JVC Calibration Software V6 For 2015 Models (X9000,X7000,X5000,RS400,RS500,RS600) - Page 110 - AVS Forum | Home Theater Discussions And Reviews
 1288Likes
post #3271 of 4381 Old 06-11-2018, 04:55 PM
Quoted: 6120 Post(s)
Liked: 2539
Originally Posted by tswire View Post
I get lost in how many models and years of models there are!! LOL. I have x770 which I THINK is the 620. So you are saying that after a gamma only autocal the included BT 2020 colour profile does not “work” or follow the auto cal?
The x770 is the same as the RS520.
I can only speak about my own experience; no one else has reported the same issue, although no one has confirmed they don’t have the issue either.
If yours behaves the same way, you would see the improved gamma right after calibration, but it will revert back if you switch modes or turn off the projector, even if you save the results.
Dominic Chan is online now
post #3272 of 4381 Old 06-11-2018, 05:13 PM
Quoted: 300 Post(s)
Liked: 74
Gotcha. Maybe I am missing it but I have run gamma and gamma/colour a few times and it seems to have “stuck”. I guess the way to test is to run it for SDR and HDR and then switch to my user mode and then run it again to see the baseline (blue line I think)
tswire is offline
post #3273 of 4381 Old 06-11-2018, 05:30 PM
Liked: 2539
At the end of autocal you would normally see a blue line higher than the white line, which indicates that the gamma droop has been corrected by autocal. However, if you run it again immediately, you should not see the blue line as it would now be hidden by the white.
For HDR I would see the blue line every time.
A more conclusive test is to measure Normal gamma using the BT.2020 profile, after autocal. You should see a flat 2.2 gamma, but I don’t.
post #3274 of 4381 Old 06-11-2018, 05:30 PM
wnholt01's Avatar
Quoted: 46 Post(s)
Liked: 4
Yeah but for every non HDR picture mode or color profile there is just one gamma baseline that is calibrated? If that is true I am confused why Manni states that you need to perform a gamma+color calibration if the lamp mode or filter settings change. If there is only one non HDR gamma baseline then wouldn't only a single gamma calibaration be required if the projector couldn't store a different gamma calibaration for each lamp/filter setting you use?
wnholt01 is offline
post #3275 of 4381 Old 06-11-2018, 05:36 PM
Liked: 2539
There is one baseline gamma for each lamp/filter/CMD combination, meaning that for the same combination, calibrating Normal will correct 2.2, 2.3, 2.4 etc, as they’re all mathematically derived from Normal.
BTW, I believe CMD High/Low share the same calibration, which is different for CMD Off.
post #3276 of 4381 Old 06-11-2018, 05:37 PM
Quoted: 300 Post(s)
Liked: 74
At the end of autocal you would normally see a blue line higher than the white line, which indicates that the gamma droop has been fixed. However, if you run it again immediately, you should not see the blue line as it would be hidden by the white.
Ok. Well I can confirm I have ran it twice one right after the first time for both SDR and HDR and the blue line was under the white. I know that worked for me. However I have not gone out of autocal and changed user setting and watched for a bit and redone autocal.
tswire is offline
post #3277 of 4381 Old 06-11-2018, 05:40 PM
Liked: 2539
On mine if you switch from HDR to User and back, the calibration would be gone.
post #3278 of 4381 Old 06-11-2018, 05:41 PM
Quoted: 300 Post(s)
Liked: 74
Interesting will give it a go.
tswire is offline
post #3279 of 4381 Old 06-11-2018, 05:42 PM
wnholt01's Avatar
Quoted: 46 Post(s)
Liked: 4
Cool, that makes sense. I read many posts back that there was one baseline gamma that all gamma curves we're derived, that was confusing me from what I understood from reading this thread. If there is a separate gamma baseline for each cmd/lamp/filter combination then all makes sense again. Thanks for the help.
wnholt01 is offline
post #3280 of 4381 Old 06-12-2018, 04:05 AM
Franin's Avatar
Quoted: 3634 Post(s)
Liked: 2561
Ive got the X5900 ( I think it x590r ) 2018 software version 10 have any of these gamma and CMS issues been fixed ?
Sent from my Nokia 1610
God Bless!
A good way to test your Iris on your projector is on the Spears and Munsil disc. Go to Video processing then select Luminance Loading. Don't stare directly at the lens but on an angle and you can actually see the Iris at work.
Franin is offline
post #3281 of 4381 Old 06-12-2018, 01:02 PM
Quoted: 300 Post(s)
Liked: 74
See post 3252 above.
EDIT: That was Dreamliner’s guide on loading custom curves. To create your own, see Jav’s guide:
https://www.avsforum.com/forum/24-dig...l#post55203652
Just clarifying this "to make your own". This link to Javs is just the instructions on how to import his curves made for Arve's Tool AND a slight correction to black (bbo). This is not really how to "create your own curves" which Arve's Tool is also able to do. I would love if someone could point me in the direction of somewhat "simple" Arve's Tool instructions from start to finish...maybe using Jav's as the start but going in further than just bbo and tweaking it to my specific setup. Anyone?
Also, has anyone used Spyder 5 with HFCR to do a) luminance nits testing and b) color calibration? I would love to hear from someone that has done this with those specific tools so I can continue to tweak this 5% left in calibration!!!
tswire is offline
post #3282 of 4381 Old 06-12-2018, 03:52 PM
Liked: 2539
Creating a basic custom curve using Arve’s Tool
Creating a basic curve is fairly easy using Arve's Tool. Essentially, to customize it all you need to know is the peak nits you're getting on your screen when in the HDR mode. In Arve's Tool this is called “bm” (maximum brightness). You can create a curve and play with the different parameters without connecting to the projector, until you're ready to upload the curve.
Assuming you're already set up to upload Jav's curves, here's what you need to do to create your own custom curve:
  • Double-click on Menu.py to start the tool
  • Type "lp" to load one of the presets.
  • Select "3" (hdr pq 1200)
  • Type "ga" to adjust the curve
  • Type "p" to plot the default curve
  • Arrange the command line window and the plot window such that you can see both side-by-side. The plot gets updated as you change the different parameters.
  • Type "bw 25" to set reference white brightness to 25
  • Type "bm" followed by your peak nits; e.g., "bm 120"
You're done with the basic curve!
Next you can either upload it to the projector with "Pw", or save it with "s filename". If saved, you can later load it with "lf" just like you've been loading Jav's curves.
If you prefer the picture brighter or dimmer, simply adjust the bw value up or down accordingly. In most cases it should be in the 20-25 range.
Alternatively, you can also use the projector’s Contrast control to set the overall brightess interactively; see the following guide by lovingdvd:
https://www.avsforum.com/forum/24-di...l#post51467921
Most of the other parameters are for fine-tuning the highlight roll-off. They have a much bigger effect on 4000-nit curves than on 1200-nit curves.
You can also "design" your curve using HCFR. The main advantage is that HCFR includes the black compensation feature of BT.2390. I've developed an Excel Macro that will produce a jgd gamma curve from the HCFR data file. Note that the jgd files are used with the JVC AutoCal software, not Arve's tool.
Using the Spyder5 is no different than using any other meter in HCFR, other than having to load the driver.
See the following post
Measuring peak nits using HCFR
post #3283 of 4381 Old 06-13-2018, 05:16 AM
jake51's Avatar
Quoted: 362 Post(s)
Liked: 116
I have taken the X5000 down from its perch to import gamma curves
But I really need a guide for super dummies
I have bought a network cable long enough
How do I find my projector's IP address
jake51 is offline
post #3284 of 4381 Old 06-13-2018, 06:59 AM
Liked: 2539
As per the instructions.
post #3285 of 4381 Old 06-13-2018, 07:55 AM
jake51's Avatar
Quoted: 362 Post(s)
Liked: 116
Never had the X5000 connected to a network, had no idea
Will fire it up tonight
jake51 is offline
post #3286 of 4381 Old 06-13-2018, 08:05 AM
Liked: 2539
In some cases it may be easier to connect the projector to the network hub instead of directly to the PC.
Dave Vaughn likes this.
post #3287 of 4381 Old 06-13-2018, 08:15 AM
Dave Vaughn's Avatar
Quoted: 1849 Post(s)
Liked: 2852
I've never had an issue going through a network switch I have installed in my theater.
David Vaughn Blu-ray Reviewer / Technical Writer Sound & Vision Magazine (Print & Online)
Dave Vaughn is offline
post #3288 of 4381 Old 06-13-2018, 10:34 AM
jake51's Avatar
Quoted: 362 Post(s)
Liked: 116
When I try to check the network connection in the JVC software under Setting, I get "Connect NG" (what is NG)
The IP address entered in the software is the same as I have set on the projector
When I click the Import/Export icon, I get "could not setup LAN connection"
What am I doing wrong?
jake51 is offline
post #3289 of 4381 Old 06-13-2018, 11:13 AM
Quoted: 300 Post(s)
Liked: 74
I have never had an issue direct or through switch connected to my router. Ever.
tswire is offline
post #3290 of 4381 Old 06-13-2018, 11:27 AM
Liked: 2539
NG=No Good.
Try clicking on SET again and see if the IP address changes; is so, enter the new address in autocal. Sometimes you have to power off, physically unplug the AC cord, and then reconnect.
post #3291 of 4381 Old 06-14-2018, 05:02 AM
Franin's Avatar
Liked: 2561
I was told that the Spyder colimer has a green channel issue has that been fixed ?
God Bless!
Franin is offline
post #3292 of 4381 Old 06-20-2018, 07:37 AM
jake51's Avatar
Quoted: 362 Post(s)
Liked: 116
I finally worked out how to import gamma curves (better late than never)
I watched the opening battle in Saving Private Ryan with BT.2020 as the color profile
I knew the blood shouldn't be that red because of the desaturated look of the movie
So I changed the color profile on the X5000 to Standard
Does that sound right? It looked right to me
Even though my Panasonic UB900 said that it was BT.2020
This is all new to me
jake51 is offline
post #3293 of 4381 Old 06-25-2018, 08:52 AM
wnholt01's Avatar
Quoted: 46 Post(s)
Liked: 4
Does anyone know what axis position corresponds to in the JVC color management system. I assume Hue, Saturation, and Lightness map to HSL, but not sure about axis position, or maybe I have it all wrong?
wnholt01 is offline
post #3294 of 4381 Old 06-25-2018, 01:29 PM
Liked: 2539
This previous post by Manni shed some light on the use of JVC axis position adjustment, or rarher, why not to use it:
https://www.avsforum.com/forum/24-di...l#post42490137
post #3295 of 4381 Old 06-25-2018, 02:51 PM
wnholt01's Avatar
Quoted: 46 Post(s)
Liked: 4
Perfect thanks.
wnholt01 is offline
post #3296 of 4381 Old 06-26-2018, 05:59 PM
wnholt01's Avatar
Quoted: 46 Post(s)
Liked: 4
I calibrated white balance and gray scale using Calman and gamma using JVC Autocal. The test patterns were calibrated with source in YUV mode and if I change the source to RGB it throws off white balance, gamma, and color. Is that normal?
wnholt01 is offline
post #3297 of 4381 Old 06-27-2018, 09:21 AM
R Harkness's Avatar
Quoted: 2885 Post(s)
Liked: 2855
Originally Posted by Dreamliner View Post
Custom Curves Quick DIY
This guide encompasses every step you need to load custom curves onto your projector and get rocking with 4K HDR. All of this is reversible and none of it is permanent, so no worries. A custom curve will significantly increase the quality of your HDR content and it only takes about 30 minutes to follow the instructions below for the first time.
In step 3 I link to a couple different curves on this forum to download. Feel free to choose your own if you find one, there is no harm in trying different curves, the projector has 3 slots for custom curves and you can overwrite them as many times as you want. You can also make your own but that process is a bit different. More information here. If you are fresh to 4K now is the time to replace your HDMI cables or you will probably have problems, more information here. I have links to posts in my sig for a reason, look at them.
This is the quick and dirty guide and will get you what you want, quickly:
1) This is the JVC Calibration Software you want to import premade gamma curves, you can also use it later to do color calibration if you want. Install this software on a PC connected to the same network as your projector. Do this first. Connect your projector to your network, check the IP address of your projector in the settings menu and enter it into the settings screen (the gear) on the software and click 'check' to verify connection. (The PDF in step 4 explains this in more detail if you need it)
2) Download the BT2020 color profile from here. Its under step 2. (You might already have this loaded on your projector)
3) Download and try some curves from this post (download via his Dropbox link) (Thanks Javs) or this post (Thanks Manni) or this post (Thanks Dominic). Full credit to Javs, Manni and Dominic on these curves, I did not make them, they did. (Or feel free to use any other curve you find on the forum)
4) Use these Import Procedure directions to load the BT2020 profile you downloaded in step 2.
5) Use the same process as step 4 to load the custom gamma curve, but you select 'gamma' from the pull-down menu on the import/export screen instead of 'color profile'. If you really want brightness, I'd start with Javs "Javs 1200nit V3" gamma curve inside the "Autocal Versions" folder in his dropbox link and/or Manni's "Manni-HDR10-BC1K" gamma curve in his zip folder into and/or "Gamma3_30_Adjusted" into Custom 3 from Dominic. (Or feel free to use any other curve you find on the forum and load them to whichever custom slot you choose)
3/4/5 alternate) You can also load a curve or two using the ARVE tool and JAVS curves. This process is a bit more complicated but his recent V3 curves are very good. Curves and steps here. Javs has also provided the regular curves to import in step 4 but the Arve tool method will technically yield a slightly better result if you like his curves. (I personally saw no difference between the loaded curve and this method but it is ‘technically’ bettter).
6) Okay all done on the PC for now. Go to your projector and stick in a 4K disc get it loaded up so the movie is playing.
7) Now we're going to set up your picture settings for HDR movies on your projector. Press a User Mode on the remote (I have a few different profiles set up so my User 1 is for HD, User 2 is for HDR and User 3 is for 3D). Choose and press a user mode that makes sense to you, then go into the projector Picture Adjust Menu and change the color profile to BT.2020. Change Gamma to Custom 1 (or where you loaded the custom gamma from step 5), then right below that in the gamma screen, change correction value to Import. (Very important to select Import, otherwise it won't load the profile you imported in step 5). I'd also suggest turning on High Lamp, CMD Off, Auto Iris off, Iris Manual on 0 and Clear Black Low. (Iris, CMD & Clear Black is a preference though).
8) Going forward, once you put in a 4K movie, all you need to do is choose that user mode and it will recall all the settings from step 7. Then once the movie is actually playing, you just need to hit the gamma button to change from Gamma D to Custom 1 (the projector will always default to Gamma D). You can also rename the Picture Mode from "User 1, 2 or 3" to "HDR" or something to make it easier for you.
That's it. Basically, in recap, load in the BT2020 and custom gamma profile with the software, choose a user mode on the remote and select the BT2020 and custom gamma profiles.
All this will take about 20-30 minutes the first time. Its pretty quick. You can try different gamma curves in slot 2 & 3 also and overwrite them all as you see fit. Once you get the hang of it you will only spend like 2 minutes loading a gamma profile. REMEMBER, be CERTAIN the gamma correction value is set to IMPORT on the projector, otherwise it's just gamma normal.
On one hand I'm extremely thankful that Dreamliner has produced a quick-start guide like this.
On the other: it's pretty much all Greek to me. I have not ever personally calibrated my JVC RS600 projector. Or downloaded anything on to it. It looks to me like a whole bunch of ways I could screw up my projector!
This is why I've used a local professional calibrationist to do it for me. The problem is everyone is telling me a calibrator can't do UHD properly, that it has to be all this custom-done stuff...which I don't know how to do.
For instance, step 1: Would I be downloading the software into the projector somehow? Or would I be downloading it to a computer used to calibrate the projector (e.g. laptop)? Same question for any other downloading steps. Where is it going? (See...I really haven't done this before).
I thought the JVC calibration software was a no-go as it sucked?
R Harkness is offline
post #3298 of 4381 Old 06-27-2018, 09:40 AM
lovingdvd's Avatar
Quoted: 3750 Post(s)
Liked: 967
Every few months when I go to use the JVC autocal software, my Windows 10 PC doesn't recognize the Spyder. To resolve it I have to reinstall the Spyder software (so the driver gets reinstalled I suppose) and reboot. Then it works. Until a few months later when I go to try again, and I have to rinse and repeat. I don't calibrate it enough to really make it worth deep troubleshooting, as it's easier to just reinstall the Spyder software than to worry with it. But while I was here I was just curious if anyone else has had this issue or knows how to solve it more easily.
lovingdvd is offline
post #3299 of 4381 Old 06-28-2018, 08:10 PM
nathan_h's Avatar
Quoted: 2950 Post(s)
Liked: 2081
If your calibrator is not familiar with these quirks and tools for setting up HDR on an RS500, just pay them for doing a great SDR calibration.
Most of them use the JVC autocal software for the gamma setup because it is more fine tuned than manual adjustment, but a few calibrators can do well without it.
The other steps and software described here are for getting HDR to work as well as possible.
Alternate methods:
1. Don’t send hdr to your projector. Use something like the oppo to convert hdr to sdr.
2. Take a trip down the rabbit hole and learn how to upload someone else’s hdr curve to your projector. It won’t be as precise as an experienced calibrator could do but it can work well. You’ll need some basic computer skills and a weekend of patience. (It can be done in an hour or two but the first time out, most of us ran into problems and had to post online for help, and wait for an answer or two....)
My current setup.
Recommended podcasts: The Next Picture Show, the /filmcast, AV Rant.
nathan_h is online now
post #3300 of 4381 Old 07-03-2018, 03:16 PM
Quoted: 44 Post(s)
Hi all,
I'm a bit of a newbie to the calibration world and will be looking to calibrate my JVC first time over the weekend. I have a few q's I was hoping someone could answer...
1) It's been said many times on the thread to calibrate with Gamma normal. I'm happy to do that, but I use MadVR HDR to SDR mapping which requires me to set Gamma to 2.4 for the best results. If I do that, will I still get a calibrated image or can I keep the gamma to normal after calibration as the spyder and the software has already calibrated to 2.4? Very confused with that one.
Thanks in advance
entourage2194 is offline
