very low APL scene (mostly black but not entirely, you get a lot more contrast with high lamp, and the black on mixed APL screens looks just as black if not more because the bright parts of the pictures look so much brighter. A good example of this is the end credits of Trolls, the animation. The background looks completely black but the foreground is very bright and colorful. Because the brighter parts are brighter, they make your pupil close a bit more, which makes the black parts blacker. So the measured native black are slightly higher, but the apparent black are the same, if not better. This of course only works in HDR, with brightness going up to +100nits. In SDR, with brightness never above 50nits, that doesn't work and you want the lower black floor.
This is one of the reasons why I keep saying that you need 100nits+ to do HDR properly. If you go down to significantly less, you still have to make room for the highlights or you clip too much, and your picture goes too dark (far darker than bluray).
Not saying that high lamp is preferable (I agree with you it's up to taste), but there are more advantages than those you listed. Main downside apart hit on lamp life is fan noise. That's one of the reasons why I tried low lamp for a while and went back to high lamp.
Asharma has very low peakY (86nits) in low lamp, so for me high lamp isn't an option in his case, it's a requirement. If you can't hit at least 100nits in low lamp, use high lamp is my advice.
I have 140nits/210nits in low/high lamp (with a new lamp), 125nits/175nits now at close to 2000 hours (that's with the filter, I get 140nits/195nits without the filter), so it's an option for me, and I still prefer high lamp due to the higher color volume.
Whether using custom curves or the Oppo, it's important to adjust the parameters so that you have the same diffuse white. Low lamp will leave less headroom for the highlights (more compression which can lead to clipping) than high lamp. Or you'll get a too dark picture if you don't adjust parameters accordingly.
By the way, recently I experienced a weird issue: when I switched to high lamp in HDR (I had been using low lamp for a while), I would get less brightness than in low lamp. But it was only in HDR. In SDR or 3D, I would get the expected higher brightness. So I decided to run an Autocal and of course, that solved it. For some reason, my HDR high lamp calibration had gone wrong. After the autocal things went back to normal, with about 40% more brightness in high lamp.
So if you question your lamp in any given mode, run an autocal (with a known good Spyder, a bad one can have the opposite effect and reduce your brightness by causing unnecessary corrections).
Thank you a Sir...a couple points...I actually only have 65 nits in low lamp so your point is even more pronounced...secondly, had a similar issue with picture going dimmer low lamp iris -5 vs iris 0. 0 was dimmer...re ran Autocal...all good but weird, to your point.
Video:JVC N7 Sony 85” 900F Sony 55” 900F
Audio: Paradigm Prestige 95, 55C, 15b Dual JL Audio D110
Receiver/Amp: Anthem 1120, Emotiva XPA-5 Gen 2
Source: Panasonic UB820, Triple black velvet batcave
125" 2.35 Stewart Cima Neve Tab Tensioned Electric
asharma is offline
post #29193 of 32125 Old 02-18-2018, 04:45 AM
AidenL's Avatar
Quoted: 674 Post(s)
Liked: 310
Ok, I'm very confused - I think I'm doing something wrong.
I have installed the Vertex in my chain, ticked the box saying Disable HDR and loaded up the Brightness challenged curves from Mannis Vertex V3 pack, 1k, 2k and 4k via Autocal.
So, tried Passengers UHD disc, and I'm seeing SDR BT2020 as the output, and the picture looks really dark and colour looks oversaturated, no matter what gamma I select.
I have BT2020 as colourspace on the projector, and I have Import selected under Gamma.
When I change chapters on the Panasonic UB 700, it mentions dynamic range conversion.
Can one of you guys with expertise sanity check what I have done please? I must be missing something really obvious?
Display : JVC X7000 Projector | SE 103" Enlightor 4k | LG 65B6 OLED |
Sources : Panasonic UDP 700 & Vertex| Apple TV4k | HTPC | Sky Q UHD Satellite | Sonos Connect | Synology 24Tb |
Audio : Marantz 8802A | Genelec 8050 LCR | Monitor Audio IDC Sides & Rears | Seaton Sub Master/Slave |
AidenL is offline
post #29194 of 32125 Old 02-18-2018, 05:25 AM
AidenL's Avatar
Quoted: 674 Post(s)
Liked: 310
Solved the problem, thanks to claws post in the Vertex thread - I was on Edid 14 instead of 11............
AidenL is offline
post #29195 of 32125 Old 02-18-2018, 07:16 AM
cannga's Avatar
Quoted: 1904 Post(s)
Liked: 1849
FWIW this is exactly what my calibrator (Chad B) told me. In fact he didn't even calibrate a low lamp HDR mode for me because IIRC my system is 105 high lamp and somewhere in the 70's low lamp.
Jive Turkey and Manni01 like this.
Regards, Can
My System & Theta Casablanca Mini-Review (CB IVa setup help HERE) Uncontrolled passion for music, and sound.
Interesting Audio Diagrams :-) & High-End Speaker Reviews
JTR Subwoofer Thread I don't always listen to subwoofers, but when I do, it's JTR :-).
cannga is online now
post #29196 of 32125 Old 02-18-2018, 07:23 AM
cannga's Avatar
Liked: 1849
HDFury, Oppo, strip metadata, HDR off, SDR2020, DI, high lamp, low lamp, etc. If like me you are in-experienced with video and calibration and cannot keep up with this discussion, this is the best solution for this HDR "situation" :
Name:	The Rite Movie (14) chad b.jpg
Jive Turkey and Rengozu like this.
Regards, Can
post #29197 of 32125 Old 02-18-2018, 07:46 AM
muzz's Avatar
Quoted: 930 Post(s)
Liked: 642
1 thing at a time
Why waste $ on more cheap stuff, it's like challenging a dragon with a pocket knife.
muzz is offline
post #29198 of 32125 Old 02-18-2018, 08:20 AM
BruceJK's Avatar
Quoted: 200 Post(s)
Liked: 380
Manni, thanks for all your advice over the years to help us get the most out of our JVC projectors.
I've only recently started watching HDR on my X750 with Netflix and iTunes using an Apple TV 4K and an Oppo 203. I agree that we need to approach HDR differently than SDR. Maximize the available brightness from the projector in HDR and then use whatever tone mapping to match diffuse white to your reference level. The black levels just don't seem to be a problem because the contrast is so high. On a total fade to black the dynamic iris still does its job and the screen disappears.
This is the opposite of how we've always approached SDR where we keep the manual iris clamped down as much as possible to lower the black floor.
BTW, I've also been impressed by the longevity and stability of the lamps in the current JVC range.
woofer, muzz, asharma and 1 others like this.
Bruce K.
BruceJK is online now
post #29199 of 32125 Old 02-18-2018, 08:43 AM
asharma's Avatar
Liked: 577
I think I’m going to tweak EVERYTHING around high lamp, iris 0, and Oppo hdr off bt2020...I’m not worried about burning thru bulbs, given what I have invested into my man cave
stevenjw, woofer and 996911 like this.
asharma is offline
post #29200 of 32125 Old 02-18-2018, 08:48 AM
996911's Avatar
Quoted: 223 Post(s)
Liked: 167
Agreed. Not sure why some spend so much on these rooms and then skimp on the brightness available to save some time on a bulb that is <$500. I want ALL the (calibrated) brightness this sucker can give me. These projectors aren't exactly light cannons. And the "it's too loud" argument is another I don't get as once the movie starts, there is no possible way you can hear the projector in high lamp if you have a proper audio volume.
asharma and BruceJK like this.
Cheers,
Ray
996911 is offline
post #29201 of 32125 Old 02-18-2018, 09:23 AM
PioManiac's Avatar
Quoted: 3341 Post(s)
Liked: 8448
Cool
Not everyone has the same room configuration, throw distance, screen gain or screen size... or ambient light control.
With my JVC sitting on a bookcase just behind my head,
the front exhaust ports are less than 36" from my ears, it bothers me on High Lamp mode.
I've already concluded I have plenty of brightness in Low Lamp in my room with a short 12' throw and 1.3 gain screen
Spoiler!
I'm a Black Level junkie first and foremost,
That's what first moved me to a JVC BCM (Black Contrast Monster) Before HDR was even out.
Hi Lamp mode with iris wide open raises "MY" black floor unnecessarily. Not interested, sorry.
All this may be moot in a few years
I suspect a 120" size wallpaper type flexible OLED screen will someday crush the home projector market.
It's just a matter time for the price of the technology to trickle down to make it happen on the consumer level.
The Unfinished Basement Theater & Whisky Guitar Lounge | Bass EQ for Filtered Movies
JVC DLA X750 4K Projector | 120" Powered Drop Screen | 65" LG 65B6P OLED | Panasonic DMP UB900 | Oppo UDP 203 | HDFury Vertex
Yamaha RX-A3070 | 7.4.4.4 | Mission M3i x11 | Funk Audio 18.0 x2 | Velodyne DLS 5000R x2 | Crowson LvL3 MA x4 | miniDSP 2x4HD
PioManiac is offline
post #29202 of 32125 Old 02-18-2018, 09:36 AM
Quoted: 235 Post(s)
Liked: 60
Spoiler!
I agree with you but unfortunately for most no one can replicate your specific situation with such crazy brights on HDR and low lamp. Like you said it's all about variables like room size, screen size and material, location of equipment, materials on walls and ceiling etc. Most if not all others cannot seem to get the brightness you can get.
Sent from my SM-N950W using Tapatalk
atabea likes this.
tswire is offline
post #29203 of 32125 Old 02-18-2018, 11:10 AM
asharma's Avatar
Liked: 577
I just watched the sand storm scene in Mad Max on high lamp, iris 0...Oppo hdr off bt2020 Mode 3 400 nits...the rapid flashes from bright to dark were blindingly awesome!! Had to squint...saaaaaaweeeet!
asharma is offline
post #29204 of 32125 Old 02-18-2018, 11:15 AM
stevenjw's Avatar
Quoted: 640 Post(s)
Liked: 833
And then let YOUR eyes be the final judge.
I have a large, scoped screen with 17' throw, so not the best for NITs. I prefer Zappiti HDMI-in and UHD playback with Oppo HDR off BT.2020, mode 4 (or 3), Lum 250 (adjust on fly using app if needed) into JVC BT.2020 filter, gamma 2.4, Auto 2 DI on, IRIS -0, lamp High. Fan noise not an issue for me with my setup. I have a Mack lamp warranty and spare lamp too.
woofer, DavidHir and asharma like this.
...Steve
"Opinions are like orgasms… mine matters most and I really don’t care if you have one or not." ;)
My HT gear
stevenjw is offline
post #29205 of 32125 Old 02-18-2018, 11:24 AM
blee0120's Avatar
Quoted: 892 Post(s)
Liked: 603
The beta have been a good upgrade? I know I mentioned to you about installing it. Been great for me.
blee0120 is online now
post #29206 of 32125 Old 02-18-2018, 12:07 PM
AidenL's Avatar
Quoted: 674 Post(s)
Liked: 310
I'm actually very happy with the tweaks today.
I have done:
Autocal
Determined Peak nits on my screen.
Added a Vertex
Uplosed the Brightness Challenged Curves
Readied the vertex to do Autoselection with my RS232 cable arrives.
It was a bit of work, but I think it will get some more life out of my existing Panasonic UB 700.
IMDave and Manni01 like this.
AidenL is offline
post #29207 of 32125 Old 02-18-2018, 12:08 PM
woofer's Avatar
Liked: 2222
Yep, Mode 3 400nits and up if you have the brightness produces excellent results.
Below 300 nits has to many compromises . Example...... put on Oblivion UHD, i think its chapter 4 or 5 ...it opens with a shot of the Sky Quarters in the right of frame, Left of frame is the Sun, On 300nits or less the Sun will "Pulse" ...the mapping appears to be not able to make up its mind on what to do. With 400 nits and up all is well.
People are only using the lower nit values on the Oppo because they either havnt got the necessary brightness needed OR are obsessed with running in Low Lamp.
asharma likes this.
woofer is offline
post #29208 of 32125 Old 02-18-2018, 12:36 PM
Dreamliner's Avatar
Quoted: 1430 Post(s)
Liked: 755
If you are using SDR2020, you should be using Gamma 2.4. Not an imported curve, those are for HDR only.
Dreamliner is online now
post #29209 of 32125 Old 02-18-2018, 12:46 PM
AidenL's Avatar
Quoted: 674 Post(s)
Liked: 310
It is HDR though, when EDID 11 is selected.
AidenL is offline
post #29210 of 32125 Old 02-18-2018, 12:51 PM
Dreamliner's Avatar
Liked: 755
Right, okay. I got confused at your Disable HDR checkbox part and mentioning Dynamic Range Conversion. I thought you were trying for SDR2020. HDR curves for EDID 11. Gamma 2.4 for EDID 14. BT2020 for both.
AidenL likes this.
post #29211 of 32125 Old 02-18-2018, 12:54 PM
AidenL's Avatar
Quoted: 674 Post(s)
Liked: 310
I managed to confuse myself at times!
All good now though!
AidenL is offline
post #29212 of 32125 Old 02-18-2018, 04:07 PM
cr500guy's Avatar
Quoted: 66 Post(s)
Liked: 24
So I painted my projector screen wall this weekend a much darker taupe. It was a lighter taupe shade before. I’ve never been able to convince my wife to allow me to paint the ceiling in our living room where I have my home theater. But I’m really, really pleased with how the screen just disappears tand how much more immersive the movie is.
With Manni’s curves and my set up now, I can not possibly see how I would need anything else to satisfy my viewing experience. Next uo will likely be a vertex for more customizable switching. Unless I can really up my game with my Harmony Elite.
JVC DLA-X750R projector, Panasonic DP-UB820 4k Bluray player, Anthem MRX-720 receiver, 5.1.4 Atmos, Klipsch Reference II Speakers, Dual Sealed 18” UXL Subwoofers - Inuke 6000dsp Sub amp, Buttkicker LFE, Vizio P-65 TV.
cr500guy is offline
post #29213 of 32125 Old 02-18-2018, 04:51 PM
Rengozu's Avatar
Quoted: 202 Post(s)
Liked: 279
Just loaded up that scene myself, and yep, pretty amazing. Gonna have to start rewatching a lot of big movies now with the new settings.
After playing with forever, I too decided Mode 3 was the one I was gonna go with. Left the nits at 300 since that's where Chad had set it, but may need to play around more and see what 400 does since you both mentioned it. Fun times for sure!
asharma likes this.
JMAX Home Theatre
Spoiler!
Rengozu is offline
post #29214 of 32125 Old 02-18-2018, 09:20 PM
Dave Vaughn's Avatar
Quoted: 1465 Post(s)
Liked: 2286
I just installed a new bulb (orange light came on the JVC and a warning...granted, the bulb had 3400 hours on it!). Anyway, I pulled out a recently purchased light meter and here are my readings:
High Power IRIS all the way open: 660 LUX, 61.3 FtL, 273 Nits (Stewart Firehawk)
Low Power IRIS open: 395 Lux, 36.71 FtL, 164 Nits
Is my math correct???? ((Lux/3.14)*1.3 gain screen)
My old bulb was still plenty bright and without the warning, I wouldn't have changed it. I was getting around 500 lux on the old bulb in high power.
David Vaughn Blu-ray Reviewer / Technical Writer Sound & Vision Magazine (Print & Online)
Dave Vaughn is offline
post #29215 of 32125 Old 02-18-2018, 09:45 PM
Manni01's Avatar
Quoted: 5438 Post(s)
Liked: 5636
Hi Dave,
The formula looks good to me, and the brightness looks like expected [EDIT: I initially thought drop was too high from high to low lamp but I must have made a mistake, 40% is bang on].
Just above 20% loss after 3400 hours is remarkable. I have 20% loss after nearly 2000 hours (and I thought it was pretty good!), so unless mine doesn't lose anything for the next 1500 hours (unlikely) you did very well. Did you use mostly high lamp or low lamp?
Specs says lamp life (4000 hours in low lamp) is when the lamp has lost 50% of its initial power. so you've done significantly above specs.
By the way, I would have replaced it too. Not worth having to clean the inside after a bulb explosion!
Batch Utility V4.02 May 16 2019 to automate measurements files for madVR with support for BD Folders
Manni01 is online now
post #29216 of 32125 Old 02-18-2018, 10:28 PM
Liked: 2286
Hi Dave,
I've had the spare bulb for nearly a year and never felt the need to replace it. I use mostly low lamp and only use high when watching UHD movies. I'll wait a week for an autocal (50 hours our so), then do another the following week and compare the two.
Ralph Potts likes this.
post #29217 of 32125 Old 02-18-2018, 11:18 PM
Rengozu's Avatar
Quoted: 202 Post(s)
Liked: 279
Nice. Haven't hit that stage yet so didn't know you could actually get a warning light when the bulb was almost up. Just thought cleaning up an exploding bulb was part of the fun of projector ownership I still had to look forward to.
JMAX Home Theatre
Spoiler!
Rengozu is offline
post #29218 of 32125 Old 02-19-2018, 02:22 AM
AidenL's Avatar
Quoted: 674 Post(s)
Liked: 310
Dave, your numbers inspired me to check my high lamp numbers, I had been focusing on low lamp up till now. I have 540 lux at the screen, in high lamp, iris fully open, 0.8 gain screen.
Turns out, on my original bulb, I have 135 nits, so I have uploaded the Enhanced Cinema Experience Curve.
It’s getting better and better !
Manni01 likes this.
AidenL is offline
post #29219 of 32125 Old 02-19-2018, 05:24 AM
nathan_h's Avatar
Quoted: 2726 Post(s)
Liked: 1961
That is fascinating. Assuming your 103” EN4K screen is a 16*9 model, I have the same screen just one size larger in 16*9 equivalence, ie, 109”.
Yet with a new lamp in rec2020 mode, Chad measured 78nits in high lamp iris fully open, off the screen — almost 60 nits less than what you are getting.
nathan_h is offline
post #29220 of 32125 Old 02-19-2018, 06:04 AM
asharma's Avatar
Liked: 577
We’re u in 2.35 zoomed mode when Chad took the measurement or 16:9 mode? 78 is sounds waaay low if u were in 16:9 mode...
asharma is offline
jvc-rs500u synch/display issue? , RS600
