JVC Calibration Software V6 For 2015 Models (X9000,X7000,X5000,RS400,RS500,RS600) - Page 146 - AVS Forum | Home Theater Discussions And Reviews
 1288Likes
post #4351 of 4381 Old 03-27-2020, 11:41 AM
Quoted: 6133 Post(s)
Liked: 2545
Originally Posted by tswire View Post
So trying to follow this. The i1DisplayPro which currently is not compatible with JVC Autocal software is now working with this hack. I have x770 and I think autocal 9. This would be the best way to do a calibration for colour and gamma on your own? Where’s the best place in Canada to pick one up Dominic?
The hack has been tested with Autocal 7 and Autocal 11; there’s no reason why it wouldn’t work with the in-between versions.
Sorry but I can’t recommend a place to buy. In Canada the price seems to be very close to the new Plus version. Ordering from the US may work out cheaper.
Dominic Chan is online now
post #4352 of 4381 Old 03-30-2020, 10:44 PM
Quoted: 137 Post(s)
Liked: 9
Going to be doing my first autocal, I have already calibrated it manually so do I need to reset colour profile and colour temp back to factory default setting or does it not affect the autocal process?
johnnyboy632 is offline
post #4353 of 4381 Old 03-31-2020, 12:27 AM
SirMaster's Avatar
Quoted: 1221 Post(s)
Liked: 842
You definitely want to reset the projector to default settings before doing an autocal.
Technically it will work either way, but it will calibrate your current settings to reference.
Wouldn’t you rather have the default zeroed out settings be reference?
johnnyboy632 likes this.
SirMaster is offline
post #4354 of 4381 Old 03-31-2020, 02:52 AM
Liked: 2545
The manual settings do not affect the actual calibration, but their effects will be reflected in the Autocal log, making it harder to judge the results shown in the log
Those previous settings will no longer be valid after Autocal in any case, so you might well reset them before rather than after running Autocal.
post #4355 of 4381 Old 04-01-2020, 02:25 AM
Quoted: 137 Post(s)
Liked: 9
My first autocal gamma/colour. anyone know if these are good results. Should I keep or try again
post #4356 of 4381 Old 04-01-2020, 09:26 PM
Liked: 2545
Ok this is where it gets confusing for me, because autocal only calibrates one colour temp only, is that correct? so do I have to manually calibrate using a custom colour temp with 6500k correction value for the picture modes that use a different iris? That means the autocal calibration I did wouldn’t apply to the new custom colour temp.
If you have done colour Autocal properly for all the mode/iris settings that you need, they should all read pretty much the same, so you only need one custom colour for manual correction.
post #4357 of 4381 Old 04-01-2020, 09:38 PM
Quoted: 137 Post(s)
Liked: 9
Yes so I did a full gamma/colour temp cal then ran colour only cal for each color profile with the specific iris setting that I am using for each user mode. after each cal the results showed that each colour profile and iris setting tracked pretty much the same at approx 6500k going by the results diagram before saving. Am I correct in saying that it should be ok to keep the same 6500k preset for all modes? So what specifically is getting adjusted when doing an color autocal only? Cheers
post #4358 of 4381 Old 04-02-2020, 01:41 PM
Quoted: 49 Post(s)
Liked: 1
I made today full calibration according to Manni guide.
In the first calibration (gamma+color) I got really good result and all the dots appears exactly on D65.
In the next step, (color, lens aperture, cmd), After few calibrations in CMD off, Lens -10 I saw that the dots is near the D65 and not on the D65 like before.
This is normally?
In another case, I want to find the peakY of my pj to import gamma curves, I tried to do that with HCFR but it’s not found my Spyder.(driver Installed).
I also made test with the Spyder5 Elite software, but I don’t understand from the results how to know the peakY.
The results:
White point - 0321 0340
Brightness - 773.5
Ty for helps
liel is offline
post #4359 of 4381 Old 04-02-2020, 01:56 PM
Liked: 2545
If you use Spyder5 for Autocal it doesn’t not take into consideration the screen characteristics. Plus some Spyder5s are not that accurate to start with.
The “adjustment” is based on measurements taken off the screen , possibly with a more accurate meter.
post #4360 of 4381 Old 04-02-2020, 01:59 PM
Liked: 2545
This is normally?
The results:
Brightness - 773.5
Ty for helps
At -10 the light level is quite a bit lower, so you may see some dots drifting away from D65, especially the darker grey ones.
You need to use the ArgyllCMS driver in HCFR’s Drivers folder.
post #4361 of 4381 Old 04-02-2020, 02:36 PM
Quoted: 49 Post(s)
Liked: 1
I can know the peakY from the spyder software?
liel is offline
post #4362 of 4381 Old 04-02-2020, 05:49 PM
Quoted: 137 Post(s)
Liked: 9
I also own i1d3 meter with hcfr. Will that work to adjust with better results? Can I adjust the 6500k preset and should that be ok for all modes sdr and HDR?
post #4363 of 4381 Old 04-02-2020, 06:04 PM
Liked: 2545
The i1D3 is generally considered a better meter than the Spyder.
post #4364 of 4381 Old 04-04-2020, 10:07 PM
kwk2293's Avatar
Quoted: 96 Post(s)
Liked: 40
does the hack work with the i1display pro oem rev a
kwk2293 is offline
post #4365 of 4381 Old 04-05-2020, 04:27 AM
Liked: 2545
The hack has been withdrawn by the author due to potential copyright issues.
post #4366 of 4381 Old 04-05-2020, 05:03 AM
nathan_h's Avatar
Quoted: 2957 Post(s)
Liked: 2082
Did the hack offer a live of control that exceeds Arve's tool or simple enable other light meters?
My current setup.
Recommended podcasts: The Next Picture Show, the /filmcast, AV Rant.
nathan_h is online now
post #4367 of 4381 Old 04-05-2020, 05:23 AM
Liked: 2545
The hack has the same functionality as the original JVC Autocal, other than supporting the i1D3.
The curves produced using Arve’s tool “overlays” on the projector’s Normal gamma, and therefore will only work correctly (accurately) if the projector has no gamma droop. And gamma droop can only be corrected with Autocal.
nathan_h likes this.
post #4368 of 4381 Old 04-05-2020, 06:10 AM
kwk2293's Avatar
Quoted: 96 Post(s)
Liked: 40
was wondering what happen to links. i have version 34 it should still work shouldn’t it
kwk2293 is offline
post #4369 of 4381 Old 04-05-2020, 08:30 AM
Danonano's Avatar
Quoted: 198 Post(s)
Liked: 56
Originally Posted by TimHamburg View Post
Edit: There is a new version to be found on the developer's website: https://autocal.banjobyte.com/
Also now in english:
https://autocal.banjobyte.com/?lang=en
I'm not able to find any downloads at the link. Do you think it was removed?
Danonano is offline
post #4370 of 4381 Old 04-05-2020, 08:49 AM
Liked: 2545
See post 4365 above.
This was what the site showed on March 30:
I am currently checking the legal situation and will contact you as soon as I have any news. Could you please remove any links to this website while checking this? Thanks
If you have any questions write me at [email protected]
https://web.archive.org/web/20200330...banjobyte.com/
post #4371 of 4381 Old 04-06-2020, 04:52 AM
nathan_h's Avatar
Liked: 2082
Anyone have a copy they downloaded and would be willing to share?
My current setup.
post #4372 of 4381 Old 04-06-2020, 07:23 AM
neo_2009's Avatar
Quoted: 384 Post(s)
Liked: 296
Damn, i haven't saved the software due to the this whole situation, and now i can't
neo_2009 is online now
post #4373 of 4381 Old 04-06-2020, 07:34 PM
Quoted: 49 Post(s)
Liked: 1
Maybe it’s beginners question but I have to know, what is that PeakY?
I try to find answer on this forum for few hours and still found nothing...
I saw in this thread that I can know the peakY with Spyder5 software, I made calibration and see that my white luminance Y is 733, what is mean?
I want to import gamma curves from jvc macros pack and don’t know what is the correct gamma for me.
Ty for helps!
liel is offline
post #4374 of 4381 Old 04-06-2020, 08:22 PM
Liked: 2545
Ty for helps!
If you click on the link in my signature “Creating a basic...”, that post contains a link describing how to measure PeakY.
post #4375 of 4381 Old 04-07-2020, 06:58 AM
Quoted: 49 Post(s)
Liked: 1
Maybe it’️s beginners question but I have to know, what is that PeakY?
I want to import gamma curves from jvc macros pack and don’️t know what is the correct gamma for me.
Ty for helps!
I saw that post but there is no explaining how to do that with Spyder5 software.
“ NOTE: Youn can also use the Spyder software to measure the peak nits.”
liel is offline
post #4376 of 4381 Old 04-07-2020, 07:17 AM
Liked: 2545
I tried out the SpyderX software and one of the first things it did was to measure the luminance and ask you to adjust to the target.
I don’t know what the “733” corresponds to. Make sure you’re measuring off the screen, not directly off the projector lens as when using Autocal.
post #4377 of 4381 Old 04-07-2020, 12:10 PM
Quoted: 49 Post(s)
Liked: 1
maybe its that?
I installed the senesor 30cm from the screen like the expamle in the software.
liel is offline
post #4378 of 4381 Old 04-09-2020, 11:04 AM
Vaugha's Avatar
Quoted: 14 Post(s)
As my luck has it, it has been removed EXACTLY two days after I decided to research doing autocal on my X790 by myself and well before I knew it existed. Now it's too late.
Vaugha is offline
post #4379 of 4381 Old 05-01-2020, 03:13 AM
saltanar's Avatar
Quoted: 30 Post(s)
autocal hack latest version
hello, can someone send me a PM with the lastest hacked version?
Thanks in advance.
saltanar is offline
post #4380 of 4381 Old 05-24-2020, 05:30 AM
Liked: 2545
Hidden Gem - Meter Correction Matrix
Originally Posted by KarlKlammer View Post
I don't know if someone else already found out that Autocal has some hidden settings that allow an XYZ correction matrix for the connected meter.
The option is called 'matrixOfSensor' and is located in the file %userprofile%\AppData\Roaming\JVCKENWOOD\Projector Calibration Software *\init.xml.
This is a feature that has been asked by many, and yet it has existed at least since v7!
